1.5SMC91A/TR7
1.5SMC91A/TR7
    YAGEO(国巨)
    SMC(DO-214AB)
    125V 夹子 12.2A Ipp TVS - 二极管 表面贴装型 DO-214AB(SMC)
1.5SMC91A/TR7 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY 1.5SMC series Product specification– June 30, 2023 V.5 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 1.5SMC Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 1500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■Typical IR less than 1μA above 12V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 16mm tape (EIA STD RS-481) ■ Weight: 0.26g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 1500 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts IFSM 200 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 1.5SMC Dimensions (SMC/DO-214AB) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 6.60 7.11 0.260 0.280 D 5.59 6.22 0.220 0.245 D1 2.90 3.20 0.114 0.126 T 7.75 8.13 0.305 0.320 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.20 2.80 0.087 0.110 H1 2.06 2.62 0.079 0.103 D1 D L H1 H d T1 T 3.20mm Pad: 1.75mm 4.69mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Unidirection Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5SMC6.8A 1.5SMC6.8CA 6V8A 6V8C 5.80 6.45~7.14 10 10.5 144.8 1000 1.5SMC7.5A 1.5SMC7.5CA 7V5A 7V5C 6.40 7.13~7.88 10 11.3 134.5 500 1.5SMC8.2A 1.5SMC8.2CA 8V2A 8V2C 7.02 7.79~8.61 10 12.1 125.6 200 1.5SMC9.1A 1.5SMC9.1CA 9V1A 9V1C 7.78 8.65~9.55 1 13.4 113.4 50 1.5SMC10A 1.5SMC10CA 10A 10C 8.55 9.50~10.50 1 14.5 104.8 10 1.5SMC11A 1.5SMC11CA 11A 11C 9.40 10.50~11.60 1 15.6 97.4 5 1.5SMC12A 1.5SMC12CA 12A 12C 10.20 11.40~12.60 1 16.7 91.0 5 1.5SMC13A 1.5SMC13CA 13A 13C 11.10 12.40~13.70 1 18.2 83.5 1 1.5SMC15A 1.5SMC15CA 15A 15C 12.80 14.30~15.80 1 21.2 71.7 1 1.5SMC16A 1.5SMC16CA 16A 16C 13.60 15.20~16.80 1 22.5 67.6 1 1.5SMC18A 1.5SMC18CA 18A 18C 15.30 17.10~18.90 1 25.2 60.3 1 1.5SMC20A 1.5SMC20CA 20A 20C 17.10 19.00~21.00 1 27.7 54.9 1 1.5SMC22A 1.5SMC22CA 22A 22C 18.80 20.90~23.10 1 30.6 49.7 1 1.5SMC24A 1.5SMC24CA 24A 24C 20.50 22.80~25.20 1 33.2 45.8 1 al www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors Part Number Unidirection Device Marking Code 9 1.5SMC Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5SMC27A 1.5SMC27CA 27A 27C 23.10 25.70~28.40 1 37.5 40.5 1 1.5SMC30A 1.5SMC30CA 30A 30C 25.60 28.50~31.50 1 41.4 36.7 1 1.5SMC33A 1.5SMC33CA 33A 33C 28.20 31.40~34.70 1 45.7 33.3 1 1.5SMC36A 1.5SMC36CA 36A 36C 30.80 34.20~37.80 1 49.9 30.5 1 1.5SMC39A 1.5SMC39CA 39A 39C 33.30 37.10~41.00 1 53.9 28.2 1 1.5SMC43A 1.5SMC43CA 43A 43C 36.80 40.90~45.20 1 59.3 25.6 1 1.5SMC47A 1.5SMC47CA 47A 47C 40.20 44.70~49.40 1 64.8 23.5 1 1.5SMC51A 1.5SMC51CA 51A 51C 43.60 48.50~53.60 1 70.1 21.7 1 1.5SMC56A 1.5SMC56CA 56A 56C 47.80 53.20~58.80 1 77.0 19.7 1 1.5SMC62A 1.5SMC62CA 62A 62C 53.00 58.90~65.10 1 85.0 17.9 1 1.5SMC68A 1.5SMC68CA 68A 68C 58.10 64.60~71.40 1 92.0 16.5 1 1.5SMC75A 1.5SMC75CA 75A 75C 64.10 71.30~78.80 1 103.0 14.8 1 1.5SMC82A 1.5SMC82CA 82A 82C 70.10 77.90~86.10 1 113.0 13.5 1 1.5SMC91A 1.5SMC91CA 91A 91C 77.80 86.50~95.50 1 125.0 12.2 1 1.5SMC100A 1.5SMC100CA 100A 100C 85.50 95.00~105.00 1 137.0 11.1 1 1.5SMC110A 1.5SMC110CA 110A 110C 94.00 105.00~116.00 1 152.0 10.0 1 1.5SMC120A 1.5SMC120CA 120A 120C 102.00 114.00~126.00 1 165.0 9.2 1 1.5SMC130A 1.5SMC130CA 130A 130C 111.00 124.00~137.0 1 179.0 8.5 1 1.5SMC150A 1.5SMC150CA 150A 150C 128.00 0 