SMCJ36A
SMCJ36A
    BLUEROCKET(蓝箭电子)
    SMC(DO-214AB)
    单向TVS 36V截止 峰值浪涌电流:25.9A
SMCJ36A 数据手册
SMCJ Series Rev. B Feb.-2021 DATA SHEET 描述 / Descriptions 表面贴装瞬态电压抑制器,10/1000μs 波形下峰值脉冲功率为:1500W,反向电压:5.0V~440V,SMC 封装。 Surface mount transient voltage suppressor,1500W peak pulse power capability at 10/1000μs waveform,Reverse Stand-Off Voltage:5.0V~440V,SMC package. 特征 / Features 玻璃钝化,低电感,适用表面贴装,无卤产品。 Glass passivated junction, Low inductance, For surface mounted applications, HF product. 用途 / Applications 一般用途. General purpose. 内部等效电路 / Equivalent Circuit 引脚排列 / Pinning 印章代码 / Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/9 SMCJ Series Rev. B Feb.-2021 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Peak Pulse Power Dissipation on 10/1000 us waveform PPPM 1500 W Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load (JEDEC Method) IFSM (UNI) 200 A Power dissipation on Infinite heat sink at TA=50 °C PD 6.5 W Maximum instantaneous forward voltage at 100 A for unidirectional only VF 3.5 V RθJL 75 15 ℃/W Tj, Tstg -55 ~ +150 ℃ RθJA Typical Thermal Resistance Junction to Ambient(Note 1) Operating Junction and Storage Temperature Range Note: 1. Mounted on 8 mm2 (0.13mm thick) land areas. http://www.fsbrec.com 2/9 SMCJ Series Rev. B Feb.-2021 DATA SHEET 电性能参数 / Electrical Characteristics(Ta=25℃) Reverse Stand-off Voltage Type Breakdown Voltage Test Current Maximum Reverse Leakage Max. Clamp Voltage Peak Pulse Current Package IT IR @ VRRM VC @ IPP IPP SMC Device Marking Ccode VBR @ IT VRRM Min Max UNI BI V V V mA uA V A UNI BI SMCJ5.0A SMCJ5.0CA 5 6.4 7 10 800 9.2 163 GDE BDE SMCJ6.0A SMCJ6.0CA 6 6.67 7.37 10 800 10.3 145.7 GDG BDG SMCJ6.5A SMCJ6.5CA 6.5 7.22 7.98 10 500 11.2 134 GDK BDK SMCJ7.0A SMCJ7.0CA 7 7.78 8.6 10 200 12.0 125 GDM BDM SMCJ7.5A SMCJ7.5CA 7.5 8.33 9.21 1 100 12.9 116.3 GDP BDP SMCJ8.0A SMCJ8.0CA 8 8.89 9.83 1 50 13.6 110.3 GDR BDR SMCJ8.5A SMCJ8.5CA 8.5 9.44 10.4 1 20 14.4 104.2 GDT BDT SMCJ9.0A SMCJ9.0CA 9 10 11.1 1 10 15.4 97.4 GDV BDV SMCJ10A SMCJ10CA 10 11.1 12.3 1 5 17.0 88.3 GDX BDX SMCJ11A SMCJ11CA 11 12.2 13.5 1 1 18.2 82.5 GDZ BDZ SMCJ12A SMCJ12CA 12 13.3 14.7 1 1 19.9 75.4 GEE BEE SMCJ13A SMCJ13CA 13 14.4 15.9 1 1 21.5 69.8 GEG BEG SMCJ14A SMCJ14CA 14 15.6 17.2 1 1 23.2 64.7 GEK BEK SMCJ15A SMCJ15CA 15 16.7 18.5 1 1 24.4 61.5 GEM BEM SMCJ16A SMCJ16CA 16 17.8 19.7 1 1 26.0 57.7 GEP BEP SMCJ17A SMCJ17CA 17 18.9 20.9 1 1 27.6 54.4 GER BER SMCJ18A SMCJ18CA 18 20 22.1 1 1 29.2 51.4 GET BET SMCJ20A SMCJ20CA 20 22.2 24.5 1 1 32.4 46.3 GEV BEV SMCJ22A SMCJ22CA 22 24.4 26.9 1 1 35.5 42.3 GEX BEX SMCJ24A SMCJ24CA 24 26.7 29.5 1 1 38.9 38.6 GEZ BEZ SMCJ26A SMCJ26CA 26 28.9 31.9 1 1 42.1 35.7 GFE BFE SMCJ28A SMCJ28CA 28 31.1 34.4 1 1 45.4 33.1 GFG BFG SMCJ30A SMCJ30CA 30 33.3 36.8 1 1 48.4 31 GFK BFK SMCJ33A SMCJ33CA 33 36.7 40.6 1 1 53.3 28.2 GFM BFM SMCJ36A SMCJ36CA 36 40 44.2 1 1 58.1 25.9 GFP BFP SMCJ40A SMCJ40CA 40 44.4 49.1 1 1 64.5 23.3 GFR BFR SMCJ43A SMCJ43CA 43 47.8 52.8 1 1 69.4 21.7 GFT BFT http://www.fsbrec.com 3/9 SMCJ Series Rev. B Feb.