SMDJ30A
SMDJ30A
    SET(赛尔特)
    SMC(DO-214AB)
    TVS二极管
SMDJ30A 数据手册
瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes ● 低浪涌电阻 ● 优异的箝位性能 ● 小型化紧凑封装,内部结构去应力设计 ● 12 V以上电压规格对应漏电典型值低于2.0 μA ● 重复率0.01% 的10/1000 μS 波形对应峰值脉冲功率3000 W ● 表贴应用,节约空间 ● 典型的故障模式为电压或电流超过额定而导致的短路 ● IEC 61000-4-2 ESD 30 kV(空气),30 kV(接触) ● 数据线EFT保护符合IEC 61000-4-4 ● 快速响应时间 瞬态抑制二极管 (TVS) 是一种电路保护元件,它可以削 ● 玻璃钝化保护 弱或过滤突增瞬态电压(过压),在浪涌到来瞬间几纳秒 ● 回流焊高温保证:260 °C/30 s 时间内发生雪崩击穿,将浪涌电流引至接地端,并将电 ● 温度系数典型值0.1% 压箝位在安全范围内,从而实现了高效能的电压保护。 ● 密封材料阻燃等级V-0 ● 湿度敏感等级符合MSL 等级1 Transient Voltage Suppressor (TVS) is a circuit ● 引脚镀锡 protection component that either attenuates (reduces) ● 无卤素,符合RoHS要求 or filters a transient voltage spike (overvoltage), TVS ● TVS 概述 Description diodes provide critical protection by going into 无铅E3:二级互连引线无铅,端子镀锡(Sn) (IPC/JEDEC J-STD609A.01) avalanche breakdown within no more than a few ● Low incremental surge resistance nanoseconds after a strike, clamping the transient ● Excellent clamping capability voltage, and routing its current to the ground. ● Low profile package with built-in strain relief ● Typical IR less than 2.0 μA above 12 V ● 3000 W peak pulse power capability with a 10/1000 μS Waveform, repetition rate (duty cycle): 0.01% 应用 Applications ● For surface mounted applications to optimize board space Typical failure mode is short from over-specified voltage or current ● 通信设备 Communication Equipment ● ● 安防 Security & Protection ● IEC 61000-4-2 ESD 30 kV (Air), 30 kV (Contact) ● 工控设备 Industrial Control Equipment ● EFT protection of data lines in accordance with IEC ● 电源 Power Supply ● 汽车电子 Automotive Electronics ● Very fast response time ● 新能源设备 New Energy ● Glass passivated chip junction ● 防雷保护 Lightning Protection ● High temperature to reflow soldering guaranteed: 61000-4-4 260 °C/30 sec ● 功能图 Functional Diagram (αT:Temperature Coefficient, typical value is 0.1%) ● 负极 Cathode 正极 Anode 单向 Uni-Directional VBR @ TJ= VBR@25 °C x (1+αT x (TJ - 25)) Plastic package is flammability rated V-0 per Underwriters Laboratories ● Meet MSL level1, per J-STD-020, ● Matte tin lead–free plated ● Halogen free and RoHS compliant ● Pb-free E3 means 2nd level interconnect is Pb-free and the terminal finish material is tin(Sn) (IPC/JEDEC J-STD-609A.01) 双向 Bi-Directional +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 1 TVS 特性 Features 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 封装尺寸 Package Outline Dimensions (DO-214AB) W1 W Symbol Max. Min. Max. L 6.600 7.110 0.260 0.280 W 5.590 6.220 0.220 0.245 W1 2.900 3.200 0.114 0.126 H 2.060 2.620 0.079 0.103 T 0.1520 0.305 0.006 0.012 L1 7.750 8.130 0.305 0.320 L2 0.760 1.520 0.030 0.060 D - 0.203 - 0.008 A - 4.200 - 0.165 B 2.400 - 0.094 - C 2.400 - 0.094 - E 3.300 - 0.129 - H L2 T TVS L1 A E B 安装布局 Mounting Pad Layout +86 592-571-5838 www.SETsafe.com C www.SETfuse.com 英制(英寸) Inches Min. L D 公制(毫米) Millimeters 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 2 TVS 符号 