SMDJ28A-AT/TR13
SMDJ28A-AT/TR13
    YAGEO(国巨)
    SMC(DO-214AB)
    45.4V 夹子 66.1A Ipp TVS - 二极管 表面贴装型 DO-214AB(SMC)
SMDJ28A-AT/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY SMDJ-AT series Product specification– June 30, 2023 V.4 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 SMDJ-AT Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 3000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 2μA above 10V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ AEC-Q101 qualified ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 16mm tape (EIA STD RS-481) ■ Weight: 0.26g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 3000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts IFSM 300 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 SMDJ-AT 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Dimensions (SMC/DO-214AB) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 6.60 7.11 0.260 0.280 D 5.59 6.22 0.220 0.245 D1 2.90 3.20 0.114 0.126 T 7.75 8.13 0.305 0.320 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.20 2.80 0.087 0.110 H1 2.06 2.62 0.079 0.103 D1 D L H1 H d T1 T 3.20mm Pad: 1.75mm 4.69mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMDJ5.0A-AT SMDJ5.0CA-AT RDE DDE 5.0 6.40~7.00 10 9.2 326.1 800 SMDJ6.0A-AT SMDJ6.0CA-AT RDG DDG 6.0 6.67~7.37 10 10.3 291.3 800 SMDJ6.5A-AT SMDJ6.5CA-AT RDK DDK 6.5 7.22~7.98 10 11.2 267.9 500 SMDJ7.0A-AT SMDJ7.0CA-AT PDM DDM 7.0 7.78~8.60 10 12.0 250.0 200 SMDJ7.5A-AT SMDJ7.5CA-AT PDP DDP 7.5 8.33~9.21 1 12.9 232.6 100 SMDJ8.0A-AT SMDJ8.0CA-AT PDR DDR 8.0 8.89~9.83 1 13.6 220.6 50 SMDJ8.5A-AT SMDJ8.5CA-AT PDT DDT 8.5 9.44~10.40 1 14.4 208.3 20 SMDJ9.0A-AT SMDJ9.0CA-AT PDV DDV 9.0 10.00~11.10 1 15.4 194.8 10 SMDJ10A-AT SMDJ10CA-AT PDX DDX 10.0 11.10~12.30 1 17.0 176.5 5 SMDJ11A-AT SMDJ11CA-AT PDZ DDZ 11.0 12.20~13.50 1 18.2 164.8 2 SMDJ12A-AT SMDJ12CA-AT PEE DEE 12.0 13.30~14.70 1 19.9 150.8 2 SMDJ13A-AT SMDJ13CA-AT PEG DEG 13.0 14.40~15.90 1 21.5 139.5 2 SMDJ14A-AT SMDJ14CA-AT PEK DEK 14.0 15.60~17.20 1 23.2 129.3 2 SMDJ15A-AT SMDJ15CA-AT PEM DEM 15.0 16.70~18.50 1 24.4 123.0 2 SMDJ16A-AT SMDJ16CA-AT PEP DEP 16.0 17.80~19.70 1 26.0 115.4 2 SMDJ17A-AT SMDJ17CA-AT PER DER 17.0 18.90~20.90 1 27.6 108.7 2 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors SMDJ18A-AT SMDJ18CA-AT PET DET 4 9 SMDJ-AT 18.0 20.00~22.10 1 29.2 102.7 2 Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRWM Electrical Characteristics (TA=25℃) Part Number Device Marking Code Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMDJ20A-AT SMDJ20CA-AT PEV DEV 20.0 22.20~24.50 1 32.4 92.6 2 SMDJ22A-AT SMDJ22CA-AT PEX DEX 22.0 24.40~26.90 1 35.5 84.5 2 SMDJ24A-AT SMDJ24CA-AT PEZ DEZ 24.0 26.70~29.50 1 38.9 77.1 2 SMDJ26A-AT SMDJ26CA-AT PFE DFE 26.0 28.90~31.90 1 42.1 71.3 2 SMDJ28A-AT SMDJ28CA-AT PFG DFG 28.0 31.10~34.40 1 45.4 66.1 2 SMDJ30A-AT SMDJ30CA-AT PFK DFK 30.0 33.30~36.80 1 48.4 62.0 2 SMDJ33A-AT SMDJ33CA-AT PFM DFM 33.0 36.70~40.60 1 53.3 56.3 2 SMDJ36A-AT SMDJ36CA-AT PFP DFP 36.0 40.00~44.20 1 58.1 51.6 2 SMDJ40A-AT SMDJ40CA-AT PFR DFR 40.0 44.40~49.10 1 64.5 46.5 2 SMDJ43A-AT SMDJ43CA-AT PFT DFT 43.0 47.80~52.80 1 69.4 43.2 2 SMDJ45A-AT SMDJ45CA-AT PFV DFV 45.0 50.00~55.30 1 72.7 41.3 2 SMDJ48A-AT SMDJ48CA-AT PFX DFX 48.0 53.30~58.90 1 77.4 38.8 2 SMDJ51A-AT SMDJ51CA-AT