5SMDJ series
Version: A1 2016-8-10
Transient Voltage Suppressor
Exterior
Features
IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact)
5000Watts peak pulse power (tp=10/1000μS)
Quick response to surge voltage
Low clamping voltage
Moisture sensitivity level:Level 1
DO-214AB
Agency Approvals
Application information
DC Port
Icon
RS485/232/422
Description
Compliance with 2011/65/EU
I/O Port
Compliance with
IEC61249-2-21:2003
Schematic symbol
cathode
anode
BI-directional
UNI-directional
Part Number and Electrical Parameter
Part Number
Marking
VR(V)
VBR
VBR
It
Max Vc
1
PP
@I
(V)
IPP○
IR@VR
(A)
(uA)
1
min.(V)
max.(V)
(mA)
11
12.2
13.5
1
18.2
275
800
5D12
12
13.3
14.7
1
19.9
252
800
5D13C
5D13
13
14.4
15.9
1
21.5
233
500
BV-5SMDJ14A
5D14C
5D14
14
15.6
17.2
1
23.2
216
200
BV-5SMDJ15CA
BV-5SMDJ15A
5D15C
5D15
15
16.7
18.5
1
24.4
205
100
BV-5SMDJ16CA
BV-5SMDJ16A
5D16C
5D16
16
17.8
19.7
1
26
193
50
BV-5SMDJ17CA
BV-5SMDJ17A
5D17C
5D17
17
18.9
20.9
1
27.6
181
BV-5SMDJ18CA
BV-5SMDJ18A
5D18C
5D18
18
1
29.2
172
10
BV-5SMDJ20CA
BV-5SMDJ20A
5D20C
5D20
24.5
1
32.4
155
5
BV-5SMDJ22CA
BV-5SMDJ22A
5D22C
5D22
22
24.4
26.9
1
35.5
141
5
BV-5SMDJ24CA
BV-5SMDJ24A
5D24C
5D24
24
26.7
29.5
1
38.9
129
2
BV-5SMDJ26CA
BV-5SMDJ26A
5D26C
5D26
26
28.9
31.9
1
42.1
119
2
BV-5SMDJ28CA
BV-5SMDJ28A
5D28C
5D28
28
31.1
34.4
1
45.4
110
2
BI
UNI
BI
UNI
BV-5SMDJ11CA
BV-5SMDJ11A
5D11C
5D11
BV-5 SMDJ12CA
BV-5SMDJ12A
5D12C
BV-5SMDJ13CA
BV-5SMDJ13A
BV-5SMDJ14CA
1/5
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
5SMDJ series
Part Number
Marking
VR(V)
VBR
VBR
It
min.(V)
max.(V)
(mA)
@IPP○
1
IPP○(A)
1
IR@VR
(uA)
BI
UNI
BI
UNI
BV-5SMDJ30CA
BV-5SMDJ30A
5D30C
5D30
30
33.3
36.8
1
48.4
103
2
BV-5SMDJ33CA
BV-5SMDJ33A
5D33C
5D33
33
36.7
40.6
1
53.3
93.9
2
BV-5SMDJ36CA
BV-5SMDJ36A
5D36C
5D36
36
40
44.2
1
58.1
86.1
2
BV-5SMDJ40CA
BV-5SMDJ40A
5D40C
5D40
40
44.4
49.1
1
64.5
77.6
2
BV-5SMDJ43CA
BV-5SMDJ43A
5D43C
5D43
43
47.8
52.8
1
69.4
72.1
2
BV-5SMDJ45CA
BV-5SMDJ45A
5D45C
5D45
45
50
55.3
1
72.7
68.8
2
BV-5SMDJ48CA
BV-5SMDJ48A
5D48C
5D48
48
53.3
58.9
1
77.4
64.7
2
BV-5SMDJ51CA
BV-5SMDJ51A
5D51C
5D51
51
56.7
62.7
1
82.4
60.7
2
BV-5SMDJ54CA
BV-5SMDJ54A
5D54C
5D54
54
60
66.3
1
87.1
57.5
2
BV-5SMDJ58CA
BV-5SMDJ58A
5D58C
5D58
58
64.4
71.2
1
93.6
53.5
2
BV-5SMDJ60CA
BV-5SMDJ60A
5D60C
5D60
60
66.7
73.7
1
96.8
51.7
2
BV-5SMDJ64CA
BV-5SMDJ64A
5D64C
5D64
64
71.1
78.6
1
103
48.6
2
BV-5SMDJ70CA
BV-5SMDJ70A
5D70C
5D70
70
77.8
86
1
113
44.3
2
BV-5SMDJ75CA
BV-5SMDJ75A
5D75C
5D75
75
83.3
92.1
1
121
41.4
2
BV-5SMDJ78CA
BV-5SMDJ78A
5D78C
5D78
78
86.7
95.8
1
126
39.7
2
BV-5SMDJ85CA
BV-5SMDJ85A
5D85C
5D85
85
94.4
104
1
137
36.5
2
BV-5SMDJ90CA
BV-5SMDJ90A
5D90C
5D90
90
100
111
1
146
34.3
2
BV-5SMDJ100CA
BV-5SMDJ100A
5D100C
5D100
100
111
123
1
162
30.9
2
BV-5SMDJ110CA
BV-5SMDJ110A
5D110C
5D110
110
122
135
1
177
28.3
2
(V)
Note:absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted).