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 额定参数与特性 Maximum Ratings and Characteristics 参数 Parameter 符号 Symbol 值 Value 单位 Unit PPPM 3000 W 10/1000 μS 测试波形1)(2)(图4)的峰值脉冲功耗(图2)-双芯片器件(5) Peak Pulse Power Dissipation(Fig.2) by 10/1000 μS Test Waveform(1)(2)(Fig.4) -Stacked Die Parts(5) PPPM 4000 W 峰值功耗 ,无限散热,TL=50 °C Peak Power Dissipation on Infinite Heat Sink at TL=50 °C PD 6.5 W IFSM 300 A 正向瞬态峰值电压 @ IF=100 A ,仅适用于单向产品(4) Maximum Instantaneous Forward Voltage at 100 A for Unidirectional Only (4) VF 3.5/5.0 V 工作温度范围 Operating Temperature Range TJ -65 to 150 °C 存储温度范围 Storage Temperature Range TSTG -65 to 175 °C 热阻(结至引线) Typical Thermal Resistance Junction to Lead RθJL 15 °C/W 热阻(结至环境) Typical Thermal Resistance Junction to Ambient RθJA 75 °C/W 10/1000 μS 脉冲波形(1)(2)((图4)下,峰值脉冲功耗 (图2)-单芯片器件 Peak Power Dissipation(Fig.2)- with a 10/1000 μS waveform(1)(2)(Fig.4)-Single Die Parts TVS 正向脉冲电流峰值(3),额定负载叠加8.3 ms 单半正弦波测得(JEDEC方法) Peak Forward Surge Current,8.3ms single half sinewave superimposed on rated load (JEDEC Method)(3) 注释 Notes 1. 2. 3. 4. 5. 参照图4非重复性脉冲电流波形,初始结温25 °C 以图3所示曲线降额(环境温度TA=25 ℃ )。 Non-repetitive current pulse, per Fig. 4 and derated above TJ (initial)=25 °C per Fig. 测试安装于8.0 mm 2 焊盘 。 Mounted on 8.0 mm 2 land areas. 叠加波形为8.3 ms 单个半周期正弦波或等幅方波 , 最长周期4次/min。 Measured of 8.3 ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minute 单芯片VF< 3.5 V,叠层芯片VF< 5.0 V。 VF < 3.5 V for single die parts and VF< 5.0 V for stacked-die parts. 双芯片产品的详细信息,请参阅电气特性中以*标示的部件编号。 For stacked die component details, please refer to models marked with * in electrical characteristics table. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 3 TVS (除另有注释,默认TA=25 ℃ Ratings at 25 °C ambient temperature unless otherwise specified.) 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 型号规则 Part Numbering System SMDJ XX C A 产品系列 Product Series 反向关断电压 Reverse Stand-off Voltage C: 双向 Bi-directional None: 单向 uni-direction 标记 Marking TVS TVS 5% VBR 电压容差 5% VBR Voltage tolerance 阴极线 Cathode Band SET SET XXX YMXXX YMXXX 商标 Trademark +86 592-571-5838 XXX 日期代码 Data Code 标记代码 Marking Code 商标 Trademark 日期代码 Data Code Y-年 Year Y-年 Year M-月 Month M-月 Month XXX-批次号 Lot code XXX-批次号 Lot code www.SETsafe.com www.SETfuse.com 标记代码 Marking Code 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 4 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 术语 Glossary 项目 Item 描述 Description 箝位电压 Clamping Voltage VC TVS在低差阻区域内的电压,用于限制设备两端的电压。 Voltage across TVS in a region of low differential resistance that serves to limit the voltage across the device terminals. 反向关断电压 Reverse Stand-off Voltage TVS TVS VR TVS 在没有导通状态下最高电压。 Maximum voltage that can be applied to the TVS without operation. 注:也用VWM(最高直流工作电压)表示,也称为截止电压(Vso)。 NOTE : It is also shown as VWM (maximum working voltage (maximum d.c. voltage)) and known as rated standoff voltage (Vso). 反向漏电流 Reverse Leakage Current IR 量测VR的电流。 Current measured at VR. 注:也用ID 待机电流表示。 