SMCJ5.0A(CA) THRU SMCJ440A(CA) SMC
Surface mount transient voltage suppressor power 1500watts
Stand-Off Voltage: 5.0V~440V
Pinning
1.Cathode
2.Anode
FEATURES
1
For surface mounted applications in order tooptimize board space.
Low profile package.
2
Unipolar
Glass passivated junction.
Low inductance.
Bipolar
Plastic package has Underwriters Laboratory Flammability.
DO-214AB/SMC
MECHANICAL DATA
Case: DO-214AB/SMC
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0.22g / 0.0077oz
Maximum Ratings and Electrical characteristics
Ratings at 25 ambient temperature unless o °C therwise specified.
Parameter
Symbol
Value
Unit
PPPM
1500
W
IFSM
(UNI)
200
A
IPPM
see Next Table
A
Power dissipation on Infinite heat sink at TA=50 °C
PD
6.5
W
Maximum instantaneous forward voltage at 100 A for unidirectional only
VF
3.5
V
RθJA
75
°C/W
RθJL
15
°C/W
TJ,TSTG
-65 to +150
°C
Peak Pulse Power Dissipation on 10/1000 us waveform
Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed
on Rated Load, (JEDEC Method)
Peak Pulse Current on 10/1000 us waveform
Typical Thermal Resistance Junction to Ambient(Note 1
Operating Junction Temperature and Storage Temperature
Range
NOTES:
1. Mounted on 8 mm2 (0.13mm thick) land areas.
www.yfwdiode.com
1/4
G uangDong YFW Electronics Co, Ltd.
Part
Number
(Uni)
Part
Number
(Bi)
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
4.$+$"
UNI
BI
Reverse
Stand off
Voltage
VR
(Volts)
(%1
(%3
(%5
(%7
(%9
(&1
(&3
(&5
(&7
(&9
('1
('3
('5
('7
('9
((1
((3
((5
((7
((9
()1
()3
()5
()7
()9
#%1
#%3
#%5
#%7
#%9
#&1
#&3
#&5
#&7
#&9
#'1
#'3
#'5
#'7
#'9
#(1
#(3
#(5
#(7
#(9
#)1
#)3
#)5
#)7
#)9
5.0
6.0
6.5
7.0
7.5
10.0
11.0
12.0
14.0
15.0
16.0
17.0
20.0
22.0
24.0
26.0
40.0
45.0
51.0
54.0
60.0
64.0
70.0
75.0
100.0
110.0
120.0
150.0
160.0
170.0
200.0
220.0
250.0
400.0
440.0
Marking
Breakdown
Voltage VBR
(Volts) @ IT
MIN
MAX
Test
Current
IT
(mA)
6.40
6.67
7.22
10.00
11.10
12.20
14.40
15.60
16.70
20.00
22.20
24.40
26.70
40.00
44.40
50.00
56.70
60.00
64.40
66.70
71.10
100.00
111.00
122.00
144.00
167.00
201.00
224.00
246.00
447.00
7.00
10.40
11.10
14.70
17.20
22.10
24.50
40.60
44.20
62.70
71.20
104.00
111.00
147.00
222.00
247.00
272.00
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Maximum Maximum Maximum
Agency
Peak
Clamping
Reverse
Approval
Pulse
Voltage VC
Leakage IR
@ Ipp
Current Ipp
@ VR
(V)
(μA)
(A)
11.2
12.0
14.4
15.4
17.0
21.5
24.4
26.0
27.6
42.1
45.4
64.5
72.7
77.4
121.0
126.0
146.0
162.0
177.0
275.0
405.0
567.0
145.7
125.0
104.2
75.4
64.7
61.5
57.7
54.4
51.4
21.7
20.6
16.1
15.5
14.6
12.4
11.0
7.2
6.2
5.5
5.1
4.6
4.2
2.6
2.1
500
200
100
50
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
'PSCJEJSFDUJPOBMUZQFIBWJOH73 of 10 volts and less, the I3 limit is double.
'PSQBSUTXJUIPVU"
UIF7#3 is ± 10% and VCJTIJHIFSUIBOXJUI"QBSUT
www.yfwdiode.com
2/4
Fig.2 Pulse Waveform
P PPM,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
150
100
T A =25°C
t f =10us
I ppm ,Peak Pulse Current (%)
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
10
1
0.31x0.31" (80 x 80mm)
Copper pad Area
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
Peak Value
100
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
td
0.1
10
1
100
1000
3.0
2.0
1.0
t d,PULSE WIDTH ,us
4.0
T,TIME,ms
Fig.3 Forward Current Derating Curve
Fig.4 Typical Junction Capacitance
100000
Bi-directional V= 0V
100
10000
Cj (pF)
PEAK PULSE POWER(P PP)OR CURRENT(I PP)
DERATINGIN PERCENTAGE%
I ppm
80
60
Uni-directional V=0V
1000
Uni-directional @ V R
100
40
Bi-directional @ V R
Tj=25℃
10
f = 1MHz
Vsig=mVp-p
1
50
75
100
125
150
1
175
T A,AMBIENT TEMPERATURE,°C
10
100
1000
V BR - Reverse Breakdown Voltage (V)
I FSM,PEAK FORWARD SURGE CURRENT,
AMPERES
Fig.5 Maximum Non-Repetitive Peak
240
200
160
120
80
40
T J=T Jmax
8.3ms Single Half Sinepwave
JEDEC Method
10
100
Number of Cycles at 60Hz
www.yfwdiode.com
3/4
Dongguan YFW Electronics Co, Ltd.
DO-214AB SMC
Package Outline
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
The recommended mounting pad size
4.1
(160)
3.8
(150)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AB SMC
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
3000
EIA-481-1
4/4
很抱歉,暂时无法提供与“SMCJ14CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.78944
- 50+0.65673
- 150+0.59038
- 500+0.54061
- 3000+0.50078
- 6000+0.48082
