SMAJ15CA
SMAJ15CA
    BLUEROCKET(蓝箭电子)
    SMA(DO-214AC)
    双向TVS 15V截止 峰值浪涌电流:16.4A
SMAJ15CA 数据手册
SMAJ Series Rev. A Jan.-2018 描述 / DATA SHEET Descriptions 表面贴装瞬态电压抑制器功率:400W,反向浪涌电压:5.0V~440V,SMA 封装。 Surface mount transient voltage suppressor power 400 watts,Stand-Off Voltage:5.0V~440V ,SMA package. 特征 / Features 玻璃钝化,低电感,适用表面贴装。无卤产品。 Glass passivated junction, Low inductance, For surface mounted applications. HF product. 用途 / Applications 一般用途. General purpose. 内部等效电路 / Equivalent Circuit 引脚排列 / Pinning 印章代码 / Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/8 SMAJ Series Rev. A Jan.-2018 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit PPPM 400 W 60 A IPPM see Table 1 A Contact VESD1 ±30 KV Air VESD2 ±30 KV RθJA 30 ℃/W Tj, Tstg -65 ~ +150 ℃ Peak Pulse Power Dissipation on TA=25°C (Note 1,2,4, Fig1) IFSM Peak Forward Surge Current (Note 3,Fig 4) (UNI) Peak Pulse Current on 10/1000 us waveform (Note 1, Fig 3) ESD Voltage per IEC6100-4-2 Typical Thermal Resistance Junction to Ambient(Note 2) Operating Junction Temperature and Storage Temperature Range Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2. 2 2. Mounted on 5mm copper pads to each terminal. 3. Peak Forward Surge Current : 8.3ms single half sine-wave Superimposed on rated load (JEDEC method). 4. Peak pulse power waveform is 10/1000μS. http://www.fsbrec.com 2/8 SMAJ Series Rev. A Jan.-2018 电性能参数 DATA SHEET / Electrical Characteristics(Ta=25℃) Reverse Stand-off Voltage Type Breakdown Voltage Test Current Reverse Leakage Max. Clamp Voltage Peak Pulse Current Package IT IR @ VRRM VC @ IPP IPP SMA Device Marking Ccode VBR @ IT VRRM Min Max UNI BI V V V mA uA V A UNI BI SMAJ5.0A SMAJ5.0CA 5 6.4 7 10 800 9.2 43.5 AE WE SMAJ6.0A SMAJ6.0CA 6 6.67 7.37 10 800 10.3 38.8 AG WG SMAJ6.5A SMAJ6.5CA 6.5 7.22 7.98 10 500 11.2 35.7 AK WK SMAJ7.0A SMAJ7.0CA 7 7.78 8.6 10 200 12.0 AM WM SMAJ7.5A SMAJ7.5CA 7.5 8.33 9.21 1 100 12.9 31.0 AP WP SMAJ8.0A SMAJ8.0CA 8 8.89 9.83 1 50 13.6 29.4 AR WR SMAJ8.5A SMAJ8.5CA 8.5 9.44 10.4 1 20 14.4 27.8 AT WT SMAJ9.0A SMAJ9.0CA 9 10 11.1 1 10 15.4 26.0 AV WV SMAJ10A SMAJ10CA 10 11.1 12.3 1 5 17.0 23.5 AX WX SMAJ11A SMAJ11CA 11 12.2 13.5 1 1 18.2 22.0 AZ WZ SMAJ12A SMAJ12CA 12 13.3 14.7 1 1 19.9 20.1 BE XE SMAJ13A SMAJ13CA 13 14.4 15.9 1 1 21.5 18.6 BG XG SMAJ14A SMAJ14CA 14 15.6 17.2 1 1 23.2 17.2 BK XK SMAJ15A SMAJ15CA 15 16.7 18.5 1 1 24.4 16.4 BM XM SMAJ16A SMAJ16CA 16 17.8 19.7 1 1 26.0 15.4 BP XP SMAJ17A SMAJ17CA 17 18.9 20.9 1 1 27.6 14.5 BR XR SMAJ18A SMAJ18CA 18 20 22.1 1 1 29.2 13.7 BT XT SMAJ20A SMAJ20CA 20 22.2 24.5 1 1 32.4 12.3 BV XV SMAJ22A SMAJ22CA 22 24.4 26.9 1 1 35.5 11.3 BX XX SMAJ24A SMAJ24CA 24 26.7 29.5 1 1 38.9 10.3 BZ XZ SMAJ26A SMAJ26CA 26 28.9 31.9 1 1 42.1 9.5 CE YE SMAJ28A SMAJ28CA 28 31.1 34.4 1 1 45.4 8.8 CG YG SMAJ30A SMAJ30CA 30 33.3 36.8 1 1 48.4 8.3 CK YK SMAJ33A SMAJ33CA 33 36.7 40.6 1 1 53.3 7.5 CM YM SMAJ36A SMAJ36CA 36 40 44.2 1 1 58.1 6.9 CP YP SMAJ40A SMAJ40CA 40 44.4 49.1 1 1 64.5 6.2 CR YR SMAJ43A SMAJ43CA 43 47.8 52.8 1 1 69.4 5.8 CT YT http://www.fsbrec.com 33.3 3/8 SMAJ Series Rev. A Jan.