1.5SMC6.8A(CA) - 1.5SMC600A(CA)
SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR
VOLTAGE RANGE: 6.8 - 600 V
POWER: 1500Wa t t s
Features
Glass Passivated Die Construction
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Case Material has UL Flammability
Classification Rating 94V-O
SMC/DO-214AB
B
Mechanical Data
A
Case :DO-214AB(SMC)
Terminals : Solder plated , solderable per
MIL-STD-750, method 2026
Marking: Date Code and Marking Code
See Page 2
Weight: 0.21 grams (approximate)
C
D
J
H
G
E
Dim
Min
Max
A
5.59
6.22
B
6.60
7.11
C
2.75
3.18
D
0.15
0.31
E
7.75
8.13
G
0.10
0.20
H
0.76
1.52
J
2.00
2.62
All Dimensions in mm
Maximum Ratings @ TA = 25°C unless otherwise specified
Characteristic
Symbol
Value
Unit
PPK
1500
W
IFSM
200
A
Peak Pulse Power Dissipation
(Non repetitive current pulse derated above TA = 25°C) (Note 1)
Peak Forward Surge Current, 8.3ms Single Half Sine Wave
Superimposed on Rated Load (JEDEC Method) (Notes 1, 2, & 3)
Steady State Power Dissipation @ TL = 75°C
PM(AV)
5.0
W
Instantaneous Forward Voltage @ IPP = 100A
(Notes 1 & 3)
VF
See Note 5
V
Operating Temperature Range
Tj
-55 to +150
°C
TSTG
-55 to +175
°C
Storage Temperature Range
NOTES:1. Non-repetitive current pulse ,per Fig. 3 and derated above TA=25℃ per Fig. 1.
2. Thermal Resistance junction to Lead.
3. 8.3ms single half-wave duty cycle=4 pulses per minutes maximum (uni-directional units only).
1 of 4
www.sunmate.tw
Reverse Breakdown Breakdown
Voltage
Voltage
Stand-Off
Voltage
Min. @IT
Max. @ IT
TYPE
(UNI)
1.5SMC6.8
1.5SMC6.8A
1.5SMC7.5
1.5SMC7.5A
1.5SMC8.2
1.5SMC8.2A
1.5SMC9.1
1.5SMC9.1A
1.5SMC10
1.5SMC10A
1.5SMC11
1.5SMC11A
1.5SMC12
1.5SMC12A
1.5SMC13
1.5SMC13A
1.5SMC15
1.5SMC15A
1.5SMC16
1.5SMC16A
1.5SMC18
1.5SMC18A
1.5SMC20
1.5SMC20A
1.5SMC22
1.5SMC22A
1.5SMC24
1.5SMC24A
1.5SMC27
1.5SMC27A
1.5SMC30
1.5SMC30A
1.5SMC33
1.5SMC33A
1.5SMC36
1.5SMC36A
1.5SMC39
1.5SMC39A
1.5SMC43
1.5SMC43A
1.5SMC47
1.5SMC47A
1.5SMC51
1.5SMC51A
1.5SMC56
1.5SMC56A
(BI)
1.5SMC6.8C
1.5SMC6.8CA
1.5SMC7.5C
1.5SMC7.5CA
1.5SMC8.2C
1.5SMC8.2CA
1.5SMC9.1C
1.5SMC9.1CA
1.5SMC10C
1.5SMC10CA
1.5SMC11C
1.5SMC11CA
1.5SMC12C
1.5SMC12CA
1.5SMC13C
1.5SMC13CA
1.5SMC15C
1.5SMC15CA
1.5SMC16C
1.5SMC16CA
1.5SMC18C
1.5SMC18CA
1.5SMC20C
1.5SMC20CA
1.5SMC22C
1.5SMC22CA
1.5SMC24C
1.5SMC24CA
1.5SMC27C
1.5SMC27CA
1.5SMC30C
1.5SMC30CA
1.5SMC33C
1.5SMC33CA
1.5SMC36C
1.5SMC36CA
1.5SMC39C
1.5SMC39CA
1.5SMC43C
1.5SMC43CA
1.5SMC47C
1.5SMC47CA
1.5SMC51C
1.5SMC51CA
1.5SMC56C
1.5SMC56CA
VRWM (V)
5.50
5.80
6.05
6.40
6.63
7.02
7.37
7.78
8.10
8.55
8.92
9.40
9.72
10.2
10.5
11.1
12.1
12.8
12.9
13.6
14.5
15.3
16.2
17.1
17.8
18.8
19.4
20.5
21.8
23.1
24.3
25.6
26.8
28.2
29.1
30.8
31.6
33.3
34.8
36.8
38.1
40.2
41.3
43.6
45.4
47.8
VBR MIN(V)
6.12
6.45
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.5
10.8
11.4
11.7
12.4
13.5
14.3
14.4
15.2
16.2
17.1
18.0
19.0
19.8
20.9
21.6
22.8
24.3
25.7
27.0
28.5
29.7
31.4
32.4
34.2
35.1
37.1
38.7
40.9
42.3
44.7
45.9
48.5
50.4
53.2
2 of 4
VBR MAX(V)
7.48
7.14
8.25
7.88
9.02
8.61
10.0
9.55
11.0
10.5
12.1
11.6
13.2
12.6
14.3
13.7
16.5
15.8
17.6
16.8
19.8
18.9
22.0
21.0
24.2
23.1
26.4
25.2
29.7
28.4
33.0
31.5
36.3
34.7
39.6
37.8
42.9
41.0
47.3
45.2
51.7
49.4
56.1
53.6
61.6
58.8
Test
Current
IT (mA)
10
10
10
10
10
10
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
Maximum
Clamping
Voltage
