SMAJ200A
SMAJ200A
    NH(纽航)
    SMA(DO-214AC)
    单向TVS 200V截止 峰值浪涌电流:1.2A
SMAJ200A 数据手册
Niuhang Electronic Co. Ltd Specification For Approval SMAJ5.0A/CA THRU SMAJ550A/CA TRANSIENT VOLTAGE SUPPRESSOR DIODES VOLTAGE: 5.0-550 Volts POWER: 400 W Marking and Polarity DO-214AC(SMA) FEATURES · · · · · For surface mounted applications FFYW Glass passivated chip FFYWW XX XX Unipolar Bipolar Low incremental surge resistance,excellent clamping capability 600W peak pulse power capability with a 10/1000μs wave from,repetition Remark: rate (duty cycle):0.01% · · Very fast response time High temperature soldering guaranteed:260℃/10 seconds, at terminals ①. XX=Modle Code,XX=AE/WE~TT/UT ②. NH=niuhang trademark ③. FF=Product line,According to actual changes MECHANICAL DATA · · · · Package: YWW=Periodic code,According to actual changes ④. DO-214AC(SMA) White band denotes cathode Epoxy UL: 94V-0 Mounting position: Any Weight: approx. 0.095 grams(0.0036 ounce) Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Symbol Value Unit Non-repetitive peak pulse power dissipation with a 10/1000μs waveform (NOTE 1) PPP 400 W Peak pulse current 10/1000μs wavefrom (NOTE 1) IPP See Table1 A Power dissipation on infinite heatsink at TL = 75 °C PD 3 W IFSM 40 A Maximum instantaneous forward voltage at 50 A for unidirectional only(NOTE 3) VF 3.5/6.5 V Junction temperature TJ -55~+150 ℃ Storage temperature range TSTG -55~+150 ℃ Thermal Resistance, Junction to Ambient Air RθJA 100 Thermal Resistance, Junction to lead RθJL 32 Peak forward surge current, 8.3 ms single half sinewave unidirectional only (NOTE 2) ℃/W Notes: 1. Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2. Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3. VF
SMAJ200A 价格&库存
很抱歉,暂时无法提供与“SMAJ200A”相匹配的价格&库存,您可以联系我们找货
SMAJ200A
    • 20+0.25056
    • 200+0.19278
    • 600+0.16071
    • 5000+0.15218
    库存:4950