-2018 电性能参数 DATA SHEET / Electrical Characteristics(Ta=25℃) Reverse Stand-off Voltage Type Breakdown Voltage Test Current Reverse Leakage Max. Clamp Voltage Peak Pulse Current IT IR @ VRRM VC @ IPP IPP VBR @ IT VRRM Min Max Package SMA Device Marking Ccode UNI BI UNI BI V V V mA uA V A SMAJ45A SMAJ45CA 45 50 55.3 1 1 72.7 5.5 CV YV SMAJ48A SMAJ48CA 48 53.3 58.9 1 1 77.4 5.2 CX YX SMAJ51A SMAJ51CA 51 56.7 62.7 1 1 82.4 4.9 CZ YZ SMAJ54A SMAJ54CA 54 60 66.3 1 1 87.1 4.6 RE ZE SMAJ58A SMAJ58CA 58 64.4 71.2 1 1 93.6 4.3 RG ZG SMAJ60A SMAJ60CA 60 66.7 73.7 1 1 96.8 4.1 RK ZK SMAJ64A SMAJ64CA 64 71.1 78.6 1 1 103.0 3.9 RM ZM SMAJ70A SMAJ70CA 70 77.8 86 1 1 113.0 3.5 RP ZP SMAJ75A SMAJ75CA 75 83.3 92.1 1 1 121.0 3.3 RR ZR SMAJ78A SMAJ78CA 78 86.7 95.8 1 1 126.0 3.2 RT ZT SMAJ85A SMAJ85CA 85 94.4 104 1 1 137.0 2.9 RV ZV SMAJ90A SMAJ90CA 90 100 111 1 1 146.0 2.7 RX ZX SMAJ100A SMAJ100CA 100 111 123 1 1 162.0 2.5 RZ ZZ SMAJ110A SMAJ110CA 110 122 135 1 1 177.0 2.3 SE VE SMAJ120A SMAJ120CA 120 133 147 1 1 193.0 2.1 SG VG SMAJ130A SMAJ130CA 130 144 159 1 1 209.0 1.9 SK VK SMAJ150A SMAJ150CA 150 167 185 1 1 243.0 1.6 SM VM SMAJ160A SMAJ160CA 160 178 197 1 1 259.0 1.5 SP VP SMAJ170A SMAJ170CA 170 189 209 1 1 275.0 1.5 SR VR SMAJ180A SMAJ180CA 180 201 222 1 1 292.0 1.4 ST VT SMAJ200A SMAJ200CA 200 224 247 1 1 324.0 1.2 SV VV SMAJ220A SMAJ220CA 220 246 272 1 1 356.0 1.1 SX VX SMAJ250A SMAJ250CA 250 279 309 1 1 405.0 1.0 SZ VZ SMAJ300A SMAJ300CA 300 335 371 1 1 486.0 0.8 TE UE SMAJ350A SMAJ300CA 350 391 432 1 1 567.0 0.7 TG UG SMAJ400A SMAJ350CA 400 447 494 1 1 648.0 0.6 TK UK SMAJ440A SMAJ400CA 440 492 543 1 1 713.0 0.6 TM UM http://www.fsbrec.com 4/8 SMAJ Series Rev. A Jan.-2018 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 5/8 SMAJ Series Rev. A Jan.-2018 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 6/8 SMAJ Series Rev. A Jan.-2018 印章说明 / DATA SHEET Marking Instructions AE   ****      说明: AE   : 为型号代码 **** : 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码  Note: AE  : Product Type Code ****:    Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No Code http://www.fsbrec.com 7/8 SMAJ Series Rev. A Jan.-2018 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 包装规格 Time:10±1 sec / REEL Package Type 封装形式 使用说明 Temp.:260±5℃ / Packaging SPEC. 卷盘包装 SMA 时间:10±1 sec. Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Reel Inner Box 盒 Outer Box 箱 5000 2 10000 5 50000 13〞×12 340X340X40 350X350X230 / Notices http://www.fsbrec.com 8/8
SMAJ15CA 价格&库存
很抱歉,暂时无法提供与“SMAJ15CA”相匹配的价格&库存,您可以联系我们找货
