SMCJ160CA
SMCJ160CA
    YFW(佑风微)
    SMC(DO-214AB)
    VRMW(V) 160 BreakdownVoltage(MAX) 197 Test Current(mA) 1 IR@VRWM(uA) 259 Vc@IPP(V) 5.8 IPP(A) 1
SMCJ160CA 数据手册
SMCJ5.0A(CA) THRU SMCJ440A(CA) SMC Surface mount transient voltage suppressor power 1500watts Stand-Off Voltage: 5.0V~440V Pinning 1.Cathode 2.Anode       FEATURES   1  For surface mounted applications in order tooptimize board space.  Low profile package.     2 Unipolar  Glass passivated junction.  Low inductance. Bipolar  Plastic package has Underwriters Laboratory Flammability. DO-214AB/SMC MECHANICAL DATA  Case: DO-214AB/SMC  Terminals: Solderable per MIL-STD-750, Method 2026  Approx. Weight: 0.22g / 0.0077oz Maximum Ratings and Electrical characteristics Ratings at 25 ambient temperature unless o °C therwise specified. Parameter Symbol Value Unit PPPM 1500 W IFSM (UNI) 200 A IPPM see Next Table A Power dissipation on Infinite heat sink at TA=50 °C PD 6.5 W Maximum instantaneous forward voltage at 100 A for unidirectional only VF 3.5 V RθJA 75 °C/W RθJL 15 °C/W TJ,TSTG -65 to +150 °C Peak Pulse Power Dissipation on 10/1000 us waveform Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) Peak Pulse Current on 10/1000 us waveform Typical Thermal Resistance Junction to Ambient(Note 1 Operating Junction Temperature and Storage Temperature Range NOTES: 1. Mounted on 8 mm2 (0.13mm thick) land areas. www.yfwdiode.com 1/4 G uangDong YFW Electronics Co, Ltd. SMCJ5.0A(CA) THRU SMCJ440A(CA) SMC Part Number (Uni) Part Number (Bi) 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" 4.$+$" UNI BI Reverse Stand off Voltage VR (Volts) (%& (%( (%, (%. (%1 (%3 (%5 (%7 (%9 (%; (&& (&( (&, (&. (&1 (&3 (&5 (&7 (&9 (&; ('& ('( (', ('. ('1 ('3 ('5 ('7 ('9 ('; ((& ((( ((, ((. ((1 ((3 ((5 ((7 ((9 ((; ()& ()( (), (). ()1 ()3 ()5 ()7 ()9 (); (+& (+( (+, (+. #%& #%( #%, #%. #%1 #%3 #%5 #%7 #%9 #%; #&& #&( #&, #&. #&1 #&3 #&5 #&7 #&9 #&; #'& #'( #', #'. #'1 #'3 #'5 #'7 #'9 #'; #(& #(( #(, #(. #(1 #(3 #(5 #(7 #(9 #(; #)& #)( #), #). #)1 #)3 #)5 #)7 #)9 #); #+& #+( #+, #+. 5.0 6.0 6.5 7.0 7.5    10.0 11.0 12.0  14.0 15.0 16.0 17.0  20.0 22.0 24.0 26.0     40.0  45.0  51.0 54.0  60.0 64.0 70.0 75.0    100.0 110.0 120.0  150.0 160.0 170.0  200.0 220.0 250.0   400.0 440.0 Marking Breakdown Voltage VBR (Volts) @ IT MIN MAX Test Current IT (mA) 6.40 6.67 7.22     10.00 11.10 12.20  14.40 15.60 16.70   20.00 22.20 24.40 26.70     40.00 44.40  50.00  56.70 60.00 64.40 66.70 71.10     100.00 111.00 122.00  144.00 167.00   201.00 224.00 246.00    447.00  7.00      10.40 11.10   14.70  17.20    22.10 24.50      40.60 44.20     62.70  71.20      104.00 111.00   147.00     222.00 247.00 272.00      10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Maximum Maximum Maximum Agency Peak Clamping Reverse Approval Pulse Voltage VC Leakage IR @ Ipp Current Ipp @ VR (V) (μA) (A)   11.2 12.0   14.4 15.4 17.0   21.5  24.4 26.0 27.6     42.1 45.4    64.5  72.7 77.4       121.0 126.0  146.0 162.0 177.0     275.0    405.0  567.0    145.7  125.0   104.2    75.4  64.7 61.5 57.7 54.4 51.4          21.7 20.6    16.1 15.5 14.6  12.4  11.0     7.2 6.2  5.5 5.1 4.6 4.2   2.6  2.1   500 200 100 50 20 10 5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X 'PSCJEJSFDUJPOBMUZQFIBWJOH73 of 10 volts and less, the I3 limit is double. 'PSQBSUTXJUIPVU" UIF7#3 is ± 10% and VCJTIJHIFSUIBOXJUI"QBSUT www.yfwdiode.com 2/4 G uangDong YFW Electronics Co, Ltd. SMCJ5.0A(CA) THRU SMCJ440A(CA) SMC Fig.2 Pulse Waveform P PPM,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 150 100 T A =25°C t f =10us I ppm ,Peak Pulse Current (%) Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C 10 1 0.31x0.31" (80 x 80mm) Copper pad Area Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp Peak Value 100 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 td 0 00 0.1 10 1 100 1000 0 10000 3.0 2.0 1.0 t d,PULSE WIDTH ,us 4.0 T,TIME,ms Fig.3 Forward Current Derating Curve Fig.4 Typical Junction Capacitance 100000 Bi-directional V= 0V 100 10000 Cj (pF) PEAK PULSE POWER(P PP)OR CURRENT(I PP) DERATINGIN PERCENTAGE% I ppm 80 60 Uni-directional V=0V 1000 Uni-directional @ V R 100 40 Bi-directional @ V R Tj=25℃ 10 20 f = 1MHz Vsig=mVp-p 1 0 25 50 75 100 125 150 1 175 T A,AMBIENT TEMPERATURE,°C 10 100 1000 V BR - Reverse Breakdown Voltage (V) I FSM,PEAK FORWARD SURGE CURRENT, AMPERES Fig.5 Maximum Non-Repetitive Peak Forward Surge Current 240 200 160 120 80 40 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz www.yfwdiode.com 3/4 Dongguan YFW Electronics Co, Ltd. SMCJ5.0A(CA) THRU SMCJ440A(CA) SMC DO-214AB SMC Package Outline Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil The recommended mounting pad size 4.1 (160) 3.8 (150) 4.3 (170) 4.1 (160) mm Unit : (mil) Summary of Packing Options Package DO-214AB SMC www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 4/4 Dongguan YFW Electronics Co, Ltd.
SMCJ160CA 价格&库存
很抱歉,暂时无法提供与“SMCJ160CA”相匹配的价格&库存,您可以联系我们找货
