BV-SMCJ48CA
BV-SMCJ48CA
    BENCENT(槟城)
    SMC(DO-214AB)
    双向TVS 48V截止 峰值浪涌电流:19.4A@10/1000US
BV-SMCJ48CA 数据手册
SMC 1500W Series Version: A7 2018/6/15 Transient Voltage Suppressor Features Exterior IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact) 1500Watts peak pulse power (tp=10/1000μ S) Quick response to surge voltage Low clamping voltage Moisture sensitivity level: Level 1 DO-214AB (SMC) Agency Approvals Application Information rmation DC Port Icon RS485/232/422 Description Compliance with 2011/65/EU I/O Port Compliance withIEC61249-2-21:2003 Schematic Symbol anode cathode BI-directional UNI-directional Part Number and Electrical Parameter Part Number Marking VR VBR (V) min.(V) VBR max.( It (mA) Max Vc@IPP○1 IPP○1 (A) IR@VR BI UNI BI UNI BV-SMCJ5CA BV-SMCJ5A C5C C5 5 6.4 7 10 9.2 163.0 800 BV-SMCJ6CA BV-SMCJ6A C6C C6 6 6.67 7.37 10 10.3 145.7 800 BV-SMCJ6.5CA BV-SMCJ6.5A C6.5C C6.5 6.5 7.22 7.98 10 11.2 134.0 500 BV-SMCJ7CA BV-SMCJ7A C7C C7 7 7.78 8.6 10 12 125.0 200 BV-SMCJ7.5CA BV-SMCJ7.5A C7.5C C7.5 7.5 8.33 9.21 1 12.9 116.3 100 BV-SMCJ8CA BV-SMCJ8A C8C C8 8 8.89 9.83 1 13.6 110.3 50 BV-SMCJ8.5CA BV-SMCJ8.5A C8.5C C8.5 8.5 9.44 10.4 1 14.4 104.2 20 BV-SMCJ9CA BV-SMCJ9A C9C C9 9 10 11.1 1 15.4 97.4 10 BV-SMCJ10CA BV-SMCJ10A C10C C10 10 11.1 12.3 1 17 88.3 5 BV-SMCJ11CA BV-SMCJ11A C11C C11 11 12.2 13.5 1 18.2 82.5 1 BV-SMCJ12CA BV-SMCJ12A C12C C12 12 13.3 14.7 1 19.9 75.4 1 BV-SMCJ13CA BV-SMCJ13A C13C C13 13 14.4 15.9 1 21.5 69.8 1 BV-SMCJ14CA BV-SMCJ14A C14C C14 14 15.6 17.2 1 23.2 64.7 1 BV-SMCJ15CA BV-SMCJ15A C15C C15 15 16.7 18.5 1 24.4 61.5 1 BV-SMCJ16CA BV-SMCJ16A C16C C16 16 17.8 19.7 1 26 57.7 1 BV-SMCJ17CA BV-SMCJ17A C17C C17 17 18.9 20.9 1 27.6 54.4 1 BV-SMCJ18CA BV-SMCJ18A C18C C18 18 20 22.1 1 29.2 51.4 1 1/6 www.bencent.com.cn V) (V) (uA) Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMC 1500W Series Version: A7 2018/6/15 Transient Voltage Suppressor Part Number Marking VR VBR VBR It Max 1 ○ IPP○1 IR@VR BI UNI BI UNI (V) min.(V) max.(V) (mA) Vc@IPP (V) (A) (uA) BV-SMCJ20CA BV-SMCJ20A C20C C20 20 22.2 24.5 1 32.4 46.3 1 BV-SMCJ22CA BV-SMCJ22A C22C C22 22 24.4 26.9 1 35.5 42.3 1 BV-SMCJ24CA BV-SMCJ24A C24C C24 24 26.7 29.5 1 38.9 38.6 1 BV-SMCJ26CA BV-SMCJ26A C26C C26 26 28.9 31.9 1 42.1 35.7 1 BV-SMCJ28CA BV-SMCJ28A C28C C28 28 31.1 34.4 1 45.4 33.1 1 BV-SMCJ30CA BV-SMCJ30A C30C C30 30 33.3 36.8 1 48.4 31.0 1 BV-SMCJ33CA BV-SMCJ33A C33C C33 33 36.7 40.6 1 53.3 28.2 1 BV-SMCJ36CA BV-SMCJ36A C36C C36 36 40 44.2 1 58.1 25.9 1 BV-SMCJ40CA BV-SMCJ40A C40C C40 40 44.4 49.1 1 64.5 23.3 1 BV-SMCJ43CA BV-SMCJ43A C43C C43 43 47.8 52.8 1 69.4 21.7 1 BV-SMCJ45CA BV-SMCJ45A C45C C45 45 50 55.3 1 72.7 20.6 1 BV-SMCJ48CA BV-SMCJ48A C48C C48 48 53.3 58.9 1 77.4 19.4 1 BV-SMCJ51CA BV-SMCJ51A C51C C51 51 56.7 62.7 1 82.4 18.2 1 BV-SMCJ54CA BV-SMCJ54A C54C C54 54 60 66.3 1 87.1 17.3 1 BV-SMCJ58CA BV-SMCJ58A C58C C58 58 64.4 71.2 1 93.6 16.1 1 BV-SMCJ60CA BV-SMCJ60A C60C C60 60 66.7 73.7 1 96.8 15.5 1 BV-SMCJ64CA BV-SMCJ64A C64C C64 64 71.1 78.6 1 103 14.6 1 BV-SMCJ70CA BV-SMCJ70A C70C C70 70 77.8 86 1 113 13.3 1 BV-SMCJ75CA BV-SMCJ75A C75C C75 75 83.3 92.1 1 121 12.4 1 BV-SMCJ78CA BV-SMCJ78A C78C C78 78 86.7 95.8 1 126 11.9 1 BV-SMCJ85CA BV-SMCJ85A C85C C85 85 94.4 104 1 137 11.0 1 BV-SMCJ90CA BV-SMCJ90A C90C C90 90 100 111 1 146 10.3 1 BV-SMCJ100CA BV-SMCJ100A C100C C100 100 111 123 1 162 9.3 1 BV-SMCJ110CA BV-SMCJ110A C110C C110 110 122 135 1 177 8.5 1 BV-SMCJ120CA BV-SMCJ120A C120C C120 120 133 147 1 193 7.8 1 BV-SMCJ130CA BV-SMCJ130A C130C C130 130 144 159 1 209 7.2 1 BV-SMCJ150CA BV-SMCJ150A C150C C150 