SMCJ30CA
SMCJ30CA
    ELECSUPER(静芯微)
    SMC(DO-214AB)
    极性:双向 最大耗散功率:1500W 反向截止电压:30V 最大反向电流:1UA 击穿电压:33.3V(MIN) 最大脉冲电流:31A 最大嵌位电压:48.4V
SMCJ30CA 数据手册
SMCJ SERIES Rev-1.1 www.elecsuper.com SuperTVS – 1500W Transient Voltage Suppressor 1. Features ⚫ For surface mounted applications in order ⚫ 1500W peak pulse power capability at to optimize board space 10/1000μs waveform, repetition rate (duty ⚫ Low profile package cycle): 0.01% ⚫ Built-in strain relief ⚫ Fast response time ⚫ Glass passivated junction ⚫ Typical IR less than 1μA above 10V ⚫ Low inductance ⚫ Plastic package has underwriters laboratory ⚫ Excellent clamping capability ⚫ Meets MSL level 1, per J-STD-020 flammability 94V-0 ⚫ High Temperature soldering: 260℃/10 seconds at terminals 2. Mechanical Data ⚫ Case: JEDEC DO-214AB. Molded plastic ⚫ over glass passivated junction ⚫ Polarity: Color band denotes cathode except bi-directional models Terminal: Solder plated, solderable per ⚫ Standard Packaging: 12mm tape MIL-STD-750, Method 2026 ⚫ Weight: 0.26g 3. Maximum Ratings and Characteristics Ratings at 25°ambient temperature unless otherwise specified Rating Symbol Value Units Peak pulse power dissipation at 10/1000us waveform(Note1,2) PPPM 1500 W Peak pulse current of at 10/1000us waveform(Note1) IPPM See Table A PM(AV) 6.5 W IFSM 200 A TJ, TSTG -65 to 150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method)(Note3) Operating junction and Storage Temperature Range Copyright© ElecSuper Incorporated Contact Us 1 / 7 SMCJ SERIES Rev-1.1 www.elecsuper.com Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. 4. Electrical Characteristics (TA=25℃) Reverse Maximum Maximum Stand Part Test Part Maximum Peak Clamping Marking Number Breakdown off Voltage VBR (Volts) Current Voltage @ IT IT Number Reverse Pulse Voltage Leakage ROHS2.0 Current VC @ Ipp VR IR @ VR Ipp UNI BI UNI BI (V) SMCJ5.0A SMCJ5.0CA GDE BDE 5 6.4 SMCJ6.0A SMCJ6.0CA GDG BDG 6 SMCJ6.5A SMCJ6.5CA GDK BDK SMCJ7.0A SMCJ7.0CA GDM SMCJ7.5A SMCJ7.5CA SMCJ8.0A (mA) (V) 7 10 9.2 163 400 y 6.67 7.37 10 10.3 145.7 400 y 6.5 7.22 7.98 10 11.2 134 250 y BDM 7 7.78 8.6 10 12 125 100 y GDP BDP 7.5 8.33 9.21 1 12.9 116.3 80 y SMCJ8.0CA GDR BDR 8 8.89 9.83 1 13.6 110.3 50 y SMCJ8.5A SMCJ8.5CA GDT BDT 8.5 9.44 10.4 1 14.4 104.2 20 y SMCJ9.0A SMCJ9.0CA GDV BDV 9 10 11.1 1 15.4 97.4 10 y SMCJ10A SMCJ10CA GDX BDX 10 11 12.3 1 17 88.3 5 y SMCJ11A SMCJ11CA GDZ BDZ 11 12.2 13.5 1 18.2 82.5 1 y SMCJ12A SMCJ12CA GEE BEE 12 13.3 14.7 1 19.9 75.4 1 y SMCJ13A SMCJ13CA GEG BEG 13 14.4 15.9 1 21.5 69.8 1 y SMCJ14A SMCJ14CA GEK BEK 14 15.6 17.2 1 23.2 64.7 1 y SMCJ15A SMCJ15CA GEM BEM 15 16.7 18.5 1 24.4 61.5 1 y SMCJ16A SMCJ16CA GEP BEP 16 17.8 19.7 1 26 57.7 1 y SMCJ17A SMCJ17CA GER BER 17 18.9 20.9 1 27.6 54.4 1 y SMCJ18A SMCJ18CA GET BET 18 20 22.1 1 29.2 51.4 1 y SMCJ20A SMCJ20CA GEV BEV 20 22.2 24.5 1 32.4 46.3 1 y SMCJ22A SMCJ22CA GEX BEX 22 24.4 26.9 1 35.5 42.3 1 y SMCJ24A SMCJ24CA GEZ BEZ 24 26.7 29.5 1 38.9 38.6 1 y SMCJ26A SMCJ26CA GFE BFE 26 28.9 31.9 1 42.1 35.7 1 y SMCJ28A SMCJ28CA GFG BFG 28 31.1 34.4 1 45.4 33.1 1 y SMCJ30A SMCJ30CA GFK BFK 30 33.3 36.8 1 48.4 31 1 y SMCJ33A