DATA SHEET
TRANSIENT VOLTAGE SUPPRESSORS
AC/DC POWER SUPPLY
SMDJ series
Product specification– February 21, 2021 V.2
RoHS compliant & Halogen free
Circuit Protection
Product Specification
Transient Voltage Suppressors
2
8
SMDJ
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
3000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 10V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
Case: JEDEC DO-214AB. Molded plastic over glass passivated junction
Terminal: Tin plated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Standard Packaging: 16mm tape (EIA STD RS-481)
Weight: 0.28g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 3000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
IFSM
300
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
15
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 8.0mm×8.0mm copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
www.yageo.com
Feb. 21, 2021 V.2
Circuit Protection
3
8
SMDJ
Dimensions (SMC/DO-214AB)
Millimeters
Inches
Symbol
Cathode Band
D1 D
Min.
Max.
Min.
Max.
L
6.60
7.11
0.260
0.280
D
5.59
6.22
0.220
0.245
D1
2.90
3.20
0.114
0.126
T
7.75
8.13
0.305
0.320
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.20
2.80
0.087
0.110
H1
2.06
2.62
0.079
0.103
L
H1 H
d
T1
T
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMDJ5.0A
SMDJ5.0CA
RDE
DDE
5.0
6.40~7.00
10
9.2
326.1
800
SMDJ6.0A
SMDJ6.0CA
RDG
DDG
6.0
6.67~7.37
10
10.3
291.3
800
SMDJ6.5A
SMDJ6.5CA
RDK
DDK
6.5
7.22~7.98
10
11.2
267.9
500
SMDJ7.0A
SMDJ7.0CA
PDM
DDM
7.0
7.78~8.60
10
12.0
250.0
200
SMDJ7.5A
SMDJ7.5CA
PDP
DDP
7.5
8.33~9.21
1
12.9
232.6
100
SMDJ8.0A
SMDJ8.0CA
PDR
DDR
8.0
8.89~9.83
1
13.6
220.6
50
SMDJ8.5A
SMDJ8.5CA
PDT
DDT
8.5
9.44~10.40
1
14.4
208.3
SMDJ9.0A
SMDJ9.0CA
PDV
DDV
9.0
10.00~11.10
1
15.4
194.8
10
SMDJ10A
SMDJ10CA
PDX
DDX
10.0
11.10~12.30
1
17.0
176.5
5
SMDJ11A
SMDJ11CA
PDZ
DDZ
11.0
12.20~13.50
1
18.2
164.8
2
SMDJ12A
SMDJ12CA
PEE
DEE
12.0
13.30~14.70
1
19.9
150.8
2
SMDJ13A
SMDJ13CA
PEG
DEG
13.0
14.40~15.90
1
21.5
139.5
2
SMDJ14A
SMDJ14CA
PEK
DEK
14.0
15.60~17.20
1
23.2
129.3
2
SMDJ15A
SMDJ15CA
PEM
DEM
15.0
16.70~18.50
1
24.4
123.0
2
SMDJ16A
SMDJ16CA
PEP
DEP
16.0
17.80~19.70
1
26.0
115.4
2
SMDJ17A
SMDJ17CA
PER
DER
17.0
18.90~20.90
1
27.6
108.7
2
SMDJ18A
SMDJ18CA
PET
DET
18.0
20.00~22.10
1
29.2
102.7
2
SMDJ20A
SMDJ20CA
PEV
DEV
20.0
22.20~24.50
1
32.4
92.6
2
www.yageo.com
Feb. 21, 2021 V.2
Circuit Protection
4
8
SMDJ
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMDJ22A
SMDJ22CA
PEX
DEX
22.0
24.40~26.90
1
35.5
84.5
2
SMDJ24A
SMDJ24CA
PEZ
DEZ
24.0
26.70~29.50
1
38.9
77.1
2
SMDJ26A
SMDJ26CA
PFE
DFE
26.0
28.90~31.90
1
42.1
71.3
2
SMDJ28A
SMDJ28CA
PFG
DFG
28.0
31.10~34.40
1
45.4
66.1
2
SMDJ30A
SMDJ30CA
PFK
DFK
30.0
33.30~36.80
1
48.4
62.0
2
SMDJ33A
SMDJ33CA
PFM
DFM
33.0
36.70~40.60
1
53.3
56.3
2
SMDJ36A
SMDJ36CA
PFP
DFP
36.0
40.00~44.20
1
58.1
51.6
2
SMDJ40A
SMDJ40CA
PFR
DFR
40.0
44.40~49.10
1
64.5
46.5
2
SMDJ43A
SMDJ43CA
PFT
DFT
43.0
47.80~52.80
1
69.4
43.2
2
SMDJ45A
SMDJ45CA
PFV
DFV
45.0
50.00~55.30
1
72.7
41.3
2
SMDJ48A
SMDJ48CA
PFX
DFX
48.0
53.30~58.90
1
77.4
38.8
2
SMDJ51A
SMDJ51CA
PFZ
DFZ
51.0
56.70~62.70
1
82.4
36.4
2
SMDJ54A
SMDJ54CA
PGE
DGE
54.0
60.00~66.30
1
87.1
34.4
2
SMDJ58A
SMDJ58CA
PGG
DGG
58.0
64.40~71.20
1
93.6
32.1
2
SMDJ60A
SMDJ60CA
PGK
DGK
60.0
66.70~73.70