NOTE : Also shown as ID for stand-by current. 击穿电压 Breakdown Voltage VBR 在击穿区以指定电流IT (测试电流)通过TVS的电压。 Voltage across TVS at a specified current IT (test current) in the breakdown region. 额定随机重复峰值脉冲电流 Rated Random Recurring Peak Impulse Current IPPM 施加在设备上的随机重复峰值脉冲电流的最大额定值。 Maximum-rated value of random recurring peak impulse current that may be applied to a device. 额定平均功率 Rated Average Power Dissipation PM(AV) 所有电源(包括瞬态电流和待机电流)在短时间内平均产生的最大额定功耗。 Maximum-rated value of power dissipation resulting from all sources, including transients and standby current, averaged over a short period of time. 额定随机重复峰值脉冲功率 Rated Random Recurring Peak Impulse Power Dissipation PPPM 额定随机重复峰值脉冲电流(IPPM) 和规定的最大箝位电压(VC)乘积的最大额定值。 Maximum-rated value of the product of rated random recurring peak impulse current (IPPM) multiplies by specified maximum clamping voltage (VC). 电容 Capacitance CJ 在规定的频率和电压下所测量的TVS电容。 Capacitance across the TVS measured at a specified frequencyx and voltage. —(GB-T 18802.321 / IEC 61643-321 / JESD210A) +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 5 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 项目 Item 描述 Description 正向浪涌峰值电压 Peak Forward Surge Voltage VFS 在指定的正向浪涌电流(IFS)和持续时间下,通过TVS的峰值电压。 Peak voltage across TVS for a specified forward surge current (IFS) and time duration. 注:也用VF 表示。 NOTE : Also shown as VF. 正向浪涌电流 Forward Surge Current IFS 在正向导通区域通过TVS的脉冲电流。 Pulsed current through TVS in the forward conducting region. 注:也用IF表示。 NOTE : Also shown as IF. 击穿电压的变化与温度变化的比值。 The change of breakdown voltage divided by the change of temperature. 峰值脉冲电流 Peak pulse Current IPP 施加在TVS上的峰值脉冲电流,以确定箝位电压VC 的特定波形。 Peak pulse current value applied across the TVS to determine the clamping voltage VC for a specified wave shape. 脉冲直流测试电流 Pulsed D.C. Test Current IT 测量击穿电压VBR的试测试电流。该电流值由制造商确定,通常以脉冲持续时间小于40 ms的毫安级电流给出。 Test current for measurement of the breakdown voltage VBR. This is defined by the manufacturer and usually given in milliamperes with a pulse duration of less than 40 ms. 注:也用IBR表示。 NOTE : Also shown as IBR . —(GB-T 18802.321 / IEC 61643-321 / JESD210A) +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 6 TVS TVS 击穿电压温度系数 Temperature Coefficient of Breakdown Voltage αV(BR) 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 电气特性 ( 除另有注释,默认TA=25 ℃ ) Electrical Characteristics (TA=25 °C unless otherwise noted )Table 1 标记代码 Device Marking Code 击穿电压 Breakdown Voltage VBR@IT TVS Min 最大反向 最大峰值 电压 Reverse Stand-off Voltage VR 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPPM (10/1000 µS) (mA) (V) (μA) (A) (V) (A) (V) 7 10 5 800 326.1 9.2 1630.5 11.89 Max (V) 最大箝位电压 Max. Clamping Voltage VC@IPPM (10/1000 µS) 最大峰值 脉冲电流 Max. Peak Pulse Current IPPM (8/20 µS) 最大箝位电压 Max. Clamping Voltage VC@IPPM (8/20 µS) Bi SMDJ5.0A SMDJ5.0CA RDE DDE SMDJ6.0A SMDJ6.0CA RDG DDG 6.67 7.37 10 6 800 291.3 10.3 1456.5 13.31 SMDJ6.5A SMDJ6.5CA RDK DDK 7.22 7.98 10 6.5 500 267.9 11.2 1339.5 14.47 SMDJ7.0A SMDJ7.0CA