DATA SHEET
TRANSIENT VOLTAGE SUPPRESSORS
AC/DC POWER SUPPLY
5.0SMDJ series
Product specification– June 30, 2023 V.5
RoHS compliant & Halogen free
Circuit Protection
Product Specification
Transient Voltage Suppressors
2
9
5.0SMDJ
Transient Voltage Suppressors (TVS) Data Sheet
Features
■ For surface mounted applications in order to optimize board space
■ Low profile package
■ Built-in strain relief
■ Glass passivated junction
■ Low inductance
■ Excellent clamping capability
■ 5000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01%
■ Fast response time
■ Typical IR less than 2μA
■ High Temperature soldering: 260℃/10 seconds at terminals
■ Plastic package has underwriters laboratory flammability 94V-0
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL
■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction
■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026
■ Polarity: Color band denotes cathode except bi-directional models
■ Standard Packaging: 16mm tape (EIA STD RS-481)
■ Weight: 0.30g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 5000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
IFSM
300
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
15
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2.
2. Mounted on 8.0mm×8.0mm copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
www.ya geo.com
Jun. 30, 2023 V.5
Circuit Protection
3
9
5.0SMDJ
Dimensions (SMC/DO-214AB)
Product:
Millimeters
Inches
Symbol
Cathode Band
Min.
Max.
Min.
Max.
L
6.60
7.11
0.260
0.280
D
5.59
6.22
0.220
0.245
D1
2.90
3.20
0.114
0.126
T
7.75
8.13
0.305
0.320
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.20
2.80
0.087
0.110
H1
2.06
2.62
0.079
0.103
D1 D
L
H1 H
d
T1
T
3.20mm
Pad:
1.75mm
4.69mm
1.75mm
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5.0SMDJ11A
5.0SMDJ11CA
5PEN
5BEN
11.0
12.20~13.50
10
18.2
275.00
800
5.0SMDJ12A
5.0SMDJ12CA
5PEP
5BEP
12.0
13.30~14.70
10
19.9
252.00
800
5.0SMDJ13A
5.0SMDJ13CA
5PEQ
5BEQ
13.0
14.40~15.90
10
21.5
233.00
500
5.0SMDJ14A
5.0SMDJ14CA
5PER
5BER
14.0
15.60~17.20
10
23.2
216.00
200
5.0SMDJ15A
5.0SMDJ15CA
5PES
5BES
15.0
16.70~18.50
1
24.4
205.00
100
5.0SMDJ16A
5.0SMDJ16CA
5PET
5BET
16.0
17.80~19.70
1
26.0
193.00
50
5.0SMDJ17A
5.0SMDJ17CA
5PEU
5BEU
17.0
18.90~20.90
1
27.6
181.00
5.0SMDJ18A
5.0SMDJ18CA
5PEV
5BEV
18.0
20.00~22.10
1
29.2
172.00
10
5.0SMDJ20A
5.0SMDJ20CA
5PEW
5BEW
20.0
22.20~24.50
1
32.4
155.00
5
5.0SMDJ22A
5.0SMDJ22CA
5PEX
5BEX
22.0
24.40~26.90
1
35.5
141.00
5
5.0SMDJ24A
5.0SMDJ24CA
5PEZ
5BEZ
24.0
26.70~29.50
1
38.9
129.00
2
5.0SMDJ26A
5.0SMDJ26CA
5PFE
5BFE
26.0
28.90~31.90
1
42.1
119.00
2
www.ya geo.com
Jun. 30, 2023 V.5
Circuit Protection
Part Number
Device
Marking
Code
4
9
5.0SMDJ
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5.0SMDJ28A
5.0SMDJ28CA
5PFG
5BFG
28.0
31.10~34.40
1
45.4
110.00
2
5.0SMDJ30A
5.0SMDJ30CA
5PFK
5BFK
30.0
33.30~36.80
1
48.4
103.00
2
5.0SMDJ33A
5.0SMDJ33CA
5PFM
5BFM
33.0
36.70~40.60
1
53.3
93.90
2
5.0SMDJ36A
5.0SMDJ36CA
5PFP
5BFP
36.0
40.00~44.20
1
58.1
86.10
2
5.0SMDJ40A
5.0SMDJ40CA
5PFR
5BFR
40.0
44.40~49.10
1
64.5
77.60
2
5.0SMDJ43A
5.0SMDJ43CA
5PFT
5BFT
43.0
47.80~52.80
1
69.4
72.10
2
5.0SMDJ45A
5.0SMDJ45CA
5PFV
5BFV
45.0
50.00~55.30
1
72.7
68.80
2
5.0SMDJ48A
5.0SMDJ48CA
5PFX
5BFX
48.0
53.30~58.90
1
77.4
64.70
2
5.0SMDJ51A
5.0SMDJ51CA
5PFZ
5BFZ
51.0
56.70~62.70
1
82.4
60.70
2
5.0SMDJ54A
5.0SMDJ54CA
5PGE
5BGE
54.0
60.00~66.30
1
87.1
57.50
2
5.0SMDJ58A
5.0SMDJ58CA
5PGG
5BGG
58.0
64.40~71.20
1
93.6
53.50
2
5.0SMDJ60A
5.0SMDJ60CA
5PGK
5BGK
60.0
66.70~73.70
1
96.8
51.70
2
5.0SMDJ64A
5.0SMDJ64CA
5PGM
5BGM
64.0
71.10~78.60
1
103.0
48.60
2
5.0SMDJ70A
5.0SMDJ70CA
5PGP
5BGP
70.0
77.80~86.00
1
113.0
44.30
2
5.0SMDJ75A
5.0SMDJ75CA
5PGR
5BGR
75.0
83.30~92.10
1
121.0
41.40
2
5.0SMDJ78A
5.0SMDJ78CA