1
96.8
31.0
2
SMDJ64A
SMDJ64CA
PGM
DGM
64.0
71.10~78.60
1
103.0
29.1
2
SMDJ70A
SMDJ70CA
PGP
DGP
70.0
77.80~86.00
1
113.0
26.5
2
SMDJ75A
SMDJ75CA
PGR
DGR
75.0
83.30~92.10
1
121.0
24.8
2
SMDJ78A
SMDJ78CA
PGT
DGT
78.0
86.70~95.80
1
126.0
23.8
2
SMDJ85A
SMDJ85CA
PGV
DGV
85.0
94.40~104.00
1
137.0
21.9
2
SMDJ90A
SMDJ90CA
PGX
DGX
90.0
100.00~111.00
1
146.0
20.5
2
SMDJ100A
SMDJ100CA
PGZ
DGZ
100.0
111.00~123.00
1
162.0
18.5
2
SMDJ110A
SMDJ110CA
PHE
DHE
110.0
122.00~135.00
1
177.0
16.9
2
SMDJ120A
SMDJ120CA
PHG
DHG
120.0
133.00~147.00
1
193.0
15.5
2
SMDJ130A
SMDJ130CA
PHK
DHK
130.0
144.00~159.00
1
209.0
14.4
2
SMDJ150A
SMDJ150CA
PHM
DHM
150.0
167.00~185.00
1
243.0
12.3
2
SMDJ160A
SMDJ160CA
PHP
DHP
160.0
178.00~197.00
1
259.0
11.6
2
SMDJ170A
SMDJ170CA
PHR
DHR
170.0
189.00~209.00
1
275.0
10.9
2
SMDJ180A
SMDJ180CA
HHT
IHT
180.0
201.00~222.00
1
292.0
10.3
2
SMDJ190A
SMDJ190CA
HHV
IHV
190.0
211.00~233.00
1
308.0
9.7
2
SMDJ200A
SMDJ200CA
HHX
IHX
200.0
224.00~247.00
1
324.0
9.3
2
SMDJ210A
SMDJ210CA
HHZ
IHZ
210.0
237.00~263.00
1
340.0
8.8
2
SMDJ220A
SMDJ220CA
HIE
IIE
220.0
246.00~272.00
1
356.0
8.4
2
www.yageo.com
Feb. 21, 2021 V.2
Circuit Protection
5
8
SMDJ
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
1000
100
10
1
0.31×0.31″(8.0×8.0mm)
Copper Pad Area
0.1
0.1
1
100
10
100
80
60
40
td-Pulse Width (µs)
125
150
175
100000
Uni-directional
10000
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
100
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
1000
Bi-directional
100
50
10/1000µs Waveform
as defined by R.E.A
10
td
1.0
2.0
3.0
4.0
Measured at
1MHz, 100mV, 0V bias
1
t-Time (ms)
Figure 5. Steady State Power Dissipation Derating
IFSM - Peak Forward Surve Current (A)
6
5
4
3
2
1
1000
Surge Current Uni-Directional Only
7
100
VRWM-Reverse Stand-Off Voltage (V)
Figure 6. Maximum Non-Repetitive Forward
Curve
PM(AV), Steady State Power Dissipation (W)
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
150
25
50
75
100
125
150
175
350
300
250
200
150
100
50
10
Number of Cycles at 60Hz
100
www.yageo.com
Feb. 21, 2021 V.2
Circuit Protection
6
8
SMDJ
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
6℃/second max.
8 minutes max.
www.yageo.com
Feb. 21, 2021 V.2
Circuit Protection
7
8
SMDJ
Marking Code
Cathode Band
YXXX
YXXX
RDE
Logo
DDE
Intermal Control Code
Marking Code
Logo
Marking Code
Part Number Code
SMDJ
XXX C A / XXXX
Package Code
TR7:7 inch reel package
TR13:13 inch reel package
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
7 inch reel package: Add suffix “ /TR7” at the end of the part number, such as SMDJXXXCA/TR7
13 inch reel package: Add suffix “ /TR13” at the end of the part number, such as SMDJXXXCA/TR13
www.yageo.com
Feb. 21, 2021 V.2
Circuit Protection
8
8
SMDJ
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
D1
A
A
B
K0
SECTION B-B
A0
SECTION A-A
7” Reel
Symbol
Dimension (mm)
W
16.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.5±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
7.50±0.10
A0
6.27±0.10
B0
8.30±0.10
K0
3.15±0.15
T
0.30±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
20.0±2.0
D4
D3
D2
13” Reel
W1
Quantity: 500PCS
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
20.0±2.0
Quantity: 3000PCS
www.yageo.com
Feb. 21, 2021 V.2
很抱歉,暂时无法提供与“SMDJ22A/TR7”相匹配的价格&库存,您可以联系我们找货
