P4SMA6.8A
P4SMA6.8A
    HXY(华轩阳)
    SMA(DO-214AC)
    单向TVS 5.8V截止 峰值脉冲电流:39A
P4SMA6.8A 数据手册
HXY P4SMA6.8(C)A-P4SMA600(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Features 400W Peak Pulse Power Dissipation 6.8V - 550V Standoff Voltages Uni- and Bi-Directional Versions Available Excellent Clamping Capability Glass Passivated Die Construction Low inductance Fast Response Time Plastic Material: UL Flammability Classification Rating 94V-0 SMA Mechanical Data Case : SMA Molded plastic body Terminals : Solderable per MIL-STD-750,Method 2026 Polarity Indicator: Cathode Band(Note:Bi-directional deviced have no polarity indicator) Making: Data Code and Marking Code Weight : 0.00095ounce, 0.027grams Maximum Ratings And Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit PPPM 400 W Peak Forward Surge Current (Note 3,Fig4 ) IFSM 60 A Peak Pulse Current on 10/1000 us waveform (Note 1) IPPM see Table 1 A Peak Pulse Power Dissipation on TA=25°C (Note 1,2,4, Fig1) ESD Voltage per IEC6100-4-2 Contact VESD1 Air VESD2 Typical Thermal Resistance Junction to Ambient(Note 2) Operating Junction Temperature and Storage Temperature Range) 30 30 kV RθJA 100 °C/W Tj, Tstg -55 ~ +150 °C NOTES: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5mm2 copper pads to each terminal. 3. Peak Forward Surge Current : 8.3ms single half sine-wave Superimposed on rated load (JEDEC method). 4. Peak pulse power waveform is 10/1000μS. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P4SMA6.8A P4SMA6.8CA 6V8A 6V8C 5.80 6.45~7.14 10 10.5 39.0 1000 P4SMA7.5A P4SMA7.5CA 7V5A 7V5C 6.40 7.13~7.88 10 11.3 36.3 500 P4SMA8.2A P4SMA8.2CA 8V2A 8V2C 7.02 7.79~8.61 10 12.1 33.9 200 P4SMA9.1A P4SMA9.1CA 9V1A 9V1C 7.78 8.65~9.55 1 13.4 30.6 50 P4SMA10A P4SMA10CA 10A 10C 8.55 9.50~10.50 1 14.5 28.3 10 P4SMA11A P4SMA11CA 11A 11C 9.40 10.50~11.60 1 15.6 26.3 5 P4SMA12A P4SMA12CA 12A 12C 10.20 11.40~12.60 1 16.7 24.6 5 P4SMA13A P4SMA13CA 13A 13C 11.10 12.40~13.70 1 18.2 22.5 1 P4SMA15A P4SMA15CA 15A 15C 12.80 14.30~15.80 1 21.2 19.3 1 P4SMA16A P4SMA16CA 16A 16C 13.60 15.20~16.80 1 22.5 18.2 1 P4SMA18A P4SMA18CA 18A 18C 15.30 17.10~18.90 1 25.2 16.1 1 P4SMA20A P4SMA20CA 20A 20C 17.10 19.00~21.00 1 27.7 14.8 1 P4SMA22A P4SMA22CA 22A 22C 18.80 20.90~23.10 1 30.6 13.4 1 P4SMA24A P4SMA24CA 24A 24C 20.50 22.80~25.20 1 33.2 12.3 1 P4SMA27A P4SMA27CA 27A 27C 23.10 25.70~28.40 1 37.5 10.9 1 P4SMA30A P4SMA30CA 30A 30C 25.60 28.50~31.50 1 41.4 9.9 1 P4SMA33A P4SMA33CA 33A 33C 28.20 31.40~34.70 1 45.7 9.0 1 P4SMA36A P4SMA36CA 36A 36C 30.80 34.20~37.80 1 49.9 8.2 1 P4SMA39A P4SMA39CA 39A 39C 33.30 37.10~41.00 1 53.9 7.6 1 Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY P4SMA6.8(C)A-P4SMA600(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P4SMA43A P4SMA43CA 43A 43C 36.80 40.90~45.20 1 59.3 6.9 1 P4SMA47A P4SMA47CA 47A 47C 40.20 44.70~49.40 1 64.8 6.3 1 P4SMA51A P4SMA51CA 51A 51C 43.60 48.50~53.60 1 70.1 5.8 1 P4SMA56A P4SMA56CA 56A 56C 47.80 53.20~58.80 1 77.0 5.3 1 P4SMA62A P4SMA62CA 62A 62C 53.00 58.90~65.10 1 85.0 4.8 1 P4SMA68A P4SMA68CA 68A 68C 58.10 64.60~71.40 1 92.0 4.5 1 P4SMA75A P4SMA75CA 75A 75C 64.10 71.30~78.80 1 103.0 4.0 1 P4SMA82A P4SMA82CA 82A 82C 70.10 77.90~86.10 1 113.0 3.6 1 P4SMA91A P4SMA91CA 91A 91C 77.80 86.50~95.50 1 125.0 3.3 1 P4SMA100A P4SMA100CA 100A 100C 85.50 95.00~105.00 1 137.0 3.0 1 P4SMA110A P4SMA110CA 110A 110C 94.00 105.00~116.00 1 152.0 2.7 1 P4SMA120A P4SMA120CA 120A 120C 102.00 114.00~126.00 1 165.0 2.5 1 P4SMA130A P4SMA130CA 130A 130C 111.00 124.00~137.0 1 179.0 2.3 1 1 207.0 2.0 1 P4SMA150A P4SMA150CA 150A 150C 128.00 0 143.00~158.0 