5.0SMDJ180A
5.0SMDJ180A
    REALCHIP(正芯)
    SMC(DO-214AB)
5.0SMDJ180A 数据手册
5.0SMDJ SERIES Surface Mount Transient Voltage Suppressor Diodes Uni-directional Features ● UL recognition, file # E517074 ● 5000 W peak pulse power capability with a 10/1000 μs waveform ● Low leakage ● Uni and Bidirectional unit ● Excellent clamping capability ● Very fast response time ● Meets MSL level 1 ● AEC-Q101 qualified Typical Applications Use in sensitive electronics protection against voltage transients induced by inductive load switching and lighting on ICs, MOSFET, signal lines of sensor units for consumer, computer, industrial, telecommunication. Bi-directional Mechanical Data ● Package: DO-214AB (SMC) Molding compound meets UL 94 V-0 flammability rating, RoHS-compliant ● Terminals: Tin plated leads, solderable per J-STD002 and JESD22-B102 ● Polarity: For uni-directional types the band denotes cathode end, no marking on bi-directional types ■Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER Peak power dissipation, with a 10/1000μs waveform Peak pulse current, with a 10/1000μs waveform UNIT PPPM W 5000 IPPM A See Next Table PD W 6.5 IFSM A 300 TJ,TSTG ℃ -55 to +150 (1)(2) (1) (2) Power dissipation, on infinite heat sink at T =75℃ L Peak forward surge current, 8.3 ms single half sine-wave unidirectional only (3) Operating junction and storage temperature range Max SYMBOL ■Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER Maximum instantaneous forward voltage at 100A for unidirectional only(4) SYMBOL UNIT VALUE VFM V 3.5/5.0 江苏正芯电子科技有限公司 www.zhengxinsemi.com ■Thermal Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER Thermal Resistance(Typical) SYMBOL UNIT Conditions VALUE RθJ-A(5) ℃/W junction to ambient 75 ℃/W junction to lead 15 ℃/W junction to case 13 (5) RθJ-L (5) RθJ-C Notes: (1) (2) (3) (4) (5) Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig.2. Mounted on 0.31 x 0.31" (8.0 x 8.0 mm) copper pads to each terminal Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. VF=3.5V Max for devices of VBR≤85V,and VF=5.0V Max for devices of VBR>85V. Mounted on minimum recommended pad layout. ■Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number (Uni) Part Number (Bi) Breakdown Voltage VBR@IT Min(V) (1) Max (V) IT (mA) Maximum Reverse Leakage IR @ VRWM (μA) Working Peak Reverse Voltage VRWM (V) Maximum Reverse Surge (2) Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) 5.0SMDJ11A 5.0SMDJ11CA 12.2 13.5 1.0 800.0 11.0 274.7 18.2 5.0SMDJ12A 5.0SMDJ12CA 13.3 14.7 1.0 800.0 12.0 251.3 19.9 5.0SMDJ13A 5.0SMDJ13CA 14.4 15.9 1.0 500.0 13.0 232.6 21.5 5.0SMDJ14A 5.0SMDJ14CA 15.6 17.2 1.0 200.0 