SMDJ51A
SMDJ51A
    RUILON(瑞隆源)
    SMC(DO-214AB)
    SMDJ系列专门设计用于保护敏感电子设备,使其免受雷击和其他瞬态电压事件引起的电压瞬变影响。
SMDJ51A 数据手册
Transient Voltage Suppressors (TVS) SMDJ Series Description The SMDJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features l Low profile package l Matte tin lead–free Plated l Halogen free and RoHS compliant Electrical symbol l Low incremental surge resistance l Typical IR less than 2μA above 10V l Compatible with industrial standard package DO DO-214AB l For surface mounted applications to optimize board space BI l 3000W peak pulse power capability with at 10/1000μs Anode Cathode waveform, repetition rate (duty cycle): 0.01% UNI l High temperature soldering:260°C/10 0 seconds at terminals Part Number Code S M D J Series code x x x C Reverse Stand-Off Voltage A 5% Voltage Tolerance Blank:Uni-Directional C:Bi-Directional Mechanical Characteristics Rating Symbol Value Units Peak Pulse Power Dissipation at TA=25ºC by 10/1000μs Waveform (Fig.2)(Note 1), (Note 2) PPP 3000 W Power Dissipation on Infinite Heat Sink at TL=75°C(Fig.6) PD 6.5 W Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) IFSM 300 A TJ -55 to 150 °C TSTG -55 to 150 °C Operating Temperature Range Storage Temperature Range Notes: 1. Non-repetitive repetitive current pulse , per Fig. 4 and derated above TA = 25°C per Fig. 3. 2. Mounted on 5.0x5.0mm copper pad to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2018-06-22 Page:1 Transient Voltage Suppressors (TVS) SMDJ Series Electrical Characteristics Type Number Reverse Stand-Off Voltage Marking VR Breakdown Voltage VBR @IT Min Max Test Current Max. Max. Clamping Peak Pulse Reverse Voltage Current Leakage 10/1000 10/1000μs 10/1000μs IT VC@IPP IPP IR@VR UNI BI UNI BI V V V mA V A µA SMDJ5.0A SMDJ5.0CA RDE DDE 5.0 6.4 7.0 10 9.2 326.09 800 SMDJ6.0A SMDJ6.0CA RDG DDG 6.0 6.67 7.37 10 10.3 291.26 800 SMDJ6.5A SMDJ6.5CA RDK DDK 6.5 7.22 7.98 10 11.2 267.86 500 SMDJ7.0A SMDJ7.0CA PDM DDM 7.0 7.78 8.6 10 12.0 250.0 200 SMDJ7.5A SMDJ7.5CA PDP DDP 7.5 8.33 9.21 1 12.9 232.56 100 SMDJ8.0A SMDJ8.0CA PDR DDR 8.0 8.89 9.83 1 13.6 220.59 50 SMDJ8.5A SMDJ8.5CA PDT DDT 8.5 9.44 10.4 1 14.4 208.33 20 SMDJ9.0A SMDJ9.0CA PDV DDV 9.0 10.0 11.1 1 15.4 194.81 10 SMDJ10A SMDJ10CA PDX DDX 10.0 11.1 12.3 1 17.0 176.47 5 SMDJ11A SMDJ11CA PDZ DDZ 11.0 12.2 13.5 1 18.2 164.84 2 SMDJ12A SMDJ12CA PEE DEE 12.0 13.3 14.7 1 19.9 150.75 2 SMDJ13A SMDJ13CA PEG DEG 13.0 14.4 15.9 1 21.5 139.53 2 SMDJ14A SMDJ14CA PEK DEK 14.0 15.6 17.2 1 23.2 129.31 2 SMDJ15A SMDJ15CA PEM DEM 15.0 16.7 18.5 1 24.4 122.95 2 SMDJ16A SMDJ16CA PEP DEP 16.0 17.8 19.7 1 26.0 115.38 2 SMDJ17A SMDJ17CA PER DER 17.0 18.9 20.9 1 27.6 108.70 2 SMDJ18A SMDJ18CA PET DET 18.0 20.0 22.1 1 29.2 102.74 2 SMDJ19A SMDJ19CA PEB DEB 19.0 21.1 23.3 1 30.8 97.47 2 SMDJ20A SMDJ20CA PEV DEV 20.0 22.2 24.5 1 32.4 92.59 2 SMDJ22A SMDJ22CA PEX DEX 22.0 24.4 26.9 1 35.5 84.51 2 SMDJ24A SMDJ24CA PEZ DEZ 24.0 26.7 29.5 1 38.9 77.12 2 SMDJ26A SMDJ26CA PFE DFE 26.0 28.9 31.9 1 42.1 71.26 2 SMDJ28A SMDJ28CA PFG DFG 28.0 31.1 34.4 1 45.4 66.08 2 SMDJ30A SMDJ30CA PFK DFK 30.0 33.3 36.8 1 48.4 61.98 2 SMDJ33A SMDJ33CA PFM DFM 33.0 36.7 40.6 1 53.3 56.29 2 SMDJ36A SMDJ36CA PFP DFP 36.0 40.0 44.2 1 58.1 51.64 2 SMDJ40A SMDJ40CA PFR DFR 40.0 44.4 49.1 1 64.5 46.51 2 SMDJ43A SMDJ43CA