-2021 DATA SHEET 电性能参数 / Electrical Characteristics(Ta=25℃) Reverse Stand-off Voltage Type Breakdown Voltage Test Current Reverse Leakage Max. Clamp Voltage Peak Pulse Current IT IR @ VRRM VC @ IPP IPP VBR @ IT VRRM Min Max Package SMA Device Marking Ccode UNI BI UNI BI V V V mA uA V A SMCJ45A SMCJ45CA 45 50 55.3 1 1 72.7 20.6 GFV BFV SMCJ48A SMCJ48CA 48 53.3 58.9 1 1 77.4 19.4 GFX BFX SMCJ51A SMCJ51CA 51 56.7 62.7 1 1 82.4 18.2 GFZ BFZ SMCJ54A SMCJ54CA 54 60 66.3 1 1 87.1 17.3 GGE BGE SMCJ58A SMCJ58CA 58 64.4 71.2 1 1 93.6 16.1 GGG BGG SMCJ60A SMCJ60CA 60 66.7 73.7 1 1 96.8 15.5 GGK BGK SMCJ64A SMCJ64CA 64 71.1 78.6 1 1 103.0 14.6 GGM BGM SMCJ70A SMCJ70CA 70 77.8 86 1 1 113.0 13.3 GGP BGP SMCJ75A SMCJ75CA 75 83.3 92.1 1 1 121.0 12.4 GGR BGR SMCJ78A SMCJ78CA 78 86.7 95.8 1 1 126.0 11.9 GGT BGT SMCJ85A SMCJ85CA 85 94.4 104 1 1 137.0 11 GGV BGV SMCJ90A SMCJ90CA 90 100 111 1 1 146.0 10.3 GGX BGX SMCJ100A SMCJ100CA 100 111 123 1 1 162.0 9.3 GGZ BGZ SMCJ110A SMCJ110CA 110 122 135 1 1 177.0 8.5 GHE BHE SMCJ120A SMCJ120CA 120 133 147 1 1 193.0 7.8 GHG BHG SMCJ130A SMCJ130CA 130 144 159 1 1 209.0 7.2 GHK BHK SMCJ150A SMCJ150CA 150 167 185 1 1 243.0 6.2 GHM BHM SMCJ160A SMCJ160CA 160 178 197 1 1 259.0 5.8 GHP BHP SMCJ170A SMCJ170CA 170 189 209 1 1 275.0 5.5 GHR BHR SMCJ180A SMCJ180CA 180 201 222 1 1 292.0 5.1 GHT BHT SMCJ200A SMCJ200CA 200 224 247 1 1 324.0 4.6 GHV BHV SMCJ220A SMCJ220CA 220 246 272 1 1 356.0 4.2 GHX BHX SMCJ250A SMCJ250CA 250 279 309 1 1 405.0 3.7 GHZ BHZ SMCJ300A SMCJ300CA 300 335 371 1 1 486.0 3.1 GJE BJE SMCJ350A SMCJ300CA 350 391 432 1 1 567.0 2.6 GJG BJG SMCJ400A SMCJ350CA 400 447 494 1 1 648.0 2.3 GJK BJK SMCJ440A SMCJ400CA 440 492 543 1 1 713.0 2.1 GJM BJM http://www.fsbrec.com 4/9 SMCJ Series Rev. B Feb.-2021 DATA SHEET 电参数曲线图 / Electrical Characteristic Curve http://www.fsbrec.com 5/9 SMCJ Series Rev. B Feb.-2021 DATA SHEET 外形尺寸图 / Package Dimensions http://www.fsbrec.com 6/9 SMCJ Series Rev. B Feb.-2021 DATA SHEET 印章说明 / Marking Instructions GDE **** 说明: GDE : **** : 为型号代码 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码 Note: GDE : Product Type Code ****: Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No Code http://www.fsbrec.com 7/9 SMCJ Series Rev. B Feb.-2021 DATA SHEET 印章说明 / Marking Instructions BDE **** 说明: BDE : 为型号代码 **** : 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码 Note: BDE : Product Type Code ****: Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No Code http://www.fsbrec.com 8/9 SMCJ Series Rev. B Feb.-2021 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 150~180℃,时间 60~90sec; 1.Preheating:150~180℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 时间:10±1 sec. Temp.:260±5℃ Time:10±1 sec 包装规格 / Packaging SPEC. 卷盘包装 / REEL Package Type 封装形式 SMC Dimension 包装尺寸 (unit:mm3) Units 包装数量 Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Reel Inner Box 盒 Outer Box 箱 3000 2 6000 6 36000 13〞×16 337X337X49 380X335X366 使用说明 / Notices http://www.fsbrec.com 9/9
