5-0SMDJ70CA
5-0SMDJ70CA
    EATON(伊顿)
    SMC(DO-214AB)
    113V 夹子 44.3A Ipp TVS - 二极管 表面贴装型 SMC
5-0SMDJ70CA 数据手册
Technical Data 11204 Effective November 2020 5-0SMDJ 5000 W Transient voltage suppressor Applications Product features • Low profile SMC package • Excellent clamping capability • 5000 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 30 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. :E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Mobile and wearables Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number 5-0SMDJ 11 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance 5-0SMDJ 5000 W Transient voltage suppressor  Technical Data 11204 Effective November 2020 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 6.5 W Peak pulse power dissipation on 10/1000 μs waveform PPP 5000 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 300 A Typical thermal resistance junction to lead R JL 15 °C/W Typical thermal resistance junction to ambient R JA 75 °C/W Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm Millimeters Dimension Minimum Part marking Inches Maximum Minimum Maximum A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 K L Cathode band (Uni-polar only) Part marking: xxxx = Date code yyyy- Refer to marking designator listed in Electrical Characteristics table 0.094 4.20 0.165 3.30 0.130 Packaging information (mm) Drawing not to scale. Dimensions Millimeters Inches Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) A0 6.05 ± 0.3 0.238 ± 0.012 B0 8.31 ± 0.3 0.327 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 7.50 ± 0.2 0.295 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.315 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 2 www.eaton.com/electronics Technical Data 11204 5-0SMDJ  5000 W Transient voltage suppressor Effective November 2020  Electrical characteristics (+25 °C) Part number Uni-polar Bi-polar Marking Uni Bi VR (V) IR @ VR (μA) VBR @ IT min (V) max (V) IT (mA) VC @I PP max (V) IPP (A) 5-0SMDJ11A 5-0SMDJ11CA 5PEN 5BEN 11 5 12.2 13.5 10 18.2 275 5-0SMDJ12A 5-0SMDJ12CA 5PEP 5BEP 12 5 13.3 14.7 10 19.9 252 5-0SMDJ13A 5-0SMDJ13CA 5PEQ 5BEQ 13 5 14.4 15.9 10 21.5 233 5-0SMDJ14A 5-0SMDJ14CA 5PER 5BER 14 5 15.6 17.2 10 23.2 216 5-0SMDJ15A 5-0SMDJ15CA 5PES 5BES 15 5 16.7 18.5 1 24.4 205 5-0SMDJ16A 5-0SMDJ16CA 5PET 5BET 16 5 17.8 19.7 1 26 193 5-0SMDJ17A 5-0SMDJ17CA 5PEU 5BEU 17 5 18.9 20.9 1 27.6 181 5-0SMDJ18A 5-0SMDJ18CA 5PEV 5BEV 18 5 20 22.1 1 29.2 172 5-0SMDJ20A 5-0SMDJ20CA 5PEW 5BEW 20 5 22.2 24.5 1 32.4 155 5-0SMDJ22A 5-0SMDJ22CA 5PEX 5BEX 22 5 24.4 26.9 1 35.5 141 5-0SMDJ24A 5-0SMDJ24CA 5PEZ 5BEZ 24 5 26.7 29.5 1 38.9 129 5-0SMDJ26A 5-0SMDJ26CA 5PFE 5BFE 26 5 28.9 31.9 1 42.1 119 5-0SMDJ28A 