PDM DDM 7.78 8.6 10 7 200 250 12 1250 15.5 SMDJ7.5A SMDJ7.5CA PDP DDP 8.33 9.21 1 7.5 100 232.6 12.9 1163 16.67 SMDJ8.0A SMDJ8.0CA PDR DDR 8.89 9.83 1 8 50 220.6 13.6 1103 17.57 SMDJ8.5A SMDJ8.5CA PDT DDT 9.44 10.4 1 8.5 20 208.3 14.4 1041.5 18.6 SMDJ9.0A SMDJ9.0CA PDV DDV 10 11.1 1 9 10 194.8 15.4 974 19.9 SMDJ10A SMDJ10CA PDX DDX 11.1 12.3 1 10 5 176.5 17 882.5 21.96 SMDJ11A SMDJ11CA PDZ DDZ 12.2 13.5 1 11 2 164.8 18.2 824 23.51 SMDJ12A SMDJ12CA PEE DEE 13.3 14.7 1 12 2 150.8 19.9 754 25.71 SMDJ13A SMDJ13CA PEG DEG 14.4 15.9 1 13 2 139.5 21.5 697.5 27.78 SMDJ14A SMDJ14CA PEK DEK 15.6 17.2 1 14 2 129.3 23.2 646.5 29.97 SMDJ15A SMDJ15CA PEM DEM 16.7 18.5 1 15 2 123 24.4 615 31.52 SMDJ16A SMDJ16CA PEP DEP 17.8 19.7 1 16 2 115.4 26 577 33.59 SMDJ17A SMDJ17CA PER DER 18.9 20.9 1 17 2 108.7 27.6 543.5 35.66 SMDJ18A SMDJ18CA PET DET 20 22.1 1 18 2 102.7 29.2 513.5 37.73 SMDJ20A SMDJ20CA PEV DEV 22.2 24.5 1 20 2 92.6 32.4 463 41.86 SMDJ22A SMDJ22CA PEX DEX 24.4 26.9 1 22 2 84.5 35.5 422.5 45.87 SMDJ24A SMDJ24CA PEZ DEZ 26.7 29.5 1 24 2 77.1 38.9 385.5 50.26 SMDJ26A SMDJ26CA PFE DFE 28.9 31.9 1 26 2 71.3 42.1 356.5 54.39 SMDJ28A SMDJ28CA PFG DFG 31.1 34.4 1 28 2 66.1 45.4 330.5 58.66 SMDJ30A SMDJ30CA PFK DFK 33.3 36.8 1 30 2 62 48.4 310 62.53 SMDJ33A SMDJ33CA PFM DFM 36.7 40.6 1 33 2 56.3 53.3 281.5 68.86 SMDJ36A SMDJ36CA PFP DFP 44.2 1 36 2 51.6 58.1 258 75.06 www.SETsafe.com Bi 反向关断 电流 Test Current IT Uni +86 592-571-5838 Uni 测试 6.4 40 www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 7 TVS 型号 Part Number 瞬态抑制二极管 TVS Diodes 型号 Part Number 标记代码 Device Marking Code 击穿电压 Breakdown Voltage VBR@IT TVS Min 最大峰值 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPPM (10/1000 µS) (mA) (V) (μA) (A) 最大箝位电压 Max. Clamping Voltage VC@IPPM (10/1000 µS) 最大峰值 最大箝位 脉冲电流 Max. Peak Pulse Current IPPM (8/20 µS) 电压 Max. Clamping Voltage VC@IPPM (8/20 µS) (V) (A) (V) SMDJ40A SMDJ40CA PFR DFR 44.4 49.1 1 40 2 46.5 64.5 232.5 83.33 SMDJ43A SMDJ43CA PFT DFT 47.8 52.8 1 43 2 43.2 69.4 216 89.66 SMDJ45A SMDJ45CA PFV DFV 55.3 1 45 2 41.3 72.7 206.5 93.93 SMDJ48A SMDJ48CA PFX DFX 53.3 58.9 1 48 2 38.8 77.4 194 100 SMDJ51A SMDJ51CA PFZ DFZ 56.7 62.7 1 51 2 36.4 82.4 182 106.46 SMDJ54A SMDJ54CA RGE DGE 66.3 1 54 2 34.4 87.1 172 112.53 SMDJ58A SMDJ58CA PGG DGG 64.4 71.2 1 58 2 32.1 93.6 160.5 120.93 SMDJ60A SMDJ60CA PGK DGK 66.7 73.7 1 60 2 31 96.8 155 125.06 SMDJ64A SMDJ64CA PGM DGM 71.1 78.6 1 64 2 29.1 103 145.5 133.07 SMDJ70A SMDJ70CA PGP DGP 77.8 1 70 2 26.5 113 132.5 145.99 SMDJ75A SMDJ75CA PGR DGR 83.3 92.1 1 75 2 24.8 121 124 156.33 SMDJ78A SMDJ78CA PGT DGT 86.7 95.8 1 78 2 23.8 126 119 162.79 SMDJ85A SMDJ85CA PGV DGV 94.4 104 1 85 2 21.9 137 109.5 177 SMDJ90A SMDJ90CA PGX DGX 100 111 1 90 2 20.5 146 102.5 188.63 SMDJ100A SMDJ100CA PGZ DGZ 111 123 1 100 2 18.5 162 92.5 209.3 SMDJ110A SMDJ110CA PHE DHE 122 135 1 110 2 16.9 177 84.5 228.68 www.SETfuse.com (V) 最大反向 电压 Reverse Stand-off Voltage VR Bi www.SETsafe.com