SMCJE200CA
SMCJE200CA
    EATON(伊顿)
    SMC(DO-214AB)
    TVS DIODE 200VWM 324VC SMC
SMCJE200CA 数据手册
Technical Data 11215 Effective November 2020 SMCJE 1500 W Transient voltage suppressor Applications Product features • Low profile SMC package • Excellent clamping capability • 1500 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 11 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. : E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Power conversion Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number SMCJE 5-0 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance SMCJE 1500 W Transient voltage suppressor  Technical Data 11215 Effective November 2020 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 6.5 W Peak pulse power dissipation on 10/1000 μs waveform PPP 1500 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 200 A Typical thermal resistance junction to lead R JL 15 °C/W Typical thermal resistance junction to ambient R JA 75 °C/W Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Part marking Mechanical parameters, pad layout- mm Millimeters Dimension Minimum Inches Maximum Minimum Maximum A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 K L Part marking: xxxx = Date code yyy- Refer to marking designator listed in Electrical Characteristics table 0.094 4.20 0.165 3.30 Packaging information (mm) Cathode band (Uni-polar only) 0.130 Dimension Millimeters Inches Drawing not to scale. A0 6.05 ± 0.3 0.238 ± 0.012 Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) B0 8.31 ± 0.3 0.327 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 7.50 ± 0.2 0.295 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.315 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 2 www.eaton.com/electronics Technical Data 11215 SMCJE 1500 W Transient voltage suppressor Effective November 2020  Electrical characteristics (+25 °C) Part number VR IR @ VR VBR@ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (μA) min (V) max (V) (mA) max (V) (A) SMCJE5-0A SMCJE5-0CA GDE BDE 5 300 6.4 7 10 9.2 163 SMCJE6-0A SMCJE6-0CA GDG BDG 6 250 6.67 7.37 10 10.3 145.6 SMCJE6-5A SMCJE6-5CA GDK BDK 6.5 150 7.22 7.98 10 11.2 134 SMCJE7-0A SMCJE7-0CA GDM BDM 7 100 7.78 8.6 10 12 125 SMCJE7-5A SMCJE7-5CA GDP BDP 7.5 50 8.33 9.21 1 12.9 116.3 SMCJE8-0A SMCJE8-0CA GDR BDR 8 30 8.89 9.83 1 13.6 110.3 SMCJE8-5A SMCJE8-5CA GDT BDT 8.5 20 9.44 10.4 1 14.4 104.2 SMCJE9-0A SMCJE9-0CA GDV BDV 9 10 10 11.1 1 15.4 97.4 SMCJE10A SMCJE10CA GDX BDX 10 5 11.1 12.3 1 17 88.2 SMCJE11A SMCJE11CA GDZ BDZ 11 2 12.2 13.5 1 18.2 82.4 SMCJE12A SMCJE12CA GEE BEE 12 1 13.3 14.7 1 19.9 75.4 SMCJE13A SMCJE13CA GEG BEG 13 1 14.4 15.9 1 21.5 69.8 SMCJE14A SMCJE14CA GEK BEK 14 1 15.6 17.2 1 23.2 64.7 SMCJE15A SMCJE15CA GEM BEM 15 1 16.7 18.5 1 24.4 61.5 SMCJE16A SMCJE16CA GEP BEP 16 1 17.8 19.7 1 26 57.7 SMCJE17A SMCJE17CA GER BER 17 1 18.9 20.9 1 27.6 54.4 SMCJE18A SMCJE18CA GET BET 18 1 20 22.1 1 29.2 51.4 SMCJE20A SMCJE20CA GEV BEV 20 1 22.2 24.5 1 32.4 46.3 SMCJE22A SMCJE22CA GEX BEX 22 1 24.4 26.9 1 35.5 42.3 SMCJE24A SMCJE24CA GEZ BEZ 24 1 26.7 29.5 1 38.9 38.6 SMCJE26A SMCJE26CA GFE BFE 26 1 28.9 31.9 1 42.1 35.6 SMCJE28A SMCJE28CA GFG BFG 28 1 31.1 34.4 1 45.4 