SMCJ6.5CA
SMCJ6.5CA
    GOODWORK(固得沃克)
    SMC(DO-214AB)
    双向TVS 6.5V截止 峰值脉冲电流:133.9A
SMCJ6.5CA 数据手册
SMCJ SERIES SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS VOLTAGE RANGE 5.0 to 440 Volts FEATURES * For surface mount application * Built-in strain relief * Excellent clamping capability 1500 Watts Peak Power DO-214AB(SMC) * Low profile package * Fast response time: Typically less than 1.0ps from 0 volt to BV min. * Typical IR less than 1 A above 10V * High temperature soldering guaranteed: 260 C / 10 seconds at terminals .245(6.22) .220(5.59) .124(3.15) .108(2.75) .280(7.11) .260(6.60) MECHANICAL DATA .012(0.31) .006(0.15) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Solderable per MIL-STD-202, method 208 guranteed * Polarity: Color band denotes cathode end except Bidirectional * Mounting position: Any * Weight: 0.21 grams .103(2.62) .079(2.00) .050(1.27) .030(0.76) .008 MAX. (.203) .320(8.13) .305(7.75) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. RATINGS SYMBOL VALUE UNITS PPK Minimum 1500 Watts IFSM 200 Amps Peak Power Dissipation at TA=25 C, TP=1ms(NOTE 1) Peak Forward Surge Current at 8.3ms Single Half Sine-Wave superimposed on rated load (JEDEC method) (NOTE 3) Maximum Instantenous Forward Voltage at 35.0A for Unidirectional only Typical Thermal Resistance Between junction and case Typical Thermal Resistance Between junction and Air VF 3.5 Volts RθJ-C q RθJ-A 15 75 C/W C/W Operating and Storage Temperature Range TJ, TSTG -55 to +150 C NOTES: 1. Non-repetitive current pulse per Fig. 3 and derated above TA=25 C per Fig. 2. 2 2. Mounted on Copper Pad area of 8.0mm (.013mm Thick) to each terminal. 3. 8.3ms single half sine-wave, duty cycle = 4 pulses per minute maximum. DEVICES FOR BIPOLAR APPLICATIONS 1. For Bidirectional use C or CA Suffix for types SMCJ5.0 thru SMCJ440. 2. Electrical characteristics apply in both directions. REV 1.0 2017 JAN PAGE:1/4 RATING AND CHARACTERISTIC CURVES (SMCJ SERIES) FIG.1-PEAK PULSE POWER DERATING CURVE PPPM, PEAK PULSE POWER, KW 100 Non-Repetitive Pulse Waveform Shown in Fig. 3 TA=25 C 10 1.0 2 5.0mm COPPER PAD AREAS 0.1 0.1ms PEAK PULSE POWER(PPP) OR CURRENT(IPP) DERATING IN PERCENTAGE FIG.2-PULSE DERATING CURVE 100 75 50 25 0 1.0ms 10ms 100ms 1.0ms 0 10ms 25 50 100 125 150 175 FIG.4-TYPICAL JUNCTION CAPACITANCE FIG.3-PULSE WAVE FORM 150 10,000 TA=25 C Pulse Width (td) is defined as the point where the Peak Current Deacys to 50% of Ipp Tf=10 s Peak Value IPPM TJ=25 C f=1.0MHz Vsig=50mVp-p 5,000 Measued at Zero Bias 100 2,000 Half Value-IPPM 2 50 1,000 10/1000 sec Waveform as Defined by R.E.A. td e-kt 0 0 1.0 2.0 3.0 4.0 t, TIME, ms CJ, CAPACITANCE, pF IPPM, PEAK PULSE CURRENT, % 75 TA, AMBIENT TEMPERATURE ( C) td, PULSE WIDTH, sec. 500 Measured at Stand-Off Voltage(VMW) 200 100 50 FIG.5-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 200 20 TJ=TJmax 8.3ms Single Half Sine-wave JEDEC Method IFSM, PEAK FORWARD SURGE CURRENT, AMPERES 160 10 1.0 120 2.0 5.0 10 20 50 100 200 V(BR), BREAKDOWN VOLTAGE, VOLTS 80 40 10 1 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz REV 1.0 2017 JAN PAGE:2/4 1500 Watt Surface Mount TVS PART NUMBER REVERSE BREAKDOWN BREAKDOWN TEST ADD C FOR BI- STAND-OFF VOLTAGE VOLTAGE CURRENT DIRECTIONAL VOLTAGE