SMAJ6.8(C)A
Glass passivated chip
400 W peak pulse power capability with a 10/1000 us
waveform, repetitive rate (duty cycle):0.01 %
Excellent clamping capability
Low reverse leakage
Very fast response time
Lead and body according with RoHS standard
ÄÅÄÆÇÈÉÅÆÄÊ
ÄÅÄËÌÈÉÅÇÄÊ
ÄÅÉÉËÈÇÅÏÄÊ
ÄÅÄÏÍÈÇÅÎÄÊ
SMA/DO-214AC
Features
ÄÅÉÍÉÈËÅÆÄÊ
ÄÅÉÎÌÈËÅÄÄÊ
ÄÑÄÉÇÈÄÑÐÄÎÊ
ÄÑÄÄÆÈÄÅÉÎÇÊ
ÄÅÄÄÍÈÄÅÇÄÐÊ
ÄÅÄÄÇÈÄÅÄÎÉÊ
ÄÅÇÄÍÈÎÅÇÍÊ
ÄÅÉÍÍÈËÅÍÄÊ
ÄÅÄÆÄÈÉÅÎÇÊ
ÄÅÄÐÄÈÄÅÌÆÊ
Mechanical Data
Case: SMA/DO-214AC Molded plastic
Lead: Solderable per MIL-STD-750, method 2026
Epoxy: UL 94V-0 rate flame retardant
Polarity: Color band denotes cathode end except Bipolar
Mounting position: Any
Dimensions:inch[mm]
Bi-directional
Uni-directional
Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
Parameter
Symbol
(1)
Value
Unit
PPP
400
W
(1)
IPP
38.1
A
Power dissipation on infinite heatsink at TL = 75 °C
PD
1.0
W
Peak forward surge current, 8.3 ms single half sinewave unidirectional
only(2)
IFSM
40
A
Maximum instantaneous forward voltage at 10 A for unidirectional only
VF
3.5/5.0
V
TJ,TSTG
-55 to +150
Peak power dissipation with a 10/1000 us waveform
Peak pulse current wih a 10/1000 us waveform
Operating junction and storage temperature range
Note:
1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1;
2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum;
Electrical Characteristics(TA = 25°C unless otherwise noted)
Part Number
Device
Reverse
Breakdown
Marking
Stand-off
Voltage
Code
Voltage
UNI-POLAR
BI-POLAR
UNI
BI
SMAJ6.8A
SMAJ6.8CA
6V8A
6V8C
0571-87006810
VRWM(V)
5.8
VBR @ IT
Test
Max. Clamping
Current
Voltage @ IPP
Min.(V)
Max.(V)
IT(mA)
VC MAX.(V)
6.46
7.14
10
10.5
www.dowosemi.cn
Max. Peak
Max. Reverse
Pulse
Current
Leakage @
VRWM
IPP(A)
IR(uA)
38.1
1000
1/2
SMAJ6.8(C)A
Ratings and Characteristics Curves (TA = 25°C unless otherwise noted)
50
100
25
100
150
50
25
40TJ = TJ max.
1
Peak Forward Surge Current, (A)
Peak Pulse Derating in Percentage of Peak
Power or Current, (%)
AM
100BIENAVERAGE FORWARD CURRENT, (A)
50
75
100
125
150
175
12
30
8.3 ms Single Half Sine-Wave
100
40
1
Fig. 1 - Pulse Derating Curve
Fig. 2 - Maximum Non-Repetitive
Surge Current
100
1.0
0.1
6
70 0.8
1
10000
0.2
Steady State Power Dissipation, (W)
100
10
Number of Cycles at 60 Hz
Ambient Temperature ,TA (℃)
10
Peak Power (kW)
0.6
0.4
1
0.2
0.0
50
75
100
125
150
175
0.1
200
0.1
1
10
Lead Temperature , TL (℃)
Fig. 3 - Steady State Power Derating Curve
1000
0.2
100
0.5
Half Value = Ipp76
1 2 50
1.5
33
10/1000
μsec. Waveform
2
23
as defined by R.E.A.
3
13
4
10
50
td
TJ = 25 °C
Pulse Width (td) is defined as the
point where the peak current
0 to 50 %0of Ipp
decays
Junction Capacitance,CJ (pF)
Peak Pulse Current , (% )
100
1
2
10
3
4
5
450
3000
50
5
450
2000
22
1650
4
5
450
1400
5
Bi-directional
@zero bias
Uni-directional
@zero bias
Bi-directional @VRWM
TJ=25 °C
f=1.0MHz
1
10
100
1000
Reverse Breakdown Voltage,VBR (V)
Time , (ms)
Fig. 5 - Pulse Waveform
0571-87006810
10000
Uni-directi5onal 4
@5V
0RWM
100
1
Fig. 4 - Peak Pulse Power Rating Curve
10000
Tr=10μs
Peak Value
(Ipp)
100
Pulse Width ,td (μs)
Fig. 6 - Typical Junction Capacitance
www.dowosemi.cn
2/2
很抱歉,暂时无法提供与“SMAJ6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.46200
- 500+0.15400
- 2500+0.10263
- 5000+0.08415
