SMDJ5.0AG THRU SMDJ170AG
SMDJ5.0CAG THRU SMDJ170CAG
The SMDJ series is designed specifically to protect
sensitive electronic equipment from voltage transients
induced by li ght n in g and other transient voltage events.
2
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Unipolar
1
Bipolar
Simplified outline SMC and symbol
FEATURES
• Halogen-Free
• Fast response time:typically less
• RoHS compliant
than l.Ops from OV to BV min
• For surface mounted applications
in order to optimize board space
• Excellent clamping capability
• Low profile package
• Low incremental surge resistance
• Built-in strain relief
• Typical IR less than 2UA above 12V
• Typical maximum temperature coefficient
• High Temperature soldering
ΔVBR = 0.1% × VBR@25℃ × ΔT
guaranteed: 260℃/40 seconds
• Glass passivated chip junction
at terminals
• 3000W peak pulse power capability
• Plastic package has Under writers
at lOxlOOOUs waveform, repetition
Laborator y Flammability 94V-O
• Matte Tin Lead-free Plated
rate {duty cycles):0.01 %
Maximum Ratings and Thermal Characteristics
(TA=25℃ unless otherwise noted)
Symbol
Value
Unit
Peak Pulse Power Dissipation at T A =25°C by 10x1000 us waveform
(Fig.l)(Note l), (Note 2)
P PPM
3000
W
Power Dissipation on infinite heat sink at TA=50℃
P M(AV)
6.5
W
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
I FSM
300
A
Maximum Instantaneous Forward
Voltage at 100A for Unidirectional only
VF
3.5
V
T j T STG
-65 to 150
Typical Thermal Resistance Junction to Lead
R UJL
15
Typical Thermal Resistance Junction to Ambient
R UJA
75
Parameter
Operating Junction and Storage Temperature Range
Notes:
1. Non-repetitive current pulse . per Fig 3 and derated above Ta = 25℃ per Fig. 2
2. Mounted on copper pad area of 0.31x0.31" (8.0 x 8.0mm) to each terminal
3. Measured on 8.3ms single half sine wave or eguivalent square wave for unidirectional
device only, duty cycle=4 per minute maximum
REV.08
1 of 4
℃/W
℃/W
Characteristics at Ta = 25°C
Table 1
Reverse
Stand-off
Voltage
Type
UNI
BI
Breakdown
Voltage
V BR @ I T
Package
Max.Clamp
Voltage
Max. Peak
Pulse Current
Max. Reverse
Leakage
IT
V C @ I PP
I PP
IR@VR
V
A
uA
UNI
RDE
DDE
RDG
DDG
Test
Current
V RMW
Min
Max
V
V
V
mA
SMC
Device Marking Ccode
BI
SMDJ5.0AG SMDJ5.0CAG
5.0
6.4
7
10
9.2
326.1
800
SMDJ6.0AG SMDJ6.0CAG
6.0
6.67
7.37
10
10.3
291.3
800
SMDJ6.5AG SMDJ6.5CAG
6.5
7.22
7.98
10
11.2
267.9
500
RDK
DDK
SMDJ7.0AG SMDJ7.0CAG
7.0
7.78
8.6
10
12
250
200
PDM
DDM
SMDJ7.5AG SMDJ7.5CAG
7.5
8.33
9.21
1
12.9
232.6
100
PDP
DDP
SMDJ8.0AG SMDJ8.0CAG
8.0
8.89
9.83
1
13.6
220.6
50
PDR
DDR
SMDJ8.5AG SMDJ8.5CAG
8.5
9.44
10.4
1
14.4
208.3
PDT
DDT
SMDJ9.0AG SMDJ9.0CAG
9.0
10
11.1
1
15.4
194.8
10
PDV
DDV
SMDJ10AG
SMDJ10CAG
10.0
11.1
12.3
1
17
176.5
5
PDX
DDX
SMDJ11AG
SMDJ11CAG
11.0
12.2
13.5
1
18.2
164.8
2
PDZ
DDZ
SMDJ12AG
SMDJ12CAG
12.0
13.3
14.7
1
19.9
150.8
2
PEE
DEE
SMDJ13AG
SMDJ13CAG
13.0
14.4
15.9
1
21.5
139.5
2
PEG
DEG
SMDJ14AG
SMDJ14CAG
14.0
15.6
17.2
1
23.2
129.3
2
PEK
DEK
SMDJ15AG
SMDJ15CAG
15.0
16.7
18.5
1
24.4
123
2
PEM
DEM
SMDJ16AG
SMDJ16CAG
16.0
17.8
19.7
1
26
115.4
2
PEP
DEP
SMDJ17AG
SMDJ17CAG
17.0
18.9
20.9
1
27.6
108.7
2
PER
DER
SMDJ18AG
SMDJ18CAG
18.0
1
29.2
102.7
2
PET
DET
SMDJ20AG
SMDJ20CAG