Bi 反向关断 电流 Test Current IT Uni +86 592-571-5838 Uni Max 测试 50 60 86 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 8 TVS SMDJ Series Transient Voltage Suppression Diodes 瞬态抑制二极管 TVS Diodes 型号 Part Number 标记代码 Device Marking Code 击穿电压 Breakdown Voltage VBR@IT TVS Min Uni Bi Max (V) 测试 反向关断 最大反向 最大峰值 电流 Test Current IT 电压 Reverse Stand-off Voltage VR 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPPM (10/1000 µS) (mA) (V) (μA) (A) 最大箝位电压 Max. Clamping Voltage VC@IPPM (10/1000 µS) 最大峰值 最大箝位 脉冲电流 Max. Peak Pulse Current IPPM (8/20 µS) 电压 Max. Clamping Voltage VC@IPPM (8/20 µS) (V) (A) (V) Uni Bi SMDJ120A SMDJ120CA PHG DHG 133 147 1 120 2 15.5 193 77.5 249.35 SMDJ130A SMDJ130CA PHK DHK 144 159 1 130 2 14.4 209 72 270.03 SMDJ150A - PHM - 167 185 1 150 2 12.3 243 61.5 313.95 - SMDJ150CA* - DHM 167 185 1 150 2 16.5 243 61.5 313.95 SMDJ160A - PHP - 178 197 1 160 2 11.6 259 58 334.63 - SMDJ160CA* - DHP 178 197 1 160 2 15.5 259 58 334.63 SMDJ170A - PHR - 189 209 1 170 2 10.9 275 54.5 355.3 - SMDJ170CA* - DHR 189 209 1 170 2 14.6 275 54.5 355.3 SMDJ180A* SMDJ180CA* PHT DHT 200 221 1 180 2 13.7 292 51.5 377.26 SMDJ200A* SMDJ200CA* PHV DHV 224 247 1 200 2 12.4 324 46.5 418.6 SMDJ220A* SMDJ220CA* PKE DKE 244 270 1 220 2 11.3 356 42 459.95 SMDJ250A* SMDJ250CA* PKG DKG 279 309 1 250 2 9.9 405 37.5 523.26 SMDJ300A* SMDJ300CA* PKI DKI 335 371 1 300 2 8.3 486 31 627.91 SMDJ350A* SMDJ350CA* PKJ DKJ 391 432 1 350 2 7.1 567 26.5 732.56 SMDJ400A* SMDJ400CA* PKL DKL 447 494 1 400 2 6.2 648 23.5 837.21 SMDJ440A* SMDJ440CA* PKN DKN 492 543 1 440 2 5.7 713 21.5 921.19 注释 Notes: 1.对于VR为10 V及更低的双向产品,IR值需乘以两倍。 For bidirectional type having VR of 10 volts and less, the IR should be doubled. 2.对于没有A的产品,VBR范围为±10%且VC也比有A的产品高5%,当前不推荐没有A的产品用于新设计,带A的产品推荐优先选用。 For parts without A in the PN, the VBR tolerance is ± 10% and VC is 5% higher than parts with A. The parts without A are currently available, but not recommended for new designs. The parts with A are preferred. 3.双芯片产品的详细信息,请参阅电气特性中以*标示的部件编号 。 For stacked die component details, please refer to models marked with * in electrical characteristics table. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 9 TVS SMDJ Series Transient Voltage Suppression Diodes 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 伏安特性曲线 I-V Curve Characteristics IF 单向 Uni-directional VC 双向 Bi-directional VBR VWM IPP IT ID VC VBR VWM ID VF IT ID IT IPP VWM VBR VC IPP TVS TVS 参考性能曲线(除有另外注释,默认TA=25 ℃ ) Performance Curve for Reference(TA=25 °C unless otherwise noted) 脉冲峰值功率 PPPM - Peak Pulse Power (KW) 电压/电流 Voltage or Current Voltage Transient Voltage Across TVS Current Throuth TVS Time 100 TJ (initial)=Tamb Stacked die,2kW At 10×1000µs,25 °C 10 Signal die,1.5 KW At 10×1000µs,25 °C 1.0 0.1 0.01 0.001 0.1 1 10 td – 脉宽 Pulse Width (ms) FIGURE 2 峰值脉冲功率额定曲线 Peak Pulse Power Rating Curve 15 100 80 60 40 20 0 0 25 50 75 100 120 150 175 TJ –初始结温 Initial Junction Temperature (°C ) IPPM - 