5.0SMDJ26A-AT/13
5.0SMDJ26A-AT/13
    YAGEO(国巨)
    SMC(DO-214AB)
    5.0SMDJ, DO-214AB, 26V, 42.1V, A
5.0SMDJ26A-AT/13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY 5.0SMDJ-AT series Product specification– June 30, 2023 V.4 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 5.0SMDJ-AT Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 5000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 2μA above 22V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ AEC-Q101 qualified ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 16mm tape (EIA STD RS-481) ■ Weight: 0.30g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform PPPM Minimum 5000 Watts (Note1, Note2, Fig.1) Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps Steady state power dissipation at TA=50℃ (Fig.5) PM(AV) 6.5 Watts Peak forward surge current, 8.3ms single half sine-wave IFSM 300 Amps superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 5.0SMDJ-AT Dimensions (SMC/DO-214AB) Product: Millimeters Inches Symbol Cathode Band D1 D Min. Max. Min. Max. L 6.60 7.11 0.260 0.280 D 5.59 6.22 0.220 0.245 D1 2.90 3.20 0.114 0.126 T 7.75 8.13 0.305 0.320 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.20 2.80 0.087 0.110 H1 2.06 2.62 0.079 0.103 L H1 H d T1 T 3.20mm Pad: 1.75mm 4.69mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 5.0SMDJ11A-AT 5.0SMDJ11CA-AT 5PEN 5BEN 11.0 12.20~13.50 10 18.2 275.00 800 5.0SMDJ12A-AT 5.0SMDJ12CA-AT 5PEP 5BEP 12.0 13.30~14.70 10 19.9 252.00 800 5.0SMDJ13A-AT 5.0SMDJ13CA-AT 5PEQ 5BEQ 13.0 14.40~15.90 10 21.5 233.00 500 5.0SMDJ14A-AT 5.0SMDJ14CA-AT 5PER 5BER 14.0 15.60~17.20 10 23.2 216.00 200 5.0SMDJ15A-AT 5.0SMDJ15CA-AT 5PES 5BES 15.0 16.70~18.50 1 24.4 205.00 100 5.0SMDJ16A-AT 5.0SMDJ16CA-AT 5PET 5BET 16.0 17.80~19.70 1 26.0 193.00 50 5.0SMDJ17A-AT 5.0SMDJ17CA-AT 5PEU 5BEU 17.0 18.90~20.90 1 27.6 181.00 20 5.0SMDJ18A-AT 5.0SMDJ18CA-AT 5PEV 5BEV 18.0 20.00~22.10 1 29.2 172.00 10 5.0SMDJ20A-AT 5.0SMDJ20CA-AT 5PEW 5BEW 20.0 22.20~24.50 1 32.4 155.00 5 5.0SMDJ22A-AT 5.0SMDJ22CA-AT 5PEX 5BEX 22.0 24.40~26.90 1 35.5 141.00 5 5.0SMDJ24A-AT 5.0SMDJ24CA-AT 5PEZ 5BEZ 24.0 26.70~29.50 1 38.9 129.00 2 5.0SMDJ26A-AT 5.0SMDJ26CA-AT 5PFE 5BFE 26.0 28.90~31.90 1 42.1 119.00 2 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors Part Number Device Marking Code 4 9 5.0SMDJ-AT Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 5.0SMDJ28A-AT 5.0SMDJ28CA-AT 5PFG 5BFG 28.0 31.10~34.40 1 45.4 110.00 2 5.0SMDJ30A-AT 5.0SMDJ30CA-AT 5PFK 5BFK 30.0 33.30~36.80 1 48.4 