SMDJ22A
SMDJ22A
    JINGYANG(晶扬电子)
    SMC(DO-214AB)
    VRWM22(V)/VBR(Min)@IT24.4(V)/VBR(Max)@IT26.9(V)/IT1(mA)/IR1(uA)/VC(Max)35.5(V)/Ipp(Max)84.5(A)
SMDJ22A 数据手册
TITAN MICRO SMDJ Series Surface Mount Transient Voltage Suppressor Rectifiers Reverse Voltage 5.0 ~ 440 V 3000 Watt Peak Pulse Power DO214AB/(SMC) Features ● Glass passivated chip ● 3000 W peak pulse power capability with a 10/1000 us waveform, repetitive rate (duty cycle):0.01 % ● Excellent clamping capability ● Low reverse leakage ● Very fast response time ● Lead and body according with RoHS standard Mechanical Data ● Case: DO214AB/(SMC) Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end except Bipolar Unit: inch (mm) ● Mounting position: Any Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. specified Symbols Value Unit Peak power dissipation with a 10/1000 us waveform(1) PPP 3000 W Peak pulse current wih a 10/1000 us waveform(1) IPP See Next Table A Power dissipation on infinite heatsink at TL = 75 °C C PD 65 6.5 W IFSM 300 A VF 3.5/6.5 V TJ,TSTG -55 to +150 ℃ Parameter Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 100 A for unidirectional only(3) Operating junction and storage temperature range Note: 1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3)VF
SMDJ22A 价格&库存
很抱歉,暂时无法提供与“SMDJ22A”相匹配的价格&库存,您可以联系我们找货