5-0SMDJ28CA 5PFG 5BFG 28 5 31.1 34.4 1 45.4 110 5-0SMDJ30A 5-0SMDJ30CA 5PFK 5BFK 30 5 33.3 36.8 1 48.4 103 5-0SMDJ33A 5-0SMDJ33CA 5PFM 5BFM 33 1 36.7 40.6 1 53.3 93.9 5-0SMDJ36A 5-0SMDJ36CA 5PFP 5BFP 36 1 40 44.2 1 58.1 86.1 5-0SMDJ40A 5-0SMDJ40CA 5PFR 5BFR 40 1 44.4 49.1 1 64.5 77.6 5-0SMDJ43A 5-0SMDJ43CA 5PFT 5BFT 43 1 47.8 52.8 1 69.4 72.1 5-0SMDJ45A 5-0SMDJ45CA 5PFV 5BFV 45 1 50 55.3 1 72.7 68.8 5-0SMDJ48A 5-0SMDJ48CA 5PFX 5BFX 48 1 53.3 58.9 1 77.4 64.7 5-0SMDJ51A 5-0SMDJ51CA 5PFZ 5BFZ 51 1 56.7 62.7 1 82.4 60.7 5-0SMDJ54A 5-0SMDJ54CA 5PGE 5BGE 54 1 60 66.3 1 87.1 57.5 5-0SMDJ58A 5-0SMDJ58CA 5PGG 5BGG 58 1 64.4 71.2 1 93.6 53.5 5-0SMDJ60A 5-0SMDJ60CA 5PGK 5BGK 60 1 66.7 73.7 1 96.8 51.7 5-0SMDJ64A 5-0SMDJ64CA 5PGM 5BGM 64 1 71.1 78.6 1 103 48.6 5-0SMDJ70A 5-0SMDJ70CA 5PGP 5BGP 70 1 77.8 86 1 113 44.3 5-0SMDJ75A 5-0SMDJ75CA 5PGR 5BGR 75 1 83.3 92.1 1 121 41.4 5-0SMDJ78A 5-0SMDJ78CA 5PGT 5BGT 78 1 86.7 95.8 1 126 39.7 5-0SMDJ85A 5-0SMDJ85CA 5PGV 5BGV 85 1 94.4 104 1 137 36.5 5-0SMDJ90A 5-0SMDJ90CA 5PGX 5BGX 90 1 100 111 1 146 34.3 5-0SMDJ100A 5-0SMDJ100CA 5PGZ 5BGZ 100 1 111 123 1 162 30.9 5-0SMDJ110A 5-0SMDJ110CA 5PHE 5BHE 110 1 122 135 1 177 28.3 5-0SMDJ120A 5-0SMDJ120CA 5PHG 5BHG 120 1 133 147 1 193 26 5-0SMDJ130A 5-0SMDJ130CA 5PHK 5BHK 130 1 144 159 1 209 24 5-0SMDJ150A 5-0SMDJ150CA 5PHM 5BHM 150 1 167 185 1 243 20.6 5-0SMDJ160A 5-0SMDJ160CA 5PHP 5BHP 160 1 178 197 1 259 19.3 5-0SMDJ170A 5-0SMDJ170CA 5PHR 5BHR 170 1 189 209 1 275 18.2 www.eaton.com/electronics 3 5-0SMDJ 5000 W Transient voltage suppressor  Technical Data 11204 Effective November 2020 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current Pulse waveform 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 PPP derating in percentage (%) Pulse derating curve Peak value Half value 50 0 0 100 80 60 40 20 td 1.0 2.0 3.0 0 0 4.0 25 50 75 100 125 150 175 TJ-Initial junction temperature (°C) t (ms) Typical junction capacitance Peak pulse power dissipation vs. pulse width 100 1000 f=1 MHz, Vdc=0 V Vrms= 0.1 V Uni-directional 1 0.1 1 Bi-directional 10 www.eaton.com/electronics 100 10 100 VR (V) 4 Ppp (kW) CJ (nF) 5000 W at 10/1000 μs +25 °C 10 1000 1.0 0.001 0.01 0.1 td-Pulse width (ms) 1.0 10 Technical Data 11204 5-0SMDJ  5000 W Transient voltage suppressor Effective November 2020  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
5-0SMDJ70CA 价格&库存
很抱歉,暂时无法提供与“5-0SMDJ70CA”相匹配的价格&库存,您可以联系我们找货
5-0SMDJ70CA
    • 1+1.26641
    • 200+0.49011
    • 500+0.47294
    • 1000+0.46440
    5-0SMDJ70CA
    • 1+15.168401+1.97185
    • 10+9.6151910+1.24995
    • 100+6.42790100+0.83561
    • 500+5.05993500+0.65778
    • 1000+4.619761000+0.60056
    库存:2750
    5-0SMDJ70CA
    • 3000+4.836053000+0.62867
    库存:2750
