SMDJ7.0CA/TR13
SMDJ7.0CA/TR13
    YAGEO(国巨)
    SMC(DO-214AB)
    12V 夹子 250A Ipp TVS - 二极管 表面贴装型 DO-214AB(SMC)
SMDJ7.0CA/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY SMDJ series Product specification– June 30, 2023 V.4 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 SMDJ Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 3000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 1μA above 10V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 16mm tape (EIA STD RS-481) ■ Weight: 0.28g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 3000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts IFSM 300 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 SMDJ Dimensions (SMC/DO-214AB) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 6.60 7.11 0.260 0.280 D 5.59 6.22 0.220 0.245 D1 2.90 3.20 0.114 0.126 T 7.75 8.13 0.305 0.320 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.20 2.80 0.087 0.110 H1 2.06 2.62 0.079 0.103 D1 D L H1 H d T1 T 3.20mm Pad: 1.75mm 4.69mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMDJ5.0A SMDJ5.0CA RDE DDE 5.0 6.40~7.00 10 9.2 326.1 800 SMDJ6.0A SMDJ6.0CA RDG DDG 6.0 6.67~7.37 10 10.3 291.3 800 SMDJ6.5A SMDJ6.5CA RDK DDK 6.5 7.22~7.98 10 11.2 267.9 500 SMDJ7.0A SMDJ7.0CA PDM DDM 7.0 7.78~8.60 10 12.0 250.0 200 SMDJ7.5A SMDJ7.5CA PDP DDP 7.5 8.33~9.21 1 12.9 232.6 100 SMDJ8.0A SMDJ8.0CA PDR DDR 8.0 8.89~9.83 1 13.6 220.6 50 SMDJ8.5A SMDJ8.5CA PDT DDT 8.5 9.44~10.40 1 14.4 208.3 20 SMDJ9.0A SMDJ9.0CA PDV DDV 9.0 10.00~11.10 1 15.4 194.8 10 SMDJ10A SMDJ10CA PDX DDX 10.0 11.10~12.30 1 17.0 176.5 5 SMDJ11A SMDJ11CA PDZ DDZ 11.0 12.20~13.50 1 18.2 164.8 2 SMDJ12A SMDJ12CA PEE DEE 12.0 13.30~14.70 1 19.9 150.8 2 SMDJ13A SMDJ13CA PEG DEG 13.0 14.40~15.90 1 21.5 139.5 2 SMDJ14A SMDJ14CA PEK DEK 14.0 15.60~17.20 1 23.2 129.3 2 SMDJ15A SMDJ15CA PEM DEM 15.0 16.70~18.50 1 24.4 123.0 2 SMDJ16A SMDJ16CA PEP DEP 16.0 17.80~19.70 1 26.0 115.4 2 SMDJ17A SMDJ17CA PER DER 17.0 18.90~20.90 1 27.6 108.7 2 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 4 9 SMDJ Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMDJ18A SMDJ18CA PET DET 18.0 20.00~22.10 1 29.2 102.7 2 SMDJ20A SMDJ20CA PEV DEV 20.0 22.20~24.50 1 32.4 92.6 2 SMDJ22A SMDJ22CA PEX DEX 22.0 24.40~26.90 1 35.5 84.5 2 SMDJ24A SMDJ24CA PEZ DEZ 24.0 26.70~29.50 1 38.9 77.1 2 SMDJ26A SMDJ26CA PFE DFE 26.0 28.90~31.90 1 42.1 71.3 2 SMDJ28A SMDJ28CA PFG DFG 28.0 31.10~34.40 1 45.4 66.1 2 SMDJ30A SMDJ30CA PFK DFK 30.0 33.30~36.80 1 48.4 62.0 2 SMDJ33A SMDJ33CA PFM DFM 33.0 36.70~40.60 1 53.3 56.3 2 SMDJ36A SMDJ36CA PFP DFP 36.0 40.00~44.20 1 58.1 51.6 2 SMDJ40A SMDJ40CA PFR DFR 40.0 44.40~49.10 1 64.5 46.5 2 SMDJ43A SMDJ43CA PFT DFT 43.0 47.80~52.80 1 69.4 43.2 2 SMDJ45A SMDJ45CA PFV DFV 45.0 50.00~55.30 1 72.7 41.3 2 SMDJ48A SMDJ48CA PFX DFX 48.0 53.30~58.90 1 77.4 38.8 2 SMDJ51A SMDJ51CA PFZ DFZ 51.0 56.70~62.70 1 82.4 36.4 2 SMDJ54A SMDJ54CA PGE DGE 54.0 60.00~66.30 1 87.1 34.4 2 SMDJ58A SMDJ58CA PGG DGG 58.0 64.40~71.20 1 93.6 32.1 2 SMDJ60A SMDJ60CA PGK DGK 60.0 66.70~73.70 1 96.8 31.0 2 SMDJ64A SMDJ64CA PGM DGM 64.0 71.10~78.60 1 103.0 29.1 2 SMDJ70A SMDJ70CA PGP DGP 70.0 77.80~86.00 1 113.0 26.5 