400Watts
Transient Voltage Suppressor
SMAFJ5.0(C)A - SMAFJ350(C)A
Features
HALOGEN
H
F
FRE E
Glass passivated chip
400 W peak pulse power capability with a 10/1000 us
waveform, repetitive rate (duty cycle):0.01 %
Pb
lead- free
Excellent clamping capability
Low reverse leakage
Very fast response time
Lead and body according with RoHS standard
RoHS
2015/863/EC
SMAF
Mechanical Characteristics
Applications
Case:SMAF Molded plastic
I/O Interfaces
Lead: Solderable per MIL-STD-750, method 2026
Power lines
Epoxy: UL 94V-0 rate flame retardant
Automotive a nd Telecommunication
Polarity: Color band denotes cathode end except Bipolar
Computers & Consumer Electronics
Mounting position: Any
Industrial Electronics
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak power dissipation with a 10/1000 us waveform
PPPM
400
W
Peak pulse current wih a 10/1000 us waveform(1)
IPPM
(1)
Power disspation on infinite heatsink at TA = 50 °C
Peak forward surge current, 8.3 ms single half
See Next Table
A
PD
3.0
W
sinewave unidirectional only(2)
Typical thermal resistance junction to lead
IFSM
40
A
RθJL
30
℃/W
Typical thermal resistance junction to ambient
RθJA
120
℃/W
TJ,TSTG
-55 to +150
Operating junction and storage temperature range
1) Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1;
2) Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum;
Specifications are subject to change without notice.
C PROSEMI Document No:P0D0410130736001Z
1 of 5
www.prosemitech.com
400Watts
Electrical Characteristics
Part Number
Marking
Reverse Breakdown Voltage Test
Stand Off
Current
Voltage
Maximum
Clamping
Voltage
Maximum
Peak Pulse
Current
Maximum
Reverse
Leakage
VR (V)
IT (mA)
VC (V) @ IPP
IPP (A)
IR (µA) @ VR
10
9.2
43.5
800
VBR (V) @ IT
Uni
Bi
Uni
Bi
Min.
Max.
SMAFJ5.0A
SMAFJ5.0CA
AE
WE
5
6.4
7
SMAFJ6.0A
SMAFJ6.0CA
AG
WG
6
6.67
7.37
10
10.3
38.8
800
SMAFJ6.5A
SMAFJ6.5CA
AK
WK
6.5
7.22
7.98
10
11.2
35.7
500
SMAFJ7.0A
SMAFJ7.0CA
AM
WM
7
7.78
8.6
10
12
33.3
200
SMAFJ7.5A
SMAFJ7.5CA
AP
WP
7.5
8.33
9.21
1
12.9
31
100
SMAFJ8.0A
SMAFJ8.0CA
AR
WR
8
8.89
9.83
1
13.6
29.4
50
SMAFJ8.5A
SMAFJ8.5CA
AT
WT
8.5
9.44
10.4
1
14.4
27.8
SMAFJ9.0A
SMAFJ9.0CA
AV
WV
9
10
11.1
1
15.4
26
10
SMAFJ10A
SMAFJ10CA
AX
WX
10
11.1
12.3
1
17
23.5
5
SMAFJ11A
SMAFJ11CA
AZ
WZ
11
12.2
13.5
1
18.2
22
1
SMAFJ12A
SMAFJ12CA
BE
XE
12
13.3
14.7
1
19.9
20.1
1
SMAFJ13A
SMAFJ13CA
BG
XG
13
14.4
15.9
1
21.5
18.6
1
SMAFJ14A
SMAFJ14CA
BK
XK
14
15.6
17.2
1
23.2
17.2
1
SMAFJ15A
SMAFJ15CA
BM
XM
15
16.7
18.5
1
24.4
16.4
1
SMAFJ16A
SMAFJ16CA
BP
XP
16
17.8
19.7
1
26
15.4
1
SMAFJ17A
SMAFJ17CA
BR
XR
17
18.9
20.9
1
27.6
14.5
1
SMAFJ18A
SMAFJ18CA
BT
XT
18
1
29.2
13.7
1
SMAFJ20A
SMAFJ20CA
BV
XV
24.5
1
32.4
12.3
1
SMAFJ22A
SMAFJ22CA
BX
XX
22
24.4
26.9
1
35.5
11.3
1
SMAFJ24A
SMAFJ24CA
BZ
XZ
24
26.7
29.5
1
38.9
10.3
1
SMAFJ26A
SMAFJ26CA
CE
YE
26
28.9
31.9
1
42.1
9.5
1
SMAFJ28A
SMAFJ28CA
CG
YG
28
31.1
34.4
1
45.4
8.8
1
SMAFJ30A
SMAFJ30CA
CK
YK
30
33.5
36.8
1
48.4
8.3
1
SMAFJ33A
SMAFJ33CA
CM
YM
33
36.7
40.6
1
53.3
7.5
1
SMAFJ36A
SMAFJ36CA
CP
YP
36
40
44.2
1
58.1
6.9
1
SMAFJ40A
SMAFJ40CA
CR
YR
40
44.4
49.1
1
64.5
6.2
1
SMAFJ43A
SMAFJ43CA
CT
YT
43
47.8
52.8
1
69.4
5.8
1
SMAFJ45A
SMAFJ45CA
CV
YV
45
50
55.3
1
72.7
5.5
1
SMAFJ48A
SMAFJ48CA
CX
YX
48
53.3
58.9
1
77.4
5.2
1
SMAFJ51A
