Niuhang
Electronic Co. Ltd
Specification
For Approval
SMAJ5.0A/CA THRU SMAJ550A/CA
TRANSIENT VOLTAGE SUPPRESSOR DIODES
VOLTAGE:
5.0-550
Volts
POWER:
400
W
Marking and Polarity
DO-214AC(SMA)
FEATURES
For surface mounted applications
FFYW
Glass passivated chip
FFYWW
XX
XX
Unipolar
Bipolar
Low incremental surge resistance,excellent
clamping capability
600W peak pulse power capability with a 10/1000μs wave from,repetition
Remark:
rate (duty cycle):0.01%
Very fast response time
High temperature soldering guaranteed:260℃/10 seconds, at terminals
①.
XX=Modle Code,XX=AE/WE~TT/UT
②.
NH=niuhang trademark
③.
FF=Product line,According to actual changes
MECHANICAL DATA
Package:
YWW=Periodic code,According to actual changes
④.
DO-214AC(SMA)
White band denotes cathode
Epoxy UL: 94V-0
Mounting position: Any
Weight: approx. 0.095 grams(0.0036 ounce)
Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.)
Parameter
Symbol
Value
Unit
Non-repetitive peak pulse power dissipation with a 10/1000μs waveform (NOTE 1)
PPP
400
W
Peak pulse current 10/1000μs wavefrom (NOTE 1)
IPP
See Table1
A
Power dissipation on infinite heatsink at TL = 75 °C
PD
3
W
IFSM
40
A
Maximum instantaneous forward voltage at 50 A for unidirectional only(NOTE 3)
VF
3.5/6.5
V
Junction temperature
TJ
-55~+150
Storage temperature range
TSTG
-55~+150
Thermal Resistance, Junction to Ambient Air
RθJA
100
Thermal Resistance, Junction to lead
RθJL
32
Peak forward surge current, 8.3 ms single half sinewave unidirectional only (NOTE 2)
℃/W
Notes: 1. Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1;
2. Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum;
3. VF
很抱歉,暂时无法提供与“SMAJ20A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12302
- 200+0.09650
- 600+0.08176
- 5000+0.07290
- 10000+0.06524
- 20000+0.06113
