SMAJ15CA
SMAJ15CA
    NH(纽航)
    SMA(DO-214AC)
    双向TVS 15V截止 峰值浪涌电流:16.4A@10/1000US
SMAJ15CA 数据手册
Niuhang Electronic Co. Ltd Specification For Approval SMAJ5.0A/CA THRU SMAJ550A/CA TRANSIENT VOLTAGE SUPPRESSOR DIODES VOLTAGE: 5.0-550 Volts POWER: 400 W Marking and Polarity DO-214AC(SMA) FEATURES · · · · · For surface mounted applications FFYW Glass passivated chip FFYWW XX XX Unipolar Bipolar Low incremental surge resistance,excellent clamping capability 600W peak pulse power capability with a 10/1000μs wave from,repetition Remark: rate (duty cycle):0.01% · · Very fast response time High temperature soldering guaranteed:260℃/10 seconds, at terminals ①. XX=Modle Code,XX=AE/WE~TT/UT ②. NH=niuhang trademark ③. FF=Product line,According to actual changes MECHANICAL DATA · · · · Package: YWW=Periodic code,According to actual changes ④. DO-214AC(SMA) White band denotes cathode Epoxy UL: 94V-0 Mounting position: Any Weight: approx. 0.095 grams(0.0036 ounce) Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Symbol Value Unit Non-repetitive peak pulse power dissipation with a 10/1000μs waveform (NOTE 1) PPP 400 W Peak pulse current 10/1000μs wavefrom (NOTE 1) IPP See Table1 A Power dissipation on infinite heatsink at TL = 75 °C PD 3 W IFSM 40 A Maximum instantaneous forward voltage at 50 A for unidirectional only(NOTE 3) VF 3.5/6.5 V Junction temperature TJ -55~+150 ℃ Storage temperature range TSTG -55~+150 ℃ Thermal Resistance, Junction to Ambient Air RθJA 100 Thermal Resistance, Junction to lead RθJL 32 Peak forward surge current, 8.3 ms single half sinewave unidirectional only (NOTE 2) ℃/W Notes: 1. Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2. Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3. VF
SMAJ15CA
物料型号: - 型号范围:SMAJ5.0A/CA 至 SMAJ550A/CA
器件简介: - 这些是瞬态电压抑制二极管,适用于表面贴装应用,具有玻璃钝化芯片,低增量浪涌电阻和优秀的钳位能力。
引脚分配: - 封装类型:DO-214AC(SMA) - 极性标记:白色带表示阴极
参数特性: - 非重复峰值脉冲功率耗散:400W - 峰值脉冲电流:见表1 - 无限热沉上的功率耗散:3W - 峰值正向浪涌电流:40A(单向8.3ms半正弦波形) - 最大瞬态正向电压:3.5V/6.5V(取决于VBR)
功能详解: - 器件具有非常快的响应时间,并且保证在260℃/10秒的高温焊接条件下的终端性能。
应用信息: - 适用于需要瞬态电压保护的电路,如电源线、数据线等。
封装信息: - 环氧树脂封装,UL等级:94V-0 - 重量:约0.095克(0.0036盎司)
SMAJ15CA 价格&库存
很抱歉,暂时无法提供与“SMAJ15CA”相匹配的价格&库存,您可以联系我们找货
SMAJ15CA
    • 20+0.23231
    • 200+0.17918
    • 600+0.14969
    库存:2976
