BV-5SMDJ30A
BV-5SMDJ30A
    BENCENT(槟城)
    SMC(DO-214AB)
    单向TVS 30V截止 峰值浪涌电流:103A@10/1000US
BV-5SMDJ30A 数据手册
5SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Exterior Features IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact) 5000Watts peak pulse power (tp=10/1000μS) Quick response to surge voltage Low clamping voltage Moisture sensitivity level:Level 1 DO-214AB Agency Approvals Application information DC Port Icon RS485/232/422 Description Compliance with 2011/65/EU I/O Port Compliance with IEC61249-2-21:2003 Schematic symbol cathode anode BI-directional UNI-directional Part Number and Electrical Parameter Part Number Marking VR(V) VBR VBR It Max Vc ○ 1 PP @I (V) IPP○ IR@VR (A) (uA) 1 min.(V) max.(V) (mA) 11 12.2 13.5 1 18.2 275 800 5D12 12 13.3 14.7 1 19.9 252 800 5D13C 5D13 13 14.4 15.9 1 21.5 233 500 BV-5SMDJ14A 5D14C 5D14 14 15.6 17.2 1 23.2 216 200 BV-5SMDJ15CA BV-5SMDJ15A 5D15C 5D15 15 16.7 18.5 1 24.4 205 100 BV-5SMDJ16CA BV-5SMDJ16A 5D16C 5D16 16 17.8 19.7 1 26 193 50 BV-5SMDJ17CA BV-5SMDJ17A 5D17C 5D17 17 18.9 20.9 1 27.6 181 20 BV-5SMDJ18CA BV-5SMDJ18A 5D18C 5D18 18 20 22.1 1 29.2 172 10 BV-5SMDJ20CA BV-5SMDJ20A 5D20C 5D20 20 22.2 24.5 1 32.4 155 5 BV-5SMDJ22CA BV-5SMDJ22A 5D22C 5D22 22 24.4 26.9 1 35.5 141 5 BV-5SMDJ24CA BV-5SMDJ24A 5D24C 5D24 24 26.7 29.5 1 38.9 129 2 BV-5SMDJ26CA BV-5SMDJ26A 5D26C 5D26 26 28.9 31.9 1 42.1 119 2 BV-5SMDJ28CA BV-5SMDJ28A 5D28C 5D28 28 31.1 34.4 1 45.4 110 2 BI UNI BI UNI BV-5SMDJ11CA BV-5SMDJ11A 5D11C 5D11 BV-5 SMDJ12CA BV-5SMDJ12A 5D12C BV-5SMDJ13CA BV-5SMDJ13A BV-5SMDJ14CA 1/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications 5SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Part Number Marking VR(V) VBR VBR It min.(V) max.(V) (mA) @IPP○ 1 IPP○(A) 1 IR@VR (uA) BI UNI BI UNI BV-5SMDJ30CA BV-5SMDJ30A 5D30C 5D30 30 33.3 36.8 1 48.4 103 2 BV-5SMDJ33CA BV-5SMDJ33A 5D33C 5D33 33 36.7 40.6 1 53.3 93.9 2 BV-5SMDJ36CA BV-5SMDJ36A 5D36C 5D36 36 40 44.2 1 58.1 86.1 2 BV-5SMDJ40CA BV-5SMDJ40A 5D40C 5D40 40 44.4 49.1 1 64.5 77.6 2 BV-5SMDJ43CA BV-5SMDJ43A 5D43C 5D43 43 47.8 52.8 1 69.4 72.1 2 BV-5SMDJ45CA BV-5SMDJ45A 5D45C 5D45 45 50 55.3 1 72.7 68.8 2 BV-5SMDJ48CA BV-5SMDJ48A 5D48C 5D48 48 53.3 58.9 1 77.4 64.7 2 BV-5SMDJ51CA BV-5SMDJ51A 5D51C 5D51 51 56.7 62.7 1 82.4 60.7 2 BV-5SMDJ54CA BV-5SMDJ54A 5D54C 5D54 54 60 66.3 1 87.1 57.5 2 BV-5SMDJ58CA BV-5SMDJ58A 5D58C 5D58 58 64.4 71.2 1 93.6 53.5 2 BV-5SMDJ60CA BV-5SMDJ60A 5D60C 5D60 60 66.7 73.7 1 96.8 51.7 2 BV-5SMDJ64CA BV-5SMDJ64A 5D64C 5D64 64 71.1 78.6 1 103 48.6 2 BV-5SMDJ70CA BV-5SMDJ70A 5D70C 5D70 70 77.8 86 1 113 44.3 2 BV-5SMDJ75CA BV-5SMDJ75A 5D75C 5D75 75 83.3 92.1 1 121 41.4 2 BV-5SMDJ78CA BV-5SMDJ78A 5D78C 5D78 78 86.7 95.8 1 126 39.7 2 BV-5SMDJ85CA BV-5SMDJ85A 5D85C 5D85 85 94.4 104 1 137 36.5 2 BV-5SMDJ90CA BV-5SMDJ90A 5D90C 5D90 90 100 111 1 146 34.3 2 BV-5SMDJ100CA BV-5SMDJ100A 5D100C 5D100 100 111 123 1 162 30.9 2 BV-5SMDJ110CA BV-5SMDJ110A 5D110C 5D110 110 122 135 1 177 28.3 2 (V) Note:absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted). 