ASMCJ24CA
ASMCJ24CA
    PTTC(聚鼎)
    SMC(DO-214AB)
    双向TVS 24V截止 峰值脉冲电流:38.6A
ASMCJ24CA 数据手册
T VS Diode – ASMCJ Series Features           Plastic package, excellent insulation strength. Glass passivated chip junction in SMC package. Excellent voltage clamping capability. Automotive grade AEC–Q101 qualified. Low Zener impedance. 1500W peak pulse power capability on 10/1000s waveform. Typical leakage current less than 1A above 13V. Very fast response time, typically less than 1.0ps from 0 volt to VBR minimum. High temperature soldering guaranteed: 265°C/10 sec. MSL: JEDEC-J-STD-020, Level 1 Applications     I/O interface, VCC bus Telecom / Automotive Industrial and consumer electronic applications. Relay and electromagnetic valve surge absorption. Agency Approval  UL certification pending Mechanical and Physical Data   Case: JEDEC SMC molded plastic. Axial leaded, solderable per MIL-STD-750, Method 2026  Polarity: Color band denoted cathode except bidirectional. Maximum Ratings and Thermal Characteristics Parameter Symbol Value Unit PPPM Min 1500 Watt Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1). Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3). IPPM See Table Amp PM(AV) 6.5 Watt IFSM 200 Amp TJ, TSTG -55~150 °C Steady State Power Dissipation at TL = 75°C, Lead lengths 0.375”, (9.5mm) (Fig.5). Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (Note 2, Fig.6). Operating Junction and Storage Temperature Range. Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2. 2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Part Number Code ASMCJ □□□ C A - □□□ Packaging Code (T13: Tape with 13” Reel; T7: Tape with 7”) VBR Voltage tolerance (A: 5%; Blank: 10%) C: Bi-directional; Blank: Uni-directional Reverse Stand-Off Voltage or Typical Breakdown Voltage Automotive ASMCJ Series (1500W) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 6 2016/12/1 Rev: A T VS Diode – ASMCJ Series I-V Curve Characteristics PPPM Peak Pulse Power Dissipation – Maximum power dissipation VR Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (I T) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional Electrical Characteristics Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi ASMCJ10A ASMCJ10CA GDXA BDXA 10.0 11.1 12.3 17.0 88.3 5 Pending ASMCJ11A ASMCJ11CA GDZA BDZA 11.0 12.2 13.5 1 18.2 82.5 1 Pending ASMCJ12A ASMCJ12CA GEEA BEEA 12.0 13.3 14.7 1 19.9 75.4 1 Pending ASMCJ13A ASMCJ13CA GEGA BEGA 13.0 14.4 15.9 1 21.5 69.8 1 Pending ASMCJ14A ASMCJ14CA GEKA BEKA 14.0 15.6 17.2 1 23.2 64.7 1 Pending ASMCJ15A ASMCJ15CA GEMA BEMA 15.0 16.7 18.5 1 24.4 61.5 1 Pending ASMCJ16A ASMCJ16CA GEPA BEPA 16.0 17.8 19.7 1 26.0 57.7 1 Pending ASMCJ17A ASMCJ17CA GERA BERA 17.0 18.9 20.9 1 27.6 54.4 1 Pending ASMCJ18A ASMCJ18CA GETA BETA 18.0 20.0 22.1 1 29.2 51.4 1 Pending ASMCJ19A ASMCJ19CA GEBA BEBA 19.0 21.1 23.3 1 30.8 48.7 1 Pending ASMCJ20A ASMCJ20CA GEVA BEVA 20.0 22.2 24.5 1 32.4 46.3 1 Pending ASMCJ22A ASMCJ22CA GEXA BEXA 22.0 24.4 26.9 1 35.5 42.3 1 Pending ASMCJ24A ASMCJ24CA GEZA BEZA 24.0 26.7 29.5 1 38.9 38.6 1 Pending ASMCJ26A ASMCJ26CA GFEA BFEA 26.0 28.9 31.9 1 42.1 35.7 1 Pending ASMCJ28A ASMCJ28CA GFGA BFGA 28.0 31.1 34.4 1 45.4 33.1 1 Pending ASMCJ30A ASMCJ30CA GFKA BFKA 30.0 33.3 36.8 1 48.4 31.0 1 Pending ASMCJ33A ASMCJ33CA GFMA BFMA 33.0 36.7 40.6 1 53.3 28.2 1 Pending ASMCJ36A ASMCJ36CA GFPA BFPA 36.0 40.0 44.2 1 58.1 25.9 1 Pending ASMCJ40A ASMCJ40CA GFRA BFRA 40.0 44.4 49.1 1 64.5 23.3 1 Pending 1 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 6 2016/12/1 Rev: A T VS Diode – ASMCJ Series Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi ASMCJ43A ASMCJ43CA GFTA BFTA 43.0 47.8 52.8 1 69.4 21.7 1 Pending ASMCJ45A ASMCJ45CA GFVA BFVA 45.0 50.0 55.3 1 72.7 20.6 1 Pending ASMCJ48A ASMCJ48CA GFXA BFXA 48.0 53.3 58.9 1 77.4 19.4 1 Pending ASMCJ51A ASMCJ51CA GFZA BFZA 51.0 56.7 62.7 1 82.4 18.2 1 Pending ASMCJ54A ASMCJ54CA GGEA BGEA 54.0 60.0 66.3 1 87.1 17.3 1 Pending ASMCJ58A ASMCJ58CA GGGA BGGA 58.0 64.4 71.2 1 93.6 16.1 1 Pending ASMCJ60A ASMCJ60CA GGKA BGKA 60.0 66.7 73.7 1 96.8 15.5 1 Pending ASMCJ64A ASMCJ64CA GGMA BGMA 64.0 71.1 78.6 1 103.0 14.6 1 Pending ASMCJ70A ASMCJ70CA GGPA BGPA 70.0 77.8 86.0 1 113.0 13.3 1 Pending ASMCJ75A ASMCJ75CA GGRA BGRA 75.0 83.3 92.1 1 121.0 12.4 1 Pending ASMCJ78A ASMCJ78CA GGTA BGTA 78.0 86.7 95.8 1 126.0 11.9 1 Pending Note: 1. For bi-directional type having VR of 10 volts and less, the IR limit is double. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 6 2016/12/1 Rev: A T VS Diode – ASMCJ Series Ratings and Characteristic Curves Fig 1 - Peak Pulse Power Rating Curve Fig 2 - Pulse Derating Curve Fig 3 - Pulse Waveform Fig 4 – Typical Junction Capacitance Uni-directional Fig 5 – Steady State Power Dissipation Derating Curve Fig 6 – Maximum Non-Repetitive Forward Surge Current (Uni-directional Only) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 6 2016/12/1 Rev: A T VS Diode – ASMCJ Series Marking Definitions PolyTrans Trade mark Lot No Marking Code Cathode Band (For Uni-directional product only) Physical Dimensions Dimension A B C D E F G H I J K L Millimeters Inches Min Max Min Max 2.90 6.60 5.59 2.20 0.76 7.75 0.15 3.30 2.40 2.40 3.20 7.11 6.22 2.80 1.52 0.20 8.13 0.31 4.20 - 0.114 0.260 0.220 0.087 0.030 0.305 0.006 0.129 0.094 0.094 0.126 0.280 0.245 0.110 0.060 0.008 0.320 0.012 0.165 - Lead Free Reflow Soldering Recommendations Preheat - Temperature Min (Ts_min) - Temperature Max (Ts_max) - Time (Ts_min to Ts_max) - Average Ramp-Up Rate 150ºC 200ºC 60-180 seconds 1~3ºC/second Peak Temperature 260ºC max. Time within 5ºC of actual Peak Temperature (tp) 40 seconds max. Ramp-Down Rate 6 ºC /second max. Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 6 2016/12/1 Rev: A T VS Diode – ASMCJ Series Packaging Information Part Number Packaging Code Component Package Quantity ASMCJ Series ASMCJ Series T13 T7 DO-214AB DO-214AB 3000 500 Packaging Option Tape & Reel – 16mm tape/13” reel Tape & Reel – 16mm tape/7” reel Packaging Specification EIA STD RS-481 EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 6 2016/12/1 Rev: A
ASMCJ24CA 价格&库存
很抱歉,暂时无法提供与“ASMCJ24CA”相匹配的价格&库存,您可以联系我们找货