103.00 2 5.0SMDJ33A-AT 5.0SMDJ33CA-AT 5PFM 5BFM 33.0 36.70~40.60 1 53.3 93.90 2 5.0SMDJ36A-AT 5.0SMDJ36CA-AT 5PFP 5BFP 36.0 40.00~44.20 1 58.1 86.10 2 5.0SMDJ40A-AT 5.0SMDJ40CA-AT 5PFR 5BFR 40.0 44.40~49.10 1 64.5 77.60 2 5.0SMDJ43A-AT 5.0SMDJ43CA-AT 5PFT 5BFT 43.0 47.80~52.80 1 69.4 72.10 2 5.0SMDJ45A-AT 5.0SMDJ45CA-AT 5PFV 5BFV 45.0 50.00~55.30 1 72.7 68.80 2 5.0SMDJ48A-AT 5.0SMDJ48CA-AT 5PFX 5BFX 48.0 53.30~58.90 1 77.4 64.70 2 5.0SMDJ51A-AT 5.0SMDJ51CA-AT 5PFZ 5BFZ 51.0 56.70~62.70 1 82.4 60.70 2 5.0SMDJ54A-AT 5.0SMDJ54CA-AT 5PGE 5BGE 54.0 60.00~66.30 1 87.1 57.50 2 5.0SMDJ58A-AT 5.0SMDJ58CA-AT 5PGG 5BGG 58.0 64.40~71.20 1 93.6 53.50 2 5.0SMDJ60A-AT 5.0SMDJ60CA-AT 5PGK 5BGK 60.0 66.70~73.70 1 96.8 51.70 2 5.0SMDJ64A-AT 5.0SMDJ64CA-AT 5PGM 5BGM 64.0 71.10~78.60 1 103.0 48.60 2 5.0SMDJ70A-AT 5.0SMDJ70CA-AT 5PGP 5BGP 70.0 77.80~86.00 1 113.0 44.30 2 5.0SMDJ75A-AT 5.0SMDJ75CA-AT 5PGR 5BGR 75.0 83.30~92.10 1 121.0 41.40 2 5.0SMDJ78A-AT 5.0SMDJ78CA-AT 5PGT 5BGT 78.0 86.70~95.80 1 126.0 39.70 2 5.0SMDJ85A-AT 5.0SMDJ85CA-AT 5PGV 5BGV 85.0 94.40~104.00 1 137.0 36.50 2 5.0SMDJ90A-AT 5.0SMDJ90CA-AT 5PGX 5BGX 90.0 100.00~111.00 1 146.0 34.30 2 5.0SMDJ100A-AT 5.0SMDJ100CA-AT 5PGZ 5BGZ 100.0 111.00~123.00 1 162.0 30.90 2 5.0SMDJ110A-AT 5.0SMDJ110CA-AT 5PHE 5BHE 110.0 122.00~135.00 1 177.0 28.30 2 5.0SMDJ120A-AT 5.0SMDJ120CA-AT 5PHG 5BHG 120.0 133.00~147.00 1 193.0 26.00 2 5.0SMDJ130A-AT 5.0SMDJ130CA-AT 5PHK 5BHK 130.0 144.00~159.00 1 209.0 24.00 2 5.0SMDJ150A-AT 5.0SMDJ150CA-AT 5PHM 5BHM 150.0 167.00~185.00 1 243.0 20.60 2 5.0SMDJ160A-AT 5.0SMDJ160CA-AT 5PHP 5BHP 160.0 178.00~197.00 1 259.0 19.30 2 5.0SMDJ170A-AT 5.0SMDJ170CA-AT 5PHR 5BHR 170.0 189.00~209.00 1 275.0 18.20 2 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 5.0SMDJ-AT Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 1000 100 10 1 0.31×0.31″(8.0×8.0mm) Copper Pad Area 0.1 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 125 150 175 100000 Uni-directional Peak Value IPPM 100 Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 10000 Half Value IPPM (IPPM/2) 1000 Bi-directional 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 Measured at 1MHz, 100mV, 0V bias 1 1.0 2.0 3.0 1 4.0 t-Time (ms) Figure 5. Steady State Power Dissipation Derating IFSM - Peak Forward Surve Current (A) 6 5 4 3 2 1 0 25 1000 Surge Current Uni-Directional Only 7 0 10 100 VRWM-Reverse Stand-Off Voltage (V) Figure 6. Maximum Non-Repetitive Forward Curve PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 50 75 100 125 150 