5PGT
5BGT
78.0
86.70~95.80
1
126.0
39.70
2
5.0SMDJ85A
5.0SMDJ85CA
5PGV
5BGV
85.0
94.40~104.00
1
137.0
36.50
2
5.0SMDJ90A
5.0SMDJ90CA
5PGX
5BGX
90.0
100.00~111.00
1
146.0
34.30
2
5.0SMDJ100A
5.0SMDJ100CA
5PGZ
5BGZ
100.0
111.00~123.00
1
162.0
30.90
2
5.0SMDJ110A
5.0SMDJ110CA
5PHE
5BHE
110.0
122.00~135.00
1
177.0
28.30
2
5.0SMDJ120A
5.0SMDJ120CA
5PHG
5BHG
120.0
133.00~147.00
1
193.0
26.00
2
5.0SMDJ130A
5.0SMDJ130CA
5PHK
5BHK
130.0
144.00~159.00
1
209.0
24.00
2
5.0SMDJ150A
5.0SMDJ150CA
5PHM
5BHM
150.0
167.00~185.00
1
243.0
20.60
2
5.0SMDJ160A
5.0SMDJ160CA
5PHP
5BHP
160.0
178.00~197.00
1
259.0
19.30
2
5.0SMDJ170A
5.0SMDJ170CA
5PHR
5BHR
170.0
189.00~209.00
1
275.0
18.20
2
5.0SMDJ180A
5.0SMDJ180CA
5HHT
5BHT
180.0
201.00~222.00
1
292.0
17.1
2
5.0SMDJ190A
5.0SMDJ190CA
5HHV
5BHU
190.0
211.00~243.00
1
308.0
16.2
2
5.0SMDJ200A
5.0SMDJ200CA
5HHX
5BHV
200.0
224.00~247.00
1
324.0
15.4
2
5.0SMDJ210A
5.0SMDJ210CA
5HHZ
5BHW
210.0
237.00~269.00
1
340.0
14.7
2
5.0SMDJ220A
5.0SMDJ220CA
5HIE
5BHX
220.0
246.00~272.00
1
356.0
14.0
2
5.0SMDJ250A
5.0SMDJ250CA
5HIG
5BHZ
250.0
279.00~309.00
1
405.0
12.3
2
www.ya geo.com
Jun. 30, 2023 V.5
Circuit Protection
5
9
5.0SMDJ
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 1. Peak Pulse Power Rating Curve
PPPM - Peak Pulse Power (kW)
1000
100
10
1
0.31×0.31″(8.0×8.0mm)
Copper Pad Area
0.1
0.1
1
100
10
100
80
60
40
td-Pulse Width (µs)
125
150
175
100000
Uni-directional
10000
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
100
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
1000
Bi-directional
100
50
10/1000µs Waveform
as defined by R.E.A
10
td
Measured at
1MHz, 100mV, 0V bias
1
1.0
2.0
3.0
4.0
1
t-Time (ms)
Figure 5. Steady State Power Dissipation Derating
IFSM - Peak Forward Surve Current (A)
6
5
4
3
2
1
1000
Surge Current Uni-Directional Only
7
100
VRWM-Reverse Stand-Off Voltage (V)
Figure 6. Maximum Non-Repetitive Forward
Curve
PM(AV), Steady State Power Dissipation (W)
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
150
25
50
75
100
125
150
175
350
300
250
200
150
100
50
10
Number of Cycles at 60Hz
100
www.ya geo.com
Jun. 30, 2023 V.5
Circuit Protection
6
9
5.0SMDJ
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
Peak Temperature (TP)
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
3℃/second max.
217℃
60-150 seconds
260℃
20-40 seconds
6℃/second max.
8 minutes max.
www.ya geo.com
Jun. 30, 2023 V.5
Circuit Protection
7
9
5.0SMDJ
Marking Code
Cathode Band
YXXX
YXXX
5PEN
Logo
5BEN
Intermal Control Code
Marking Code
Logo
Marking Code
Part Number Code
5.0SMDJ
XXX C A / XXXX
Package Code
TR7:7 inch reel package
TR13:13 inch reel package
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
7 inch reel package: Add suffix “/TR7 ” at the end of the part number, such as 5.0SMDJXXXCA/TR7
13 inch reel package: Add suffix “/TR13 ” at the end of the part number, such as 5.0SMDJXXXCA/TR13.
www.ya geo.com
Jun. 30, 2023 V.5
Circuit Protection
8
9
5.0SMDJ
Packaging
Tape
P0
P1
P2
D0
B
T
E
Symbol
Dimension (mm)
W
16.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.5±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
7.50±0.10
A0
6.27±0.10
B0
8.30±0.10
K0
3.15±0.15
T
0.30±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
20.0±2.0
F
W
B0
D1
A
A
B
K0
SECTION B-B
A0
SECTION A-A
7” Reel
D4
D3
D2
W1
Quantity: 500PCS
13” Reel
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
20.0±2.0
Quantity: 3000PCS
www.ya geo.com
Jun. 30, 2023 V.5
Circuit Protection Components
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum exten t permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates
do not recommend the use of commercial or automotive grade products for high reliability
applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
