SMCJ36CA
SMCJ36CA
    HXY(华轩阳)
    SMC(DO-214AB)
    双向TVS 36V截止 峰值浪涌电流:25.9A
SMCJ36CA 数据手册
HXY SMCJ5.0(C)A-SMCJ440(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Features For surface mounted applications in order to optimize board space Low profile package Built-in strain relief Glass passivated junction Low inductance Excellent clamping capability 1500W peak pulse power capability at 10/1000μs waveform, SMC repetition rate (duty cycle): 0.01% Fast response time Typical IR less than 1μA above 10V High Temperature soldering: 260C/10 seconds at terminals Plastic package has underwriters laboratory flammability 94V-0 Mechanical Data PartNumber Code Case : JEDEC SMC molded plastic body Terminals : Solderable per MIL-STD-750, Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.003 ounce, 0.095 grams Standard Packaging: 12 mm tape (EIA STD RS-481) SMCJ XXX C A 5 % VBR Voltage Tolerance Bidirectional Voltage Series Code Applications I/O interface AC/ DC power supply Low frequency signal transmission line (RS232, RS485, etc.) MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 2 5 C ambient temperature unless otherwise specified. Peak pulse power dissipation at 1 0 / 1 0 0 0 μ s waveform ( Note1 , Note2 , Fig . 1 ) PPP M Peak pulse current of at 1 0 / 1 0 0 0 μ s waveform ( Note 1 , Fig . 3 ) I PP M Steady state power dissipation at TA = 5 0 C ( Fig . 5 ) Peak forward surge current, superimposed on rated load, Operating junction and Storage Temperature Typical thermal resistance junction Typical thermal resistance junction to to Range lead ambient . See W Table A 6. 5 W IFS M 200 A TJ , TSTG - 6 5 to + 1 5 0 C PM( 8 . 3 ms single half sine- wave ( JEDEC Method) ( Note3 , Fig . 6 ) Minimum 1 5 0 0 AV) Rθ JL 15 C/ W Rθ JA 75 C/ W Notes : 1 . Non- repetitive current pulse, per Fig . 3 and derated above TA = 2 5 C per Fig . 2 . 2 . Mounted on 5 . 0 mm× 5 . 0 mm ( 0 . 0 3 mm thick) copper pads to each terminal . 3 . 8 . 3 ms single half sine- wave, or equivalent square wave, duty cycle= 4 pulses per minutes maximum . Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SMCJ5.0(C)A-SMCJ440(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Electrical Characteristics (TA=25℃) Part Number Unidirectional Bidirectional Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRWM UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(pA) SMCJ5.0A SMCJ5.0CA GDE GDE 5.0 6.40~7.00 10 9.2 163.0 800 SMCJ6.0A SMCJ6.0CA GDG GDG 6.0 6.67~7.37 10 10.3 145.7 800 SMCJ6.5A SMCJ6.5CA GDK BDK 6.5 7.22~7.98 10 11.2 134.0 500 SMCJ7.0A SMCJ7.0CA GDM GDM 7.0 7.78~8.60 10 12.0 125.0 200 SMCJ7.5A SMCJ7.5CA GDP GDP 7.5 8.33~9.21 1 12.9 116.3 100 SMCJ8.0A SMCJ8.0CA GDR BDR 8.0 8.89~9.83 1 13.6 110.3 50 SMCJ8.5A SMCJ8.5CA GDT BDT 8.5 9.44~10.40 1 14.4 104.2 20 SMCJ9.0A SMCJ9.0CA GDV BDV 9.0 10.00~11.10 1 15.4 97.4 10 SMCJ10A SMCJ10CA GDX BDX 10.0 11.10~12.30 1 17.0 88.3 5 SMCJ11A SMCJ11CA GDZ GDZ 11.0 12.20~13.50 1 18.2 82.5 1 SMCJ12A SMCJ12CA GEE BEE 12.0 13.30~14.70 1 19.9 75.4 1 SMCJ13A SMCJ13CA GEG GEG 13.0 14.40~15.90 1 21.5 69.8 1 SMCJ14A SMCJ14CA GEK BEK 14.0 15.60~17.20 1 23.2 64.7 1 SMCJ15A SMCJ15CA GEM BEM 15.0 16.70~18.50 1 24.4 61.5 1 SMCJ16A SMCJ16CA GEP GEP 16.0 17.80~19.70 1 26.0 57.7 1 SMCJ17A SMCJ17CA GER GER 17.0 18.90~20.90 1 27.6 54.4 1 SMCJ18A SMCJ18CA GET BET 18.0 20.00~22.10 1 29.2 51.4 1 SMCJ20A SMCJ20CA GEV BEV 20.0 22.20~24.50 1 32.4 46.3 1 SMCJ22A SMCJ22CA GEX BEX 22.0 24.40~26.90 1 35.5 42.3 1 SMCJ24A SMCJ24CA GEZ BEZ 24.0 26.70~29.50 1 38.9 38.6 1 Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SMCJ5.0(C)A-SMCJ440(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRWM Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(pA) SMCJ26A SMCJ26CA GFE BFE 26.0 