SMCJ33CA GFM BFM 33 36.7 40.6 1 53.3 28.2 1 y SMCJ36A SMCJ36CA GFP BFP 36 40 44.2 1 58.1 25.9 1 y SMCJ40A SMCJ40CA GFR BFR 40 44.4 49.1 1 64.5 23.3 1 y SMCJ43A SMCJ43CA GFT BFT 43 47.8 52.8 1 69.4 21.7 1 y Copyright© ElecSuper Incorporated MIN MAX Contact Us (A) (µA) 2 / 7 SMCJ SERIES Rev-1.1 www.elecsuper.com Reverse Maximum Maximum Part Part Number Number Stand Breakdown Test off Voltage VBR (Volts) Current Maximum Peak Clamping Marking Reverse Pulse Voltage Voltage @ IT IT Leakage ROHS2.0 Current VC @ Ipp VR IR @ VR Ipp UNI BI UNI BI (V) MIN MAX (mA) (V) (A) (µA) SMCJ45A SMCJ45CA GFV BFV 45 50 55.3 1 72.7 20.6 1 y SMCJ48A SMCJ48CA GFX BFX 48 53.3 58.9 1 77.4 19.4 1 y SMCJ51A SMCJ51CA GFZ BFZ 51 56.7 62.7 1 82.4 18.2 1 y SMCJ54A SMCJ54CA GGE BGE 54 60 66.3 1 87.1 17.3 1 y SMCJ58A SMCJ58CA GGG BGG 58 64.4 71.2 1 93.6 16.1 1 y SMCJ60A SMCJ60CA GGK BGK 60 66.7 73.7 1 96.8 15.5 1 y SMCJ64A SMCJ64CA GGM BGM 64 71.1 78.6 1 103 14.6 1 y SMCJ70A SMCJ70CA GGP BGP 70 77.8 86 1 113 13.3 1 y SMCJ75A SMCJ75CA GGR BGR 75 83.3 92.1 1 121 12.4 1 y SMCJ78A SMCJ78CA GGT BGT 78 86.7 95.8 1 126 11.9 1 y SMCJ85A SMCJ85CA GGV BGV 85 94.4 104 1 137 11 1 y SMCJ90A SMCJ90CA GGX BGX 90 100 111 1 146 10.3 1 y SMCJ100A SMCJ100CA GGZ BGZ 100 111 123 1 162 9.3 1 y SMCJ110A SMCJ110CA GHE BHE 110 122 135 1 177 8.5 1 y SMCJ120A SMCJ120CA GHG BHG 120 133 147 1 193 7.8 1 y SMCJ130A SMCJ130CA GHK BHK 130 144 159 1 209 7.2 1 y SMCJ150A SMCJ150CA GHM BHM 150 167 185 1 243 6.2 1 y SMCJ160A SMCJ160CA GHP BHP 160 178 197 1 259 5.8 1 y SMCJ170A SMCJ170CA GHR BHR 170 189 209 1 275 5.5 1 y SMCJ180A SMCJ180CA GHT BHT 180 201 222 1 292 5.1 1 y SMCJ200A SMCJ200CA GHV BHV 200 224 247 1 324 4.6 1 y SMCJ220A SMCJ220CA GHX BHX 220 246 272 1 356 4.2 1 y SMCJ250A SMCJ250CA GHZ BHZ 250 279 309 1 405 3.7 1 y SMCJ300A SMCJ300CA GJE BJE 300 335 371 1 486 3.1 1 y SMCJ350A SMCJ350CA GJG BJG 350 391 432 1 567 2.6 1 y SMCJ400A SMCJ400CA GJK BJK 400 447 494 1 648 2.3 1 y SMCJ440A SMCJ440CA GJM BJM 440 492 543 1 713 2.1 1 y For bidirectional type having VR of 10 volts and less, the IR limit is double. Copyright© ElecSuper Incorporated Contact Us 3 / 7 SMCJ SERIES Rev-1.1 www.elecsuper.com 5. Ratings and Characteristic Curves (TA =25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2 Pulse Derating Curve Figure 3 Pulse Waveform Figure 4 Typical Junction Capacitance Figure 5 Steady State Power Dissipation Derating Curve Figure 6 Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Copyright© ElecSuper Incorporated Contact Us 4 / 7 SMCJ SERIES Rev-1.1 www.elecsuper.com 6. Dimension (SMC/DO-214AB) Dimensions Inches Millimeters Min Max Min Max A 0.114 0.126 2.9 3.2 B 0.26 0.28 6.6 7.11 C 0.22 0.245 5.59 6.22 D 0.079 0.103 2.06 2.62 E 0.03 0.06 0.76 1.52 F - 0.008 - 0.203 G 0.305 0.32 7.75 8.13 H 0.006 0.012 0.152 0.305 I 0.129 - 3.3 - J 0.094 - 2.4 - K - 0.165 - 4.2 L 0.094 - 2.4 - Copyright© ElecSuper Incorporated Contact Us 5 / 7 SMCJ SERIES Rev-1.1 www.elecsuper.com 7. Packaging Copyright© ElecSuper Incorporated Contact Us 6 / 7 SMCJ SERIES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
SMCJ30CA 价格&库存
很抱歉,暂时无法提供与“SMCJ30CA”相匹配的价格&库存,您可以联系我们找货
