5.0SMDJ78CA/TR13
5.0SMDJ78CA/TR13
    YAGEO(国巨)
    SMC(DO-214AB)
    126V 夹子 39.7A Ipp TVS - 二极管 表面贴装型 DO-214AB(SMC)
5.0SMDJ78CA/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY 5.0SMDJ series Product specification– June 30, 2023 V.5 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 5.0SMDJ Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 5000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 2μA ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 16mm tape (EIA STD RS-481) ■ Weight: 0.30g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 5000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts IFSM 300 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 5.0SMDJ Dimensions (SMC/DO-214AB) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 6.60 7.11 0.260 0.280 D 5.59 6.22 0.220 0.245 D1 2.90 3.20 0.114 0.126 T 7.75 8.13 0.305 0.320 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.20 2.80 0.087 0.110 H1 2.06 2.62 0.079 0.103 D1 D L H1 H d T1 T 3.20mm Pad: 1.75mm 4.69mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 5.0SMDJ11A 5.0SMDJ11CA 5PEN 5BEN 11.0 12.20~13.50 10 18.2 275.00 800 5.0SMDJ12A 5.0SMDJ12CA 5PEP 5BEP 12.0 13.30~14.70 10 19.9 252.00 800 5.0SMDJ13A 5.0SMDJ13CA 5PEQ 5BEQ 13.0 14.40~15.90 10 21.5 233.00 500 5.0SMDJ14A 5.0SMDJ14CA 5PER 5BER 14.0 15.60~17.20 10 23.2 216.00 200 5.0SMDJ15A 5.0SMDJ15CA 5PES 5BES 15.0 16.70~18.50 1 24.4 205.00 100 5.0SMDJ16A 5.0SMDJ16CA 5PET 5BET 16.0 17.80~19.70 1 26.0 193.00 50 5.0SMDJ17A 5.0SMDJ17CA 5PEU 5BEU 17.0 18.90~20.90 1 27.6 181.00 20 5.0SMDJ18A 5.0SMDJ18CA 5PEV 5BEV 18.0 20.00~22.10 1 29.2 172.00 10 5.0SMDJ20A 5.0SMDJ20CA 5PEW 5BEW 20.0 22.20~24.50 1 32.4 155.00 5 5.0SMDJ22A 5.0SMDJ22CA 5PEX 5BEX 22.0 24.40~26.90 1 35.5 141.00 5 5.0SMDJ24A 5.0SMDJ24CA 5PEZ 5BEZ 24.0 26.70~29.50 1 38.9 129.00 2 5.0SMDJ26A 5.0SMDJ26CA 5PFE 5BFE 26.0 28.90~31.90 1 42.1 119.00 2 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors Part Number Device Marking Code 4 9 5.0SMDJ Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 5.0SMDJ28A 5.0SMDJ28CA 5PFG 5BFG 28.0 31.10~34.40 1 45.4 110.00 2 5.0SMDJ30A 5.0SMDJ30CA 5PFK 5BFK 30.0 33.30~36.80 1 48.4 103.00 2 5.0SMDJ33A 5.0SMDJ33CA 5PFM 5BFM 33.0 36.70~40.60 1 53.3 93.90 2 5.0SMDJ36A 5.0SMDJ36CA 5PFP 5BFP 36.0 40.00~44.20 1 58.1 86.10 2 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 40.0 44.40~49.10 1 64.5 77.60 2 5.0SMDJ43A 5.0SMDJ43CA 5PFT 5BFT 43.0 47.80~52.80 1 69.4 72.10 2 5.0SMDJ45A 5.0SMDJ45CA 5PFV 5BFV 45.0 50.00~55.30 1 72.7 68.80 2 5.0SMDJ48A 5.0SMDJ48CA 5PFX 5BFX 48.0 53.30~58.90 1 77.4 64.70 2 5.0SMDJ51A 5.0SMDJ51CA 5PFZ 5BFZ 51.0 56.70~62.70 1 82.4 60.70 2 5.0SMDJ54A 5.0SMDJ54CA 5PGE 5BGE 54.0 60.00~66.30 1 87.1 57.50 2 5.0SMDJ58A 5.0SMDJ58CA 5PGG 5BGG 58.0 64.40~71.20 1 93.6 53.50 2 5.0SMDJ60A 5.0SMDJ60CA 5PGK 5BGK 60.0 66.70~73.70 1 96.8 51.70 2 5.0SMDJ64A 5.0SMDJ64CA 5PGM 5BGM 64.0 71.10~78.60 1 103.0 48.60 2 5.0SMDJ70A 5.0SMDJ70CA 5PGP 5BGP 70.0 77.80~86.00 1 113.0 44.30 2 5.0SMDJ75A 5.0SMDJ75CA 5PGR 5BGR 75.0 83.30~92.10 1 121.0 41.40 2 5.0SMDJ78A 5.0SMDJ78CA 5PGT 5BGT 78.0 86.70~95.80 1 126.0 39.70 2 5.0SMDJ85A 5.0SMDJ85CA 5PGV 5BGV 85.0 94.40~104.00 1 137.0 36.50 2 5.0SMDJ90A 5.0SMDJ90CA 5PGX 5BGX 90.0 100.00~111.00 1 146.0 34.30 2 5.0SMDJ100A 5.0SMDJ100CA 5PGZ 5BGZ 100.0 111.00~123.00 1 162.0 30.90 2 5.0SMDJ110A 5.0SMDJ110CA 5PHE 5BHE 110.0 122.00~135.00 1 177.0 28.30 2 5.0SMDJ120A 5.0SMDJ120CA 5PHG 5BHG 120.0 133.00~147.00 1 193.0 26.00 2 5.0SMDJ130A 5.0SMDJ130CA 5PHK 5BHK 130.0 144.00~159.00 1 209.0 24.00 2 5.0SMDJ150A 5.0SMDJ150CA 5PHM 5BHM 150.0 167.00~185.00 1 243.0 20.60 2 5.0SMDJ160A 5.0SMDJ160CA 5PHP 5BHP 160.0 178.00~197.00 1 259.0 19.30 2 5.0SMDJ170A 5.0SMDJ170CA 5PHR 5BHR 170.0 189.00~209.00 1 275.0 18.20 