14.0 215.5 23.2 5.0SMDJ15A 5.0SMDJ15CA 16.7 18.5 1.0 100.0 15.0 204.9 24.4 5.0SMDJ16A 5.0SMDJ16CA 17.8 19.7 1.0 50.0 16.0 192.3 26 5.0SMDJ17A 5.0SMDJ17CA 18.9 20.9 1.0 20.0 17.0 181.2 27.6 5.0SMDJ18A 5.0SMDJ18CA 20.0 22.1 1.0 10.0 18.0 171.2 29.2 5.0SMDJ19A 5.0SMDJ19CA 21.1 23.3 1.0 10.0 19.0 162.3 30.8 5.0SMDJ20A 5.0SMDJ20CA 22.2 24.5 1.0 5.0 20.0 154.3 32.4 5.0SMDJ22A 5.0SMDJ22CA 24.4 26.9 1.0 5.0 22.0 140.8 35.5 5.0SMDJ24A 5.0SMDJ24CA 26.7 29.5 1.0 5.0 24.0 128.5 38.9 5.0SMDJ26A 5.0SMDJ26CA 28.9 31.9 1.0 5.0 26.0 118.8 42.1 5.0SMDJ28A 5.0SMDJ28CA 31.1 34.4 1.0 5.0 28.0 110.1 45.4 5.0SMDJ30A 5.0SMDJ30CA 33.3 36.8 1.0 5.0 30.0 103.3 48.4 5.0SMDJ33A 5.0SMDJ33CA 36.7 40.6 1.0 5.0 33.0 93.8 53.3 5.0SMDJ36A 5.0SMDJ36CA 40.0 44.2 1.0 5.0 36.0 86.1 58.1 5.0SMDJ40A 5.0SMDJ40CA 44.4 49.1 1.0 5.0 40.0 77.5 64.5 5.0SMDJ43A 5.0SMDJ43CA 47.8 52.8 1.0 5.0 43.0 72.0 69.4 5.0SMDJ45A 5.0SMDJ45CA 50.0 55.3 1.0 5.0 45.0 68.8 72.7 5.0SMDJ48A 5.0SMDJ48CA 53.3 58.9 1.0 5.0 48.0 64.6 77.4 5.0SMDJ51A 5.0SMDJ51CA 56.7 62.7 1.0 5.0 51.0 60.7 82.4 5.0SMDJ54A 5.0SMDJ54CA 60.0 66.3 1.0 5.0 54.0 57.4 87.1 5.0SMDJ58A 5.0SMDJ58CA 64.4 71.2 1.0 5.0 58.0 53.4 93.6 5.0SMDJ60A 5.0SMDJ60CA 66.7 73.7 1.0 5.0 60.0 51.7 96.8 5.0SMDJ64A 5.0SMDJ64CA 71.1 78.6 1.0 5.0 64.0 48.5 103 5.0SMDJ70A 5.0SMDJ70CA 77.8 86.0 1.0 5.0 70.0 44.2 113 5.0SMDJ75A 5.0SMDJ75CA 83.3 92.1 1.0 5.0 75.0 41.3 121 5.0SMDJ78A 5.0SMDJ78CA 86.7 95.8 1.0 5.0 78.0 39.7 126 江苏正芯电子科技有限公司 www.zhengxinsemi.com 5.0SMDJ80A 5.0SMDJ80CA 88.96 97.6 1.0 5.0 80.0 38.6 129.6 Working Peak Reverse Voltage VRWM (V) Maximum Reverse Surge (2) Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) ■Electrical Characteristics (TA=25℃ unless otherwise noted) Min(V) Max (V) IT (mA) Maximum Reverse Leakage IR @ VRWM (μA) 5.0SMDJ85CA 94.4 104.0 1.0 5.0 85.0 36.5 137 5.0SMDJ90A 5.0SMDJ90CA 100.0 111.0 1.0 5.0 90.0 34.2 146 5.0SMDJ100A 5.0SMDJ100CA 111.0 123.0 1.0 5.0 100.0 30.9 162 5.0SMDJ110A 5.0SMDJ110CA 122.0 135.0 1.0 5.0 110.0 28.2 177 5.0SMDJ120A 5.0SMDJ120CA 133.0 147.0 1.0 5.0 120.0 25.9 193 5.0SMDJ130A 5.0SMDJ130CA 144.0 159.0 1.0 5.0 130.0 23.9 209 5.0SMDJ140A 5.0SMDJ140CA 155.0 171.0 1.0 5.0 140.0 22.0 226.8 5.0SMDJ150A 5.0SMDJ150CA 167.0 185.0 1.0 5.0 150.0 20.6 243 5.0SMDJ160A 5.0SMDJ160CA 178.0 197.0 1.0 5.0 160.0 19.3 259 5.0SMDJ170A 5.0SMDJ170CA 189.0 209.0 1.0 5.0 170.0 18.2 275 5.0SMDJ180A 5.0SMDJ180CA 200.2 220.0 1.0 5.0 180.0 17.1 291.6 5.0SMDJ190A 5.0SMDJ190CA 211.0 232.0 1.0 5.0 190.0 16.2 307.8 5.0SMDJ200A 5.0SMDJ200CA 224.0 247.0 1.0 5.0 200.0 15.4 324 5.0SMDJ220A 5.0SMDJ220CA 246.0 272.0 1.0 5.0 220.0 14.0 356 5.0SMDJ250A 5.0SMDJ250CA 279.0 309.0 1.0 5.0 250.0 12.3 