PFT DFT 43.0 47.8 52.8 1 69.4 43.23 2 SMDJ45A SMDJ45CA PFV DFV 45.0 50.0 55.3 1 72.7 41.27 2 SMDJ48A SMDJ48CA PFX DFX 48.0 53.3 58.9 1 77.4 38.76 2 Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2018-06-22 Page:2 Transient Voltage Suppressors (TVS) SMDJ Series Electrical Characteristics Type Number Reverse Stand-Off Voltage Marking VRWM Breakdown Voltage VBR @IT Min Max Test Current Max. Max. Clamping Peak Pulse Reverse Voltage Current Leakage 10/1000 10/1000μs 10/1000μs IT VC@IPP IPP IR@VRWM UNI BI UNI BI V V V mA V A µA SMDJ51A SMDJ51CA PFZ DFZ 51.0 56.7 62.7 1 82.4 36.41 2 SMDJ54A SMDJ54CA PGE DGE 54.0 60.0 66.3 1 87.1 34.44 2 SMDJ58A SMDJ58CA PGG DGG 58.0 64.4 71.2 1 93.6 32.05 2 SMDJ60A SMDJ60CA PGK DGK 60.0 66.7 73.7 1 96.8 30.99 2 SMDJ64A SMDJ64CA PGM DGM 64.0 71.1 78.6 1 103.0 29.13 2 SMDJ70A SMDJ70CA PGP DGP 70.0 77.8 86.0 1 113.0 26.55 2 SMDJ75A SMDJ75CA PGR DGR 75.0 83.3 92.1 1 121.0 24.79 2 SMDJ78A SMDJ78CA PGT DGT 78.0 86.7 95.8 1 126.0 23.81 2 SMDJ80A SMDJ80CA PGB DGB 80.0 88.8 97.6 1 129.6 23.15 2 SMDJ85A SMDJ85CA PGV DGV 85.0 94.4 104.0 1 137.0 21.9 2 SMDJ90A SMDJ90CA PGX DGX 90.0 100.0 111.0 1 146.0 20.55 2 SMDJ100A SMDJ100CA PGZ DGZ 100.0 111.0 123.0 1 162.0 18.52 2 SMDJ110A SMDJ110CA PHE DHE 110.0 122.0 135.0 1 177.0 16.95 2 SMDJ120A SMDJ120CA PHG DHG 120.0 133.0 147.0 1 193.0 15.54 2 SMDJ130A SMDJ130CA PHK DHK 130.0 144.0 159.0 1 209.0 14.35 2 SMDJ140A SMDJ140CA PHB DHB 140.0 155.0 171.0 1 226.8 13.23 2 SMDJ150A SMDJ150CA PHM DHM 150.0 167.0 185.0 1 243.0 12.35 2 SMDJ160A SMDJ160CA PHP DHP 160.0 178.0 197.0 1 259.0 11.58 2 SMDJ170A SMDJ170CA PHR DHR 170.0 189.0 209.0 1 275.0 10.91 2 SMDJ180A SMDJ180CA PHT DHT 180.0 200.0 220.0 1 291.6 10.29 2 SMDJ190A SMDJ190CA PHV DHV 190.0 211.0 232.0 1 307.8 9.75 2 SMDJ200A SMDJ200CA PHW DHW 200.0 224.0 247.0 1 324.0 9.26 2 SMDJ220A SMDJ220CA PHX DHX 220.0 246.0 272.0 1 356.0 8.43 2 SMDJ250A SMDJ250CA PHZ DHZ 250.0 279.0 309.0 1 405.0 7.41 2 SMDJ300A SMDJ300CA PJE DJE 300.0 335.0 371.0 1 486.0 6.17 2 SMDJ350A SMDJ350CA PJG DJG 350.0 391.0 432.0 1 567.0 5.29 2 SMDJ400A SMDJ400CA PJK DJK 400.0 447.0 494.0 1 648.0 4.63 2 SMDJ440A SMDJ440CA PJM DJM 440.0 492.0 543.0 1 713.0 4.21 2 Notes: For bidirectional type having VR of 10V and less, the IR limit is double. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2018-06-22 Page:3 Transient Voltage Suppressors (TVS) SMDJ Series I-V Curve Characteristics Uni-directional I Bi-directional IPP VC VBR VR IR VF IT IT IR VC VBR VR V IR IT VR VBR VC V IPP IPP PPPM Peak Pulse Power Dissipation -- Max power dissipation VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (I T) VC Clamping Voltage -- Peak voltage measured across the TVS at a specified Ippm (peak impulse current) IR Reverse Leakage Current -- Current measured at VR VF Forward Voltage Drop for Uni-directional directional Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 1 - TVS Transients Clamping Waveform Figure 2 - Peak Pulse Power Rating Curve 100 PPPM-Peak Pulse Power (kW) Voltage or Current Voltage Transients Voltage Across TVS Current Through TVS stacked-die, 4KW at 10x1000μs, 25°C 10 Single die, 3KW at 10x1000μs, 25°C 1 TJ initial = Tamb 0.1 0.001 Time Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. 0.01 0. 