峰值脉冲电流 Peak Pulse Current, % IRSM 降额百分比 Peak Pulse Power (PPP) or Current (IPPM) Derating in Percentage, % FIGURE 1 TVS瞬态箝位波形 TVS Transients Clamping Waveform Tr=10μs TJ = 25 °C Pulse Width (td) is defined as the Point where the Peak Current decays to 50 % of IPPM Peak Value IPPM 10 Half Value IPPM/2 10/1000 μs Waveform as defined by R.E.A. 50 td 0 0 1.0 2.0 3.0 4.0 t –时间 Time (ms) FIGURE 3 峰值脉冲功率降额曲线 Peak Pulse Power Derating Curve +86 592-571-5838 www.SETsafe.com www.SETfuse.com FIGURE 4 脉冲波形 Pulse Waveform 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 10 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes Uni-direction at Zero-bias 10000 电容 CJ –(pF) Bi-direction at Zero-bias 1000 Uni-direction at VR-bias 100 Bi-direction at VR-bias 10 1 TVS 1 10 100 1000 100 10 1 0.1 0.01 0.001 0.01 VBR – 反向击穿电压 Reverse Breakdown Voltage (V) 1 10 100 1000 TP – 脉宽 Pulse Duration (s) FIGURE 5 典型结电容 Typical Junction Capacitance FIGURE 6 典型瞬态热阻 Typical Transient Thermal Impedance 500 IF– 正向峰值电流 Peak Forward Current (A) IFSM - 正向浪涌峰值电流 Peak Forward Surge Current (A) 0.1 TVS 瞬态热阻 Transient Thermal Impedance (°C /W) 100000 450 400 350 300 250 200 150 100 50 0 1 10 60 Hz周波数 Number of Cycles at 60 Hz 100 Single die 100.0 10.0 Stacked die 1.0 0.1 0.01 0.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 VF– 正向峰值电压 Peak Forward Voltage (V) FIGURE 7 最大非重复正向浪涌电流(单向型) FIGURE 8 峰值正向电压及电流(典型值) Maximum Non-Repetitive Forward Surge Current Peak Forward Drop vs Peak Forward Current (Typical Values) Uni-Directional only 环境特性 Environmental Specifications 高温存储 High Temp. Storage JESD22-A103 高温反偏 HTRB JESD22-A108 温度循环 Temperature Cycling JESD22-A104 湿度敏感性等级 MSL JESDEC-J-STD-020, Level 1 高温高湿反偏 H3TRB JESD22-A101 耐焊接热 RSH JESD22-A111 +86 592-571-5838 www.SETsafe.com www.SETfuse.com 物理特性 Physical Specifications 重量 Weight 0.007 ounce,0.21 grams 封装 Case JESD22DO214AB. Molded plastic body over glass passivated junction 极性 Polarity Color band denotes positive end (cathode) except Bidirectional 端子 Terminal Matte Tin-plated leads, Solderability per JESD22-B102 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 11 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 焊接参数 Soldering Parameters tP TP Critical Zone TL to TP Ramp-up tL TS (max) TS (min) Ramp-down TVS 温度 Temperature (T) TVS TL tS Preheat 25 °C t 25 °C to Peak 时间 Time (t) 回流焊条件 Reflowing Condition 回流焊接参数 Reflow Soldering Parameters 预热 Pre-heat 无铅组装 Lead-Free Assembly 最低温(TS (min)) Temperature Min (TS (min)) 150 °C 最高温(TS (max)) Temperature Max (TS (max)) 200 °C 升温时长(tS) Time (min to max) (tS) 60 ~ 120 seconds 平均升温速率(液相温度(TL)至峰值温度(TP)) 3 °C / second max. Average Ramp-up Rate ( Liquidus Temp (TL) to Peak Temp (TP)) TS (max) 到TL升温速率 3 °C / second max. TS (max) to TL Ramp-up Rate 温度 Temperature (TL) (Liquidus) 回流 Reflow 时长 Time (min to max) (tL) 实际峰值温度 (tP) 5 °C 以内的时间 Time of within 5 °C of Actual Peak Temperature (tP) 降温速率 Ramp-down Rate 8 Minutes max. 260 °C 极限温度 Do