5.0SMDJ60CA
5.0SMDJ60CA
    LGE(鲁光)
    SMC(DO-214AB)
    双向TVS 60V截止 峰值浪涌电流:51.7A
5.0SMDJ60CA 数据手册
5.0SMDJ Series Surface Mount Transient Voltage Suppressors Working Voltage: 11 to 440 V Peak Pulse Power: 5000 W Features ˗ ˗ ˗ ˗ ˗ ˗ ˗ SMC/ DO-214AB Glass passivated chip 5000 W peak pulse power capability with a 10/1000 ȝs waveform, repetitive rate (duty cycle):0.01 % Low leakage Uni and Bidirectional unit Excellent clamping capability Very fast response time RoHS compliant Mechanical Data ˗ ˗ ˗ ˗ ˗ Case: Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Solderable per MIL-STD-750, method 2026 Polarity: Color band denotes cathode end except Bipolar Mounting position: Any Maximum Ratings(TA=25ɗ unless otherwise noted) Parameter Peak power dissipation with a 10/1000ȝs waveform(1) Peak pulse current wih a 10/1000ȝs waveform(1) Power dissipation on infinite heatsink at TL = 75 °C Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 100 A for unidirectional only(3) Operating junction and storage temperature range Value Symbol PPP 5000 IPP See Next Table PD 6.5 UNIT W A W IFSM 300 A VF 3.5/5.0 V TJ, TSTG –55 to +150 °C Note: (1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1 (2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum (3)VF
5.0SMDJ60CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ60CA”相匹配的价格&库存,您可以联系我们找货