175 350 300 250 200 150 100 50 0 1 10 Number of Cycles at 60Hz 100 TA-Ambient Temperature (℃) www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 5.0SMDJ-AT Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 5.0SMDJ-AT Marking Code Cathode Band YXXX YXXX 5PEN Logo 5BEN Intermal Control Code Marking Code Logo Intermal Control Code Marking Code Part Number Code 5.0SMDJ XXX C A AT / XX Package Code 7: 7 inch reel package 13: 13 inch reel package Internal Control Code 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “/7” at the end of the part number, such as 5.0SMDJXXXCA-AT/7 13 inch reel package: Add suffix “/13” at the end of the part number, such as 5.0SMDJXXXCA-AT/13 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 5.0SMDJ-AT Packaging Tape P0 P1 P2 D0 B Symbol Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 K0 F 7.50±0.10 SECTION B-B A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 T E F W B0 D1 A A B A0 SECTION A-A 7” Reel D4 D3 D2 13” Reel W1 Quantity: 500PCS D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.4 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
5.0SMDJ26A-AT/13
1. 物料型号:5.0SMDJ-AT系列,包括多种型号如5.0SMDJ11A-AT、5.0SMDJ12A-AT等,具有不同的反向工作电压和击穿电压。
2. 器件简介:这是YAGEO公司生产的瞬态电压抑制二极管(Transient Voltage Suppressors, TVS),适用于表面贴装,优化板空间,具有低轮廓封装、内置应力消除、玻璃钝化结、低电感、优秀的钳位能力、5000W峰值脉冲功率能力、快速响应时间等特点。
3. 引脚分配:根据JEDEC DO-214AB标准,带有锡镀层的引脚,符合MIL-STD-750标准,极性由色带表示,除了双向型号。
4. 参数特性:包括峰值脉冲功率耗散、峰值脉冲电流、稳态功率耗散、正向浪涌电流、工作和存储温度范围、典型热阻等。
5. 功能详解:这些TVS二极管用于保护电子设备免受电压瞬变的影响,如输入/输出接口、交流/直流电源、低频信号传输线等。
6. 应用信息:适用于多种应用场景,包括I/O接口、AC/DC电源、低频信号传输线等。
7. 封装信息:提供了详细的封装尺寸和标记代码,包括7英寸和13英寸的卷轴包装信息。
5.0SMDJ26A-AT/13 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ26A-AT/13”相匹配的价格&库存,您可以联系我们找货
5.0SMDJ26A-AT/13
  • 3000+3.127923000+0.40510
  • 6000+2.897116000+0.37521
  • 9000+2.779569000+0.35998
  • 15000+2.6475015000+0.34288
  • 21000+2.5693221000+0.33276
  • 30000+2.5020530000+0.32404
库存:3613
5.0SMDJ26A-AT/13
  • 1+7.74977
  • 10+6.19502
  • 100+5.72548
  • 250+5.11700
  • 1000+4.79839
  • 3000+4.36957
  • 9000+4.17673
  • 15000+4.05216
  • 30000+3.87249
5.0SMDJ26A-AT/13
  • 1+8.376181+1.08480
  • 10+6.6922210+0.86671
  • 100+6.17743100+0.80004
  • 250+5.52305250+0.71529
  • 1000+5.174041000+0.67009
  • 3000+4.711603000+0.61020
  • 9000+4.510929000+0.58421
  • 15000+4.3713215000+0.56613
  • 30000+4.1793730000+0.54127
5.0SMDJ26A-AT/13
  • 1+12.248961+1.58637
  • 10+7.6787910+0.99448
  • 100+5.06823100+0.65639
  • 500+3.94739500+0.51123
  • 1000+3.586371000+0.46447
库存:3613
