P4SMA SERIES
Transient Voltage Suppressor Diodes
Features
Uni-directional
● For surface mounted applications
● Low-profile package
● Ideal for automated placement
● Available in Unidirectional and Bidirectional
● 400 W peak pulse power capability with a 10/1000 μs
waveform
● Low incremental surge resistance, excellent clamping
capability
● Very fast response time
● High temperature soldering guaranteed: 260 °C/10 s at
terminals
● Meets MSL level 1
● Component in accordance to RoHS
Bi-directional
Typical Applications
Use in sensitive electronics protection against voltage transients
induced by inductive load switching and lighting on ICs, MOSFET,
signal lines of sensor units for consumer, computer, industrial,
telecommunication.
Mechanical Data
● Package: DO-214AC (SMA)
Molding compound meets UL 94 V-0 flammability
rating, RoHS-compliant, halogen-free
● Terminals: Matte tin plated leads, solderable per
J-STD-002B and JESD22-B102D
● Polarity: For uni-directional types the band denotes cathode
end, no marking on bi-directional types
■Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
Max
PPPM
W
400
IPPM
A
See Next Table
Power dissipation, on infinite heat sink at TL=75℃
PD
W
1.0
Peak forward surge current, 8.3 ms single
(2)
half sine-wave unidirectional only
IFSM
A
40
TJ,TSTG
-55 to +150
SYMBOL
UNIT
VALUE
Maximum instantaneous forward voltage
(3)
@ at 25A for unidirectional only
VF
V
3.5/5.0
@ at 1A for unidirectional only
VF
V
1.5
Peak power dissipation, with a 10/1000us waveform
(Fig.1)
Peak pulse current, with a 10/1000us waveform
(1) (2)
(1)
Operating junction and storage temperature range
■Electrical Characteristics(Ta=25℃ Unless otherwise specified)
PARAMETER
■Thermal Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
Conditions
VALUE
RθJL
℃/W
junction to lead
30
RθJA
℃/W
junction to ambient
120
Thermal resistance(Typical)
Notes:
(1)
Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2.
(2)
(3)
VF
很抱歉,暂时无法提供与“P4SMA12CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33124
- 100+0.26385
- 300+0.23015
- 1000+0.20488
- 5000+0.18468
- 10000+0.17453
