Technical Data ELX1065
Effective June 2021
SMDJE
Automotive grade 3000 W Transient voltage suppressor
Applications
Product features
Automotive grade (AEC-Q101 qualified)
Low profile SMC package
Excellent clamping capability
High reliability application
3000 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 5 μA
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
Plastic package meets UL 94 V-0
flammability rating
Meets moisture sensitivity level (MSL) level 1
Terminal: tin plated, solderable per J-STD-002
UL 497B recognized.
File No. : E198449 Guide QVGQ2
Automotive chassis and safety systems
Advanced driver assistance systems (ADAS)
Communication and infotainment systems
Network systems and body electronics
Power Train controls
xEV and battery systems
Environmental compliance and general
specifications
ISO16750-2 P5A: 12 V system
(90 V/4 Ω/200 ms)
ISO16750-2 P5A: 24 V system
(151 V/8 Ω/200 ms)
AEC-Q101 qualified
Ordering part number
SMDJE 12 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
PIN configuration
H
SMDJE
Effective June 2021
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
6.5
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
3000
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
300
A
Typical thermal resistance junction to lead
R
JL
15
°C/W
Typical thermal resistance junction to ambient
R
JA
75
°C/W
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm/inches
Millimeters
Part marking
Inches
Dimension Minimum
Maximum
Minimum
Maximum
A
5.75
6.25
0.226
0.246
B
6.90
7.40
0.272
0.291
C
2.75
3.25
0.108
0.128
D
0.95
1.52
0.037
0.060
E
7.70
8.20
0.303
0.323
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.15
2.62
0.085
0.103
J
2.40
0.094
K
4.20
0.165
L
3.30
0.130
Cathode band (uni-polar only)
Part marking:
xxxx = Date code
yyyy- Refer to marking designator listed in
Electrical characteristics table
Packaging information - mm/inches
Drawing not to scale.
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant)
2
www.eaton.com/electronics
Dimensions
Millimeters
Inches
A0
6.05 ± 0.3
0.238 ± 0.012
B0
8.31 ± 0.3
0.327 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
7.50 ± 0.2
0.295 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.3145 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
16.0 ± 0.2
0.630 ± 0.008
W1
19.7 ± 2.0
0.776 ± 0.079
SMDJE
Effective June 2021
Electrical specifications (+25 °C)
Part number
VR
IR @ VR
VBR @ IT
IT
VC @ IPP
IPP
Uni-polar
Bi-polar
Marking
Uni
Bi
(V)
(µA)
min (V)
max (V)
(mA)
max (V)
(A)
SMDJE12AH
SMDJE12CAH
H12A
H12C
12
5
13.3
14.7
5
19.9
150.8
SMDJE13AH
SMDJE13CAH
H13A
H13C
13
5
14.4
15.9
5
21.5
139.5
SMDJE14AH
SMDJE14CAH
H14A
H14C
14
5
15.6
17.2
5
23.2
129.3
SMDJE15AH
SMDJE15CAH
H15A
H15C
15
5
16.7
18.5
5
24.4
123
SMDJE16AH
SMDJE16CAH
H16A
H16C
16
5
17.8
19.7
5
26
115.4
SMDJE17AH
SMDJE17CAH
H17A
H17C
17
5
18.9
20.9
5
27.6
108.7
SMDJE18AH
SMDJE18CAH
H18A
H18C
18
5
5
29.2
102.7
SMDJE20AH
SMDJE20CAH
H20A
H20C
22.2
24.5
5
32.4
92.6
SMDJE22AH
SMDJE22CAH
H22A
H22C
22
5
24.4
26.9
5
35.5
84.5
SMDJE24AH
SMDJE24CAH
H24A
H24C
24
5
26.7
29.5
5
38.9
77.1
SMDJE26AH
SMDJE26CAH
H26A
H26C
26
5
28.9
31.9
5
42.1
71.3
SMDJE28AH
SMDJE28CAH
H28A
H28C
28
5
31.1
34.4
5
45.4
66.1
SMDJE30AH
SMDJE30CAH
H30A
H30C
30
5
33.3
36.8
5
48.4
62
SMDJE33AH
SMDJE33CAH
H33A
H33C
33
5
36.7
40.6
5
53.3
56.3
SMDJE36AH
SMDJE36CAH
H36A
H36C
36
5
40
44.2
5
58.1
51.6
SMDJE40AH
SMDJE40CAH
H40A
H40C
40
5
44.4
49.1
5
64.5
46.5
SMDJE43AH
SMDJE43CAH
H43A
H43C
43
5
47.8
52.8
5
69.4
43.2
SMDJE45AH
SMDJE45CAH
H45A
H45C
45
5
50
55.3
5
72.7
41.3
SMDJE48AH
SMDJE48CAH
H48A
H48C
48
5
53.3
58.9
5
77.4
38.8
SMDJE51AH
SMDJE51CAH
H51A
H51C
51
5
56.7
62.7
5
82.4
36.4
SMDJE54AH
SMDJE54CAH
H54A
H54C
54
5
60
66.3
1
87.1
34.4
3
SMDJE
Effective June 2021
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional
Pulse waveform
IPPM (% IRSM)
PPP derating in percentage (%)
Pulse derating curve
t (ms)
TJ (°C)
ISO16750-2 Test pulse 5A
U
US
0.9(US-UA)
tr
td
4
12V system
24V system
Us
79V to 101V
151V to 202V
Ri
0.5Ω¸to 4Ω¸
1Ω ¸to 8Ω¸
td
0.1(US-UA)
UA
Parameter
t
tr
40ms to 400ms 100ms to 350ms
5-10ms
5-10ms
SMDJE
Effective June 2021
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SMDJE54AH”相匹配的价格&库存,您可以联系我们找货