Not Exceed www.SETfuse.com 20 ~ 40 seconds 6 °C / second max. 25 °C 至峰值温度时长 Time from 25 °C to Peak Temperature www.SETsafe.com 60 ~ 150 seconds 260+0/-5 °C 峰值温度 Peak Temperature (TP) +86 592-571-5838 217 °C 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 12 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 尺寸 Dimension (mm) W 16.00+0.3/-0.1 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 E 编带 Tape D0 1.55±0.05 D1 1.55±0.05 E 1.75±0.10 F 7.50±0.10 A0 6.15±0.10 B0 8.30±0.10 K0 2.48±0.10 T 0.30±0.05 P2 T D0 D1 A0 B0 W TVS P0 P1 K0 卷盘尺寸 Reel Size 13寸卷盘 13” Reel A A 330 mm C 13.2 mm W1 16.4 mm C Arbor hole Dia. Direction of Feed W1 型号 Part Number 封装 Package 卷盘数量 QTY (Reel) 包装选项 Packaging Option 包装规格 Packaging Specification SMDJ××× DO-214AB 3000 PCS Tape & Reel – 16 mm tape/13” reel EIA STD RS-481 +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 13 TVS 符号 Symbol F 包装信息 Packaging Information 瞬态抑制二极管 TVS Diodes SMDJ Series TVS TVS Transient Voltage Suppression Diodes 注意 ATTENTION 使用方法 Usage 1. 2. 3. 请在规定的温度范围内使用TVS。 TVS must be operated in the specified ambient temp. 请勿使用强极性溶剂清洗TVS以免破坏封装层。 Do not clean the TVS with strong polar solvent such as ketone, esters, benzene and halogenated hydrocarbon, to avoid damaging the encapsulating layer. 请勿对TVS施加剧烈的振动,冲击或压力,以避免元件开裂。 Please do not apply severe vibration, shock or pressure to TVS, to avoid element cracking. 更换 Replacement 1. 2. 若TVS出现可视化损伤,请将其更换。 If TVS is visually damaged, please replace it. TVS为非修理型产品,安全起见,请更换同等规格的TVS。 TVS is a non-repairable product. For safety sake, please use equivalent TVS for replacement. 存储 Storage 1. 存储温度范围。 Storage Temp. Range: (-55 to 150) °C. 2. 请勿将TVS存放于高温高湿或腐蚀性气体环境中,已避免影响引脚的焊接性能,请于收货后一年内进行使用 。 Do not store the TVS at the high temp., high humidity or corrosive gas environment, to avoid influencing the solder-ability of the lead wires. The product shall be used up within 1 year after receiving the goods. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 14 瞬态抑制二极管 TVS Diodes SMDJ Series Transient Voltage Suppression Diodes 环境条件 Environmental Conditions 1. 2. 3. 请勿暴露于室外阳光直射环境。 TVS should not be exposed to the open air, nor direct sunshine. 请避免雨水,水汽等高温高湿环境。 TVS should avoid rain, water vapor or other condition of high temp. and high humidity. 请避免沙尘,盐雾等有害环境。 TVS should avoid sand dust, salt mist, or other harmful gases. TVS最大典型结电容 Max. Typical Capacitance of TVS 高频线路应用中请参照规格书中所给出的典型电容曲线。 The typical capacitance of TVS is listed in the specifications. Designers may refer to it when designing TVS in high frequency circuit. 1. TVS TVS 安装机械应力 Installation Mechanical Stress 安装TVS时请避免敲击,防止物理损伤。 Do not knock TVS when installing, to avoid mechanical damage. 2. 请不要对 TVS 施加剧烈的振动、冲击或压力,以免表面树脂或元件破裂。 Please do not apply severe vibration, shock or pressure to TVS, to avoid surface resin or element cracking. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 15
SMDJ30A 价格&库存
很抱歉,暂时无法提供与“SMDJ30A”相匹配的价格&库存,您可以联系我们找货