33.1 SMCJE30A SMCJE30CA GFK BFK 30 1 33.3 36.8 1 48.4 31 SMCJE33A SMCJE33CA GFM BFM 33 1 36.7 40.6 1 53.3 28.2 SMCJE36A SMCJE36CA GFP BFP 36 1 40 44.2 1 58.1 25.8 SMCJE40A SMCJE40CA GFR BFR 40 1 44.4 49.1 1 64.5 23.3 SMCJE43A SMCJE43CA GFT BFT 43 1 47.8 52.8 1 69.4 21.6 SMCJE45A SMCJE45CA GFV BFV 45 1 50 55.3 1 72.7 20.6 SMCJE48A SMCJE48CA GFX BFX 48 1 53.3 58.9 1 77.4 19.4 SMCJE51A SMCJE51CA GFZ BFZ 51 1 56.7 62.7 1 82.4 18.2 SMCJE54A SMCJE54CA GGE BGE 54 1 60 66.3 1 87.1 17.2 SMCJE58A SMCJE58CA GGG BGG 58 1 64.4 71.2 1 93.6 16.1 SMCJE60A SMCJE60CA GGK BGK 60 1 66.7 73.7 1 96.8 15.5 SMCJE64A SMCJE64CA GGM BGM 64 1 71.1 78.6 1 103 14.6 SMCJE70A SMCJE70CA GGP BGP 70 1 77.8 86 1 113 13.3 SMCJE75A SMCJE75CA GGR BGR 75 1 83.3 92.1 1 121 12.4 SMCJE78A SMCJE78CA GGT BGT 78 1 86.7 95.8 1 126 11.9 SMCJE85A SMCJE85CA GGV BGV 85 1 94.4 104 1 137 11 SMCJE90A SMCJE90CA GGX BGX 90 1 100 111 1 146 10.3 SMCJE100A SMCJE100CA GGZ BGZ 100 1 111 123 1 162 9.3 SMCJE110A SMCJE110CA GHE BHE 110 1 122 135 1 177 8.5 SMCJE120A SMCJE120CA GHG BHG 120 1 133 147 1 193 7.8 SMCJE130A SMCJE130CA GHK BHK 130 1 144 159 1 209 7.2 SMCJE150A SMCJE150CA GHM BHM 150 1 167 185 1 243 6.2 SMCJE160A SMCJE160CA GHP BHP 160 1 178 197 1 259 5.8 SMCJE170A SMCJE170CA GHR BHR 170 1 189 209 1 275 5.5 SMCJE180A SMCJE180CA GHT BHT 180 1 201 222 1 292 5.2 SMCJE190A SMCJE190CA GHU BHU 190 1 211 234 1 307 4.9 SMCJE200A SMCJE200CA GHV BHV 200 1 224 247 1 324 4.7 SMCJE210A SMCJE210CA GHW BHW 210 1 233 258 1 337 4.5 SMCJE220A SMCJE220CA GHX BHX 220 1 246 272 1 356 4.2 SMCJE250A SMCJE250CA GJG BJG 250 1 279 309 1 405 3.7 SMCJE300A SMCJE300CA GJK BJK 300 1 335 371 1 486 3.1 SMCJE350A SMCJE350CA GJM BJM 350 1 391 432 1 567 2.7 SMCJE400A SMCJE400CA GJP BJP 400 1 447 494 1 648 2.3 SMCJE440A SMCJE440CA GJR BJR 440 1 492 543 1 713 2.1 www.eaton.com/electronics 3 SMCJE 1500 W Transient voltage suppressor  Technical Data 11215 Effective November 2020 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional TVS diode Pulse derating curve 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 Peak value Half value 50 0 0 td 1.0 2.0 3.0 4.0 t (ms) 100 Ppp (kW) 1500 W at 10/1000 μs +25 °C 10 1.0 0.1 0.001 0.01 0.1 td-Pulse width (ms) www.eaton.com/electronics 100 80 60 40 20 0 0 25 50 75 100 125 150 TJ-Initial junction temperature (°C) Peak pulse power dissipation vs. pulse width 4 PPP derating in percentage (%) Pulse waveform 1.0 10 175 Technical Data 11215 SMCJE 1500 W Transient voltage suppressor Effective November 2020  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMCJE200CA
物料型号:SMCJE系列,例如SMCJE5-0CA、SMCJE6-5A等。
器件简介:这是一种瞬态电压抑制器,具有1500W的峰值脉冲功率能力,在10/1000μs波形下工作,适用于消费电子、通信、计算和服务器、家电、工业自动化和功率转换等领域。
引脚分配:文档中提到了表面贴装应用的引脚配置,但具体的引脚分配图或描述在文档中未明确展示。
参数特性:包括工作温度范围(-55°C至+150°C)、稳态功率消耗(6.5W)、峰值脉冲功率消耗(1500W)、最大瞬态正向电压(例如5.0V)、峰值正向浪涌电流(200A)、典型热阻等。
功能详解:瞬态电压抑制器用于保护电子设备免受电压瞬变的影响,具有快速响应时间(小于1.0ps)、低反向漏电流(典型值小于1μA)、高温度回流焊接能力(+260°C/40s)。
应用信息:适用于多种应用领域,如消费电子、通信、计算和服务器、家电、工业自动化和功率转换。
封装信息:低剖面SMC封装,符合UL 94 V-0可燃性等级,满足湿度敏感性等级1,终端为电镀引线,可按照J-STD-002进行焊接。
SMCJE200CA 价格&库存
很抱歉,暂时无法提供与“SMCJE200CA”相匹配的价格&库存,您可以联系我们找货
SMCJE200CA
    SMCJE200CA
      • 1+0.72155
      • 200+0.27929
      • 500+0.26946
      • 1000+0.26460