0.1 1 10 td-Pulse Pulse Width (ms) ( Revised: 2018-06-22 Page:4 Transient Voltage Suppressors (TVS) SMDJ Series Ratings and Characteristic Curves (TA=25°C unless otherwise noted) (Continued) Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % Figure 3 - Pulse Derating Curve Figure 4 - Pulse Waveform 100 IPPM - Peak Pulse Cur rent, % IRSM 150 80 60 40 20 tr=10μsec 25 50 75 100 125 Peak Value IPPM 100 Half Value IPPM ( IPPM ) 2 50 10/1000μsec.Waveform as defined by R.E.A td 0 0 0 150 175 0 1.0 Bi-directional V=0V Uni-directional directional V=0V 1000 Cj (pF) Uni-directional @VR 100 Bi-directional @VR 10 Tj=25ºC f=1.0MHz Vsig=50mVp-p 1 100.0 1000.0 PM(AV), Steady State Power Dissipation (W) 100000 10.0 3.0 4.0 Figure 6 - Steady State Power Derating Curve Figure 5 - Typical Junction Capacitance 1.0 2.0 t-Time(ms) TA-Ambient temperature (ºC) C) 10000 TJ =25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM 6.5 6.0 5.0 4.0 3.0 2.0 1.0 0 0 25 50 75 100 125 150 175 TA-Ambient Temperature T (ºC) VBR - Reverse Breakdown Voltage (V) Figure 7 - Maximum Non-Repetitive Surge Current IFSM - Peak Forward Surve Current (A) 350 300 250 200 150 100 50 0 1 10 100 Number of Cycles at 60 Hz Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2018-06-22 Page:5 Transient Voltage Suppressors (TVS) SMDJ Series Soldering Parameters - Reflow Soldering (Surface Mount Devices) Reflow Condition TP Ramp-up Critical Zone TL to TP TL Pre Heat Temperature TS(max) Ramp-down TS(min) Preheat Time to peak temperature (t 25℃ to peak) -Temperature Temperature Min (Ts(min)) 150°C -Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) 60 -180 Seconds Average ramp up rate ( Liquids Liquid Temp TL) to peak 3°C/second max TS(max) to TL - Ramp-up Rate 3°C/second max Reflo w 25 Pb - Free assembly Time - Temperature (TL) (Liquids) 217°C - Time (min to max) (ts) 60 -150 Seconds Peak Temperature (TP) 260 +0/-5°C Time within 5°C of actual peak Temperature (tp) 20 - 40 Seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max Do not exceed 260°C Part Marking System Cathode band(for Uni-directional products only) RUILON XXX XXX Date Code Product Code Marking code Dimensions Millimeters Cathode Band Inches DIM Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2018-06-22 Min Max Min Max A 2.75 3.25 0.108 0.128 B 6.50 7.15 0.256 0.281 C 5.50 6.22 0.217 0.245 D 1.98 2.70 0.078 0.106 E 0.75 1.52 0.030 0.060 G 7.40 8.40 0.291 0.331 I 3.300 - 0.129 - J 2.400 - 0.094 - K - 4.200 - 0.165 L 2.400 - 0.094 - Page:6 Transient Voltage Suppressors (TVS) SMDJ Series Taping and Reel Specifications Symbol Millimeters Inches W 16±0.3 0.630±0.012 P 8±0.1 ±0.1 0.315±0.004 F 7.25±0.1 5±0.1 0.285±0.004 E 1.75±0.1 0.069±0.004 D 1.5+0.1/ 1.5+0.1/-0.0 0.059+0.004/-0.0 P0 4±0.1 0.157±0.004 P2 2±0.1 0.079±0.004 D0 16.7±0.15 ±0.15 0.657±0.006 D1 178 178±2 7.007±0.079 D2 59.6+1/ +1/-2 2.346+0.039/-0.079 W1 17.2±0.4 ±0.4 0.677±0.016 Direction of Unreeling Part Number Component package Quantity Packaging option Packaging specification SMDJXXXA/CA DO-214AB(SMC) B(SMC) 500 Tape&Reel-16mm/7”tape EIA STD RS-481 Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2018-06-22 Page:7
SMDJ51A 价格&库存
很抱歉,暂时无法提供与“SMDJ51A”相匹配的价格&库存,您可以联系我们找货
SMDJ51A
  • 5+0.83791
  • 50+0.66373
  • 150+0.58908
  • 500+0.49594
  • 2500+0.45447
  • 5000+0.42958
库存:289