@IPP
VC(V)
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.2
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
73.5
70.1
80.5
77.0
Peak
Pulse
Current
Reverse
Leakage
@VRWM
IPP(A)
140.7
144.8
129.9
134.5
121.6
125.6
110.1
113.4
101.3
104.8
93.8
97.4
87.9
91.0
80.0
83.5
69.1
71.7
64.7
67.6
57.4
60.3
52.2
54.9
47.6
49.7
43.8
45.8
38.9
40.5
34.9
36.7
31.9
33.3
29.2
30.5
27.0
28.2
24.6
25.6
22.4
23.5
20.7
21.7
18.9
19.7
IR(uA)
1000.0
1000.0
500.0
500.0
200.0
200.0
50.0
50.0
10.0
10.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
www.sunmate.tw
Reverse
Stand-Off
Voltage
TYPE
Breakdown Breakdown
Test
Voltage
Voltage
Current
Min. @IT
Max. @ I
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
VC(V)
IPP(A)
IR(uA)
(BI)
VRWM (V)
1.5SMC62
1.5SMC62C
50.2
55.8
68.2
1.0
89.0
17.1
5.0
1.5SMC62A
1.5SMC68
1.5SMC62CA
1.5SMC68C
53.0
55.1
58.9
61.2
65.1
74.8
1.0
1.0
85.0
98.0
17.9
13.5
5.0
5.0
1.5SMC68A
1.5SMC75
1.5SMC68CA
1.5SMC75C
58.1
60.7
64.6
67.5
71.4
82.5
1.0
1.0
92.0
108
16.5
14.1
5.0
5.0
1.5SMC75A
1.5SMC75CA
64.1
71.3
78.8
1.0
103
14.8
5.0
1.5SMC82
1.5SMC82C
66.4
73.8
90.2
1.0
118
12.9
5.0
1.5SMC82A
1.5SMC82CA
70.1
77.9
86.1
1.0
113
13.5
5.0
1.5SMC91
1.5SMC91A
1.5SMC100
1.5SMC100A
1.5SMC110
1.5SMC110A
1.5SMC91C
1.5SMC91CA
1.5SMC100C
1.5SMC100CA
1.5SMC110C
1.5SMC110CA
73.7
77.8
81.0
85.5
89.2
94.0
81.9
86.5
90.0
95.0
99.0
105
100
95.5
110
105
121
116
1.0
1.0
1.0
1.0
1.0
1.0
131
125
144
137
158
152
11.6
12.2
10.6
11.1
9.6
10.0
5.0
5.0
5.0
5.0
5.0
5.0
1.5SMC120
1.5SMC120A
1.5SMC130
1.5SMC130A
1.5SMC150
1.5SMC150A
1.5SMC160
1.5SMC160A
1.5SMC170
1.5SMC170A
1.5SMC180
1.5SMC180A
1.5SMC200
1.5SMC200A
1.5SMC220
1.5SMC220A
1.5SMC250
1.5SMC250A
1.5SMC300
1.5SMC300A
1.5SMC350
1.5SMC350A
1.5SMC400
1.5SMC400A
1.5SMC440
1.5SMC440A
1.5SMC480A
1.5SMC510A
1.5SMC530A
1.5SMC540A
1.5SMC550A
1.5SMC600A
1.5SMC120C
1.5SMC120CA
1.5SMC130C
1.5SMC130CA
1.5SMC150C
1.5SMC150CA
1.5SMC160C
1.5SMC160CA
1.5SMC170C
1.5SMC170CA
1.5SMC180C
1.5SMC180CA
1.5SMC200C
1.5SMC200CA
1.5SMC220C
1.5SMC220CA
1.5SMC250C
1.5SMC250CA
1.5SMC300C
1.5SMC300CA
1.5SMC350C
1.5SMC350CA
1.5SMC400C
1.5SMC400CA
1.5SMC440C
1.5SMC440CA
1.5SMC480CA
1.5SMC510CA
1.5SMC530CA
1.5SMC540CA
1.5SMC550CA
1.5SMC600CA
97.2
102
105
111
121
128
130
136
138
145
146
154
162
171
175
185
202
214
243
256
284
300
324
342
356
376
408
434
450
459
467
509
108
114
117
124
135
143
144
152
153
162
162
171
180
190
198
209
225
237
270
285
315
333
360
380
396
418
456
485
503
513
522
570
132
126
143
137
165
158
176
168
187
179
198
189
220
210
242
231
275
263
330
315
385
368
440
420
484
462
504
535
556
567
577
630
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
173
165
187
179
215
207
230
219
244
234
258
246
287
274
344
328
360
344
430
414
504
482
574
548
631
600
658
698
725
740
760
820
8.7
9.2
8.1
8.5
7.1
7.3
6.6
6.9
6.2
6.5
5.9
6.2
5.3
5.5
4.4
4.6
4.2
4.4
3.5
3.7
3.0
3.2
2.6
2.8
2.4
2.5
2.30
2.10
2.10
2.00
2.00
1.80
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
1.0
(UNI)
VBR MIN(V)
3 of 4
VBR MAX(V)
T
(mA)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
www.sunmate.tw
Ratings and Characteristic Curves TA=25°C unless otherwise noted
4 of 4
www.sunmate.tw
很抱歉,暂时无法提供与“1.5SMC540A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.18764
- 50+1.72225
- 150+1.52279
- 500+1.25316
- 2500+1.14235
- 5000+1.07577
