SMCJ Series
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low zener impedance
Excellent clamping capability
1500W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle):0.01%
Fast response time
Typical IR less than 1μA above 11V.
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020.
Mechanical Data
Case: JEDEC DO-214ABMoulded plastic
Terminal:solderplated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
Minimum
1500
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
IFSM
200
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
15
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Steady state power dissipation at TL=75℃ (Fig.4)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:10-May-18
1/6
www.ftrqg.com
SMCJ Series
Dimensions (DO-214AB/SMC)
Millimeters
Inches
Symbol
D1 D
L
H
d
T1
T
Min.
Max.
Min.
Max.
L
6.60
7.71
0.260
0.280
D
5.59
6.22
0.220
0.245
D1
2.9
3.20
0.114
0.126
T
7.75
8.13
0.305
0.320
T1
0.76
1.52
0.030
0.060
d
0.20
0.008
H
2.06
2.62
0.079
0.103
Electrical Characteristics (TA=25℃)
Part Number
Unidirectional
Bidirectional
Device
Marking
Code
Reverse
Stand-O
ff
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage@
IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMCJ5.0A
SMCJ5.0CA
GDE
BDE
5.0
6.4~7.0
10
9.2
163.0
800
SMCJ6.0A
SMCJ6.0CA
GDG
BDG
6.0
6.7~7.4
10
10.3
145.6
800
SMCJ6.5A
SMCJ6.5CA
GDK
BDK
6.5
7.2~8.0
10
11.2
133.9
500
SMCJ7.0A
SMCJ7.0CA
GDM
BDM
7.0
7.8~8.6
10
12.0
125.0
200
SMCJ7.5A
SMCJ7.5CA
GDP
BDP
7.5
8.3~9.2
1
12.9
116.3
100
SMCJ8.0A
SMCJ8.0CA
GDR
BDR
8.0
8.9~9.8
1
13.6
110.3
50
SMCJ8.5A
SMCJ8.5CA
GDT
BDT
8.5
9.4~10.4
1
14.4
104.2
SMCJ9.0A
SMCJ9.0CA
GDV
BDV
9.0
10.0~11.0
1
15.4
97.4
10
SMCJ10A
SMCJ10CA
GDX
BDX
10.0
11.1~12.3
1
17.0
88.3
5
SMCJ11A
SMCJ11CA
GDZ
BDZ
11.0
12.2~13.5
1
18.2
82.4
1
SMCJ12A
SMCJ12CA
GEE
BEE
12.0
13.3~14.7
1
19.9
75.4
1
SMCJ13A
SMCJ13CA
GEG
BEG
13.0
14.4~15.9
1
21.5
69.8
1
SMCJ14A
SMCJ14CA
GEK
BEK
14.0
15.6~17.2
1
23.2
64.7
1
SMCJ15A
SMCJ15CA
GEM
BEM
15.0
16.7~18.5
1
24.4
61.5
1
SMCJ16A
SMCJ16CA
GEP
BEP
16.0
17.8~19.7
1
26.0
57.7
1
SMCJ17A
SMCJ17CA
GER
BER
17.0
18.9~20.9
1
27.6
54.4
1
SMCJ18A
SMCJ18CA
GET
BET
18.0
20.0~22.1
1
29.2
51.4
1
SMCJ19A
SMCJ19CA
GEW
BEW
19.0
21.1~23.3
1
30.8
48.7
1
SMCJ20A
SMCJ20CA
GEV
BEV
20.0
22.2~24.5
1
32.4
46.3
1
SMCJ22A
SMCJ22CA
GEX
BEX
22.0
24.4~26.9
1
35.5
42.3
1
SMCJ24A
SMCJ24CA
GEZ
BEZ
24.0
26.7~29.5
1
38.9
38.6
1
SMCJ26A
SMCJ26CA
GFE
BFE
26.0
28.9~31.9
1
42.1
35.6
1
Revision:10-May-18
2/6
www.ftrqg.com
SMCJ Series
Part Number
Unidirectional
Bidirectional
Device
Marking
Code
Reverse
Stand-O
ff
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage@
IPP
Peak
Pulse
Current
Reverse
Leakage
@ VRWM
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMCJ28A
SMCJ28CA
GFG
BFG
28.0
31.1~34.4
1
45.4
33.1
1
SMCJ30A
SMCJ30CA
GFK
BFK
30.0
33.3~36.8
1
48.4
31.0
1
SMCJ33A
SMCJ33CA
GFM
BFM
33.0
36.7~40.6
1
53.3
28.1
1
SMCJ36A
SMCJ36CA
GFP
BFP
36.0
40.0~44.2
1
58.1
25.8
1
SMCJ40A
SMCJ40CA
GFR
BFR
40.0
44.4~49.1
1
64.5
23.3
1
SMCJ43A
SMCJ43CA
GFT
