SMDJ36CA
SMDJ36CA
    ELECSUPER(静芯微)
    SMC(DO-214AB)
    双向TVS 36V截止 峰值脉冲电流:51.6A
SMDJ36CA 数据手册
SMDJ SERIES Rev-1.1 www.elecsuper.com SuperTVS – 3000W Transient Voltage Suppressor 1. Features ⚫ For surface mounted applications in order ⚫ 3000W peak pulse power capability at to optimize board space 10/1000μs waveform, repetition rate (duty ⚫ Low profile package cycle): 0.01% ⚫ Built-in strain relief ⚫ Fast response time ⚫ Glass passivated junction ⚫ Typical IR less than 1μA above 10V ⚫ Low inductance ⚫ Plastic package has underwriters laboratory ⚫ Excellent clamping capability ⚫ Meets MSL level 1, per J-STD-020 flammability 94V-0 ⚫ High Temperature soldering: 260℃/10 seconds at terminals 2. Mechanical Data ⚫ Case: JEDEC DO-214AB. Molded plastic ⚫ over glass passivated junction ⚫ Polarity: Color band denotes cathode except bi-directional models Terminal: Solder plated, solderable per ⚫ Standard Packaging: 12mm tape MIL-STD-750, Method 2026 ⚫ Weight: 0.28g 3. Maximum Ratings and Characteristics Ratings at 25°ambient temperature unless otherwise specified Rating Symbol Value Units Peak pulse power dissipation at 10/1000us waveform(Note1,2) PPPM 3000 W Peak pulse current of at 10/1000us waveform(Note1) IPPM See Table A PM(AV) 6.5 W IFSM 300 A TJ, TSTG -65 to 150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method)(Note3) Operating junction and Storage Temperature Range Copyright© ElecSuper Incorporated Contact Us 1 / 7 SMDJ SERIES Rev-1.1 www.elecsuper.com Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. 4. Electrical Characteristics (TA=25℃) Reverse Maximum Maximum Stand Part Test Part Maximum Peak Clamping Marking Number Breakdown off Voltage VBR (Volts) Current Voltage @ IT IT Number Reverse Pulse Voltage Leakage ROHS2.0 Current VC @ Ipp VR IR @ VR Ipp UNI BI UNI BI (V) (mA) (V) (A) SMDJ5.0A SMDJ5.0CA RDE DDE 5 6.4 7 10 9.2 326.1 400 y SMDJ6.0A SMDJ6.0CA RDG DDG 6 6.67 7.37 10 10.3 291.3 400 y SMDJ6.5A SMDJ6.5CA RDK DDK 6.5 7.22 7.98 10 11.2 267.9 250 y SMDJ7.0A SMDJ7.0CA PDM DDM 7 7.78 8.6 10 12 250 100 y SMDJ7.5A SMDJ7.5CA PDP DDP 7.5 8.33 9.21 1 12.9 232.6 80 y SMDJ8.0A SMDJ8.0CA PDR DDR 8 8.89 9.83 1 13.6 220.6 50 y SMDJ8.5A SMDJ8.5CA PDT DDT 8.5 9.44 10.4 1 14.4 208.3 20 y SMDJ9.0A SMDJ9.0CA PDV DDV 9 10 11.1 1 15.4 194.8 10 y SMDJ10A SMDJ10CA PDX DDX 10 11.1 12.3 1 17 176.5 5 y SMDJ11A SMDJ11CA PDZ DDZ 11 12.2 13.5 1 18.2 164.8 2 y SMDJ12A SMDJ12CA PEE DEE 12 13.3 14.7 1 19.9 150.8 2 y SMDJ13A SMDJ13CA PEG DEG 13 14.4 15.9 1 21.5 139.5 2 y SMDJ14A SMDJ14CA PEK DEK 14 15.6 17.2 1 23.2 129.3 2 y SMDJ15A SMDJ15CA PEM DEM 15 16.7 18.5 1 24.4 123 2 y SMDJ16A SMDJ16CA PEP DEP 16 17.8 19.7 1 26 115.4 2 y SMDJ17A SMDJ17CA PER DER 17 18.9 20.9 1 27.6 108.7 2 y SMDJ18A SMDJ18CA PET DET 18 20 22.1 1 29.2 102.7 2 y SMDJ20A SMDJ20CA PEV DEV 20 22.2 24.5 1 32.4 92.6 2 y SMDJ22A SMDJ22CA PEX DEX 22 24.4 26.9 1 35.5 84.5 2 y SMDJ24A SMDJ24CA PEZ DEZ 24 26.7 29.5 1 38.9 77.1 2 y SMDJ26A SMDJ26CA PFE DFE 26 28.9 31.9 1 42.1 71.3 2 y SMDJ28A