SMDJ5.0A(CA) THRU SMDJ170A(CA) SMC
Surface mount transient voltage suppressor power 3000watts
Stand-Off Voltage: 5.0V~170V
Pinning
1.Cathode
2.Anode
FEATURES
1
For surface mounted applications in order tooptimize board space.
Low profile package.
2
Unipolar
Glass passivated junction.
Low inductance.
Bipolar
3000W peak pulse power capability at 10x1000us waveform,
DO-214AB/SMC
repetition rate {duty cycles):0.01 %
Plastic package has Underwriters Laboratory Flammability.
Excellent clamping capability
Low incremental surge resistance
Matte Tin Lead-free Plated
MECHANICAL DATA
Case: DO-214AB/SMC
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0.22g / 0.0077oz
Maximum Ratings and Electrical characteristics
Ratings at 25 ambient temperature unless o °C therwise specified.
Parameter
Symbol
Value
Unit
Peak Pulse Power Dissipation at Ta=25℃ by 10x1000 us waveform
(Fig.l)(Note l), (Note 2)
PPPM
3000
W
Power Dissipation on infinite heat sink at TA=50℃
PM(AV)
6.5
W
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
IFSM
300
A
Maximum Instantaneous Forward Voltage at 100A for Unidirectional only
VF
3.5
V
Typical Thermal Resistance Junction to Lead
RθJL
15
°C/W
Typical Thermal Resistance Junction to Ambient
RθJA
75
°C/W
TJ,TSTG
-65 to +150
°C
Operating Junction Temperature and Storage Temperature Range
NOTES:
1. Non-repetitive current pulse . per Fig 3 and derated above Ta = 25℃ per Fig. 2
2. Mounted on copper pad area of 0.31x0.31" (8.0 x 8.0mm) to each terminal
3. Measured on 8.3ms single half sine wave or eguivalent square wave for unidirectional device only, duty cycle=4 per minute maximum
www.yfwdiode.com
1/4
G uangDong YFW Electronics Co, Ltd.
Characteristics at Ta = 25°C
Table 1
Reverse
Stand-off
Voltage
Type
UNI
BI
Breakdown
Voltage
V BR @ I T
Max.Clamp
Voltage
Max. Peak
Pulse Current
Max. Reverse
Leakage
Package
IT
V C @ I PP
I PP
IR@VR
Device Marking Ccode
uA
UNI
RDE
DDE
RDG
DDG
Test
Current
V RMW
Min
Max
V
V
V
mA
V
A
10
9.2
326.1
800
SMC
BI
SMDJ5.0CA
5.0
6.4
7
SMDJ6.0A
SMDJ6.0CA
6.0
6.67
7.37
10
10.3
291.3
800
SMDJ6.5A
SMDJ6.5CA
6.5
7.22
7.98
10
11.2
267.9
500
RDK
DDK
SMDJ7.0A
SMDJ7.0CA
7.0
7.78
8.6
10
12
250
200
PDM
DDM
SMDJ5.0A
SMDJ7.5A
SMDJ7.5CA
7.5
8.33
9.21
1
12.9
232.6
100
PDP
DDP
SMDJ8.0A
SMDJ8.0CA
8.0
8.89
9.83
1
13.6
220.6
50
PDR
DDR
SMDJ8.5A
SMDJ8.5CA
8.5
9.44
10.4
1
14.4
208.3
PDT
DDT
SMDJ9.0A
SMDJ9.0CA
9.0
10
11.1
1
15.4
194.8
10
PDV
DDV
SMDJ10A
SMDJ10CA
10.0
11.1
12.3
1
17
176.5
5
PDX
DDX
SMDJ11A
SMDJ11CA
11.0
12.2
13.5
1
18.2
164.8
2
PDZ
DDZ
SMDJ12A
SMDJ12CA
12.0
13.3
14.7
1
19.9
150.8
2
PEE
DEE
SMDJ13A
SMDJ13CA
13.0
14.4
15.9
1
21.5
139.5
2
PEG
DEG
SMDJ14A
SMDJ14CA
14.0
15.6
17.2
1
23.2
129.3
2
PEK
DEK
SMDJ15A
SMDJ15CA
15.0
16.7
18.5
1
24.4
123
2
PEM
DEM
SMDJ16A
SMDJ16CA
16.0
17.8
19.7
1
26
115.4
2
PEP
DEP
SMDJ17A
SMDJ17CA
17.0
18.9
20.9
1
27.6
108.7
2
PER
DER
SMDJ18A
SMDJ18CA
18.0
1
29.2
102.7
2
PET
DET
SMDJ20A
SMDJ20CA
20.0
22.2
24.5
1
32.4
92.6
2
PEV
DEV
SMDJ22A
SMDJ22CA
22.0
24.4
26.9
1
35.5
84.5
2
PEX
DEX
SMDJ24A
SMDJ24CA
24.0
26.7
29.5