28.90~31.90 1 42.1 35.7 1 SMCJ28A SMCJ28CA GFG BFG 28.0 31.10~34.40 1 45.4 33.1 1 SMCJ30A SMCJ30CA GFK BFK 30.0 33.30~36.80 1 48.4 31.0 1 SMCJ33A SMCJ33CA GFM BFM 33.0 36.70~40.60 1 53.3 28.2 1 SMCJ36A SMCJ36CA GFP BFP 36.0 40.00~44.20 1 58.1 25.9 1 SMCJ40A SMCJ40CA GFR BFR 40.0 44.40~49.10 1 64.5 23.3 1 SMCJ43A SMCJ43CA GFT BFT 43.0 47.80~52.80 1 69.4 21.7 1 SMCJ45A SMCJ45CA GFV GFV 45.0 50.00~55.30 1 72.7 20.6 1 SMCJ48A SMCJ48CA GFX BFX 48.0 53.30~58.90 1 77.4 19.4 1 SMCJ51A SMCJ51CA GFZ GFZ 51.0 56.70~62.70 1 82.4 18.2 1 SMCJ54A SMCJ54CA GGE GGE 54.0 60.00~66.30 1 87.1 17.3 1 SMCJ58A SMCJ58CA GGG GGG 58.0 64.40~71.20 1 93.6 16.1 1 SMCJ60A SMCJ60CA GGK GGK 60.0 66.70~73.70 1 96.8 15.5 1 SMCJ64A SMCJ64CA GGM GGM 64.0 71.10~78.60 1 103.0 14.6 1 SMCJ70A SMCJ70CA GGP GGP 70.0 77.80~86.00 1 113.0 13.3 1 SMCJ75A SMCJ75CA GGR GGR 75.0 83.30~92.10 1 121.0 12.4 1 SMCJ78A SMCJ78CA GGT GGT 78.0 86.70~95.80 1 126.0 11.9 1 SMCJ85A SMCJ85CA GGV GGV 85.0 94.40~104.00 1 137.0 11.0 1 SMCJ90A SMCJ90CA GGX GGX 90.0 100.00~111.00 1 146.0 10.3 1 SMCJ100A SMCJ100CA GGZ GGZ 100.0 111.00~123.00 1 162.0 9.3 1 SMCJ110A SMCJ110CA GHE GHE 110.0 122.00~135.00 1 177.0 8.5 1 SMCJ120A SMCJ120CA GHG GHG 120.0 133.00~147.00 1 193.0 7.8 1 SMCJ130A SMCJ130CA GHK BHK 130.0 144.00~159.00 1 209.0 7.2 1 SMCJ150A SMCJ150CA GHM GHM 150.0 167.00~185.00 1 243.0 6.2 1 SMCJ160A SMCJ160CA GHP GHP 160.0 178.00~197.00 1 259.0 5.8 1 SMCJ170A SMCJ170CA GHR GHR 170.0 189.00~209.00 1 275.0 5.5 1 SMCJ188A SMCJ188CA GHS GHS 180.0 201.00~222.00 1 292.0 5.1 1 SMCJ190A SMCJ190CA GHU BHU 190.0 211.00~233.00 1 308.0 4.8 1 SMCJ200A SMCJ200CA GHV BHV 200.0 224.00~247.00 1 324.0 4.6 1 SMCJ210A SMCJ210CA GHW BHW 210.0 237.00~263.00 1 340.0 4.4 1 SMCJ220A SMCJ220CA GHX BHX 220.0 246.00~272.00 1 356.0 4.2 1 SMCJ250A SMCJ250CA GHZ BHZ 250.0 279.00~309.00 1 405.0 3.7 1 SMCJ300A SMCJ300CA GJE BJE 300.0 335.00~371.00 1 486.0 3.1 1 SMCJ350A SMCJ350CA GJG BJG 350.0 391.00~432.00 1 567.0 2.6 1 SMCJ400A SMCJ400CA GJK BJK 400.0 447.00~494.00 1 648.0 2.3 1 SMCJ440A SMCJ440CA GJM BJM 440.0 492.00~543.00 1 713.0 2.1 1 Unidirectional Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SMCJ5.0(C)A-SMCJ440(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Ratings and Characteristic Curves (TA=25 Figure 1. Peak Pulse Power Rating Curve unless otherwise noted) Figure 2. Pulse Derating Curve 100 80 Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 60 40 20 0.2 ×0 .2 ″ (5 .0×5 .0 mm) Copper Pad Area 0.1 1 0 10 100 0 1000 150 t =10 r he point where t he Bi- peak PPM ( IP 1 td t-Time2.0 (ms) 3.0 V =0V 7 6 5 4 3 2 1 125 150 TA- Ambient Temperature ( C) Shenzhen HuaXuanYang Electronics CO.,LTD @V R 175 10 100 1000 VBR- Reverse Breakdown Voltage ( V) Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only IFSM - Peak Forward Surve Current (A) PM(AV) , Steady State Power Dissipation (W) Curve 100 1 4.0 Figure 5. Steady State Power Dissipation Derating 75 onal TJ= 25 ℃ f=1. 0M Hz Vsig =5 0mV p -p as defined by R. E. A 50 dire c t i B i-d irec tional @ V R 10 10 / 10 0 0 µ s Wavef o r m 25 ni- 100 PM/ 2 ) 50 0 175 di rec tion al V = 0 V U Half Value 0 150 100 0 U ni- dir ec ti onal 1.0 125 10000 P P M Peak Val u e IPPM 0 100 100000 TJ = 2 5 C Pulse W idth( td) is defined as µs current decays to 50% of I 0 75 Figure 4. Typical Junction Capacitance t 100 50 TA- Ambient Temperature ( C) td-Pulse Width (µs) Figure 3. Pulse Waveform 25 200 180 160 140 120 100 80 60 40 20 0 1 10 Number of Cycles at 60Hz 100 www.hxymos.com HXY SMCJ5.0(C)A-SMCJ440(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG SMC Package Outline Dimensions Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SMCJ5.0(C)A-SMCJ440(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
