Technical Data 11204
Effective November 2020
5-0SMDJ
5000 W Transient voltage suppressor
Applications
Product features
Low profile SMC package
Excellent clamping capability
5000 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 1 μA above 30 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0 flammability
rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Solder plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized.
File No. :E198449 Guide QVGQ2
PIN configuration
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Mobile and wearables
Environmental compliance and general
specifications
HALOGEN
Pb HF
FREE
Ordering part number
5-0SMDJ 11 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
5-0SMDJ
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
6.5
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
5000
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
300
A
Typical thermal resistance junction to lead
R
JL
15
°C/W
Typical thermal resistance junction to ambient
R
JA
75
°C/W
Storage operating junction temperature range
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm
Millimeters
Dimension Minimum
Part marking
Inches
Maximum
Minimum
Maximum
A
5.75
6.25
0.226
0.246
B
6.90
7.40
0.272
0.291
C
2.75
3.25
0.108
0.128
D
0.95
1.52
0.037
0.060
E
7.70
8.20
0.303
0.323
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.15
2.62
0.085
0.103
J
2.40
K
L
Cathode band (Uni-polar only)
Part marking: xxxx = Date code
yyyy- Refer to marking designator
listed in Electrical Characteristics table
0.094
4.20
0.165
3.30
0.130
Packaging information (mm)
Drawing not to scale.
Dimensions
Millimeters
Inches
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel
(EIA-481 compliant)
A0
6.05 ± 0.3
0.238 ± 0.012
B0
8.31 ± 0.3
0.327 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
7.50 ± 0.2
0.295 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.315 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
16.0 ± 0.2
0.630 ± 0.008
W1
19.7 ± 2.0
0.776 ± 0.079
2
www.eaton.com/electronics
5-0SMDJ
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
Marking
Uni
Bi
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @I PP
max (V)
IPP
(A)
5-0SMDJ11A
5-0SMDJ11CA
5PEN
5BEN
11
5
12.2
13.5
10
18.2
275
5-0SMDJ12A
5-0SMDJ12CA
5PEP
5BEP
12
5
13.3
14.7
10
19.9
252
5-0SMDJ13A
5-0SMDJ13CA
5PEQ
5BEQ
13
5
14.4
15.9
10
21.5
233
5-0SMDJ14A
5-0SMDJ14CA
5PER
5BER
14
5
15.6
17.2
10
23.2
216
5-0SMDJ15A
5-0SMDJ15CA
5PES
5BES
15
5
16.7
18.5
1
24.4
205
5-0SMDJ16A
5-0SMDJ16CA
5PET
5BET
16
5
17.8
19.7
1
26
193
5-0SMDJ17A
5-0SMDJ17CA
5PEU
5BEU
17
5
18.9
20.9
1
27.6
181
5-0SMDJ18A
5-0SMDJ18CA
5PEV
5BEV
18
5
1
29.2
172
5-0SMDJ20A
5-0SMDJ20CA
5PEW
5BEW
22.2
24.5
1
32.4
155
5-0SMDJ22A
5-0SMDJ22CA
5PEX
5BEX
22
5
24.4
26.9
1
35.5
141
5-0SMDJ24A
5-0SMDJ24CA
5PEZ
5BEZ
24
5
26.7
29.5
1
38.9
129
5-0SMDJ26A
5-0SMDJ26CA
5PFE
5BFE
26
5
28.9
31.9
1
42.1
119
5-0SMDJ28A
5-0SMDJ28CA
5PFG
5BFG
28
5
31.1
34.4
1
45.4
110
5-0SMDJ30A
5-0SMDJ30CA
5PFK
5BFK
30
5
33.3
36.8
1
48.4
103
5-0SMDJ33A
5-0SMDJ33CA
5PFM
5BFM
33
1
36.7
40.6
1
53.3
93.9
5-0SMDJ36A
5-0SMDJ36CA
5PFP
5BFP
36
1
40
44.2
1
58.1
86.1
5-0SMDJ40A
5-0SMDJ40CA
5PFR
5BFR
40
1
44.4
49.1
1
64.5
77.6
5-0SMDJ43A
5-0SMDJ43CA
5PFT
5BFT
43
1
47.8
52.8
1
69.4
72.1
5-0SMDJ45A
5-0SMDJ45CA
5PFV
5BFV
45
1
50
55.3
1
72.7
68.8
5-0SMDJ48A
5-0SMDJ48CA
5PFX
5BFX
48
1
53.3
58.9
1
77.4
64.7
5-0SMDJ51A
5-0SMDJ51CA
5PFZ
5BFZ
51
1
56.7
62.7
1
82.4
60.7
5-0SMDJ54A
5-0SMDJ54CA
5PGE
5BGE
54
1
60
66.3
1
87.1
57.5
5-0SMDJ58A
5-0SMDJ58CA
5PGG
5BGG
58
1
64.4
71.2
1
93.6
53.5
5-0SMDJ60A
5-0SMDJ60CA
5PGK
5BGK
60
1
66.7
73.7
1
96.8
51.7
5-0SMDJ64A
5-0SMDJ64CA
5PGM
5BGM
64
1
71.1
78.6
1
103
48.6
5-0SMDJ70A
5-0SMDJ70CA
5PGP
5BGP
70
1
77.8
86
1
113
44.3
5-0SMDJ75A
5-0SMDJ75CA
5PGR
5BGR
75
1
83.3
92.1
1
121
41.4
5-0SMDJ78A
5-0SMDJ78CA
5PGT
5BGT
78
1
86.7
95.8
1
126
39.7
5-0SMDJ85A
5-0SMDJ85CA
5PGV
5BGV
85
1
94.4
104
1
137
36.5
5-0SMDJ90A
5-0SMDJ90CA
5PGX
5BGX
90
1
100
111
1
146
34.3
5-0SMDJ100A
5-0SMDJ100CA
5PGZ
5BGZ
100
1
111
123
1
162
30.9
5-0SMDJ110A
5-0SMDJ110CA
5PHE
5BHE
110
1
122
135
1
177
28.3
5-0SMDJ120A
5-0SMDJ120CA
5PHG
5BHG
120
1
133
147
1
193
26
5-0SMDJ130A
5-0SMDJ130CA
5PHK
5BHK
130
1
144
159
1
209
24
5-0SMDJ150A
5-0SMDJ150CA
5PHM
5BHM
150
1
167
185
1
243
20.6
5-0SMDJ160A
5-0SMDJ160CA
5PHP
5BHP
160
1
178
197
1
259
19.3
5-0SMDJ170A
5-0SMDJ170CA
5PHR
5BHR
170
1
189
209
1
275
18.2
3
5-0SMDJ
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
Pulse waveform
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
PPP derating in percentage (%)
Pulse derating curve
Peak value
Half value
50
80
60
40
td
1.0
2.0
3.0
25
50
75
100
125
150
175
TJ-Initial junction temperature (°C)
t (ms)
Typical junction capacitance
Peak pulse power dissipation vs. pulse width
100
1000
f=1 MHz, Vdc=0 V
Vrms= 0.1 V
Uni-directional
1
0.1
1
Bi-directional
10
100
10
100
VR (V)
4
Ppp (kW)
CJ (nF)
5000 W at 10/1000 μs +25 °C
10
1000
1.0
0.001
0.01
0.1
td-Pulse width (ms)
1.0
10
5-0SMDJ
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“5-0SMDJ36A”相匹配的价格&库存,您可以联系我们找货