SMDJ28CA PFG DFG 28 31.1 34.4 1 45.4 66.1 2 y SMDJ30A SMDJ30CA PFK DFK 30 33.3 36.8 1 48.4 62 2 y SMDJ33A SMDJ33CA PFM DFM 33 36.7 40.6 1 53.3 56.3 2 y SMDJ36A SMDJ36CA PFP DFP 36 40 44.2 1 58.1 51.6 2 y SMDJ40A SMDJ40CA PFR DFR 40 44.4 49.1 1 64.5 46.5 2 y SMDJ43A SMDJ43CA PFT DFT 43 47.8 52.8 1 69.4 43.2 2 y Copyright© ElecSuper Incorporated MIN MAX Contact Us (µA) 2 / 7 SMDJ SERIES Rev-1.1 www.elecsuper.com Reverse Maximum Maximum Part Part Number Number Stand Breakdown Test off Voltage VBR (Volts) Current Maximum Peak Clamping Marking Reverse Pulse Voltage Voltage @ IT IT Leakage ROHS2.0 Current VC @ Ipp VR IR @ VR Ipp UNI BI UNI BI (V) MIN MAX (mA) (V) (A) (µA) SMDJ45A SMDJ45CA PFV DFV 45 50 55.3 1 72.7 41.3 2 y SMDJ48A SMDJ48CA PFX DFX 48 53.3 58.9 1 77.4 38.8 2 y SMDJ51A SMDJ51CA PFZ DFZ 51 56.7 62.7 1 82.4 36.4 2 y SMDJ54A SMDJ54CA RGE DGE 54 60 66.3 1 87.1 34.4 2 y SMDJ58A SMDJ58CA PGG DGG 58 64.4 71.2 1 93.6 32.1 2 y SMDJ60A SMDJ60CA PGK DGK 60 66.7 73.7 1 96.8 31 2 y SMDJ64A SMDJ64CA PGM DGM 64 71.1 78.6 1 103 29.1 2 y SMDJ70A SMDJ70CA PGP DGP 70 77.8 86 1 113 26.5 2 y SMDJ75A SMDJ75CA PGR DGR 75 83.3 92.1 1 121 24.8 2 y SMDJ78A SMDJ78CA PGT DGT 78 86.7 95.8 1 126 23.8 2 y SMDJ85A SMDJ85CA PGV DGV 85 94.4 104 1 137 21.9 2 y SMDJ90A SMDJ90CA PGX DGX 90 100 111 1 146 20.5 2 y SMDJ100A SMDJ100CA PGZ DGZ 100 111 123 1 162 18.5 2 y SMDJ110A SMDJ110CA PHE DHE 110 122 135 1 177 16.9 2 y SMDJ120A SMDJ120CA PHG DHG 120 133 147 1 193 15.5 2 y SMDJ130A SMDJ130CA PHK DHK 130 144 159 1 209 14.4 2 y SMDJ150A SMDJ150CA PHM DHM 150 167 185 1 243 12.3 2 y SMDJ160A SMDJ160CA PHP DHP 160 178 197 1 259 11.6 2 y SMDJ170A SMDJ170CA PHR DHR 170 189 209 1 275 10.9 2 y SMDJ180A SMDJ180CA PHT DHT 180 200 221 1 292 10.3 2 y SMDJ220A SMDJ220CA PKE DKE 220 244 270 1 356 8.4 2 y For bidirectional type having VRWM of 10 volts and less, the IR limit is double. Copyright© ElecSuper Incorporated Contact Us 3 / 7 SMDJ SERIES Rev-1.1 www.elecsuper.com 5. Ratings and Characteristic Curves (TA =25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2 Pulse Derating Curve Figure 3 Pulse Waveform Figure 4 Typical Junction Capacitance Figure 5 Steady State Power Dissipation Derating Curve Figure 6 Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Copyright© ElecSuper Incorporated Contact Us 4 / 7 SMDJ SERIES Rev-1.1 www.elecsuper.com 6. Dimension (SMC/DO-214AB) Dimensions Inches Millimeters Min Max Min Max A 0.114 0.126 2.9 3.2 B 0.26 0.28 6.6 7.11 C 0.22 0.245 5.59 6.22 D 0.079 0.103 2.06 2.62 E 0.03 0.06 0.76 1.52 F - 0.008 - 0.203 G 0.305 0.32 7.75 8.13 H 0.006 0.012 0.152 0.305 I 0.129 - 3.3 - J 0.094 - 2.4 - K - 0.165 - 4.2 L 0.094 - 2.4 - Copyright© ElecSuper Incorporated Contact Us 5 / 7 SMDJ SERIES Rev-1.1 www.elecsuper.com 7. Packaging Copyright© ElecSuper Incorporated Contact Us 6 / 7 SMDJ SERIES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper product. Copyright© ElecSuper Incorporated Contact Us 7 / 7
SMDJ36CA 价格&库存
很抱歉,暂时无法提供与“SMDJ36CA”相匹配的价格&库存,您可以联系我们找货
