BV-SMDJ33A
BV-SMDJ33A
    BENCENT(槟城)
    SMC(DO-214AB)
    瞬态电压抑制器
BV-SMDJ33A 数据手册
SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Features Exterior IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact) 3000Watts peak pulse power (tp=10/1000μS) Quick response to surge voltage Low clamping voltage Moisture sensitivity level:Level 1 DO-214AB Agency Approvals Application information DC Port Icon RS485/232/422 Description Compliance with 2011/65/EU I/O Port Compliance with IEC61249-2-21:2003 Schematic symbol anode cathode BI-directional UNI-directional Part Number and Electrical Parameter Part Number Marking VR(V) VBR VBR It Max Vc@I 1 ○ PP (V) IPP○1 (A) IR@VR min.(V) max.(V) (mA) 5 6.4 7 10 9.2 326.1 800 D6 6 6.67 7.37 10 10.3 291.3 800 D6.5C D6.5 6.5 7.22 7.98 10 11.2 267.9 500 BV-SMDJ7A D7C D7 7 7.78 8.6 10 12 250.0 200 BV-SMDJ7.5CA BV-SMDJ7.5A D7.5C D7.5 7.5 8.33 9.21 1 12.9 232.6 100 BV-SMDJ8CA BV-SMDJ8A D8C D8 8 8.89 9.83 1 13.6 220.6 50 BV-SMDJ8.5CA BV-SMDJ8.5A D8.5C D8.5 8.5 9.44 10.4 1 14.4 208.3 20 BV-SMDJ9CA BV-SMDJ9A D9C D9 9 10 11.1 1 15.4 194.8 10 BV-SMDJ10CA BV-SMDJ10A D10C D10 10 11.1 12.3 1 17 176.5 5 BV-SMDJ11CA BV-SMDJ11A D11C D11 11 12.2 13.5 1 18.2 164.8 2 BV-SMDJ12CA BV-SMDJ12A D12C D12 12 13.3 14.7 1 19.9 150.8 1 BV-SMDJ13CA BV-SMDJ13A D13C D13 13 14.4 15.9 1 21.5 139.5 1 BI UNI BI UNI BV-SMDJ5CA BV-SMDJ5A D5C D5 BV-SMDJ6CA BV-SMDJ6A D6C BV-SMDJ6.5CA BV-SMDJ6.5A BV-SMDJ7CA 1/5 www.bencent.com.cn (uA) Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Part Number Marking VR(V) VBR VBR It Max Vc@I ○ 1 PP IPP○(A) 1 (V) IR@VR (uA) min.(V) max.(V) (mA) 14 15.6 17.2 1 23.2 129.3 1 D15 15 16.7 18.5 1 24.4 123.0 1 D16C D16 16 17.8 19.7 1 26 115.4 1 BV-SMDJ17A D17C D17 17 18.9 20.9 1 27.6 108.7 1 BV-SMDJ18CA BV-SMDJ18A D18C D18 18 20 22.1 1 29.2 102.7 1 BV-SMDJ20CA BV-SMDJ20A D20C D20 20 22.2 24.5 1 32.4 92.6 1 BV-SMDJ22CA BV-SMDJ22A D22C D22 22 24.4 26.9 1 35.5 84.5 1 BV-SMDJ24CA BV-SMDJ24A D24C D24 24 26.7 29.5 1 38.9 77.1 1 BV-SMDJ26CA BV-SMDJ26A D26C D26 26 28.9 31.9 1 42.1 71.3 1 BV-SMDJ28CA BV-SMDJ28A D28C D28 28 31.1 34.4 1 45.4 66.1 1 BV-SMDJ30CA BV-SMDJ30A D30C D30 30 33.3 36.8 1 48.4 62.0 1 BV-SMDJ33CA BV-SMDJ33A D33C D33 33 36.7 40.6 1 53.3 56.3 1 BV-SMDJ36CA BV-SMDJ36A D36C D36 36 40 44.2 1 58.1 51.6 1 BV-SMDJ40CA BV-SMDJ40A D40C D40 40 44.4 49.1 1 64.5 46.5 1 BV-SMDJ43CA BV-SMDJ43A D43C D43 43 47.8 52.8 1 69.4 43.2 1 BV-SMDJ45CA BV-SMDJ45A D45C D45 45 50 55.3 1 72.7 41.3 1 BV-SMDJ48CA BV-SMDJ48A D48C D48 48 53.3 58.9 1 77.4 38.8 1 BV-SMDJ51CA BV-SMDJ51A D51C D51 51 56.7 62.7 1 82.4 36.4 1 BV-SMDJ54CA BV-SMDJ54A D54C D54 54 60 66.3 1 87.1 34.4 1 BV-SMDJ58CA BV-SMDJ58A D58C D58 58 64.4 71.2 1 93.6 32.1 1 BV-SMDJ60CA BV-SMDJ60A D60C D60 60 66.7 73.7 1 96.8 31.0 1 BV-SMDJ64CA BV-SMDJ64A D64C D64 64 71.1 78.6 1 103 29.1 1 BV-SMDJ70CA BV-SMDJ70A D70C D70 70 77.8 86 1 113 26.5 1 BV-SMDJ75CA BV-SMDJ75A D75C D75 75 83.3 92.1 1 121 24.8 1 BV-SMDJ78CA BV-SMDJ78A D78C D78 78 86.7 95.8 1 126 23.8 1 BV-SMDJ85CA BV-SMDJ85A D85C D85 85 94.4 104 1 137 21.9 1 BV-SMDJ90CA BV-SMDJ90A D90C D90 90 100 111 1 146 20.5 1 BV-SMDJ100CA BV-SMDJ100A D100C D100 100 111 123 1 162 18.5 1 BV-SMDJ110CA BV-SMDJ110A D110C D110 110 122 135 1 177 16.9 1 BI UNI BI UNI BV-SMDJ14CA BV-SMDJ14A D14C D14 BV-SMDJ15CA BV-SMDJ15A D15C BV-SMDJ16CA BV-SMDJ16A BV-SMDJ17CA Note:absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted). 