20.0
22.2
24.5
1
32.4
92.6
2
PEV
DEV
SMDJ22AG
SMDJ22CAG
22.0
24.4
26.9
1
35.5
84.5
2
PEX
DEX
SMDJ24AG
SMDJ24CAG
24.0
26.7
29.5
1
38.9
77.1
2
PEZ
DEZ
SMDJ26AG
SMDJ26CAG
26.0
28.9
31.9
1
42.1
71.3
2
PFE
DFE
SMDJ28AG
SMDJ28CAG
28.0
31.1
34.4
1
45.4
66.1
2
PFG
DFG
SMDJ30AG
SMDJ30CAG
30.0
33.3
36.8
1
48.4
62
2
PFK
DFK
SMDJ33AG
SMDJ33CAG
33.0
36.7
40.6
1
53.3
56.3
2
PFM
DFM
SMDJ36AG
SMDJ36CAG
36.0
40
44.2
1
58.1
51.6
2
PFP
DFP
SMDJ40AG
SMDJ40CAG
40.0
44.4
49.1
1
64.5
46.5
2
PFR
DFR
SMDJ43AG
SMDJ43CAG
43.0
47.8
52.8
1
69.4
43.2
2
PFT
DFT
SMDJ45AG
SMDJ45CAG
45.0
50
55.3
1
72.7
41.3
2
PFV
DFV
SMDJ48AG
SMDJ48CAG
48.0
53.3
58.9
1
77.4
38.8
2
PFX
DFX
SMDJ51AG
SMDJ51CAG
51.0
56.7
62.7
1
82.4
36.4
2
PFZ
DFZ
SMDJ54AG
SMDJ54CAG
54.0
60
66.3
1
87.1
34.4
2
RGE
DGE
SMDJ58AG
SMDJ58CAG
58.0
64.4
71.2
1
93.6
32.1
2
PGG
DGG
SMDJ60AG
SMDJ60CAG
60.0
66.7
73.7
1
96.8
31
2
PGK
DGK
SMDJ64AG
SMDJ64CAG
64.0
71.1
78.6
1
103
29.1
2
PGM
DGM
SMDJ70AG
SMDJ70CAG
70.0
77.8
86
1
113
26.5
2
PGP
DGP
SMDJ75AG
SMDJ75CAG
75.0
83.3
92.1
1
121
24.8
2
PGR
DGR
SMDJ78AG
SMDJ78CAG
78.0
86.7
95.8
1
126
23.8
2
PGT
DGT
SMDJ85AG
SMDJ85CAG
85.0
94.4
104
1
137
21.9
2
PGV
DGV
SMDJ90AG
SMDJ90CAG
90.0
100
111
1
146
20.5
2
PGX
DGX
100.0
111
123
1
162
18.5
2
PGZ
DGZ
SMDJ100AG SMDJ100CAG
SMDJ110AG SMDJ110CAG
110.0
122
135
1
177
16.9
2
PHE
DHE
SMDJ120AG SMDJ120CAG
120.0
133
147
1
193
15.5
2
PHG
DHG
SMDJ130AG SMDJ130CAG
130.0
144
159
1
209
14.4
2
PHK
DHK
SMDJ150AG SMDJ150CAG
150.0
167
185
1
243
12.3
2
PHM
DHM
SMDJ160AG SMDJ160CAG
160.0
178
197
1
259
11.6
2
PHP
DHP
SMDJ170AG SMDJ170CAG
170.0
189
209
1
275
10.9
2
PHR
DHR
REV.08
2 of 4
Fig.2 Forward Current Derating Curve
PEAK PULSE POWER(P PP)OR CURRENT(I PP)
DERATINGIN PERCENTAGE%
P PPM,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
1000
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
100
10
0.31x0.31" (80 x 80mm)
Copper pad Area
1.0
0.1
1
10
100
1000
10000
100
80
60
40
Fig.3 Pulse Waveform
I ppm
10000
Bi-directional V= 0V
80
Half Value-I pp /2
60
Uni-directional V=0V
1000
Uni-directional @ VR
100
10/1000usec Waveform as Defined bye R.E.A.
40
Bi-directional @ VR
10
2.0
3.0
1
4.0
T,TIME,ms
100
1000
Fig.6 Maximum Non-Repetitive Peak
I FSM,PEAK FORWARD SURGE CURRENT,
AMPERES
6
5
4
3
2
1
V BR - Reverse Breakdown Voltage (V)
Fig.5 Steady State Power Derating Curve
P M(AV) Steady Sate Power
Dissipation (W)
175
100000
REV.08
150
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
Cj (pF)
I ppm ,Peak Pulse Current (%)
Peak Value
100
125
Fig.4 Typical Junction Capacitance
T A =25°C
t f =10usec
100
T A,AMBIENT TEMPERATURE,°C
t d,PULSE WIDTH ,us
120
75
50
25 50 75 100 125 150 175
TA - Ambient Temperature(ºC)
360
300
240
180
120
60
T J=T Jmax
8.3ms Single Half Sinepwave
JEDEC Method
10
Number of Cycles at 60Hz
3 of 4
100
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.1
6.2
8.1
0.21
0.31
1.7
3.25
min
2.00
6.6
5.6
7.8
0.05
0.15
1.0
2.75
max
103
280
244
319
8.3
12
59
128
min
79
260
220
307
2.0
5.9
32
108
UNIT
mm
mil
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
REV.08
4 of 4
很抱歉,暂时无法提供与“SMDJ60CAG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.86768
- 50+0.68516
- 150+0.59379
- 500+0.52532
- 3000+0.47056
- 6000+0.44324