1 Surge Waveform: 10/1000μ S
Mark
5DXXC
cathode
5DXX
anode
UNI:5DXX
BI:5DXXC
Part Number System
BV
5SMDJ
XX
C
A
(1)
(2)
(3)
(4) (5)
(1) Bencent Transient Voltage Suppressor
(2) Series Code
(3) VR=XXV
(4) BI-directional
(5) Suffix ‘A’ denotes 5% tolerance devices
2/5
www.bencent.com.cn
5SMDJ series
V-I Curve
IPP
VC VBR VR
It
IR
IR
It
VR
V
VBR VC
VC VBR VR
IR
It
BI-directional
V
VF
UNI-directional
IPP
IPP
Parameters
Definition
VF
Forward Voltage drop for UNI-directional
VC
Clamping Voltage
Ipp
Surge Waveform 10/1000μs
VR
Stand-off Voltage
VBR
Breakdown Voltage
IR
Reverse Leakage Current
It
Test Current
Ppp
Peak Pulse Power Dissipation
Thermal Considerations
symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature Range
-55 to +150
TS
Storage Temperature Range
-55 to +150
Environmental Characteristics
Testing items
High Temperature Reverse Bias Test
High Temperature Life Test
High-low Temperature Cycle Test
High Temperature &High Humidity Test
Pressure Cooker Test
Resistance of Soldering Heat
Technical standards
Temperature: 150±3℃ Bias=80%VR
Time:168H
Temperature: 150℃
Time:168H
Temperature: From -40℃ to125℃
Dwell time :30min,10cycles
Temperature: 85℃ Humidity:85%
Time:168H
Temperature: 121℃,2atm. Humidity:100%
Time:24H
Temperature: 260±5℃
Time of dip soldering:10s,3times
Note: The above testing items can be specified by customer’s special request
3/5
www.bencent.com.cn
5SMDJ series
Product Dimensions
REF
A
B
C
D
E
F
G
H
mm
2.85--3.05
5.85--6.15
6.75--7.05
2.45--2.95
0.15—0.25
0.90--1.60
0.00—0.40
7.75--8.25
inch
0.112--0.120
0.230--0.242
0.266--0.278
0.096--0.116
0.006--0.012
0.035--0.063
0.000--0.016
0.305--0.325
Recommended Soldering Pad
REF
mm
inch
A
8.25
0.325
B
5.05
0.199
C
3.05
0.12
Reflow Profile
Reflow Condition
Pre Heat
Pb-Free
assembly
Temperature Min
150°C
Temperature Max
200°C
Time (min to max)
60 – 180 secs
TP
TP
Average ramp up rate(Liquidus)Tamp(TL)
3°C/s max
to peak
Reflow
3°C/s max
- Temperature (TL) (Liquidus)
217°C
- Temperature (TL)
60 – 150 secs
Peak Temperature (TP)
260+0/-5 °C
Time within 5°C of actual peak Temperature
(TP)
30secs
Ramp-down Rate
6°C/s max
Time 25°C to peak Temperature (TP)
8 min max.
Do not exceed
260°C
4/5
www.bencent.com.cn
TL
Temperature
TS(max) to TL - Ramp-up Rate
Critical Zone
TL to TP
Ramp-up
TL
TS(max)
Ramp-down
Preheat
TS(min)
TS
25
time to peak temperature
Time
5SMDJ series
Package
5/5
Reel
Information
REF.
mm
inch
A
6.15+/-0.1
0.242+/-0.004
B
8.2+/-0.1
0.323+/0-.004
d
1.5+/-0.05
0.059+/-0.002
D
330.0
13.0
D1
72+/-3
2.835+/-0.118
D2
13+/-0.3
0.512+/-0.012
E
1.75+/-0.1
0.069+/-0.004
F
5.5+/-0.05
0.212+/-0.002
P
8.0+/-0.1
0.315+/-0.004
P0
4.0+/-0.1
0.157+/-0.004
P1
2.0+/-0.05
0.079+/-0.004
W
16+/-0.1
0.630+/-0.004
W1
22+/-2.0
0.866+/-0.079
Outline
Reel
(pcs)
Per Carton
(pcs)
Reel Diameters
(mm)
Taping
3,000
24,000
330
www.bencent.com.cn
Carton Size(mm)
L
W
H
360
360
380
很抱歉,暂时无法提供与“BV-5SMDJ26A”相匹配的价格&库存,您可以联系我们找货