PFZ DFZ 51.0 56.70~62.70 1 82.4 36.4 2 SMDJ54A-AT SMDJ54CA-AT PGE DGE 54.0 60.00~66.30 1 87.1 34.4 2 SMDJ58A-AT SMDJ58CA-AT PGG DGG 58.0 64.40~71.20 1 93.6 32.1 2 SMDJ60A-AT SMDJ60CA-AT PGK DGK 60.0 66.70~73.70 1 96.8 31.0 2 SMDJ64A-AT SMDJ64CA-AT PGM DGM 64.0 71.10~78.60 1 103.0 29.1 2 SMDJ70A-AT SMDJ70CA-AT PGP DGP 70.0 77.80~86.00 1 113.0 26.5 2 SMDJ75A-AT SMDJ75CA-AT PGR DGR 75.0 83.30~92.10 1 121.0 24.8 2 SMDJ78A-AT SMDJ78CA-AT PGT DGT 78.0 86.70~95.80 1 126.0 23.8 2 SMDJ85A-AT SMDJ85CA-AT PGV DGV 85.0 94.40~104.00 1 137.0 21.9 2 SMDJ90A-AT SMDJ90CA-AT PGX DGX 90.0 100.00~111.00 1 146.0 20.5 2 SMDJ100A-AT SMDJ100CA-AT PGZ DGZ 100.0 111.00~123.00 1 162.0 18.5 2 SMDJ110A-AT SMDJ110CA-AT PHE DHE 110.0 122.00~135.00 1 177.0 16.9 2 SMDJ120A-AT SMDJ120CA-AT PHG DHG 120.0 133.00~147.00 1 193.0 15.5 2 SMDJ130A-AT SMDJ130CA-AT PHK DHK 130.0 144.00~159.00 1 209.0 14.4 2 SMDJ150A-AT SMDJ150CA-AT PHM DHM 150.0 167.00~185.00 1 243.0 12.3 2 SMDJ160A-AT SMDJ160CA-AT PHP DHP 160.0 178.00~197.00 1 259.0 11.6 2 SMDJ170A-AT SMDJ170CA-AT PHR DHR 170.0 189.00~209.00 1 275.0 10.9 2 SMDJ180A-AT SMDJ180CA-AT HHT IHT 180.0 201.00~222.00 1 292.0 10.3 2 SMDJ190A-AT SMDJ190CA-AT HHV IHV 190.0 211.00~233.00 1 308.0 9.7 2 SMDJ200A-AT SMDJ200CA-AT HHX IHX 200.0 224.00~247.00 1 324.0 9.3 2 SMDJ210A-AT SMDJ210CA-AT HHZ IHZ 210.0 237.00~263.00 1 340.0 8.8 2 SMDJ220A-AT SMDJ220CA-AT HIE IIE 220.0 246.00~272.00 1 356.0 8.4 2 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 SMDJ-AT Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve 100 10 1 0.31×0.31″(8.0×8.0mm) Copper Pad Area 0.1 0.1 1 100 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 1000 100 10 80 60 40 20 0 1000 0 td-Pulse Width (µs) 125 150 175 100000 Uni-directional 10000 Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 Peak Value IPPM 100 Half Value IPPM (IPPM/2) 1000 Bi-directional 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 1 1.0 2.0 3.0 4.0 Measured at 1MHz, 100mV, 0V bias 1 t-Time (ms) Figure 5. Steady State Power Dissipation Derating Curve 7 6 5 4 3 2 1 0 0 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 10 100 VRWM-Reverse Stand-Off Voltage (V) 1000 Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 350 300 250 200 150 100 50 0 1 10 Number of Cycles at 60Hz 100 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 SMDJ-AT Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 SMDJ-AT Marking Code Cathode Band YXXX YXXX RDE Logo DDE Intermal Control Code Marking Code Logo Intermal Control Code Marking Code Part Number Code SMDJ XXX C A AT / XXXX Package code TR7: 7 inch reel package TR13: 13 inch reel package Internal Control Code 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as SMDJXXXCA-AT/TR7 13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as SMDJXXXCA-AT/TR13 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 SMDJ-AT Packaging Tape P0 P1 P2 D0 B Symbol Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 K0 F 7.50±0.10 SECTION B-B A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 T E F W B0 D1 A A B A0 SECTION A-A 7” Reel D4 D3 D2 W1 Quantity: 500PCS 13” Reel D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.4 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
SMDJ28A-AT/TR13 价格&库存
很抱歉,暂时无法提供与“SMDJ28A-AT/TR13”相匹配的价格&库存,您可以联系我们找货