143.00~158.0 1 207.0 7.3 1 136.00 0 152.00~168.0 1 219.0 6.9 1 1 234.0 6.5 1 al 1.5SMC160A 1.5SMC160CA 160A 160C 1.5SMC170A 1.5SMC170CA 170A 170C 145.00 0 162.00~179.0 1.5SMC180A 1.5SMC180CA 180A 180C 154.00 0 171.00~189.0 1 246.0 6.2 1 1.5SMC200A 1.5SMC200CA 200A 200C 171.00 0 190.00~210.0 1 274.0 5.5 1 185.00 0 209.00~231.0 1 328.0 4.6 1 1 344.0 4.4 1 1.5SMC220A 1.5SMC220CA 220A 220C 1.5SMC250A 1.5SMC250CA 250A 250C 214.00 0 237.00~263.0 1.5SMC300A 1.5SMC300CA 300A 300C 256.00 0 285.00~315.0 1 414.0 3.7 1 1.5SMC350A 1.5SMC350CA 350A 350C 300.00 0 332.00~368.0 1 482.0 3.2 1 342.00 0 380.00~420.0 1 548.0 2.8 1 1 602.0 2.5 1 1.5SMC400A 1.5SMC400CA 400A 400C 1.5SMC440A 1.5SMC440CA 440A 440C 376.00 0 418.00~462.0 1.5SMC480A 1.5SMC480CA 480A 480C 408.00 0 456.00~504.0 1 658.0 2.3 1 1.5SMC510A 1.5SMC510CA 510A 510C 434.00 0 485.00~535.0 1 698.0 2.1 1 450.00 0 503.50~556.5 1 725.0 2.1 1 1 740.0 2.0 1 1 760.0 2.0 1 1 828.0 1.8 1 1.5SMC530A 1.5SMC530CA 530A 530C 4 1.5SMC540A 1.5SMC540CA 540A 540C 459.00 0 513.00~567.0 1.5SMC550A 1.5SMC550CA 550A 550C 467.00 0 522.50~577.5 1.5SMC600A 1.5SMC600CA 600A 600C 510.00 0 570.00~630.0 0 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 1.5SMC Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.2×0.2″(5.0×5.0mm) Copper Pad Area 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 150 175 Bi-directional V=0V Uni-directional V=0V Cj (pF) IPPM - Peak Pulse Current, %IRSM 125 10000 Half Value IPPM (IPPM/2) 1000 Uni-directional @VR 100 50 10/1000µs Waveform as defined by R.E.A 0 1 1.0 2.0 3.0 Bi-directional @VR 10 td 0 4.0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 10 100 1000 VBR-Reverse Breakdown Voltage (V) t-Time (ms) Figure 5. Steady State Power Dissipation Derating Curve Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 200 7 IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 100 100000 Peak Value IPPM 100 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 6 5 4 3 2 1 0 0 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 180 160 140 120 100 80 60 40 20 0 1 10 Number of Cycles at 60Hz 100 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 1.5SMC Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 1.5SMC Marking Code Cathode Band YXXX YXXX 6V8C 6V8A Logo Internal control code Logo Marking Code Internal control code Marking Code Part Number Code 1.5SMC XXX C A / XXXX Package Code TR7:7 inch reel package TR13:13 inch reel package 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “/TR7” at the end of the part number, such as 1.5SMCXXXCA/TR7 13 inch reel package: Add suffix “/TR13” at the end of the part number, such as 1.5SMCXXXCA/TR13 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 1.5SMC Packaging Tape P0 P1 P2 D0 B Symbol Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 K0 F 7.50±0.10 SECTION B-B A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 T E F W B0 D1 A A B A0 SECTION A-A 7” Reel D4 D3 D2 W1 Quantity: 500PCS 13” Reel D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.5 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
1.5SMC91A/TR7 价格&库存
很抱歉,暂时无法提供与“1.5SMC91A/TR7”相匹配的价格&库存,您可以联系我们找货
1.5SMC91A/TR7
    1.5SMC91A/TR7
    • 500+1.82881500+0.23627
    • 1000+1.639641000+0.21183
    • 1500+1.543061500+0.19935
    • 2500+1.434512500+0.18533
    • 3500+1.370153500+0.17702
    • 5000+1.307595000+0.16893
    库存:500
