SMA6L18A
SMA6L18A
    SCME(晟驰微)
    SMA-F
    SMA6L18A
SMA6L18A 数据手册
SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus Features - 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycles):0.01% - Excellent clamping capability - Typical failure mode is a short circuit condition for current events exceeding component rating - Plastic package is flammability rated V-0 per UL-94 - Meet MSL level1, per J-STD-020, lead-frame maximum peak of 260°C Applications TVS devices are ideal for the transient voltage clamp protection of I/O Interfaces, DC power line bus and other circuits used in Telecom, Computer, Industrial and Consumer electronic applications. Function Diagram Maximum Ratings and Thermal Characteristics (TA=25OC unless otherwise noted) Parameter Peak Pulse Power Dissipation at TA=25ºC by 10/1000µs Waveform Symbol Value Unit PPPM 600 W PD 3.3 W IFSM 60 A 3.5 V AGENCY AGENCY FILE NUMBER Pending (Fig.3) Power Dissipation on Infinite Heat O Sink at T L=50 C Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 1) Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only VF Operating Temperature Range TJ -55 to 150 °C TSTG -55 to 150 °C Storage Temperature Range Notes: 1. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. Jiangsu Semicon Champion Microelectronics Co., Ltd. 1/8 SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus Characteristics (T =25°C unless otherwise noted) Part Number Part Number (Uni) (Bi) Key Marking UNI BI Reverse Stand off Voltage VR (Volts) Breakdown Test Maximum Voltage VBR Current Clamping (Volts) @ IT IT MIN MAX (mA) Maximum Peak Maximum Reverse Voltage VC @ Ipp Pulse Current 65.3 800 Ipp (A) (V) Leakage IR @ VR (µA) SMA6L5.0A \ 6A005 \ 5.0 6.40 7.00 10 9.2 SMA6L6.0A \ 6A006 \ 6.0 6.67 7.37 10 10.3 58.3 800 10 11.2 53.6 500 50.0 200 SMA6L6.5A \ 6A06F \ 6.5 7.22 7.98 SMA6L7.0A \ 6A007 \ 7.0 7.78 8.60 10 12.0 SMA6L7.5A \ 6A07F \ 7.5 8.33 9.21 1 12.9 46.6 100 44.2 50 SMA6L8.0A \ 6A008 \ 8.0 8.89 9.83 1 13.6 SMA6L8.5A \ 6A08F \ 8.5 9.44 10.40 1 14.4 41.7 20 SMA6L9.0A \ 6A009 \ 9.0 10.00 11.10 1 15.4 39.0 10 SMA6L10A \ 6A010 \ 10.0 11.10 12.30 1 35.3 5 SMA6L11A \ 6A011 \ 11.0 12.20 13.50 1 18.2 33.0 1 SMA6L12A \ 6A012 \ 12.0 13.30 14.70 1 19.9 30.2 1 SMA6L13A \ 6A013 \ 13.0 14.40 15.90 1 21.5 28.0 1 SMA6L14A \ 6A014 \ 14.0 15.60 17.20 1 23.2 25.9 1 SMA6L15A \ 6A015 \ 15.0 16.70 18.50 1 24.4 24.6 1 SMA6L16A \ 6A016 \ 16.0 17.80 19.70 1 26.0 23.1 1 SMA6L17A \ 6A017 \ 17.0 18.90 20.90 1 27.6 21.8 1 SMA6L18A \ 6A018 \ 18.0 20.00 22.10 1 29.2 20.6 1 SMA6L20A \ 6A020 \ 20.0 22.20 24.50 1 32.4 18.6 1 16.9 1 17.0 SMA6L22A \ 6A022 \ 22.0 24.40 26.90 1 35.5 SMA6L24A \ 6A024 \ 24.0 26.70 29.50 1 38.9 15.5 1 SMA6L26A \ 6A026 \ 26.0 28.90 31.90 1 42.1 14.3 1 SMA6L28A \ 6A028 \ 28.0 31.10 34.40 1 45.4 13.3 1 SMA6L30A \ 6A030 \ 30.0 33.30 36.80 1 48.4 12.4 1 SMA6L33A \ 6A033 \ 33.0 36.70 40.60 1 53.3 11.3 1 SMA6L36A \ 6A036 \ 36.0 40.00 44.20 1 58.1 10.4 1 SMA6L40A \ 6A040 \ 40.0 44.40 49.10 1 64.5 9.3 1 SMA6L43A \ 6A043 \ 43.0 47.80 52.80 1 69.4 8.7 1 SMA6L45A \ 6A045 \ 45.0 50.00 55.30 1 72.7 8.3 1 SMA6L48A \ 6A048 \ 48.0 53.30 58.90 1 77.4 7.8 1 SMA6L51A \ 6A051 \ 51.0 56.70 62.70 1 82.4 7.3 1 6.9 1 SMA6L54A \ 6A054 \ 54.0 60.00 66.30 1 87.1 SMA6L58A \ 6A058 \ 58.0 64.40 71.20 1 93.6 6.5 1 SMA6L60A \ 6A060 \ 60.0 66.70 73.70 1 96.8 6.2 1 5.9 1 SMA6L64A \ 6A064 \ 64.0 71.10 78.60 1 103.0 SMA6L70A \ 6A070 \ 70.0 77.80 86.00 1 113.0 5.3 1 5.0 1 SMA6L75A \ 6A075 \ 75.0 83.30 92.10 1 121.0 SMA6L78A \ 6A078 \ 78.0 86.70 95.80 1 126.0 4.8 1 SMA6L85A \ 6A085 \ 85.0 94.40 104.0 1 137.0 4.4 1 Jiangsu Semicon Champion Microelectronics Co., Ltd. 2/8 Agency Approval SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus I-V Curve Characteristics PPPM Peak Pulse Power Dissipation -- Max power dissipation VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT) VC Clamping Voltage -- Peak voltage measured across the TVS at a specified IPPM (peak impulse current) IR Reverse Leakage Current -- Current measured at VR VF Forward Voltage Drop for Uni-directional Jiangsu Semicon Champion Microelectronics Co., Ltd. 3/8 SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus Ratings and Characteristic Curves (T =25°C unless otherwise noted) Figure 1. Peak pulse power derating curve Figure2. Pulse waveform Figure3. Peak pulse power rating curve Figure4. Maximum non-repetitive surge current Jiangsu Semicon Champion Microelectronics Co., Ltd. 4/8 SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus Soldering Parameters Reflow Condition Pre Heat Soldering profile Lead–free assembly - Temperature Min (Ts(min)) 150°C - Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) 60 – 180 secs Average ramp up rate (Liquidus Temp (T A) to peak 3°C/second max TS(max) to TA - Ramp-up Rate 3°C/second max Reflow - Temperature (TA) (Liquidus) 217°C - Time (min to max) (ts) 60 – 150 seconds Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (tp) 20 – 40 seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 260°C Jiangsu Semicon Champion Microelectronics Co., Ltd. 5/8 SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus Dimensions Jiangsu Semicon Champion Microelectronics Co., Ltd. 6/8 SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus Part Numbering Part Marking Product Type Marking Code SMA6L xx xx A: Uni-directional CA: Bi-directional Reverse Standard off Voltage VR Product series Cathode band (for uni-directional products only) Packing Part number Package name Small packing quantity Packing method SMA6LXXXX SMAF 5000 Tape & Reel Jiangsu Semicon Champion Microelectronics Co., Ltd. 7/8 SEMICON CHAMPION Surface Mount 600W_SMA6L Series Quality | Customer Focus Tape and Reel Specification Symbol Millimeter A 12.00±0.10 B 4.00±0.10 C 4.00±0.10 D 1.55±0.05 E 330.20±2.00 F 15.70±2.00 G 13.30±0.30 Revision history of Specification Version Change Items Effective Date 1.0 Initial Release 13-July-2021 1.1 Modified Temperature Range & Details Jiangsu Semicon Champion Microelectronics Co., Ltd. 8/8 16-August-2021
SMA6L18A 价格&库存
很抱歉,暂时无法提供与“SMA6L18A”相匹配的价格&库存,您可以联系我们找货
