SMCJE36AH
SMCJE36AH
    EATON(伊顿)
    SMC(DO-214AB)
    58.1V 夹子 25.8A Ipp TVS - 二极管 表面贴装型 SMC
SMCJE36AH 数据手册
Technical Data ELX1064 Effective June 2021 SMCJE Automotive grade 1500 W Transient voltage suppressor Applications Product features • Automotive grade (AEC-Q101 qualified) • Low profile SMC package • Excellent clamping capability • High reliability application • 1500 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: tin plated, solderable per J-STD-002 • UL 497B recognized. File No. : E198449 Guide QVGQ2 • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • AEC-Q101 qualified Ordering part number SMCJE 15 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance High reliability application PIN configuration H SMCJE Automotive grade 1500 W Transient voltage suppressor  Technical Data ELX1064 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 6.5 W Peak pulse power dissipation on 10/1000 μs waveform PPP 1500 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 200 A Typical thermal resistance junction to lead R JL 15 °C/W Typical thermal resistance junction to ambient R JA 75 °C/W 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Millimeters Inches Part marking Dimension Minimum Maximum Minimum Maximum A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 - 0.094 - K - 4.20 - 0.165 L 3.30 - 0.130 - Cathode band (uni-polar only) Part marking: xxxx = Date code yyy- Refer to marking designator listed in Electrical characteristics table Packaging information - mm/inches Drawing not to scale. Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) 2 www.eaton.com/electronics Dimensions Millimeters Inches A0 6.05 ± 0.3 0.238 ± 0.012 B0 8.31 ± 0.3 0.327 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 7.50 ± 0.2 0.295 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.3145 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 Technical Data ELX1064 SMCJE  Automotive grade 1500 W Transient voltage suppressor Effective June 2021  Electrical specifications (+25 °C) Part number VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) SMCJE15AH SMCJE15CAH GEM BEM 15 1 16.7 18.5 1 24.4 61.5 SMCJE16AH SMCJE16CAH GEP BEP 16 1 17.8 19.7 1 26 57.7 SMCJE17AH SMCJE17CAH GER BER 17 1 18.9 20.9 1 27.6 54.4 SMCJE18AH SMCJE18CAH GET BET 18 1 20 22.1 1 29.2 51.4 SMCJE20AH SMCJE20CAH GEV BEV 20 1 22.2 24.5 1 32.4 46.3 SMCJE22AH SMCJE22CAH GEX BEX 22 1 24.4 26.9 1 35.5 42.3 SMCJE24AH SMCJE24CAH GEZ BEZ 24 1 26.7 29.5 1 38.9 38.6 SMCJE26AH SMCJE26CAH GFE BFE 26 1 28.9 31.9 1 42.1 35.6 SMCJE28AH SMCJE28CAH GFG BFG 28 1 31.1 34.4 1 45.4 33.1 SMCJE30AH SMCJE30CAH GFK BFK 30 1 33.3 36.8 1 48.4 31 SMCJE33AH SMCJE33CAH GFM BFM 33 1 36.7 40.6 1 53.3 28.2 SMCJE36AH SMCJE36CAH GFP BFP 36 1 40 44.2 1 58.1 25.8 SMCJE40AH SMCJE40CAH GFR BFR 40 1 44.4 49.1 1 64.5 23.3 SMCJE43AH SMCJE43CAH GFT BFT 43 1 47.8 52.8 1 69.4 21.6 SMCJE45AH SMCJE45CAH GFV BFV 45 1 50 55.3 1 72.7 20.6 SMCJE48AH SMCJE48CAH GFX BFX 48 1 53.3 58.9 1 77.4 19.4 SMCJE51AH SMCJE51CAH GFZ BFZ 51 1 56.7 62.7 1 82.4 18.2 SMCJE54AH SMCJE54CAH GGE BGE 54 1 60 66.3 1 87.1 17.2 SMCJE58AH SMCJE58CAH GGG BGG 58 1 64.4 71.2 1 93.6 16.1 SMCJE60AH SMCJE60CAH GGK BGK 60 1 66.7 73.7 1 96.8 15.5 SMCJE64AH SMCJE64CAH GGM BGM 64 1 71.1 78.6 1 103 14.6 SMCJE70AH SMCJE70CAH GGP BGP 70 1 77.8 86 1 113 13.3 SMCJE75AH SMCJE75CAH GGR BGR 75 1 83.3 92.1 1 121 12.4 SMCJE78AH SMCJE78CAH GGT BGT 78 1 86.7 95.8 1 126 11.9 SMCJE85AH SMCJE85CAH GGV BGV 85 1 94.4 104 1 137 11 SMCJE90AH SMCJE90CAH GGX BGX 90 1 100 111 1 146 10.3 SMCJE100AH SMCJE100CAH GGZ BGZ 100 1 111 123 1 162 9.3 SMCJE110AH SMCJE110CAH GHE BHE 110 1 122 135 1 177 8.5 SMCJE120AH SMCJE120CAH GHG BHG 120 1 133 147 1 193 7.8 SMCJE130AH SMCJE130CAH GHK BHK 130 1 144 159 1 209 7.2 SMCJE150AH SMCJE150CAH GHM BHM 150 1 167 185 1 243 6.2 SMCJE160AH SMCJE160CAH GHP BHP 160 1 178 197 1 259 5.8 SMCJE170AH SMCJE170CAH GHR BHR 170 1 189 209 1 275 5.5 SMCJE180AH SMCJE180CAH GHT BHT 180 1 201 222 1 292 5.2 SMCJE190AH SMCJE190CAH GHU BHU 190 1 211 234 1 307 4.9 SMCJE200AH SMCJE200CAH GHV BHV 200 1 224 247 1 324 4.7 SMCJE210AH SMCJE210CAH GHW BHW 210 1 233 258 1 337 4.5 SMCJE220AH SMCJE220CAH GHX BHX 220 1 246 272 1 356 4.2 SMCJE250AH SMCJE250CAH GJG BJG 250 1 279 309 1 405 3.7 SMCJE300AH SMCJE300CAH GJK BJK 300 1 335 371 1 486 3.1 SMCJE350AH SMCJE350CAH GJM BJM 350 1 391 432 1 567 2.7 SMCJE400AH SMCJE400CAH GJP BJP 400 1 447 494 1 648 2.3 SMCJE440AH SMCJE440CAH GJR BJR 440 1 492 543 1 713 2.1 www.eaton.com/electronics 3 SMCJE Automotive grade 1500 W Transient voltage suppressor  Technical Data ELX1064 Effective June 2021 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) PPP derating in percentage (%) Pulse derating curve t (ms) TJ (°C) Peak pulse power dissipation curve 100 1500W at 10/1000 µs PPP (KW) 10 1.0 0.1 0.001 0.01 0.1 td - Pulse width (ms) 4 www.eaton.com/electronics 1.0 10 Technical Data ELX1064 SMCJE  Automotive grade 1500 W Transient voltage suppressor Effective June 2021  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMCJE36AH 价格&库存
很抱歉,暂时无法提供与“SMCJE36AH”相匹配的价格&库存,您可以联系我们找货
SMCJE36AH
    • 1+0.70989
    • 200+0.27476
    • 500+0.26514
    • 1000+0.26028
