SMCJ Series
Surface Mount Transient Voltage Suppress
1500W
/ 5.0~440V
Features
Package Outline
SMC (DO-214AB)
● 1500W peak pulse powercapability at 10/1000μs
waveform, repetition rate (duty cycles):0.01%
● Low profile package
● Glass Passivated Junction
● Excellent clamping capability
● Fast response time:typically less than 1.0ps
from 0V to BV min
● Meets MSL level 1, per J-STD-020, LF maximum
peak of 260 °C
● Compliant to RoHS Directive 2002/95/EC and in
accordance to WEEE 2002/96/EC
Typical Applications
TVS devices are ideal for the protection of I/O
Interfaces,VCC bus and other vulnerable circuits
Functional Diagram
used in Telecom,Computer, Industrial and
Consumer electronic applications.
Mechanical Data
Bi-directional
Cathode
Anode
● Case:SMC Plastic Package
Uni-directional
● Polarity: Indicated by cathode band
Maximum Ratings and Thermal Characteristics
Ratings at TA=25℃ (unless otherwise specified)
Parameter
Symbol
Value
Unit
PPPM
1500
W
PD
6.5
W
IFSM
200
A
VF
1.5
V
Storage temperature range
TS
-55 ~ 175
°C
Operating Junction temperature range
Tj
-55 ~ 150
°C
RthJL
15
°C /W
Peak Pulse Power Dissipation at TA=25ºC
by 10/1000µs Waveform (Fig.1)
(Note 1), (Note 2), (Note 5)
Steady State Power Dissipation @ TL = 75℃
Peak Forward Surge Current, 8.3ms Single Half
Sine Wave (Note 3)
Maximum Instantaneous Forward Voltage at
5.0A for Unidirectional Only (Note 4)
Thermal Resistance (Note2)
Note:1. Non-repetitive current pulse , per Fig. 4 and derated above TJ (initial) =25℃per Fig. 3.
2. Mounted on copper pad area of 0.31x0.31” (8.0 x 8.0mm) to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only.
4. VF
很抱歉,暂时无法提供与“SMAJ26A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.22983
- 200+0.18026
- 600+0.15272