1 Surge Waveform: 10/1000μ S ○ Mark 5DXXC cathode 5DXX anode UNI:5DXX BI:5DXXC Part Number System BV 5SMDJ XX C A (1) (2) (3) (4) (5) (1) Bencent Transient Voltage Suppressor (2) Series Code (3) VR=XXV (4) BI-directional (5) Suffix ‘A’ denotes 5% tolerance devices 2/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications 5SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor V-I Curve IPP VC VBR VR It IR IR It VR V VBR VC VC VBR VR IR It BI-directional V VF UNI-directional IPP IPP Parameters Definition VF Forward Voltage drop for UNI-directional VC Clamping Voltage Ipp Surge Waveform 10/1000μs VR Stand-off Voltage VBR Breakdown Voltage IR Reverse Leakage Current It Test Current Ppp Peak Pulse Power Dissipation Thermal Considerations symbol Parameter Value Unit TJ Operating Junction Temperature Range -55 to +150 ℃ TS Storage Temperature Range -55 to +150 ℃ Environmental Characteristics Testing items High Temperature Reverse Bias Test High Temperature Life Test High-low Temperature Cycle Test High Temperature &High Humidity Test Pressure Cooker Test Resistance of Soldering Heat Technical standards Temperature: 150±3℃ Bias=80%VR Time:168H Temperature: 150℃ Time:168H Temperature: From -40℃ to125℃ Dwell time :30min,10cycles Temperature: 85℃ Humidity:85% Time:168H Temperature: 121℃,2atm. Humidity:100% Time:24H Temperature: 260±5℃ Time of dip soldering:10s,3times Note: The above testing items can be specified by customer’s special request 3/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications 5SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Product Dimensions REF A B C D E F G H mm 2.85--3.05 5.85--6.15 6.75--7.05 2.45--2.95 0.15—0.25 0.90--1.60 0.00—0.40 7.75--8.25 inch 0.112--0.120 0.230--0.242 0.266--0.278 0.096--0.116 0.006--0.012 0.035--0.063 0.000--0.016 0.305--0.325 Recommended Soldering Pad REF mm inch A 8.25 0.325 B 5.05 0.199 C 3.05 0.12 Reflow Profile Reflow Condition Pre Heat Pb-Free assembly Temperature Min 150°C Temperature Max 200°C Time (min to max) 60 – 180 secs TP TP Average ramp up rate(Liquidus)Tamp(TL) 3°C/s max to peak Reflow 3°C/s max - Temperature (TL) (Liquidus) 217°C - Temperature (TL) 60 – 150 secs Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (TP) 30secs Ramp-down Rate 6°C/s max Time 25°C to peak Temperature (TP) 8 min max. Do not exceed 260°C 4/5 www.bencent.com.cn TL Temperature TS(max) to TL - Ramp-up Rate Critical Zone TL to TP Ramp-up TL TS(max) Ramp-down Preheat TS(min) TS 25 time to peak temperature Time Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications 5SMDJ series Version: A1 2016-8-10 Transient Voltage Suppressor Package 5/5 Reel Information REF. mm inch A 6.15+/-0.1 0.242+/-0.004 B 8.2+/-0.1 0.323+/0-.004 d 1.5+/-0.05 0.059+/-0.002 D 330.0 13.0 D1 72+/-3 2.835+/-0.118 D2 13+/-0.3 0.512+/-0.012 E 1.75+/-0.1 0.069+/-0.004 F 5.5+/-0.05 0.212+/-0.002 P 8.0+/-0.1 0.315+/-0.004 P0 4.0+/-0.1 0.157+/-0.004 P1 2.0+/-0.05 0.079+/-0.004 W 16+/-0.1 0.630+/-0.004 W1 22+/-2.0 0.866+/-0.079 Outline Reel (pcs) Per Carton (pcs) Reel Diameters (mm) Taping 3,000 24,000 330 www.bencent.com.cn Carton Size(mm) L W H 360 360 380 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BV-5SMDJ30A 价格&库存
很抱歉,暂时无法提供与“BV-5SMDJ30A”相匹配的价格&库存,您可以联系我们找货
