SMDJE30AH
SMDJE30AH
    EATON(伊顿)
    SMC(DO-214AB)
    48.4V 夹子 62A Ipp TVS - 二极管 表面贴装型 SMC
SMDJE30AH 数据手册
Technical Data ELX1065 Effective June 2021 SMDJE Automotive grade 3000 W Transient voltage suppressor Applications Product features • Automotive grade (AEC-Q101 qualified) • Low profile SMC package • Excellent clamping capability • High reliability application • 3000 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 5 μA • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: tin plated, solderable per J-STD-002 • UL 497B recognized. File No. : E198449 Guide QVGQ2 • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • ISO16750-2 P5A: 12 V system (90 V/4 Ω/200 ms) • ISO16750-2 P5A: 24 V system (151 V/8 Ω/200 ms) • AEC-Q101 qualified Ordering part number SMDJE 12 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance High reliability application PIN configuration H SMDJE Automotive grade 3000 W Transient voltage suppressor  Technical Data ELX1065 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 6.5 W Peak pulse power dissipation on 10/1000 μs waveform PPP 3000 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 300 A Typical thermal resistance junction to lead R JL 15 °C/W Typical thermal resistance junction to ambient R JA 75 °C/W 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Millimeters Part marking Inches Dimension Minimum Maximum Minimum Maximum A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 - 0.094 - K - 4.20 - 0.165 L 3.30 - 0.130 - Cathode band (uni-polar only) Part marking: xxxx = Date code yyyy- Refer to marking designator listed in Electrical characteristics table Packaging information - mm/inches Drawing not to scale. Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) 2 www.eaton.com/electronics Dimensions Millimeters Inches A0 6.05 ± 0.3 0.238 ± 0.012 B0 8.31 ± 0.3 0.327 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 7.50 ± 0.2 0.295 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.3145 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 Technical Data ELX1065 SMDJE  Automotive grade 3000 W Transient voltage suppressor Effective June 2021  Electrical specifications (+25 °C) Part number VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) SMDJE12AH SMDJE12CAH H12A H12C 12 5 13.3 14.7 5 19.9 150.8 SMDJE13AH SMDJE13CAH H13A H13C 13 5 14.4 15.9 5 21.5 139.5 SMDJE14AH SMDJE14CAH H14A H14C 14 5 15.6 17.2 5 23.2 129.3 SMDJE15AH SMDJE15CAH H15A H15C 15 5 16.7 18.5 5 24.4 123 SMDJE16AH SMDJE16CAH H16A H16C 16 5 17.8 19.7 5 26 115.4 SMDJE17AH SMDJE17CAH H17A H17C 17 5 18.9 20.9 5 27.6 108.7 SMDJE18AH SMDJE18CAH H18A H18C 18 5 20 22.2 5 29.2 102.7 SMDJE20AH SMDJE20CAH H20A H20C 20 5 22.2 24.5 5 32.4 92.6 SMDJE22AH SMDJE22CAH H22A H22C 22 5 24.4 26.9 5 35.5 84.5 SMDJE24AH SMDJE24CAH H24A H24C 24 5 26.7 29.5 5 38.9 77.1 SMDJE26AH SMDJE26CAH H26A H26C 26 5 28.9 31.9 5 42.1 71.3 SMDJE28AH SMDJE28CAH H28A H28C 28 5 31.1 34.4 5 45.4 66.1 SMDJE30AH SMDJE30CAH H30A H30C 30 5 33.3 36.8 5 48.4 62 SMDJE33AH SMDJE33CAH H33A H33C 33 5 36.7 40.6 5 53.3 56.3 SMDJE36AH SMDJE36CAH H36A H36C 36 5 40 44.2 5 58.1 51.6 SMDJE40AH SMDJE40CAH H40A H40C 40 5 44.4 49.1 5 64.5 46.5 SMDJE43AH SMDJE43CAH H43A H43C 43 5 47.8 52.8 5 69.4 43.2 SMDJE45AH SMDJE45CAH H45A H45C 45 5 50 55.3 5 72.7 41.3 SMDJE48AH SMDJE48CAH H48A H48C 48 5 53.3 58.9 5 77.4 38.8 SMDJE51AH SMDJE51CAH H51A H51C 51 5 56.7 62.7 5 82.4 36.4 SMDJE54AH SMDJE54CAH H54A H54C 54 5 60 66.3 1 87.1 34.4 www.eaton.com/electronics 3 SMDJE Automotive grade 3000 W Transient voltage suppressor  Technical Data ELX1065 Effective June 2021 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) PPP derating in percentage (%) Pulse derating curve t (ms) TJ (°C) ISO16750-2 Test pulse 5A U US 0.9(US-UA) tr td 4 www.eaton.com/electronics 12V system 24V system Us 79V to 101V 151V to 202V Ri 0.5Ω¸to 4Ω¸ 1Ω ¸to 8Ω¸ td 0.1(US-UA) UA 0 Parameter t tr 40ms to 400ms 100ms to 350ms 5-10ms 5-10ms Technical Data ELX1065 SMDJE  Automotive grade 3000 W Transient voltage suppressor Effective June 2021  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMDJE30AH
1. 物料型号:SMDJE系列,包括不同的电压等级,如SMDJE12AH、SMDJE13AH等,直到SMDJE54AH。
2. 器件简介:这些瞬态电压抑制器适用于汽车底盘和安全系统、高级驾驶辅助系统(ADAS)、通信和信息娱乐系统、网络系统和车身电子、动力传动控制、xEV和电池系统等。
3. 引脚分配:文档中提到了阴极和阳极的引脚配置,包括单向和双向配置。
4. 参数特性:包括工作温度范围、稳态功率耗散、峰值脉冲功率耗散、最大瞬态正向电压、峰值正向浪涌电流、典型热阻等。
5. 功能详解:瞬态电压抑制器具备3000W的峰值脉冲功率能力、快速响应时间、低正向电压降、低反向漏电流等特性。
6. 应用信息:适用于汽车电子系统中的多种应用,包括但不限于上述简介中提到的系统。
7. 封装信息:提供了封装的尺寸信息,包括最小和最大尺寸,以及标记和包装信息。
8. 电气特性:列出了不同型号的电气规格,包括工作电压、测试电流、正向电压降、最大漏电流、峰值脉冲电流等。
9. V-I特性曲线:提供了单向和双向瞬态电压抑制器的V-I特性曲线图。
10. 焊接回流曲线:提供了焊接过程中的标准SnPb焊料和无铅焊料的温度曲线。
SMDJE30AH 价格&库存
很抱歉,暂时无法提供与“SMDJE30AH”相匹配的价格&库存,您可以联系我们找货
SMDJE30AH
    SMDJE30AH
      • 1+1.16835
      • 200+0.45220
      • 500+0.43622
      • 1000+0.42844