2 SMDJ75A SMDJ75CA PGR DGR 75.0 83.30~92.10 1 121.0 24.8 2 SMDJ78A SMDJ78CA PGT DGT 78.0 86.70~95.80 1 126.0 23.8 2 SMDJ85A SMDJ85CA PGV DGV 85.0 94.40~104.00 1 137.0 21.9 2 SMDJ90A SMDJ90CA PGX DGX 90.0 100.00~111.00 1 146.0 20.5 2 SMDJ100A SMDJ100CA PGZ DGZ 100.0 111.00~123.00 1 162.0 18.5 2 SMDJ110A SMDJ110CA PHE DHE 110.0 122.00~135.00 1 177.0 16.9 2 SMDJ120A SMDJ120CA PHG DHG 120.0 133.00~147.00 1 193.0 15.5 2 SMDJ130A SMDJ130CA PHK DHK 130.0 144.00~159.00 1 209.0 14.4 2 SMDJ150A SMDJ150CA PHM DHM 150.0 167.00~185.00 1 243.0 12.3 2 SMDJ160A SMDJ160CA PHP DHP 160.0 178.00~197.00 1 259.0 11.6 2 SMDJ170A SMDJ170CA PHR DHR 170.0 189.00~209.00 1 275.0 10.9 2 SMDJ180A SMDJ180CA HHT IHT 180.0 201.00~222.00 1 292.0 10.3 2 SMDJ190A SMDJ190CA HHV IHV 190.0 211.00~233.00 1 308.0 9.7 2 SMDJ200A SMDJ200CA HHX IHX 200.0 224.00~247.00 1 324.0 9.3 2 SMDJ210A SMDJ210CA HHZ IHZ 210.0 237.00~263.00 1 340.0 8.8 2 SMDJ220A SMDJ220CA HIE IIE 220.0 246.00~272.00 1 356.0 8.4 2 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 SMDJ Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 1000 100 10 1 0.31×0.31″(8.0×8.0mm) Copper Pad Area 0.1 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 125 150 175 100000 Uni-directional 10000 Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 Peak Value IPPM 100 Half Value IPPM (IPPM/2) 1000 Bi-directional 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 1 1.0 2.0 3.0 4.0 Measured at 1MHz, 100mV, 0V bias 1 t-Time (ms) Figure 5. Steady State Power Dissipation Derating IFSM - Peak Forward Surve Current (A) 6 5 4 3 2 1 0 25 1000 Surge Current Uni-Directional Only 7 0 10 100 VRWM-Reverse Stand-Off Voltage (V) Figure 6. Maximum Non-Repetitive Forward Curve PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 350 300 250 200 150 100 50 0 1 10 Number of Cycles at 60Hz 100 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 SMDJ Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 SMDJ Marking Code Cathode Band YXXX YXXX RDE Logo DDE Intermal Control Code Marking Code Logo Intermal Control Code Marking Code Part Number Code SMDJ XXX C A / XXXX Package Code TR7:7 inch reel package TR13:13 inch reel package 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as SMDJXXXCA/TR7 13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as SMDJXXXCA/TR13 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 SMDJ Packaging Tape P0 P1 P2 D0 B T E Symbol Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 7.50±0.10 A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 F W B0 D1 A A B K0 SECTION B-B A0 SECTION A-A 7” Reel D4 D3 D2 13” Reel W1 Quantity: 500PCS D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.4 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
SMDJ7.0CA/TR13 价格&库存
很抱歉,暂时无法提供与“SMDJ7.0CA/TR13”相匹配的价格&库存,您可以联系我们找货
SMDJ7.0CA/TR13
  • 3000+2.417213000+0.31239
  • 6000+2.228816000+0.28804
  • 9000+2.132829000+0.27563
  • 15000+2.0249815000+0.26170
  • 21000+1.9611321000+0.25344
  • 30000+1.8991030000+0.24543
库存:3000
SMDJ7.0CA/TR13
  • 1+9.821451+1.26925
  • 10+6.1228910+0.79128
  • 100+4.00016100+0.51695
  • 500+3.08578500+0.39879
  • 1000+2.791411000+0.36074
库存:3000
