TPSMA6L5.0A
TPSMA6L5.0A
    SCME(晟驰微)
    SMA-F
    TPSMA6L5.0A
TPSMA6L5.0A 数据手册
SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus Features - Same power as standard SMB devices (600 W) - IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact) - Typical failure mode is a short circuit condition for current events exceeding component rating - ESD protection of data lines in accordance with IEC 61000-4-2 - EFT protection of data lines in accordance with IEC 61000-4-4 (IEC801-4) - High reliability application and automotive grade AEC-Q101 qualified Applications TVS devices are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applications. Function Diagram Maximum Ratings and Thermal Characteristics (TA=25OC unless otherwise noted) Parameter Symbol Value PPPM 600 W PD 3 W IFSM 60 A Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only(Note 2) VF 3.5/5 V Operating Temperature Range TJ -65 to 150 °C TSTG -65 to 150 °C AGENCY AGENCY FILE NUMBER Pending Unit Peak Pulse Power Dissipation at TA=25ºC by 10/1000µs Waveform (Fig.3) Power Dissipation on Infinite Heat O Sink at T L=50 C Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 1) Storage Temperature Range Notes: 2. Mounted on 5.0x5.0mm copper pad to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only Jiangsu Semicon Champion Microelectronics Co., Ltd. 1/8 SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus Characteristics (T =25°C unless otherwise noted) Part Number Marking (Uni) Code Reverse Stand off Voltage VR (Volts) Breakdown Voltage VBR Test (Volts) @ IT Current IT MIN MAX (mA) Maximum Maximum Peak Reverse Pulse Current Ipp Leakage I @ R Voltage VC @ Ipp VR (A) (V) (µA) Maximum Clamping TPSMA6L5.0A A6005 5.0 6.40 7.00 10 9.2 65.3 800 TPSMA6L6.0A A6006 6.0 6.67 7.37 10 10.3 58.3 800 TPSMA6L6.5A A606F 6.5 7.22 7.98 10 11.2 53.6 500 TPSMA6L7.0A A6007 7.0 7.78 8.60 10 12.0 50.0 200 TPSMA6L7.5A A607F 7.5 8.33 9.21 1 12.9 46.6 100 TPSMA6L8.0A A6008 8.0 8.89 9.83 1 13.6 44.2 50 TPSMA6L8.5A A608F 8.5 9.44 10.40 1 14.4 41.7 20 TPSMA6L9.0A A6009 9.0 10.00 11.10 1 15.4 39.0 10 TPSMA6L10A A6010 10.0 11.10 12.30 1 17.0 35.3 5 TPSMA6L11A A6011 11.0 12.20 13.50 1 18.2 33.0 1 TPSMA6L12A A6012 12.0 13.30 14.70 1 19.9 30.2 1 TPSMA6L13A A6013 13.0 14.40 15.90 1 21.5 28.0 1 TPSMA6L14A A6014 14.0 15.60 17.20 1 23.2 25.9 1 TPSMA6L15A A6015 15.0 16.70 18.50 1 24.4 24.6 1 TPSMA6L16A A6016 16.0 17.80 19.70 1 26.0 23.1 1 TPSMA6L17A A6017 17.0 18.90 20.90 1 27.6 21.8 1 TPSMA6L18A A6018 18.0 20.00 22.10 1 29.2 20.6 1 TPSMA6L20A A6020 20.0 22.20 24.50 1 32.4 18.6 1 TPSMA6L22A A6022 22.0 24.40 26.90 1 35.5 16.9 1 TPSMA6L24A A6024 24.0 26.70 29.50 1 38.9 15.5 1 TPSMA6L26A A6026 26.0 28.90 31.90 1 42.1 14.3 1 TPSMA6L28A A6028 28.0 31.10 34.40 1 45.4 13.3 1 TPSMA6L30A A6030 30.0 33.30 36.80 1 48.4 12.4 1 TPSMA6L33A A6033 33.0 36.70 40.60 1 53.3 11.3 1 TPSMA6L36A A6036 36.0 40.00 44.20 1 58.1 10.4 1 TPSMA6L40A A6040 40.0 44.40 49.10 1 64.5 9.3 1 TPSMA6L43A A6043 43.0 47.80 52.80 1 