BFT
43.0
47.8~52.8
1
69.4
21.6
1
SMCJ45A
SMCJ45CA
GFV
BFV
45.0
50.0~55.3
1
72.7
20.6
1
SMCJ48A
SMCJ48CA
GFX
BFX
48.0
53.3~58.9
1
77.4
19.4
1
SMCJ51A
SMCJ51CA
GFZ
BFZ
51.0
56.7~62.7
1
82.4
18.2
1
SMCJ54A
SMCJ54CA
GGE
BGE
54.0
60.0~66.3
1
87.1
17.2
1
SMCJ58A
SMCJ58CA
GGG
BGG
58.0
64.4~71.2
1
93.6
16.0
1
SMCJ60A
SMCJ60CA
GGK
BGK
60.0
66.7~73.7
1
96.8
15.5
1
SMCJ64A
SMCJ64CA
GGM
BGM
64.0
71.1~78.6
1
103.0
14.6
1
SMCJ70A
SMCJ70CA
GGP
BGP
70.0
77.8~86.0
1
113.0
13.3
1
SMCJ75A
SMCJ75CA
GGR
BGR
75.0
83.3~92.1
1
121.0
12.4
1
SMCJ78A
SMCJ78CA
GGT
BGT
78.0
86.7~95.8
1
126.0
11.9
1
SMCJ80A
SMCJ80CA
GGW
BGW
80.0
88.8~97.6
1
129.6
11.6
1
SMCJ85A
SMCJ85CA
GGV
BGV
85.0
94.4~104
1
137.0
11.0
1
SMCJ90A
SMCJ90CA
GGX
BGX
90.0
100~111
1
146.0
10.3
1
SMCJ100A
SMCJ100CA
GGZ
BGZ
100.0
111~123
1
162.0
9.3
1
SMCJ110A
SMCJ110CA
GHE
BHE
110.0
122~135
1
177.0
8.5
1
SMCJ120A
SMCJ120CA
GHG
BHG
120.0
133~147
1
193.0
7.8
1
SMCJ130A
SMCJ130CA
GHK
BHK
130.0
144~159
1
209.0
7.2
1
SMCJ140A
SMCJ140CA
GHL
BHL
140.0
155~171
1
227.0
6.6
1
SMCJ150A
SMCJ150CA
GHM
BHM
150.0
167~185
1
243.0
6.2
1
SMCJ160A
SMCJ160CA
GHP
BHP
160.0
178~197
1
259.0
5.8
1
SMCJ170A
SMCJ170CA
GHR
BHR
170.0
189~209
1
275.0
5.5
1
SMCJ180A
SMCJ180CA
GHT
BHT
180.0
200~220
1
291.0
5.1
1
SMCJ190A
SMCJ190CA
GHW
BHW
190.0
211~232
1
308.0
4.9
1
SMCJ200A
SMCJ200CA
GHV
BHV
200.0
224~247
1
324.0
4.6
1
SMCJ220A
SMCJ220CA
GHX
BHX
220.0
246~272
1
356.0
4.2
1
SMCJ250A
SMCJ250CA
GHZ
BHZ
250.0
279~309
1
405.0
3.7
1
SMCJ300A
SMCJ300CA
GJE
BJE
300.0
335~371
1
486.0
3.1
1
SMCJ350A
SMCJ350CA
GJG
BJG
350.0
391~432
1
567.0
2.6
1
SMCJ400A
SMCJ400CA
GJK
BJK
400.0
447~494
1
648.0
2.3
1
SMCJ440A
SMCJ440CA
GJM
BJM
440.0
492~543
1
713.0
2.1
1
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
Revision:10-May-18
3/6
www.ftrqg.com
SMCJ Series
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TLto TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
150℃
200℃
60-180 seconds
TS maxto TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual PeakTemperature (tP)
20-40 seconds
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
Revision:10-May-18
8 minutes max.
4/6
www.ftrqg.com
SMCJ Series
Partnumber code
SMCJ 18 CA
FTR XXXX
XXX
Bidirectional
(A:Uni-directional)
VRWM Voltage
FTR logo
Series Code
Date Code
Marking Code
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 3. Pulse Waveform
Revision:10-May-18
Figure 2. Pulse Derating Curve
Figure 4. Steady State Power Dissipation Derating
Curve
5/6
www.ftrqg.com
SMCJ Series
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
D1
A
A
K0
B
SECTION B-B
A0
SECTION A-A
Reel
Symbol
Dimension (mm)
W
16.00±0.10
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
E
1.75±0.10
F
7.50±0.10
A0
6.05±0.1
B0
8.31±0.1
K0
2.54±0.1
T
0.25±0.1
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
20.0±2.0
Quantity: 3000PCS
Revision:10-May-18
6/6
www.ftrqg.com
很抱歉,暂时无法提供与“SMCJ60CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.98151
- 50+0.79780
- 150+0.70589
- 500+0.63699
- 3000+0.54108
- 6000+0.51354