1 Surge Waveform: 10/1000μS ○ 2/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Mark DXXC cathode BI:DXXC Part Number BV SMDJ (1) DXX anode UNI:DXX System XX C (3) (4) (5) (2) A (1) Bencent Transient Voltage Suppressor (2)Series Code (3) VR=XXV (4)BI-directional (5) Suffix ‘A’ denotes 5% tolerance devices V-I Curve IPP VC VBR VR It IR IR It VR VBR V VC VC VBR VR IR It VF UNI-directional BI-directional IPP IPP 3/5 Parameters Definition VF Forward Voltage drop for UNI-directional VC Clamping Voltage Ipp Surge Waveform 10/1000μs VR Stand-off Voltage VBR Breakdown Voltage IR Reverse Leakage Current It Test Current Ppp Peak Pulse Power Dissipation www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications V SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Thermal Considerations symbol Parameter Value Unit TJ Operating Junction Temperature Range -55 to +150 ℃ TS Storage Temperature Range -55 to +150 ℃ Environmental Characteristics Technical standards Testing items High Temperature Reverse Bias Test High Temperature Life Test High-low Temperature Cycle Test High Temperature &High Humidity Test Pressure Cooker Test Resistance of Soldering Heat Temperature: 150±3℃ Bias=80%VR Time:168H Temperature: 150℃ Time:168H Temperature: From -40℃ to125℃ Dwell time :30min,10cycles Temperature: 85℃ Humidity:85% Time:168H Temperature: 121℃,2atm. Humidity:100% Time:24H Temperature: 260±5℃ Time of dip soldering:10s,3times Note: The above testing items can be specified by customer’s special request Product Dimensions REF A B C D E F G H mm 2.85--3.05 5.85--6.15 6.75--7.05 2.45--2.95 0.15—0.25 0.90--1.60 0.00—0.40 7.75--8.25 inch 0.112--0.120 0.230--0.242 0.266--0.278 0.096--0.116 0.006--0.012 0.035--0.063 0.000--0.016 0.305--0.325 Recommended Soldering Pad 4/5 www.bencent.com.cn REF mm inch A 8.25 0.325 B 5.05 0.199 C 3.05 0.12 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Reflow Profile Reflow Condition Pre Heat Pb-Free assembly Temperature Min 150°C Temperature Max 200°C Time (min to max) 60 – 180 secs TP TP Average ramp up rate(Liquidus)Tamp(TL) 3°C/s max to peak Reflow 3°C/s max - Temperature (TL) (Liquidus) 217°C - Temperature (TL) 60 – 150 secs Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (TP) 30secs Ramp-down Rate 6°C/s max Time 25°C to peak Temperature (TP) 8 min max. Do not exceed 260°C Package 5/5 Reel Ramp-up TL Temperature TS(max) to TL - Ramp-up Rate Critical Zone TL to TP TL TS(max) Ramp-down Preheat TS(min) TS 25 Time time to peak temperature Information REF. mm inch A 6.15+/-0.1 0.242+/-0.004 B 8.2+/-0.1 0.323+/0-.004 d 1.5+/-0.05 0.059+/-0.002 D 330.0 13.0 D1 72+/-3 2.835+/-0.118 D2 13+/-0.3 0.512+/-0.012 E 1.75+/-0.1 0.069+/-0.004 F 5.5+/-0.05 0.212+/-0.002 P 8.0+/-0.1 0.315+/-0.004 P0 4.0+/-0.1 0.157+/-0.004 P1 2.0+/-0.05 0.079+/-0.004 W 16+/-0.1 0.630+/-0.004 W1 22+/-2.0 0.866+/-0.079 Outline Reel (pcs) Per Carton (pcs) Reel Diameters (mm) Taping 3,000 24,000 330 www.bencent.com.cn Carton Size(mm) L W H 360 360 380 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BV-SMDJ33A
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装形式。
BV-SMDJ33A 价格&库存
很抱歉,暂时无法提供与“BV-SMDJ33A”相匹配的价格&库存,您可以联系我们找货
