SMCJ33CA-L
SMCJ33CA-L
    JINGDAO(晶导微电子)
    SMC(DO-214AB)
    33V截止 峰值浪涌电流:11.3A@10/1000US
SMCJ33CA-L 数据手册
山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD SMCJ-L Series PINNING PIN The SMC series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. FEATURES • 1500W peak pulse power capability at 10/1000μs waveform • For surface mounted applications to optimize board space • Glass passivated chip junction • Halogen free and RoHS compliant DESCRIPTION 1 Cathode 2 Anode 2 Unipolar 1 MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g (0.0077oz) Bipolar Simplified outline SMC and symbol Symbol Value Unit Peak Pulse Power Dissipation on 10/1000 us waveform P PPM 600 W Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load (JEDEC Method) (UNI) 100 A 3.5 V Parameter Maximum instantaneous forward voltage at 100 A for unidirectional only I FSM VF Peak Pulse Current on 10/1000 us waveform I PPM See Next Table A Typical Thermal Resistance Junction to Ambient(Note 1) RθJA RθJL 75 15 °C/W Operating Junction Temperature and Storage Temperature Range T j , T stg -55 ~ +150 °C NOTES: 1. Mounted on 8 mm 2 (0.13mm thick) land areas. 2018.03 SMC-TVS-SMCJ-L Series-600W Page 1 of 4 Characteristics at Ta = 25°C Marking Type UNI BI Reverse Stand-off Voltage Breakdown Voltage V RMW V BR @ I T Test Current Max Clamping Voltage Peak Pulse Current Maximum Reverse Leakage IR IT V C @ I PP I PP UNI BI V Min(V) Max(V) mA V A μA SMCJ5.0A-L SMCJ5.0CA-L GDE BDE 5 6.4 7 10 9.2 65.3 800 SMCJ6.0A-L SMCJ6.0CA-L GDG BDG 6 6.67 7.37 10 10.3 58.3 800 SMCJ6.5A-L SMCJ6.5CA-L GDK BDK 6.5 7.22 7.98 10 11.2 53.6 500 SMCJ7.0A-L SMCJ7.0CA-L GDM BDM 7 7.78 8.6 10 12 50.0 200 SMCJ7.5CA-L GDP BDP 7.5 8.33 9.21 1 12.9 46.6 100 SMCJ7.5A-L SMCJ8.0A-L SMCJ8.0CA-L GDR BDR 8 8.89 9.83 1 13.6 44.2 50 SMCJ8.5A-L SMCJ8.5CA-L GDT BDT 8.5 9.44 10.4 1 14.4 41.7 20 SMCJ9.0A-L SMCJ9.0CA-L GDV BDV 9 10 11.1 1 15.4 39.0 10 SMCJ10A-L SMCJ10CA-L GDX BDX 10 11.1 12.3 1 17 35.3 5 SMCJ11A-L SMCJ11CA-L GDZ BDZ 11 12.2 13.5 1 18.2 33.0 1 SMCJ12CA-L GEE BEE 12 13.3 14.7 1 19.9 30.2 1 SMCJ13A-L SMCJ13CA-L GEG BEG 13 14.4 15.9 1 21.5 28.0 1 SMCJ14A-L SMCJ14CA-L GEK BEK 14 15.6 17.2 1 23.2 25.9 1 SMCJ12A-L SMCJ15A-L SMCJ15CA-L GEM BEM 15 16.7 18.5 1 24.4 24.6 1 SMCJ16A-L SMCJ16CA-L GEP BEP 16 17.8 19.7 1 26 23.1 1 SMCJ17A-L SMCJ17CA-L GER BER 17 18.9 20.9 1 27.6 21.8 1 SMCJ18A-L SMCJ18CA-L GET BET 18 20 22.1 1 29.2 20.6 1 SMCJ20A-L SMCJ20CA-L GEV BEV 20 22.2 24.5 1 32.4 18.6 1 SMCJ22CA-L GEX BEX 22 24.4 26.9 1 35.5 16.9 1 SMCJ24A-L SMCJ24CA-L GEZ BEZ 24 26.7 29.5 1 38.9 15.5 1 SMCJ26A-L SMCJ26CA-L GFE BFE 26 28.9 31.9 1 42.1 14.3 1 SMCJ28CA-L GFG BFG 28 31.1 34.4 1 45.4 13.3 1 SMCJ22A-L SMCJ28A-L SMCJ30A-L SMCJ30CA-L GFK BFK 30 33.3 36.8 1 48.4 12.4 1 SMCJ33A-L SMCJ33CA-L GFM BFM 33 36.7 40.6 1 53.3 11.3 1 SMCJ36CA-L GFP BFP 36 40 44.2 1 58.1 10.4 1 SMCJ40A-L SMCJ40CA-L GFR BFR 40 44.4 49.1 1 64.5 9.3 1 SMCJ43A-L SMCJ43CA-L GFT BFT 43 47.8 52.8 1 69.4 8.7 1 SMCJ36A-L SMCJ45A-L SMCJ45CA-L GFV BFV 45 50 55.3 1 72.7 8.3 1 SMCJ48A-L SMCJ48CA-L GFX BFX 48 53.3 58.9 1 77.4 7.8 1 SMCJ51A-L SMCJ51CA-L GFZ BFZ 51 56.7 62.7 1 82.4 7.3 1 SMCJ54A-L SMCJ54CA-L GGE BGE 54 60 66.3 1 87.1 6.9 1 SMCJ58A-L SMCJ58CA-L GGG BGG 58 64.4 71.2 1 93.6 6.5 1 SMCJ60CA-L GGK BGK 60 66.7 73.7 1 96.8 6.2 1 SMCJ64A-L SMCJ64CA-L GGM BGM 64 71.1 78.6 1 103 5.9 1 SMCJ70A-L SMCJ70CA-L GGP BGP 70 77.8 86 1 113 5.3 1 SMCJ75CA-L GGR BGR 75 83.3 92.1 1 121 5.0 1 SMCJ60A-L SMCJ75A-L SMCJ78A-L SMCJ78CA-L GGT BGT 78 86.7 95.8 1 126 4.8 1 SMCJ85A-L SMCJ85CA-L GGV BGV 85 94.4 104 1 137 4.4 1 SMCJ90A-L SMCJ90CA-L GGX BGX 90 100 111 1 146 4.1 1 SMCJ100A-L SMCJ100CA-L GGZ BGZ 100 111 123 1 162 3.7 1 SMCJ110A-L SMCJ110CA-L GHE BHE 110 122 135 1 177 3.4 1 SMCJ120A-L SMCJ120CA-L GHG BHG 120 133 147 1 193 3.1 1 SMCJ130A-L SMCJ130CA-L GHK BHK 130 144 159 1 209 2.9 1 SMCJ150A-L SMCJ150CA-L GHM BHM 150 167 185 1 243 2.5 1 SMCJ160A-L SMCJ160CA-L GHP BHP 160 178 197 1 259 2.3 1 SMCJ170A-L SMCJ170CA-L GHR BHR 170 189 209 1 275 2.2 1 SMCJ180A-L SMCJ180CA-L GHT BHT 180 201 222 1 292 2.1 1 SMCJ200A-L SMCJ200CA-L GHV BHV 200 224 247 1 324 1.9 1 SMCJ220A-L SMCJ220CA-L GHX BHX 220 246 272 1 356 1.7 1 SMCJ250CA-L GHZ BHZ 250 279 309 1 405 1.5 1 SMCJ250A-L SMCJ300A-L SMCJ300CA-L GJE BJE 300 335 371 1 486 1.3 1 SMCJ350A-L SMCJ350CA-L GJG BJG 350 391 432 1 567 1.1 1 SMCJ400A-L SMCJ400CA-L GJK BJK 400 447 494 1 648 0.9 1 SMCJ440A-L SMCJ440CA-L GJM BJM 440 492 543 1 713 0.9 1 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD SMCJ-L Series Fig.2 Pulse Waveform P PPM,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 150 100 10 1 0.31x0.31" (80 x 80mm) Copper pad Area T A =25°C t f =10us I ppm ,Peak Pulse Current (%) Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp Peak Value 100 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 td 0 0.1 1 0.1 10 100 1000 0 10000 3.0 2.0 1.0 t d,PULSE WIDTH ,us 4.0 T,TIME,ms Fig.3 Forward Current Derating Curve Fig.4 Typical Junction Capacitance 100000 Bi-directional V= 0V 100 10000 Cj (pF) PEAK PULSE POWER(P PP)OR CURRENT(I PP) DERATINGIN PERCENTAGE% I ppm 80 60 Uni-directional V=0V 1000 Uni-directional @ V R 100 40 Bi-directional @ V R Tj=25℃ 10 20 f = 1MHz Vsig=mVp-p 1 0 25 50 75 100 125 150 175 T A,AMBIENT TEMPERATURE,°C 1 10 100 1000 V BR - Reverse Breakdown Voltage (V) I FSM,PEAK FORWARD SURGE CURRENT, AMPERES Fig.5 Maximum Non-Repetitive Peak Forward Surge Current 120 100 80 60 40 20 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz 2018.03 www.sdjingdao.com Page 3 of 4 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD SMCJ-L Series PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil The recommended mounting pad size 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) 2018.03 JD 0404 9B0/9B5 Page 4 of 4
SMCJ33CA-L
物料型号:SMCJ-L系列
器件简介:该系列是专为保护敏感电子设备免受由雷击和其他瞬态电压事件引起的电压瞬态而设计的。
引脚分配: - PIN 1: 阴极 (Cathode) - PIN 2: 阳极 (Anode)
参数特性: - 1500W的峰值脉冲功率能力,符合10/1000μs波形 - 适用于表面贴装,以优化板空间 - 玻璃钝化芯片结 - 无卤素且符合RoHS标准
功能详解: - 提供了详细的电气特性表,包括峰值脉冲功率耗散、峰值正向浪涌电流、最大瞬态正向电压、峰值脉冲电流和典型热阻等参数。
应用信息: - 适用于需要电压保护的电子设备,如通信设备、电源、汽车电子等。
封装信息: - 塑料表面贴装封装,2个引脚 - 提供了详细的机械数据,包括封装尺寸和推荐安装垫尺寸。
SMCJ33CA-L 价格&库存
很抱歉,暂时无法提供与“SMCJ33CA-L”相匹配的价格&库存,您可以联系我们找货
SMCJ33CA-L
库存:3953