405 5.0SMDJ300A 5.0SMDJ300CA 335.0 371.0 1.0 5.0 300.0 10.3 486 5.0SMDJ350A 5.0SMDJ350CA 391.0 432.0 1.0 5.0 350.0 8.8 567 5.0SMDJ400A 5.0SMDJ400CA 447.0 494.0 1.0 5.0 400.0 7.7 648 5.0SMDJ440A 5.0SMDJ440CA 492.0 543.0 1.0 5.0 440.0 7.0 713 Part Number (Uni) Part Number (Bi) 5.0SMDJ85A Breakdown Voltage VBR@IT (1) Notes: (1) Pulse Test:tp≤50ms Pulse test: tp≤50ms. (2) Surge current waveform per Fig. 3 and derated per Fig.2. ■Ordering Information (Example) PREFERED P/N PACKAG E CODE UNIT WEIGHT(g) MINIMUM PACKAGE(pcs) INNER BOX QUANTITY(pcs) OUTER CARTON QUANTITY(pcs) DELIVERY MODE 5.0SMDJ SERIES F1 Approximate 0.270 3000 6000 42000 13” reel ■ Characteristics(Typical) FIG2: Pulse Power or Current vs. Initial Junction Temperature 100 Non- Repet itive Pulse Wav eform shown in Fige.3 TA=25℃ PPP or IPP(%) PPPM(KW) FIG1:Peak Pulse Power Rating Curve 100 75 10 50 1.0 25 0.1 0.31×0.31"(8.0×8.0mm) Copper Pad Areas 0.1μs 1μs 10μs 100μs 1.0ms 10ms td(μs) 0 0 25 50 75 100 125 150 175 200 TJ(℃) 江苏正芯电子科技有限公司 www.zhengxinsemi.com FIG3: Pulse Waveform tr=10μs Rth(℃/W) IPPM(%) 150 FIG4:Typical Transient Thermal Impedance TJ=25℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM Peak Value IPPM 100 100 10 Half Value - IPP 2 IPPM 50 1 10/1000μs Waveform as Defined by R.E.A. td 0 0 1.0 2.0 3.0 4.0 0.1 0.001 0.01 0.1 1 10 100 1000 t(ms) TJ= TJMax. 8.3 ms Single Half Sin e-W av e 250 PD(W) IFSM(A) FIG5: Maximum Non-Repetitive Surge Current 300 tp(s) FIG6:Steady State Power Dissipation 7 6 5 200 4 150 3 100 2 50 1 0 0 10 100 Number of Cycles 0 0 25 50 75 100 125 150 175 200 TL(℃) ■ Outline Dimensions DO-214AB(SMC) DO-214AB (SMC) Dim Min Max A 6.60 7.11 B 2.85 3.27 C 5.59 6.22 D 7.75 8.13 E 1.99 2.61 F 0.15 0.31 G 0.76 1.52 H 0.05 0.20 Dimensions in millimeters 江苏正芯电子科技有限公司 www.zhengxinsemi.com ■ Suggested pad layout P2 Q1 Dim Min P1 9.9 P2 3.84 Q1 3.03 Q2 3.82 Q2 P1 Dimensions in millimeters 江苏正芯电子科技有限公司 www.zhengxinsemi.com
5.0SMDJ180A
物料型号:5.0SMDJ系列
器件简介:这是一系列单向和双向表面安装瞬态电压抑制二极管,具有UL认可,5000W峰值脉冲功率能力,低漏电,优秀的钳位能力,非常快的响应时间,符合MSL等级1和AEC-Q101认证。
引脚分配:对于单向类型,带子的一端表示阴极;双向类型没有标记。
参数特性: - 峰值脉冲功率:5000W(10/1000μs波形) - 峰值脉冲电流:见下表 - 功率耗散:在无限大散热器上,T=75°C时为6.5W - 单向类型峰值正向浪涌电流:300A(8.3ms单半正弦波) - 工作结和存储温度范围:-55至+150℃
功能详解:用于保护敏感电子设备免受由感性负载切换和IC、MOSFET、传感器信号线上的照明引起的电压瞬态。
应用信息:适用于消费电子、计算机、工业、电信等领域。
封装信息:DO-214AB(SMC),封装符合UL 94 V-0阻燃等级,RoHS合规,端子为锡镀引线,可按照J-STD002和JESD22-B102进行焊接。
电气特性和热特性表格提供了详细的参数,包括但不限于最大瞬态正向电压、热阻等。
5.0SMDJ180A 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ180A”相匹配的价格&库存,您可以联系我们找货
5.0SMDJ180A
    • 5+2.02749
    • 50+1.59203
    • 150+1.40541
    • 500+1.17256
    • 3000+1.06888
    • 6000+1.00656
    库存:266