69.4 8.7 1 TPSMA6L45A A6045 45.0 50.00 55.30 1 72.7 8.3 1 TPSMA6L48A A6048 48.0 53.30 58.90 1 77.4 7.8 1 TPSMA6L51A A6051 51.0 56.70 62.70 1 82.4 7.3 1 TPSMA6L54A A6054 54.0 60.00 66.30 1 87.1 6.9 1 TPSMA6L58A A6058 58.0 64.40 71.20 1 93.6 6.5 1 TPSMA6L60A A6060 60.0 66.70 73.70 1 96.8 6.2 1 TPSMA6L64A A6064 64.0 71.10 78.60 1 103.0 5.9 1 TPSMA6L70A A6070 70.0 77.80 86.00 1 113.0 5.3 1 TPSMA6L75A A6075 75.0 83.30 92.10 1 121.0 5.0 1 TPSMA6L78A A6078 78.0 86.70 95.80 1 126.0 4.8 1 TPSMA6L85A A6085 85.0 94.40 104.00 1 137.0 4.4 1 Jiangsu Semicon Champion Microelectronics Co., Ltd. 2/8 Agency Approval SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus I-V Curve Characteristics PPPM Peak Pulse Power Dissipation -- Max power dissipation VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT) VC Clamping Voltage -- Peak voltage measured across the TVS at a specified IPPM (peak impulse current) IR Reverse Leakage Current -- Current measured at VR VF Forward Voltage Drop for Uni-directional Jiangsu Semicon Champion Microelectronics Co., Ltd. 3/8 SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus Ratings and Characteristic Curves (T =25°C unless otherwise noted) Figure 1. Peak pulse power derating curve Figure 3. Figure2. Pulse waveform Peak pulse power rating curve Figure 4. Jiangsu Semicon Champion Microelectronics Co., Ltd. 4/8 Typical Junction Capacitance SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus Soldering Parameters Reflow Condition Pre Heat Soldering profile Lead–free assembly - Temperature Min (Ts(min)) 150°C - Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) 60 – 180 secs Average ramp up rate (Liquidus Temp (T A) to peak 3°C/second max TS(max) to TA - Ramp-up Rate 3°C/second max Reflow - Temperature (TA) (Liquidus) 217°C - Time (min to max) (ts) 60 – 150 seconds Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (tp) 30 seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 280°C Jiangsu Semicon Champion Microelectronics Co., Ltd. 5/8 SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus Dimensions Jiangsu Semicon Champion Microelectronics Co., Ltd. 6/8 SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus Part Numbering Part Marking Product Type Marking Code TPSMA6L xx xx A: Uni-directional CA: Bi-directional xxx Reverse Standard off Voltage VR Product series Cathode band (for uni-directional products only) Packing Part number Package name Small packing quantity Packing method TPSMA6LXXXX SMAF 3000 Tape & Reel Jiangsu Semicon Champion Microelectronics Co., Ltd. 7/8 SEMICON CHAMPION Surface Mount 600W_TPSMA6L Series Quality | Customer Focus Tape and Reel Specification Symbol Millimeter A 16.00±0.10 B 4.00±0.10 C 8.00±0.10 D 1.55±0.05 E 330.20±2.00 F 19.70±2.00 G 13.30±0.30 Revision history of Specification Version Change Items Effective Date 1.0 Initial Release 13-Aug-2021 Jiangsu Semicon Champion Microelectronics Co., Ltd. 8/8
TPSMA6L5.0A 价格&库存
很抱歉,暂时无法提供与“TPSMA6L5.0A”相匹配的价格&库存,您可以联系我们找货