1
38.9
77.1
2
PEZ
DEZ
SMDJ26A
SMDJ26CA
26.0
28.9
31.9
1
42.1
71.3
2
PFE
DFE
SMDJ28A
SMDJ28CA
28.0
31.1
34.4
1
45.4
66.1
2
PFG
DFG
SMDJ30A
SMDJ30CA
30.0
33.3
36.8
1
48.4
62
2
PFK
DFK
SMDJ33A
SMDJ33CA
33.0
36.7
40.6
1
53.3
56.3
2
PFM
DFM
SMDJ36A
SMDJ36CA
36.0
40
44.2
1
58.1
51.6
2
PFP
DFP
SMDJ40A
SMDJ40CA
40.0
44.4
49.1
1
64.5
46.5
2
PFR
DFR
SMDJ43A
SMDJ43CA
43.0
47.8
52.8
1
69.4
43.2
2
PFT
DFT
SMDJ45A
SMDJ45CA
45.0
50
55.3
1
72.7
41.3
2
PFV
DFV
SMDJ48A
SMDJ48CA
48.0
53.3
58.9
1
77.4
38.8
2
PFX
DFX
SMDJ51A
SMDJ51CA
51.0
56.7
62.7
1
82.4
36.4
2
PFZ
DFZ
SMDJ54A
SMDJ54CA
54.0
60
66.3
1
87.1
34.4
2
RGE
DGE
SMDJ58A
SMDJ58CA
58.0
64.4
71.2
1
93.6
32.1
2
PGG
DGG
SMDJ60A
SMDJ60CA
60.0
66.7
73.7
1
96.8
31
2
PGK
DGK
SMDJ64A
SMDJ64CA
64.0
71.1
78.6
1
103
29.1
2
PGM
DGM
SMDJ70A
SMDJ70CA
70.0
77.8
86
1
113
26.5
2
PGP
DGP
SMDJ75A
SMDJ75CA
75.0
83.3
92.1
1
121
24.8
2
PGR
DGR
SMDJ78A
SMDJ78CA
78.0
86.7
95.8
1
126
23.8
2
PGT
DGT
SMDJ85A
SMDJ85CA
85.0
94.4
104
1
137
21.9
2
PGV
DGV
SMDJ90A
SMDJ90CA
90.0
100
111
1
146
20.5
2
PGX
DGX
SMDJ100A
SMDJ100CA
100.0
111
123
1
162
18.5
2
PGZ
DGZ
SMDJ110A
SMDJ110CA
110.0
122
135
1
177
16.9
2
PHE
DHE
SMDJ120A
SMDJ120CA
120.0
133
147
1
193
15.5
2
PHG
DHG
SMDJ130A
SMDJ130CA
130.0
144
159
1
209
14.4
2
PHK
DHK
SMDJ150A
SMDJ150CA
150.0
167
185
1
243
12.3
2
PHM
DHM
SMDJ160A
SMDJ160CA
160.0
178
197
1
259
11.6
2
PHP
DHP
SMDJ170A
SMDJ170CA
170.0
189
209
1
275
10.9
2
PHR
DHR
www.yfwdiode.com
2/4
Fig.2 Forward Current Derating Curve
PEAK PULSE POWER(P PP)OR CURRENT(I PP)
DERATINGIN PERCENTAGE%
P PPM,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
1000
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
100
10
0.31x0.31" (80 x 80mm)
Copper pad Area
1.0
0.1
10
1
100
1000
10000
100
80
60
40
Fig.3 Pulse Waveform
175
100000
I ppm
10000
Bi-directional V= 0V
80
Half Value-I pp /2
60
Uni-directional V=0V
1000
Uni-directional @ VR
100
10/1000usec Waveform as Defined bye R.E.A.
40
Bi-directional @ VR
10
2.0
3.0
1
4.0
T,TIME,ms
I FSM,PEAK FORWARD SURGE CURRENT,
AMPERES
5
4
3
2
1
www.yfwdiode.com
100
1000
Fig.6 Maximum Non-Repetitive Peak
6
V BR - Reverse Breakdown Voltage (V)
Fig.5 Steady State Power Derating Curve
P M(AV) Steady Sate Power
Dissipation (W)
150
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
Cj (pF)
I ppm ,Peak Pulse Current (%)
Peak Value
100
125
Fig.4 Typical Junction Capacitance
T A =25°C
t f =10usec
100
T A,AMBIENT TEMPERATURE,°C
t d,PULSE WIDTH ,us
120
75
50
25 50 75 100 125 150 175
TA - Ambient Temperature(ºC)
360
300
240
180
120
60
T J=T Jmax
8.3ms Single Half Sinepwave
JEDEC Method
10
100
Number of Cycles at 60Hz
3/4
DO-214AB SMC
Package Outline
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
The recommended mounting pad size
4.1
(160)
3.8
(150)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AB SMC
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
3000
EIA-481-1
4/4
很抱歉,暂时无法提供与“SMDJ60CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.78451
- 50+1.49144
- 150+1.36582
- 500+1.20917
- 3000+1.13936
- 6000+1.09746
