SMDJE9-0CA
SMDJE9-0CA
    EATON(伊顿)
    SMC(DO-214AB)
    15.4V 夹子 20.5A Ipp TVS - 二极管 表面贴装型 SMC
SMDJE9-0CA 数据手册
Technical Data 11217 Effective March 2021 Supersedes November 2020 SMDJE 3000 W Transient voltage suppressor Applications Product features • Low profile SMC package • Excellent clamping capability • 3000 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 14 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. : E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Power conversion Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number SMDJE 5-0 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance SMDJE 3000 W Transient voltage suppressor  Technical Data 11217 Effective March 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 6.5 W Peak pulse power dissipation on 10/1000 μs waveform PPP 3000 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 300 A Typical thermal resistance junction to lead R JL 15 °C/W Typical thermal resistance junction to ambient R JA 75 °C/W Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm Part marking Millimeters Dimension Minimum Inches Maximum Minimum Maximum A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 K L Cathode band (Uni-polar only) Part marking: xxxx = Date code yyy- Refer to marking designator listed in Electrical Characteristics table 0.094 4.20 3.30 Packaging information (mm) 0.165 0.130 Dimensions Millimeters Inches Drawing not to scale. A0 6.05 ± 0.3 0.238 ± 0.012 Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) B0 8.31 ± 0.3 0.327 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 7.50 ± 0.2 0.295 ± 0.008 2 www.eaton.com/electronics P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.3145 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 Technical Data 11217 SMDJE 3000 W Transient voltage suppressor Effective March 2021  Electrical characteristics (+25 °C) Part number Uni-polar Bi-polar Marking Uni Bi VR (V) IR @ VR (μA) VBR @ IT min (V) max (V) IT (mA) VC @ IPP max (V) IPP (A) SMDJE5-0A SMDJE5-0CA HDE IDE 5 800 6.4 7 10 9.2 326.1 SMDJE6-0A SMDJE6-0CA HDG IDG 6 800 6.67 7.37 10 10.3 291.3 SMDJE6-5A SMDJE6-5CA HDK IDK 6.5 500 7.22 7.98 10 11.2 267.9 SMDJE7-0A SMDJE7-0CA HDM IDM 7 200 7.78 8.6 10 12 250 SMDJE7-5A SMDJE7-5CA HDP IDP 7.5 100 8.33 9.21 1 12.9 232.6 SMDJE8-0A SMDJE8-0CA HDR IDR 8 50 8.89 9.83 1 13.6 220.6 SMDJE8-5A SMDJE8-5CA HDT IDT 8.5 20 9.44 10.4 1 14.4 208.3 SMDJE9-0A SMDJE9-0CA HDV IDV 9 10 10 11.1 1 15.4 194.8 SMDJE10A SMDJE10CA HDX IDX 10 5 11.1 12.3 1 17 176.5 SMDJE11A SMDJE11CA HDZ IDZ 11 2 12.2 13.5 1 18.2 164.8 SMDJE12A SMDJE12CA HEE IEE 12 2 13.3 14.7 1 19.9 150.8 SMDJE13A SMDJE13CA HEG IEG 13 2 14.4 15.9 1 21.5 139.5 SMDJE14A SMDJE14CA HEK IEK 14 2 15.6 17.2 1 23.2 129.3 SMDJE15A SMDJE15CA HEM IEM 15 1 16.7 18.5 1 24.4 123 SMDJE16A SMDJE16CA HEP IEP 16 1 17.8 19.7 1 26 115.4 SMDJE17A SMDJE17CA HER IER 17 1 18.9 20.9 1 27.6 108.7 SMDJE18A SMDJE18CA HET IET 18 1 20 22.1 1 29.2 102.7 SMDJE20A SMDJE20CA HEV IEV 20 1 22.2 24.5 1 32.4 92.6 SMDJE22A SMDJE22CA HEX IEX 22 1 24.4 26.9 1 35.5 84.5 