VBR (V) VBR (V) IT See Note 1 VRWM (V) MIN. @IT MAX. @IT (mA) MAXIMUM CLAMPING VOLTAGE @Ipp Vc (V) PEAK REVERSE PULSE LEAKAGE CURRENT @ VRWM Ipp (A) IR( A) MARKING CODE UNI BI GDE SMCJ5.0(C)A 5.0 6.40 7.25 10 9.2 163.0 1000 GDE SMCJ6.0(C)A 6.0 6.67 7.67 10 10.3 145.6 1000 GDG GDG SMCJ6.5(C)A 6.5 7.22 8.30 10 11.2 133.9 500 GDK SMCJ7.0(C)A 7.0 7.78 8.95 10 12.0 125.0 200 GDM GDM SMCJ7.5(C)A 7.5 8.33 9.58 1 12.9 116.3 100 GDP BDP SMCJ8.0(C)A 8.0 8.89 10.23 1 13.6 110.3 50 GDR BDR SMCJ8.5(C)A 8.5 9.44 10.82 1 14.4 104.2 20 GDT BDT SMCJ9.0(C)A 9.0 10.0 11.50 1 15.4 97.4 10 GDV BDV SMCJ10(C)A 10 11.1 12.80 1 17.0 88.2 5 GDX BDX SMCJ11(C)A 11 12.2 14.00 1 18.2 82.4 5 GDZ GDZ SMCJ12(C)A 12 13.3 15.30 1 19.9 75.3 5 GEE BEE SMCJ13(C)A 13 14.4 16.50 1 21.5 69.7 5 GEG GEG SMCJ14(C)A 14 15.6 17.90 1 23.2 64.7 5 GEK BEK SMCJ15(C)A 15 16.7 19.20 1 24.4 61.5 5 GEM BEM SMCJ16(C)A 16 17.8 20.50 1 26.0 57.7 5 GEP GEP SMCJ17(C)A 17 18.9 21.70 1 27.6 53.3 5 GER GER SMCJ18(C)A 18 20.0 23.30 1 29.2 51.4 5 GET BET SMCJ20(C)A 20 22.2 25.50 1 32.4 46.3 5 GEV BEV SMCJ22(C)A 22 24.4 28.00 1 35.5 42.2 5 GEX BEX SMCJ24(C)A 24 26.7 30.70 1 38.9 38.6 5 GEZ BEZ SMCJ26(C)A 26 28.9 33.20 1 42.1 35.6 5 GFE BFE SMCJ28(C)A 28 31.1 35.80 1 45.4 33.0 5 GFG BFG SMCJ30(C)A 30 33.3 38.30 1 48.4 31.0 5 GFK BFK SMCJ33(C)A 33 36.7 42.20 1 53.3 28.1 5 GFM BFM SMCJ36(C)A 36 40.0 46.00 1 58.1 25.8 5 GFP BFP SMCJ40(C)A 40 44.4 51.10 1 64.5 23.2 5 GFR BFR SMCJ43(C)A 43 47.8 54.90 1 69.4 21.6 5 GFT BFT SMCJ45(C)A 45 50.0 57.50 1 72.7 20.6 5 GFV GFV SMCJ48(C)A 48 53.3 61.30 1 77.4 19.4 5 GFX GFX SMCJ51(C)A 51 56.7 65.20 1 82.4 18.2 5 GFZ GFZ SMCJ54(C)A 54 60.0 69.00 1 87.1 17.2 5 GGE GGE SMCJ58(C)A 58 64.4 74.10 1 93.6 16.0 5 GGG GGG BDK REV 1.0 2017 JAN PAGE:3/4 1500 Watt Surface Mount TVS PART NUMBER REVERSE BREAKDOWN BREAKDOWN TEST ADD C FOR BI- STAND-OFF VOLTAGE VOLTAGE CURRENT DIRECTIONAL VOLTAGE VBR (V) VBR (V) IT See Note 1 VRWM (V) MIN. @IT MAX. @IT (mA) MAXIMUM CLAMPING VOLTAGE @Ipp Vc (V) PEAK REVERSE PULSE LEAKAGE CURRENT @ VRWM Ipp (A) IR( A) MARKING CODE UNI BI GGK SMCJ60(C)A 60 66.7 76.7 1 96.8 15.5 5 GGK SMCJ64(C)A 64 71.1 81.8 1 103 14.6 5 GGM GGM SMCJ70(C)A 70 77.8 89.5 1 113 13.3 5 GGP GGP SMCJ75(C)A 75 83.3 95.8 1 121 12.4 5 GGR GGR SMCJ78(C)A 78 86.7 99.7 1 126 11.4 5 GGT GGT SMCJ85(C)A 85 94.4 108.2 1 137 10.4 5 GGV GGV SMCJ90(C)A 90 100 115.5 1 146 10.3 5 GGX GGX SMCJ100(C)A 100 111 128.0 1 162 9.3 5 GGZ GGZ SMCJ110(C)A 110 122 140.5 1 177 8.4 5 GHE GHE SMCJ120(C)A 120 133 153.0 1 193 7.9 5 GHG GHG SMCJ130(C)A 130 144 165.5 1 209 7.2 5 GHK GHK SMCJ150(C)A 150 167 192.5 1 243 6.2 5 GHM GHM SMCJ160(C)A 160 178 205.0 1 259 5.8 5 GHP GHP SMCJ170(C)A 170 189 217.5 1 275 5.5 5 GHR GHR SMCJ188(C)A 188 209 231.0 1 308 4.6 5 GHS GHS SMCJ200(C)A 200 224 247 1 324 4.6 5 GHV BHV SMCJ220 (C)A 220 246 272 1 356 4.2 5 GHX BHX SMCJ250 (C)A 250 279 309 1 405 3.7 5 GHZ BHZ SMCJ300 (C)A 300 335 371 1 486 3.1 5 GJE BJE SMCJ350 (C)A 350 391 432 1 567 2.6 5 GJG BJG SMCJ400 (C)A 400 447 494 1 648 2.3 5 GJK BJK SMCJ440 (C)A 440 492 543 1 713 2.1 5 GJM BJM REV 1.0 2017 JAN PAGE:4/4
SMCJ6.5CA 价格&库存
很抱歉,暂时无法提供与“SMCJ6.5CA”相匹配的价格&库存,您可以联系我们找货
SMCJ6.5CA
  • 5+0.55288
  • 50+0.44505
  • 150+0.39114
  • 500+0.35070
  • 3000+0.31433
  • 6000+0.29808
库存:3643