P4SMA160A P4SMA160CA 160A 160C 136.00 0 152.00~168.0 1 219.0 1.9 1 P4SMA170A P4SMA170CA 170A 170C 145.00 0 162.00~179.0 1 234.0 1.8 1 P4SMA180A P4SMA180CA 180A 180C 154.00 0 171.00~189.0 1 246.0 1.7 1 171.00 0 190.00~210.0 1 274.0 1.5 1 185.00 0 209.00~231.0 1 328.0 1.3 1 1 344.0 1.2 1 P4SMA200A P4SMA220A P4SMA200CA P4SMA220CA 200A 220A 200C 220C P4SMA250A P4SMA250CA 250A 250C 214.00 0 237.00~263.0 P4SMA300A P4SMA300CA 300A 300C 256.00 0 285.00~315.0 1 414.0 1.0 1 P4SMA350A P4SMA350CA 350A 350C 300.00 0 332.00~368.0 1 482.0 0.85 1 P4SMA400A P4SMA400CA 400A 400C 342.00 0 380.00~420.0 1 548.0 0.75 1 376.00 0 418.00~462.0 1 602.0 0.68 1 1 658.0 0.61 1 P4SMA440A P4SMA440CA 440A 440C P4SMA480A P4SMA480CA 480A 480C 408.00 0 456.00~504.0 P4SMA510A P4SMA510CA 510A 510C 434.00 0 485.00~535.0 1 698.0 0.57 1 P4SMA530A P4SMA530CA 530A 530C 450.00 0 503.50~556.5 1 725.0 0.55 1 P4SMA540A P4SMA540CA 540A 540C 459.00 0 513.00~567.0 1 740.0 0.54 1 467.00 0 522.50~577.5 1 760.0 0.52 1 510.00 0 570.00~630.0 1 828.0 0.48 1 P4SMA550A P4SMA600A P4SMA550CA P4SMA600CA 550A 600A 550C 600C 0 Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY P4SMA6.8(C)A-P4SMA600(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (P PP ) or Current (I PP ) Derating in Percentage % PPPM - Peak Pulse Power (kW) 10 1 0.2×0.2 ″(5.0×5.0mm) Copper Pad Area 0.1 1 10 100 100 80 60 40 20 0 0 1000 Figure 3. Pulse Waveform 1000 Cj (pF) IPPM - Peak Pulse Current, %I RSM 125 150 175 Bi-directional V=0V Half Value I PPM (IPPM /2) Uni-directional V=0V Uni-directional @V R 100 50 10 10/1000µs Waveform as defined by R.E.A td 0 0 1 1.0 2.0 3.0 4.0 Bi-directional @V 1 3.0 2.4 1.8 1.2 0.6 25 50 75 100 100 1000 Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only IFSM - Peak Forward Surve Current (A) 3.6 0 10 VBR -Reverse Breakdown Voltage (V) Figure 5. Steady State Power Dissipation Derating Curve 0 R TJ=25 ℃ f=1.0MHz Vsig=50mVp-p t-Time (ms) PM(AV), Steady State Power Dissipation (W) 100 10000 Peak Value I PPM 100 75 Figure 4. Typical Junction Capacitance TJ=25 ℃ Pulse Width(t d) is defined as the point where the peak current decays to 50% of I PPM tr=10µs 50 TA-Ambient Temperature ( ℃) td-Pulse Width (µs) 150 25 125 150 TA-Ambient Temperature ( ℃) Shenzhen HuaXuanYang Electronics CO.,LTD 175 45 40 35 30 25 20 15 10 5 0 1 10 100 Number of Cycles at 60Hz www.hxymos.com HXY P4SMA6.8(C)A-P4SMA600(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Fig.1 Peak Pulse Power Rating Curve Fig.2 Forward Current Derating Curve 100 ulse.Wavefom PEAK PULSE POWER(PPP)OR CURRENT(IPP) DERATINGIN PERCENTAGE% Non-Repetive e Shown in Figure.3 PPPM,PEAK PULSE FORWARD ,kW TA=25°C 10 1.0 0.1 100 80 60 40 20 0 0.1 10 1 100 1000 10000 25 td,PULSE WIDTH ,us Width (td) is Defined Ippm,Peak Pulse Current (%) Peak k Value Current Decayst to 50% of Ipp Ippm 80 Half Value-Ipp/2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 3.0 T,TIME,ms Shenzhen HuaXuanYang Electronics CO.,LTD 4.0 IFSM,PEAK FORWARD SURGE CURRENT, AMPERES Pulse as the Point where the Peak. 100 100 125 150 175 Fig.4 Maximum Non-Repetitive Peak Forward Surge Current TA=25°C tf=10usec 75 TA,AMBIENT TEMPERATURE,°C Fig.3 Pulse Waveform 120 50 60 50 40 30 20 10 TJ=TJmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz www.hxymos.com HXY P4SMA6.8(C)A-P4SMA600(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG SMA Package Outline Dimensions 0.106(2.70) 0.096(2.45) Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY P4SMA6.8(C)A-P4SMA600(C)A ELECTRONICS CO.,LTD TRANSIENT VOLTAGE SUPPRESSOR HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