SMDJE24A SMDJE24CA HEZ IEZ 24 1 26.7 29.5 1 38.9 77.1 SMDJE26A SMDJE26CA HFE IFE 26 1 28.9 31.9 1 42.1 71.3 SMDJE28A SMDJE28CA HFG IFG 28 1 31.1 34.4 1 45.4 66.1 SMDJE30A SMDJE30CA HFK IFK 30 1 33.3 36.8 1 48.4 62 SMDJE33A SMDJE33CA HFM IFM 33 1 36.7 40.6 1 53.3 56.3 SMDJE36A SMDJE36CA HFP IFP 36 1 40 44.2 1 58.1 51.6 SMDJE40A SMDJE40CA HFR IFR 40 1 44.4 49.1 1 64.5 46.5 SMDJE43A SMDJE43CA HFT IFT 43 1 47.8 52.8 1 69.4 43.2 SMDJE45A SMDJE45CA HFV IFV 45 1 50 55.3 1 72.7 41.3 SMDJE48A SMDJE48CA HFX IFX 48 1 53.3 58.9 1 77.4 38.8 SMDJE51A SMDJE51CA HFZ IFZ 51 1 56.7 62.7 1 82.4 36.4 SMDJE54A SMDJE54CA HGE IGE 54 1 60 66.3 1 87.1 34.4 SMDJE58A SMDJE58CA HGG IGG 58 1 64.4 71.2 1 93.6 32.1 SMDJE60A SMDJE60CA HGK IGK 60 1 66.7 73.7 1 96.8 31 SMDJE64A SMDJE64CA HGM IGM 64 1 71.1 78.6 1 103 29.1 SMDJE70A SMDJE70CA HGP IGP 70 1 77.8 86 1 113 26.5 SMDJE75A SMDJE75CA HGR IGR 75 1 83.3 92.1 1 121 24.8 SMDJE78A SMDJE78CA HGT IGT 78 1 86.7 95.8 1 126 23.8 SMDJE85A SMDJE85CA HGV IGV 85 1 94.4 104 1 137 21.9 SMDJE90A SMDJE90CA HGX IGX 90 1 100 111 1 146 20.5 SMDJE100A SMDJE100CA HGZ IGZ 100 1 111 123 1 162 18.5 SMDJE110A SMDJE110CA HHE IHE 110 1 122 135 1 177 16.9 SMDJE120A SMDJE120CA HHG IHG 120 1 133 147 1 193 15.5 SMDJE130A SMDJE130CA HHK IHK 130 1 144 159 1 209 14.4 SMDJE150A SMDJE150CA HHM IHM 150 1 167 185 1 243 12.3 SMDJE160A SMDJE160CA HHP IHP 160 1 178 197 1 259 11.6 SMDJE170A SMDJE170CA HHR IHR 170 1 189 209 1 275 10.9 SMDJE180A SMDJE180CA HHT IHT 180 1 201 222 1 292 10.3 SMDJE190A SMDJE190CA HHV IHV 190 1 211 234 1 307 9.7 SMDJE200A SMDJE200CA HHX IHX 200 1 224 247 1 324 9.3 SMDJE210A SMDJE210CA HHZ IHZ 210 1 233 258 1 337 8.8 SMDJE220A SMDJE220CA HIE IIE 220 1 244 270 1 356 8.4 www.eaton.com/electronics 3 SMDJE 3000 W Transient voltage suppressor  Technical Data 11217 Effective March 2021 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional TVS diode Pulse waveform 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 PPP derating in percentage (%) Pulse derating curve Peak value Half value 50 td 0 0 1.0 2.0 3.0 100 Ppp (kW) 3000 W at 10/1000 μs +25 °C 10 1.0 0.1 td-Pulse width (ms) 4 www.eaton.com/electronics 60 40 20 25 50 75 100 125 150 TJ-Initial junction temperature (°C) Peak pulse power dissipation vs. pulse width 0.01 80 0 0 4.0 t (ms) 0.1 0.001 100 1.0 10 175 Technical Data 11217 SMDJE 3000 W Transient voltage suppressor Effective March 2021  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMDJE9-0CA
物料型号:SMDJE系列,例如SMDJE5-0C A
器件简介:SMDJE系列是瞬态电压抑制二极管,用于保护电子设备免受电压突波的损害。
引脚分配:文档中未明确提供引脚分配图,但提到了表面贴装应用,通常这类器件会有明确的引脚标记。
参数特性: - 工作结温范围:-55°C 至 +150°C - 稳态功率耗散:6.5W - 峰值脉冲功率耗散:3000W(10/1000μs波形) - 最大瞬态正向电压:5.0V(100A时) - 峰值正向浪涌电流:300A(8.3ms单半正弦波) - 典型热阻:结到引脚15°C/W,结到环境75°C/W
功能详解:SMDJE系列瞬态电压抑制二极管具有低轮廓的SMC封装,优秀的钳位能力,快速响应时间(从0V到VBR最小值通常小于1.0ps),并且可以在高温下进行回流焊接。
应用信息:适用于消费电子、电信、计算和服务器、家电、工业自动化和功率转换等领域。
封装信息:塑料封装符合UL 94 V-0可燃性等级,符合湿度敏感性等级1,终端:焊锡镀层引线,可按照J-STD-002进行焊接。
SMDJE9-0CA 价格&库存
很抱歉,暂时无法提供与“SMDJE9-0CA”相匹配的价格&库存,您可以联系我们找货
SMDJE9-0CA
    • 1+1.02384
    • 200+0.39626
    • 500+0.38232
    • 1000+0.37541