150 167 185 1 243 6.2 1 BV-SMCJ160CA BV-SMCJ160A C160C C160 160 178 197 1 259 5.8 1 BV-SMCJ170CA BV-SMCJ170A C170C C170 170 189 209 1 275 5.5 1 BV-SMCJ180CA BV-SMCJ180A C180C C180 180 201 222 1 292 5.1 1 BV-SMCJ200CA BV-SMCJ200A C200C C200 200 224 247 1 324 4.6 1 BV-SMCJ220CA BV-SMCJ220A C220C C220 220 246 272 1 356 4.2 1 BV-SMCJ250CA BV-SMCJ250A C250C C250 250 279 309 1 405 3.7 1 BV-SMCJ300CA BV-SMCJ300A C300C C300 300 335 371 1 486 3.1 1 BV-SMCJ350CA BV-SMCJ350A C350C C350 350 391 432 1 567 2.6 1 BV-SMCJ400CA BV-SMCJ400A C400C C400 400 447 494 1 648 2.3 1 BV-SMCJ440CA BV-SMCJ440A C440C C440 440 492 543 1 713 2.1 1 Note: absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted). 1 Surge Waveform: 10/1000μ S ○ 2/6 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMC 1500W Series Version: A7 2018/6/15 Transient Voltage Suppressor Mark cathode BI:CXXC anode UNI:CXX Part Number System BV SMCJ XX C A (1) (3) (4) (5) (2) (1) Bencent Transient Voltage Suppressor (2) Series Code (3) VR=XXV (4) BI-directional (5) Suffix ‘A’ denotes 5% tolerance devices V-I Curve IPP VC VBR VR IR It IR It VR V VBR VC VC VBR VR IR It BI-directional V VF UNI-directional IPP IPP Parameters Definition VF Forward Voltage drop for UNI-directional VC ClampingVoltage Ipp Surge Waveform 10/1000μ s VR Stand-off Voltage VBR Breakdown Voltage IR Reverse Leakage Current It TestCurrent Ppp Peak Pulse Power Dissipation Thermal Considerations symbol Parameter Value Unit TJ Operating Junction Temperature Range -55 to +150 ℃ TS Storage Temperature Range -55 to +150 ℃ 3/6 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMC 1500W Series Version: A7 2018/6/15 Transient Voltage Suppressor Typical Characteristics Peak Pulse Power Rating Curve Typical Junction Capacitance Pulse Waveform Steady State Power Dissipation Derating Curve 4/6 www.bencent.com.cn Pulse Derating Curve Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMC 1500W Series Version: A7 2018/6/15 Transient Voltage Suppressor Product Dimensions REF A B C D E F G H M mm 3±0.1 6±0.2 7±0.2 2.7±0.3 0.2±0.1 1.3±0.3 0~0.4 8±0.25 4.4±0.2 inch 0.118±0.004 0.236±0.008 0.276±0.008 0.106±0.012 0.008±0.004 0.051±0.012 0.000~0.016 0.315±0.010 0.173±0.008 Recommended Soldering Pad REF mm inch A 8.25 0.325 B 5.05 0.199 C 3.05 0.120 Reflow Profile Pre Heat Pb-Free Assembly Temperature Min. +150°C Temperature Max. +200°C Time(Min to Max) 60 – 180 seconds Average ramp up rate (Liquidus Temp (TL) to peak) TS(max) to TL - Ramp-up Rate - Temperature (TL) Reflow (Liquidus) - Temperature (TL) Peak Temp (TP) Time within 5°C of actual Peak Temp (TP) TL 3°C/second max 217°C 60 – 150 seconds 8-15 seconds Time 25°C to peak Temp (TP) 8 min max. Do not exceed 260°C TL TS(max) Ramp-down Preheat TS(min) 260+0/-5 °C 6°C/s max www.bencent.com.cn Critical Zone TL to TP 3°C/second max Ramp-down Rate 5/6 TP TP Temperature Reflow Condition TS TL 25 time to peak temperature Time Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications SMC 1500W Series Version: A7 2018/6/15 Transient Voltage Suppressor Package Reel Information 6/6 REF. mm inch A 6.1±0.3 0.240±0.012 B 8.3±0.3 0.327±0.012 d 1.5±0.1 0.059±0.004 D 330.0 13.0 D2 13±1.5 0.512±0.059 E 1.7±0.3 0.067±0.012 F 7.5±0.3 0.295±0.012 P 8±0.3 0.315±0.012 P0 4±0.3 0.157±0.012 P1 2±0.3 0.079±0.012 W 16±0.5 0.630±0.020 W1 23±3 0.906±0.118 Outline Reel (pcs) Per Carton (pcs) Reel Diameters (mm) Taping 3,000 48,000 330 www.bencent.com.cn Carton Size(mm) L W H 360 360 385 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BV-SMCJ48CA 价格&库存
很抱歉,暂时无法提供与“BV-SMCJ48CA”相匹配的价格&库存,您可以联系我们找货
