SMCJ100A
SMCJ100A
    ZHIDE(志得)
    SMC(DO-214AB)
    单向TVS 100V截止 峰值浪涌电流:9.26A
SMCJ100A 数据手册
SMCJxx(C)A Series Surface Mount Transient Voltage Suppressor Rectifiers Reverse Voltage 5.0 ~ 550 V 1500 Watt Peak Pulse Power DO214AB/(SMC) Features ● Glass passivated chip ● 1500 W peak pulse power capability with a 10/1000 us waveform, repetitive rate (duty cycle):0.01 % ● Excellent clamping capability ● Low reverse leakage ● Very fast response time ● Lead and body according with RoHS standard Mechanical Data ● Case: DO214AB/(SMC) Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end except Bipolar Unit: inch (mm) ● Mounting position: Any Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Symbols Value Unit Peak power dissipation with a 10/1000 us waveform(1) PPP 1500 W Peak pulse current wih a 10/1000 us waveform(1) IPP See Next Table A Power dissipation on infinite heatsink at TL = 75 °C PD 5.0 W IFSM 200 A VF 3.5/6.5 V TJ,TSTG -55 to +150 ℃ Parameter Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 100 A for unidirectional only(3) Operating junction and storage temperature range Note: 1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3)VF
SMCJ100A
物料型号:SMCJxx(C)A系列
器件简介:这是一款表面安装瞬态电压抑制二极管,具有1500瓦的峰值脉冲功率能力,响应时间快,反向漏电低,符合RoHS标准。
引脚分配:文档中未明确提供引脚分配信息,但通常这类器件会有极性标记,如色带表示阴极端。
参数特性: - 峰值脉冲功率:1500W,10/1000μs波形 - 峰值脉冲电流:具体值见下表 - 在无限大散热器上,TL=75°C时的功率耗散:5.0W - 单向8.3ms单半正弦波峰值浪涌电流:200A - 100A时的最大瞬态正向电压:3.5V/6.5V - 工作结和存储温度范围:-55°C至+150°C
功能详解:文档提供了脉冲降额曲线、最大非重复浪涌电流、稳态功率降额曲线、峰值脉冲功率额定值、脉冲波形和典型结电容等图表,以展示器件的性能。
应用信息:文档未明确提供应用信息,但这类器件通常用于电源保护、汽车电子、工业控制等领域。
封装信息:封装类型为DO214AB/(SMC),是模塑塑料封装,引脚可焊性符合MIL-STD-750标准,环氧树脂为UL 94V-0级阻燃。
SMCJ100A 价格&库存
很抱歉,暂时无法提供与“SMCJ100A”相匹配的价格&库存,您可以联系我们找货
