Transient Voltage Suppression Diodes
SMCJ Series
Trustworthy electronic circuit protection expert
SMCJ Transient Voltage Suppressor Diode Series
General Information
The SMC series is designed to protect voltage sensitive components from high
voltage, high energy transients. They have excellent clamping capability, high surge
capability, low zener impedance and fast response time. The SMC series is supplied
in YINT Semiconductor’s exclusive, cost-effective, highly reliable and is ideally
suited for use in communication systems, automotive, numerical controls, process
controls, medical equipment, business machines, power supplies and many other
Molded plastic
industrial/consumer Applications.
glass passivated junction.
Features
Applications
●Case: DO-214AB/SMC
TVS
●For surface mounted applications in order to optimize board space.
protection of I/O Interfaces, VCC bus
●Polarity: Color band denoted positive end (cathode) except Bidirectional.
and other vulnerable circuits used in
●Typical failure mode is short from over-specified voltage or current
Telecom,
●High Temperature soldering:260°C/10 seconds at terminals.
Consumer electronic applications.
devices
are
ideal
for
Computer, Industrial
the
and
●Terminal: Solder plated, solderable per MIL-STD-750, Method 2026.
Electrical Characteristics (@ TA = 25°C Unless Otherwise Noted)
Parameter
Minimum Peak Pulse Power Dissipation (T = 1 ms) (note1 note 2)
Symbol
Value
Unit
PPK
1500
Watts
IFSM
200
Amps
PM(AV)
6.5
Watts
VF
3.5/5
Volts
TJ
-55 to +150
°C
TSTG
-55 to +175
°C
Peak Forward Surge Current
8.3 ms Single Half Sine Wave Superimposed on Rated Load
(JEDEC Method) (Note 3)
Steady State Power Dissipation @ TL = 75 °C
Maximum Instantaneous Forward Voltage @ I PP = 50 A
(For Unidirectional Units Only)(note4 note 5)
Operating Temperature Range
Storage Temperature Range
NOTES:
1. Non-repetitive current pulse, per Pulse Waveform graph and derated above TA = 25 °C per Pulse Derating Curve.
2. Thermal Resistance Junction to Lead.
3. 8.3 ms Single Half-Sine Wave duty cycle = 4 pulses maximum per minute (unidirectional units only).
4. Single Phase, Half Wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20 %.
5. VF
很抱歉,暂时无法提供与“SMCJ36CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.10528
- 50+0.86033
- 150+0.75536
- 500+0.62435