SMAFJ51CA
CZ
YZ
51
56.7
62.7
1
82.4
4.9
1
SMAFJ54A
SMAFJ54CA
RE
ZE
54
60
66.3
1
87.1
4.6
1
SMAFJ58A
SMAFJ58CA
RG
ZG
58
64.4
71.2
1
93.6
4.3
1
SMAFJ60A
SMAFJ60CA
RK
ZK
60
66.7
73.7
1
96.8
4.1
1
SMAFJ64A
SMAFJ64CA
RM
ZM
64
71.1
78.6
1
103
3.9
1
SMAFJ70A
SMAFJ70CA
RP
ZP
70
77.8
86
1
113
3.5
1
SMAFJ75A
SMAFJ75CA
RR
ZR
75
83.3
92.1
1
121
3.3
1
SMAFJ78A
SMAFJ78CA
RT
ZT
78
86.7
95.8
1
126
3.2
1
SMAFJ85A
SMAFJ85CA
RV
ZV
85
94.4
104
1
137
2.9
1
SMAFJ90A
SMAFJ90CA
RX
ZX
90
100
111
1
146
2.7
1
SMAFJ100A
SMAFJ100CA
RZ
ZZ
100
111
123
1
162
2.5
1
2 of 5
www.prosemitech.com
400Watts
Electrical Characteristics (continued)
Part Number
Uni
Marking
Bi
Stand Off
Current
Voltage
Maximum
Clamping
Voltage
Maximum
Peak Pulse
Current
Maximum
Reverse
Leakage
VR (V)
VBR (V) @ IT
IT (mA)
VC (V) @ IPP
IPP (A)
IR (µA) @ VR
Uni
Bi
Min.
Max.
SMAFJ110A
SMAFJ110CA SE
VE
110
122
135
1
177
2.3
1
SMAFJ120A
SMAFJ120CA SG
VG
120
133
147
1
193
2.1
1
SMAFJ130A
SMAFJ130CA SK
VK
130
144
159
1
209
1.9
1
SMAFJ150A
SMAFJ150CA SM
VM
150
167
185
1
243
1.6
1
SMAFJ160A
SMAFJ160CA SP
VP
160
178
197
1
259
1.5
1
SMAFJ170A
SMAFJ170CA SR
VR
170
189
209
1
275
1.5
1
SMAFJ180A
SMAFJ180CA ST
VT
180
201
222
1
292
1.4
1
SMAFJ190A
SMAFJ190CA SU
YU
190
209
243
1
308
1.3
1
SMAFJ200A
SMAFJ200CA SV
VV
200
224
247
1
324
1.2
1
SMAFJ210A
SMAFJ210CA SW
YW
210
231
268
1
340
1.2
1
SMAFJ220A
SMAFJ220CA GX
VX
220
246
272
1
356
1.1
1
SMAFJ250A
SMAFJ250CA SZ
VZ
250
279
309
1
405
1
1
SMAFJ300A
SMAFJ300CA TE
UE
300
335
371
1
486
0.8
1
SMAJF350A
TG
350
391
432
1
567
0.7
1
3 of 5
www.prosemitech.com
400Watts
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
Peak Forward Surge Current, (A)
PEAKPULSE DETATING IN % OF
PEAK POWER OR CUNRRENT
100
75
50
25
10X1000Waveform
as defined REA
50
75
100
125
150
175
60
40
30
1
PM(AV) STEADY STATE POWER DISSIPATION(W)
Fig. 2-Maxmum Non-Repetitive Surge Current
Fig. 1-Pulse Derating Curve
100
Peak Power(KW)
3.0
2.4
1.8
1.2
10
1
60Hz Resistive or
Inductive Load
0.6
0.1
0.0
50
75
100
125
150
175
1
200
10
10000
Curve
Tj=25℃
Pulse Width(td) is defined as the
point where the peak current
decays to 50% of IPP
Peak Value (Ipp)
Junction Capacitancem, CJ (pF)
100
Half Value=IPP/2
50
10/1000 usec.Waveform
as defined by R.E.A
2
3
4
10000
Bi-directional
@zener bias
Uni-directional
1000
@zener bias
Uni-directional@VRWM
100
10
Bi-directional@VRWM
TJ=25℃
f=1.0MHz
1
1
10
100
1000
Reverse Breakdown Voltage, VBR (V)
Time,(ms)
Fig. 5-Pulse Waveform
1000
Fig. 4-Peak Pulse Power Rating Curve
Fig. 3-Steady State Power Derating
Tr=10us
100
Pulse Width,td(us)
Ambient Temperature,TA(℃)
Peak Pulse Current,(%)
100
10
Number of Cycles at 60 Hz
3.6
Pulse Width 8.3ms
Single Half-SineWave
(JEDEC METHOD)
50
Fig. 6-Typical Junction Capacitance
4 of 5
www.prosemitech.com
400Watts
Dimension (Unit: mm)
D
B
E
A
A1
E1
E1
L
A1
A
B
E
E1
L
D
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
1.00
1.40
0.10
0.25
1.30
1.60
3.30
3.70
0.60
1.20
2.40
2.80
4.35
4.85
Packaging: 5,000/Tape & Reel
Part Marking System
SMAFJ xx CA
CA:Bi-directional
A:Uni-directional
Reverse Stand off Voltage
Series
5 of 5
www.prosemitech.com
很抱歉,暂时无法提供与“SMAFJ20A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.51970
- 50+0.41084
- 150+0.35640
- 500+0.31558
- 2500+0.28286