2 5.0SMDJ180A 5.0SMDJ180CA 5HHT 5BHT 180.0 201.00~222.00 1 292.0 17.1 2 5.0SMDJ190A 5.0SMDJ190CA 5HHV 5BHU 190.0 211.00~243.00 1 308.0 16.2 2 5.0SMDJ200A 5.0SMDJ200CA 5HHX 5BHV 200.0 224.00~247.00 1 324.0 15.4 2 5.0SMDJ210A 5.0SMDJ210CA 5HHZ 5BHW 210.0 237.00~269.00 1 340.0 14.7 2 5.0SMDJ220A 5.0SMDJ220CA 5HIE 5BHX 220.0 246.00~272.00 1 356.0 14.0 2 5.0SMDJ250A 5.0SMDJ250CA 5HIG 5BHZ 250.0 279.00~309.00 1 405.0 12.3 2 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 5.0SMDJ Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % Figure 1. Peak Pulse Power Rating Curve PPPM - Peak Pulse Power (kW) 1000 100 10 1 0.31×0.31″(8.0×8.0mm) Copper Pad Area 0.1 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 125 150 175 100000 Uni-directional 10000 Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 Peak Value IPPM 100 Half Value IPPM (IPPM/2) 1000 Bi-directional 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 Measured at 1MHz, 100mV, 0V bias 1 1.0 2.0 3.0 4.0 1 t-Time (ms) Figure 5. Steady State Power Dissipation Derating IFSM - Peak Forward Surve Current (A) 6 5 4 3 2 1 0 25 1000 Surge Current Uni-Directional Only 7 0 10 100 VRWM-Reverse Stand-Off Voltage (V) Figure 6. Maximum Non-Repetitive Forward Curve PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 350 300 250 200 150 100 50 0 1 10 Number of Cycles at 60Hz 100 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 5.0SMDJ Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate Time maintained above: -Temperature (TL) -Time (tL) Peak Temperature (TP) Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 3℃/second max. 217℃ 60-150 seconds 260℃ 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 5.0SMDJ Marking Code Cathode Band YXXX YXXX 5PEN Logo 5BEN Intermal Control Code Marking Code Logo Intermal Control Code Marking Code Part Number Code 5.0SMDJ XXX C A / XXXX Package Code TR7:7 inch reel package TR13:13 inch reel package 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “/TR7 ” at the end of the part number, such as 5.0SMDJXXXCA/TR7 13 inch reel package: Add suffix “/TR13 ” at the end of the part number, such as 5.0SMDJXXXCA/TR13. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 5.0SMDJ Packaging Tape P0 P1 P2 D0 B T E Symbol Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 7.50±0.10 A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 F W B0 D1 A A B K0 SECTION B-B A0 SECTION A-A 7” Reel D4 D3 D2 W1 Quantity: 500PCS 13” Reel D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.5 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
5.0SMDJ78CA/TR13
物料型号:5.0SMDJ系列
器件简介:瞬态电压抑制二极管(TVS),适用于表面贴装,优化板空间,低剖面封装,内置应力消除,玻璃钝化结,低电感,优秀的钳位能力。
引脚分配:JEDEC DO-214AB封装,端子为锡镀层,符合MIL-STD-750标准,极性由色带表示。
参数特性: - 峰值脉冲功率:5000W,10/1000μs波形 - 稳态功率耗散:6.5W(TA=50°C) - 峰值正向浪涌电流:300A(8.3ms单半正弦波) - 工作和存储温度范围:-55°C至+150°C - 典型热阻:结到引线15°C/W,结到环境75°C/W
功能详解: - 快速响应时间 - 典型反向漏电流小于2μA - 高温焊接:260℃/10秒 - 符合UL安全认证,IEC61000-4-2 ESD标准
应用信息: - 用于交流/直流电源的VO接口 - 低频信号传输线(如RS232, RS485等)
封装信息:塑料封装,符合94V-0可燃性标准,符合J-STD-020的MSL等级1。
电气特性表格详细列出了单向和双向TVS的型号、设备标记代码、反向工作电压、击穿电压、测试电流、最大钳位电压、峰值脉冲电流和反向漏电流。
5.0SMDJ78CA/TR13 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ78CA/TR13”相匹配的价格&库存,您可以联系我们找货
5.0SMDJ78CA/TR13
    • 1+0.76637
    • 200+0.30586
    • 500+0.29560
    • 1000+0.29052
    5.0SMDJ78CA/TR13
    • 1+7.54614
    • 10+5.25714
    • 100+4.62830
    • 250+4.12522
    • 1000+3.87369
    • 3000+3.52393
    • 9000+3.38379
    • 15000+3.27239
    • 30000+3.13225
    5.0SMDJ78CA/TR13
    • 1+10.365741+1.34752
    • 10+6.4902710+0.84372
    • 100+4.24910100+0.55237
    • 500+3.28690500+0.42729
    • 1000+2.976941000+0.38700
    库存:207
    5.0SMDJ78CA/TR13
    • 3000+2.594333000+0.33726
    • 9000+2.467489000+0.32077
