SMCJ5.0CA
SMCJ5.0CA
    PAKER(派克微)
    SMC(DO-214AB)
SMCJ5.0CA 数据手册
SMCJ Series 1500W Surface Mount Transinet Voltage Suppression Features SMC Peak power disspation 1500W@10 x 1000 us Pluse Low incremental surge resistance Excellent clamping capability Glass passivated junction Fast response time Low leakage current Halogen free and RoHS compliant Mechanical Data CASE: SMCJ(DO-214AB) Molded Plastic Polarity: By cathode band denites uni-directional decice, none cathode band denotes bi-directional device Mounting Position:Any Symbol Making Code & information Package SMCJ XXX A Packing Description Packing Quantity Tape/Reel,13" reel 3000 SMC SMCJ XXX C A SMCJ 5% VBR Voltage Tolerance XXX CA Bidirectional VRWM Voltage Series Code Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Symbol Value Units Remarks PPPM 1500 W (Note1)(Note2) Steady State Power Dissipation PD 6.5 W (Note3) Peak Forward Surge Current IFSM 200 A (Note4) Maximum Instantaneous Forward Voltage at 100A VFM 3.5/5 V (Note5) Typical Thermal Resistance Junction to Lead RθJL 15 ℃/W Typical Thermal Resistance Junction to Ambient RθJA 75 ℃/W TJ -55 to 150 ℃ TSTG -55 to 150 ℃ Peak Pulse Power Dissipation Operating Temperature Range Storage Temperature Range Notes1: Non-repetitive current pulse , 10/1000us Waveform. Notes2: Mounted on copper pad area of 8×8mm to each terminal. Notes3: Infinite HeatSink at T A=50°C Notes4: Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 perminute maximum. Notes5: For UnidirectionalOnly, VFM
SMCJ5.0CA 价格&库存
很抱歉,暂时无法提供与“SMCJ5.0CA”相匹配的价格&库存,您可以联系我们找货
